VW t6 composition media
bigwig74
C?ID=167787
so ive had a composition media retro fitted to my vw t6 with reprogramming with ODIS and no component protection but now i cant get the bluetooth to work, which worked faultlessly with the previous radio cheers
Thursday,21,December,2017,17:49:15:20876
VCDS Version: 17.12.0.1 (x64)
Data version: 20171213 DS285.1
VIN: WV1ZZZ7HZHX015628   License Plate:
Mileage: 17940km-11147mi   Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 5F 61 0B
VIN: WV1ZZZ7HZHX015628   Mileage: 17940km-11147miles
Address 01: Engine (2D2D2-CXGB)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 KA    HW: 04L 907 445
   Component: R4 2.0l TDI   H02 4047
   Revision: 23002001
   Coding: 00114014432501090000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM20TDI03004L906056KA 004003
   ROD: EV_ECM20TDI03004L906056BF_004.rod
   VCID: 76E5DB8EC996B19AE5E-8022
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels:. 7E0-907-37x-MK100ESC.clb
   Revision: 00000000    Serial number: 43026000000226
   Coding: 517E4098256384838A7B0278A48A21D3790000
   VCID: 3F8B7EAAA62C30D2F68-806A
   Serial number: 08111613471381
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF5C3AEE1A6F9DABDE-802A
   Part No SW: 7E0 907 047 AK    HW: 7E0 907 047 AK
   Component: Climatic-T5   H22 0708
   Revision: 00001002
   Coding: 0000000003
   ROD: EV_ClimaT5Basis.rod
   VCID: 73E3E29ADAE4A4B2C20-8026
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 309162812
   Coding: A0AC393A4A61341193284F747CEB9E750F84710F60CC2D20320400230840
   Shop #: WSC 35110 377 00143
   VCID: 2A5D3FFE45AEA57AB16-807E
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 281016 04  42  0106
   Coding: 0228EE
   Subsystem 2 - Part No SW: 7E0 959 801 P    HW: 7E0 959 801 P
   Component: J386__TSG_FT  003 0653
   Serial number: KU0KU023101662970089
   Coding: 1400B0
   Subsystem 3 - Part No SW: 7E0 959 802 P    HW: 7E0 959 802 P
   Component: J387__TSG_BT  003 0653
   Serial number: KU0KU023101662970571
   Coding: 0400A0
   Subsystem 4 - Part No: 7E1 951 172
   Subsystem 5 - Part No: 1K0 951 605 F
   Subsystem 6 - Part No: 7E1 951 172
   Subsystem 7 - Part No SW: 7E0 959 442     HW: 7E0 959 442   Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H02 0103
   Serial number: 29160001815530026406
   Coding: B0FFFF
   Part No SW: 7E0 919 475 T    HW: 1Q0 919 475
   Component: PARKHILFE 4K  H03 0212
   Revision: --------    Serial number: 32961626800229
   Coding: 108008
   ASAM Dataset: EV_VW75XParkAssis4K 001013
   ROD: EV_VW75XParkAssis4K_001.rod
   VCID: 4383725ACAC45432920-8016
   Part No SW: 7E0 959 655 G    HW: 7E0 959 655 G
   Component: VW10Airbag021 H08 0018
   Revision: --------    Serial number: 003V3002SKJK
   Coding: 000000000000000000000000000000003231
   VCID: 3A7D0FBEBD0E15FAC16-806E
   Part No SW: 7E0 920 970 S    HW: 7E0 920 970 S
   Coding: 7519230300
   Part No SW: 7E0 909 901     HW: 7E0 937 090
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 042305
   VCID: 68D985F69B22576A672-803C
   Component: IMMO          H03 1104
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADDFFFE8D2E657A716-803E
   Part No SW: 5K7 035 200 K    HW: 5K7 035 200 K
   Component: MU-S-D-ER     H41 0449
   Serial number: VWZAZ2T5287387
   Coding: 065700003C00000011111101008808001F0309D60020010003
   Shop #: WSC 02759 790 50316
   ROD: EV_MUStd4CTSAT_VN35.rod
   VCID: 2C5139E6475ABB4A43A-8078
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H81 0744
   Coding: 030B7A73
   Shop #: WSC 35110 377 08192
   Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
   Serial number: 75410903001610180199
End-------------------------(Elapsed Time: 03:00)--------------------------
Westbury, UK
New radio doesn't show up in the Auto-Scan - strange?
m87a
Bosnia and Herzegovina
C?ID=156900
each of the functions bluetooth, Wi Fi, mirrorlink etc.. are Swap functions which needs to be payed to be unlocked, even if device has bluetooth it's "missing software" to run it, so you need to buy code from stealership in order to unlock it over odis
PetrolDave it does 5F
golfi_vend
Tartu, Estonia
C?ID=195131
Did they enable FEC?
downtime
Finland
C?ID=280813
^ Most likely not as there shouldn't be any available for the car in factory database.
