Someone else posted previously having what appears to be identical issues. Car will not start, various faults come up on the dash, headlight range defective, parking brake fault, stability fault etc. Its not all the time though. Previous posted said that a new engine ecu was required. Given VCDS's changes since then the autoscan looks similar but not identical, but whats peoples opinion? For the price of a second hand ecu and getting it cloned i think its worth a shot
Wednesday,28,March,2018,16:17:08:34436
VCDS Version: 18.2.0.3 (x64)
VIN: WAUZZZ4G1CN137347 License Plate: EL60MED
Mileage: 249907km-155285mi Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 3B 42 44 46 52 53 55 56
5F 62 72
VIN: WAUZZZ4G1CN137347 Mileage: 249907km-155285miles
Address 01: Engine (J623-CGLC) Labels:. 03L-906-018-CGL.clb
Part No SW: 03L 906 018 LB HW: 03L 906 018 JL
Component: R4 2.0l TDI H24 9977
Revision: 45H24---
Coding: 12034012242401080000
Shop #: WSC 78387 152 452326
ASAM Dataset: EV_ECM20TDI01103L906018LB 003011
ROD: EV_ECM20TDI01103L906018HA.rod
VCID: 75E65F71D447B2EC3B-8020
U1113 00 [032] - -
Mileage: 249806 km
Date: 2018.03.25
Time: 21:03:17
Engine speed: 890.00 /min
Normed load value: 21.2 %
Coolant temperature: 59 °C
Intake air temperature: 21 °C
Voltage terminal 30: 11.940 V
Unlearning counter according OBD: 37
Cruise Control System (CCS): switch position-Bits 0-7: 129
Cruise Control System (CCS): status-Bits 0-7: 45
Cruise control switch-off: irreversible-Bits 0-7: 255
Cruise control switch-off: reversible-Bits 0-7: 255
Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
U1113 00 [032] - -
Mileage: 249806 km
Date: 2018.03.25
Time: 21:03:17
Address 02: Auto Trans (J217) Labels:| 0AW-927-156.clb
Part No SW: 4G0 927 155 T HW: 0AW 927 156 K
Component: 0AW 20TDI RdW H04 0005
Revision: --H04--- Serial number: 0000000105
Shop #: WSC 06795 666 30556
ASAM Dataset: EV_TCMVL381 A02430
ROD: EV_TCMVL381.rod
VCID: 3C708A55B7ED23A404-8068
10077 - Valve for Transmission Fluid Cooler
P2753 00 [046] - Open Circuit
Fault Frequency: 8
Mileage: 249765 km
Date: 2018.03.25
Time: 11:48:19
Engine speed: 100.00 /min
Transmission input speed: 1 /min
Transmission output speed: 1 /min
Engine torque: -28 Nm
Transmission fluid temperature: 68 °C
Accelerator position: 0.0 %
Clutch status: 1
Occurrence_counter_over_length_of_life: 254
2264 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [044] - -
Mileage: 249806 km
Date: 2018.03.25
Time: 20:57:48
Engine torque: 0 Nm
Transmission fluid temperature: 47 °C
Clutch status: 1
Occurrence_counter_over_length_of_life: 7
7066 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [044] - -
Mileage: 249806 km
Date: 2018.03.25
Time: 20:57:48
Engine torque: 0 Nm
Clutch status: 1
Occurrence_counter_over_length_of_life: 6
Part No SW: 4G0 907 379 H HW: 4G0 907 379 H
Component: ESP PREMIUM H09 0361
Coding: 06A187016085E180DB00
Shop #: WSC 02391 785 00200
VCID: 3664987D89C1F9F4F2-8062
8 Faults Found:
0004 - Brake Switch (F)
P0571 00 [008] - Implausible Signal
Reset counter: 45
Mileage: 249806 km
Date: 2018.03.25
Time: 20:57:48
VzRef: 00
Bit Info 1: 80
Bit Info 2: 0F
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 01
F-Type: F6
Uz: 9E
0069 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 48
Mileage: 249806 km
Date: 2018.03.25
Time: 20:57:48
VzRef: 00
Bit Info 1: 80
Bit Info 2: 0F
Bit Info 3: 00
Bit Info 4: 1F
F-Path: 00
F-Type: E3
Uz: 9E
0071 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 48
Mileage: 249806 km
Date: 2018.03.25
Time: 20:57:48
VzRef: 00
Bit Info 1: 80
Bit Info 2: 0F
Bit Info 3: 00
Bit Info 4: 1F
F-Path: 00
F-Type: F0
Uz: 9E
0073 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 48
Mileage: 249806 km
Date: 2018.03.25
Time: 20:57:48
VzRef: 00
Bit Info 1: 80
Bit Info 2: 0F
Bit Info 3: 00
