Lost ABS coding PASSAT (3c)
n8301
C?ID=93207
lost ABS coding while testing park brake issue.
I have pr codes
Wednesday,28,March,2018,14:51:19:51327
VCDS Version: 18.2.0.3 (x64)
VIN: WVWPU73C57E009839   License Plate:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 36 42 44 46 52 53 56 62
          65 6D 72
VIN: WVWPU73C57E009839   Mileage: 199370km-123882miles
36-Seat Mem. Drvr -- Status: Cannot be reached 1100
53-Parking Brake -- Status: Malfunction 1010
Address 01: Engine        Labels: 03H-906-032-BLV.clb
   Part No SW: 03H 997 033 N    HW: Hardware No
   Component: P3.6-FSI-LEV2   G00 2371
   Revision: --H11---    Serial number: VWZCZ000000000
   Coding: 0000075
   Shop #: WSC 05311 000 00000
               P1653 - 004 -
                    Mileage: 199377 km
                    Date: 2018.03.26
                    Time: 04:06:41
                    RPM: 1126 /min
                    Load: 62.7 %
                    Temperature: 61.0°C
                    Temperature: 39.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 10.287 V
               P1653 - 001 -
                    Fault Status: 01100001
                    Mileage: 199377 km
                    Date: 2018.03.26
                    Time: 04:06:43
                    RPM: 1290 /min
                    Load: 46.6 %
                    Temperature: 15.0°C
                    Temperature: 17.0°C
                    Voltage: 11.811 V
Readiness: 0110 0101
   Part No SW: 09G 927 750 HK    HW: 09G 927 750 AJ
   Component: AQ 250 6F           1271
   Revision: 00H38000    Serial number:
   Coding: 0000072
   Shop #: WSC 02607 444 58981
                    Reset counter: 39
                    Mileage: 45057 km
                    Date: 2008.04.29
                    Time: 09:16:12
Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
   Part No SW: 3C0 614 095 S    HW: 3C0 614 095 S
   Component: ESP 440 C2     H015 0004
   Revision:  H015       Serial number: 0100007377
   Coding: 0000000
                    Reset counter: 154
                    Time: 04:03:49
                    Reset counter: 154
                    Time: 04:03:49
                    Reset counter: 154
                    Time: 04:03:49
                    Reset counter: 154
                    Time: 04:03:49
                    Reset counter: 154
                    Time: 04:03:49
                    Fault Frequency: 9
                    Reset counter: 154
                    Mileage: 199377 km
                    Date: 2018.03.26
                    Time: 04:03:49
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 AC    HW: 3C0 907 044 AC
   Component: ClimatronicPQ46 050 0404
   Revision: 00050005    Serial number: 00000000000000
   Part No SW: 3C0 937 049 Q    HW: 3C0 937 049 Q
   Component: Bordnetz-SG     H46 1501
   Revision: 00H46000    Serial number: 00000005594134
   Coding: F58C8F0340041A00470A00000F00000000285D435C0000
   Subsystem 1 - Part No: 3C1 955 419   Labels: 1KX-955-119.CLB
   Component: Wischer VW461 001   0101
   Coding: 00063445
   Shop #: WSC 05311
   Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 011  1110
   Coding: 00208933
   Shop #: WSC 05311
01064 - Terminal 58d; Interior Dimming
                    Reset counter: 192
                    Time: 06:03:00
02092 - Enabling Heated Seat
                    Reset counter: 155
                    Time: 14:19:00
01335 - Drivers Seat/Mirror Position Control Module (J543)
                    Reset counter: 155
                    Time: 13:06:00
02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
                    Reset counter: 194
                    Mileage: 199377 km
                    Date: 2018.03.16
                    Time: 09:05:00
                    Voltage: 9.80 V
   Part No SW: 8E0 035 593 D    HW: 8E0 035 593 D
   Component: SDAR SIRIUS     H03 0060
   Revision: 00000000    Serial number: AUZ4Z7F3017670
                    Reset counter: 194