I don't think Transporter had MQB composition media system at that year yet. Isn't OPs car still PQ platform?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
The T5 has always been based electronically on the PQ2X platform. The T5GP (MY 2010-2015) is PQ24, while the T6 (which is actually a T5GP2, MY 2016+) shares PQ24 and PQ25 components. All T6 support the MIB-PQ, with the instrument cluster being the component protection master. This specific unit was available from factory for this car (not this MY, but that won't matter in this scenario), so there is nothing wrong with the compatibility in general.
SWaP activations are NOT device specific, but VIN specific. While this specific car/VIN came with BT support, it is unclear if the donor car ever came with it. That said, it would be interesting to see if the SVM properly recognizes the existing SWaP BT "license" and would enable it, even though this device isn't meant for this car or if this results in unwanted side effects (like other functions going missing etc.)...
downtime
Finland
C?ID=280813
If the device is compatible to this car model as you wrote, then the SWaP should not be an issue. If the original system had BT then there's FEC for this cars VIN and it should be possible to enable it in the new system as well. If there was not BT originally, then it will be more trickier.
For example in Seat, retrofit from MIB1 to MIB2 goes just fine. CP removal and FeC enable succeeds as long as the car VIN has the FeCs in factory database as per Sebastian's post. Even if you retrofit MIB2 to a model year that did not have it originally.
m87a
C?ID=156900
Yes i know that since i did couple of these retrofits but even if device did come with bluetooth once it's component protection is removed, (new vin stored in device) all of the swap functions are invalid, so SVM won't enable these licenses. only way we did manage to get these license is if it had all these or buy them, SVM has restored when we removed similar device but just radio without navigation (he had from factory bluetooth, wifi, mirrorlink but no nav) and replaced it with same but navigation, in this case svm restored licenses but not for map /navigation, since the car didn't had it, so in the end it stayed the same we couldn't unlock maps.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
CP and SVM/SWaP are separate, you can match CP w/o touching the SWaP licenses.
I was under the impression that SWaP codes/functions were tried to a particular VIN?
golfi_vend
Tartu, Estonia
C?ID=195131
Yes, that is correct.
But before you can restore FEC/SWAP, You must remove CP. Then restore FEC.
They are 2 separate Test Plan inserts.
Option 2:
owdi
C?ID=147985
@Sebastian - apart from the radio unit, instrument cluster and ECU, do any other modules in the T6 have component security data on them?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Compontent Protection, as Robert stated, just J285/#17 (Instrument Cluster, as Master), J428/#13 (Distance Control, as Participant) and J794/#5F (Infotainment, as Participant).
Immobilizer should be just J285+J362/#17+#25 (Instrument Cluster, as Master) and J624/#01 (ECM, as Participant). As far as I am aware the Automatic Transmission isn't part of the Immobilizer here.
That leaves SWaP (Software as Product)/Feature Codes as stated in previous codes.
owdi
C?ID=147985
@Sebastian and @Robert-VW thanks for the info. So based on the above, if we had a basic specification T6 that has no radar and has had the radio already swapped out for an aftermarket unit, the instrument cluster could be replaced/upgraded providing the immobiliser/component security data block was written to the new cluster using third party/offline tools without it affecting any other feature on the vehicle or needing any online/ODIS coding?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Not an expert there, you might get away with that though.
dnoermann
C?ID=358118
Yes if you dont have Radio with CP requirement or the ACC than you dont need the ComponetProtection Master.
You can Just use any T6 Cluster to Upgrade and just restore Immo Data.
Amarok Cluster is a good Fit, too, (FW is Same as T6) only need to change the Casing, and Eeeprom Data, for Shure.
To get no errors you just put 0xFF in Cluster Eeprom 0x1500 till 0x16FF this disables CP Master in Cluster.
Else you might get some Cluster Error regarding CP or regarding Checksum of eeprom Area.
@dnoermann: hmm........ do you know why this works in disabling the CP function? I'm trying to understand if a similar fix is possible on other MQB platform models that use the hex19 module as the CP master?
For example, if I look at the factory hex pattern on the memory locations quoted above for a car where the cluster is the CP master - and I identify a similar pattern on the CAN Gateway module for a car that uses the hex19 module as CP master - can the same fix work?