                    Mileage: 199377 km
                    Date: 2018.03.26
                    Time: 00:36:08
   Part No SW: 3C0 909 605 K    HW: 3C0 909 605 K
   Component: 0P AIRBAG VW8R  029 2521
   Revision: 10029000    Serial number: 003A3P7FFCEI
   Coding: 0012368
   Subsystem 1 - Part No: 000 000 000 00
   Component: BF-Gewichtsens. 000 0000
   Subsystem 2 - Serial number: 00000000000000
   Subsystem 3 - Serial number: 0001.01.000000000000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332MSME0D186852Eÿ†63
   Subsystem 5 - Serial number: 86852Eÿ†6342MSME1047326B6ÿ†63
   Subsystem 6 - Serial number: 7326B6ÿ†6351HTS6TLLMEIJ2Qÿ†63
   Subsystem 7 - Serial number: MEIJ2Qÿ†6361HTS6OLL6EP732ÿ†63
   Subsystem 8 - Serial number: 6EP732ÿ†63727TS63IKI9KU2-ÿ†63
   Subsystem 9 - Serial number: I9KU2-ÿ†63827TS61IKAOK52Hÿ
   Subsystem 10 - Serial number: AOK52Hÿ
02511 - Control Module for Seat Occupied Recognition (J706)
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
01217 - Side Airbag Igniter; Driver Side (N199)
01218 - Side Airbag Igniter; Passenger Side (N200)
00591 - Seat Belt Switch; Driver (E24)
00592 - Seat Belt Switch; Passenger (E25)
   Part No SW: 3C0 953 549 E    HW: 3C0 953 549 E
   Component: J0527               0015
   Revision: 00005000    Serial number: 3C9953507P
   Coding: 0002212
   Part No SW: 3C0 920 970 R    HW: 3C0 920 970 R
   Component: KOMBIINSTRUMENT VD1 4240
   Revision: V0033000    Serial number: 00000000000000
   Coding: 0007205
                    Reset counter: 194
                    Time: 14:19:19
                    Reset counter: 154
                    Time: 13:06:58
Address 19: CAN Gateway        Labels:. 3C0-907-530-V1.clb
   Component: Gateway         007 0040
   Coding: 3FFD0F0CD32002
                    Reset counter: 154
                    Time: 13:06:58
                    Reset counter: 194
                    Time: 14:19:19
   Component: Kompass         001 0002
   Component:    IMMO         041 0364
   Shop #: WSC 02607 444 14564
   Component:    ELV          028 0380
Address 36: Seat Mem. Drvr
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
   Component: Tuer-SG         024 2801
   Component: EPS_ZFLS Kl.5   D04 1607
   Component:    KSG PQ46 RDK 041 0213
   Coding: 13900E88D1032E521804141FF00A8F0E081800
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
Address 53: Parking Brake        Labels: 3C0-907-801-53.clb
   Component: EPB  VC8HC001   013 0001
   Coding: 0010000
02432 - Supply Voltage for Left Parking Brake Motor (V282)
                    Fault Status: 11111100
                    Reset counter: 154
                    Mileage: 199376 km
                    Date: 2018.03.26
                    Time: 00:35:03
                    Voltage: 12.53 V
                    Count: 86
                    Fault Status: 11101101
                    Reset counter: 155
                    Mileage: 199376 km
                    Date: 2018.03.26
                    Time: 19:45:06
                    Voltage: 11.70 V
                    Count: 220
                    Reset counter: 155
                    Mileage: 199376 km
                    Date: 2018.03.26
                    Time: 04:03:49
                    Voltage: 13.35 V
                    Count: 236
02433 - Supply Voltage for Right Parking Brake Motor (V283)
                    Reset counter: 154
                    Mileage: 199376 km
                    Date: 2018.03.26
                    Time: 00:35:12
                    Voltage: 12.73 V
                    Count: 87
02431 - Right Parking Brake Motor (V283) Resistance to Movement
            003 - Mechanical Failure - MIL ON
                    Fault Status: 11110011
                    Reset counter: 154
                    Mileage: 199376 km
                    Date: 2018.03.26
                    Time: 00:35:12
                    Voltage: 13.15 V
                    Count: 89
   Part No SW: 1K0 035 180 C    HW: 1K0 035 180 C
   Component: Radio PM6       016 0017
   Revision: 00016000    Serial number: VWZ5Z7F2069037
   Coding: 0040400
   Shop #: WSC 05311 000 08193
   Part No: 3C9 959 703 A
   Component: Tuer-SG         021 2507
   Coding: 0000144
   Part No SW: 3C0 959 433 C    HW: 3C0 959 433 C
   Component:    RDK              0391
   Revision: 00041000    Serial number: VWZCZ000000000
   Coding: 0100101
00667 - Ambient Temperature Signal
                    Fault Status: 00111000
                    Reset counter: 194
                    Mileage: 199377 km
                    Date: 2018.03.26
                    Time: 00:09:58
Address 6D: Trunk Elect.        Labels: None
   Part No SW: 3C9 827 383 B    HW: 3C9 827 383 C
   Component: J605  HECKDECKEL    0405
   Revision: 00H20001
   Shop #: WSC 23250 384 715754
   Subsystem 1 - Part No: 3C9 827 384 B
   Component: J756  HECKDECKEL    0405
   Subsystem 2 - Serial number: 0600H20001000A0006ÿ
   Part No: 3C9 959 704 A
   Coding: 0000144
End-------------------------(Elapsed Time: 02:20)--------------------------
Controller Software Versions:
ECU 1 = Engine 2371
ECU 2 = Auto Trans 1271
ECU 3 = ABS Brakes 0004
ECU 4 = Auto HVAC 0404
ECU 5 = Cent. Elect. 1501
Sub ECU 5 > 1 = Cent. Elect. 0101
Sub ECU 5 > 2 = Cent. Elect. 1110
ECU 6 = Digital Radio 0060
ECU 7 = Airbags 2521
Sub ECU 7 > 1 = Airbags 0000
ECU 8 = Steering wheel 0015
Sub ECU 8 > 1 = Steering wheel 2001
ECU 9 = Instruments Labels:
ECU 10 = CAN Gateway 0040
ECU 11 = Position Sensing 00
ECU 12 = Immobilizer 0364
Sub ECU 12 > 1 = Immobilizer 8038
ECU 13 =
ECU 14 = Door Elect, Driver
ECU 15 = Steering Assist 160
ECU 16 = Central Conv. 0213
ECU 17 = Door Elect, Pass. 2
ECU 18 = Parking Brake 0001
ECU 19 = Radio 0017
ECU 20 = Door, Rear Left 250
ECU 21 = Tire Pressure 0391
ECU 22 = Trunk Elect. 0405
Sub ECU 22 > 1 = Trunk Elect. 040
ECU 23 = Door, Rear Right 25
n8301
C?ID=93207
Thanks I will give that a try, tomorrow
Is anyone else wondering why the OP might have edited his scan in the manner that he did? :rolleyes:
NEtech
Denmark
C?ID=56995
I guess he inserted it to, and then copied it from VCDSToolbox.
NostraJackAss
I thought it must be a fetish for controller firmware versions ? ........ ;)
Does that strip out one line from the data for each control module?
NEtech
Denmark
C?ID=56995
Yes, and from sub modules.
It is a test I tried out.
ECU 1 = Engine 0001
ECU 2 = Auto Trans 2817
ECU 3 = ABS Brakes 0521
ECU 4 = Acc/Start Auth. 0551
Sub ECU 4 > 1 = Acc/Start Auth. 0046
ECU 5 = Auto HVAC 1406
ECU 6 = Cent. Elect. 0311
Sub ECU 6 > 1 = Cent. Elect. 0021
Sub ECU 6 > 2 = Cent. Elect. 0020
Sub ECU 6 > 3 = Cent. Elect. 0040
Sub ECU 6 > 4 = Cent. Elect. 0030
ECU 7 = Park/Steer Assist 0030
ECU 8 = Auto Dist. Reg 0400
ECU 9 = Airbags 0043
Sub ECU 9 > 1 = Airbags 0005
ECU 10 = Steering wheel 0005
Sub ECU 10 > 1 = Steering wheel 0028
ECU 11 = Instruments 0515
ECU 12 = CAN Gateway 6042
Sub ECU 12 > 1 = CAN Gateway 0190
ECU 13 = Seat Mem. Drvr 0156
ECU 14 = Lane Change 0021
Sub ECU 14 > 1 = Lane Change 0021
ECU 15 = Door Elect, Driver 0306
ECU 16 = Central Conv. 0551
Sub ECU 16 > 1 = Central Conv. 0059
Sub ECU 16 > 2 = Central Conv. 1501
Sub ECU 16 > 3 = Central Conv. 0008
Sub ECU 16 > 4 = Central Conv. 0008
Sub ECU 16 > 5 = Central Conv. 0813
ECU 17 = Sound System 0090
ECU 18 = Door Elect, Pass. 0306
ECU 19 = Parking Brake 1201
ECU 20 = Headlight Range 0091
Sub ECU 20 > 1 = Headlight Range 0005
Sub ECU 20 > 2 = Headlight Range 0005
ECU 21 = Radio 0133
ECU 22 = Information Electr. 0881
Sub ECU 22 > 1 = Information Electr. 1102
Sub ECU 22 > 2 = Information Electr. 0046
Sub ECU 22 > 3 = Information Electr. 0046
Sub ECU 22 > 4 = Information Electr. 5950
ECU 23 = Door, Rear Left 0306
ECU 24 = Tire Pressure 0002
ECU 25 = Trailer 0137
ECU 26 = Back-up Cam. 0115
ECU 27 = Trunk Elect. 0043
ECU 28 = Door, Rear Right 0306
ECU 29 = On Board Cam. 0035
Sub ECU 29 > 1 = On Board Cam. 0001
ECU 30 = Adaptive Cruise 2 0400
ECU 31 = Image Processing 0035