Bit Info 4: 1F
F-Path: 00
F-Type: F5
Uz: 9E
0075 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 48
Mileage: 249806 km
Date: 2018.03.25
Time: 20:57:48
VzRef: 00
Bit Info 1: 80
Bit Info 2: 0F
Bit Info 3: 00
Bit Info 4: 1F
F-Path: 00
F-Type: F8
Uz: 9E
0077 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 48
Mileage: 249806 km
Date: 2018.03.25
Time: 20:57:50
VzRef: 00
Bit Info 1: 80
Bit Info 2: 2F
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 00
F-Type: FD
Uz: 9F
0091 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 48
Mileage: 249806 km
Date: 2018.03.25
Time: 20:57:48
VzRef: 00
Bit Info 1: 80
Bit Info 2: 0F
Bit Info 3: 00
Bit Info 4: 1F
F-Path: 01
F-Type: 0C
Uz: 9E
0486 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 48
Mileage: 249806 km
Date: 2018.03.25
Time: 20:57:49
VzRef: 00
Bit Info 1: 80
Bit Info 2: 2F
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 02
F-Type: 04
Uz: 9E
Part No SW: 4H0 907 064 BN HW: 4H0 907 064 BN
Component: BCM2 2.0 H31 0333
Coding: 01B93006000000000000
VCID: 76E4587DC141B9F432-8022
Serial number: 2312000010543011
Fault Status: 00101101
Reset counter: 48
Mileage: 249806 km
Date: 2018.03.25
Time: 20:57:48
Part No SW: 4G0 820 043 K HW: 4G0 820 043 K
Component: KLIMA 4 ZONEN H12 0064
Serial number: 20021200040518
Coding: 34220078A0
ASAM Dataset: EV_AirCondiComfoUDS 002036
VCID: 275A45395E6B907C79-8072
0278 - Coolant Shut-Off Valve
B10C8 13 [009] - Open Circuit
Fault Frequency: 12
Reset counter: 7
Mileage: 249765 km
Date: 2018.03.25
Time: 11:48:04
Voltage terminal 30: 12.04 V
Outside air temperature: 14.5 °C
Interior temperature: 19.85 °C
0331 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 11
Reset counter: 48
Mileage: 249806 km
Date: 2018.03.25
Time: 20:57:51
Voltage terminal 30: 12.30 V
Outside air temperature: 9.5 °C
Part No SW: 4H0 907 063 BN HW: 4H0 907 063 F
Component: BCM1 2.0 H12 0111
Revision: 20012002 Serial number: 00000001410124
Coding: 2600201040349FE00181008300001D0C0F9DC70827090101000008602100
VCID: 75E65F71DC47B2EC3B-8020
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 120116 H35 0080
Serial number: 120130132055
Coding: 0045F7
Component: RLS H04 0003
Serial number: 12008216
Coding: 02512B
Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
Component: E1 - LDS H07 0044
Serial number: 17 02 2012 00001329
Component: AQ_Hum_Sensor H02 0002
Serial number: 0D3844E5000000000001
Reset counter: 48
Mileage: 249806 km
Date: 2018.03.25
Time: 20:57:00
Part No SW: 4H0 919 475 N HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0050
Revision: 11001001 Serial number: 55901204500467
Coding: 080308
ROD: EV_EPHVA18AU57X0000_002_AU57.rod
VCID: 3D768751ACF72AAC33-8068
12648448 - Databus
Reset counter: 48
Mileage: 249806 km
Date: 2018.03.25
Time: 20:57:50
Address 15: Airbags (J234) Labels:| 4H0-959-655.clb
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG0074L9-
Coding: 30323436313230303235554A305234473053
Serial number: 3575HRB405L12NLA7GMZ
Serial number: 3585HRB406712NLC9PJX
Serial number: 3515JRB40530O32K99DY
Serial number: 3525JRB40184UH6IK0V$
Serial number: 3554VRB404V14KDMIOGS
Serial number: 3564VRB405D14KDMAHK1
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20120221000529
Coding: 000035
VCID: 3068AE6563A5D7C4A8-8064
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Component: E221 - MFL H08 0009
Part No SW: 4G8 920 982 K HW: 4G8 920 982 K
Component: TDieGb H79 0416
Revision: 28460177 Serial number: 658270112596033
Coding: 33AF10000B012600010000
ASAM Dataset: EV_RBD4K 004045
ROD: EV_RBD4K.rod
16776971 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 48
Mileage: 249806 km
Date: 2018.03.25
Time: 20:57:50
Part No SW: 4G0 907 468 G HW: 4G0 907 468 A
Component: J533--Gateway H08 0214
Revision: -------- Serial number: 00000000408726
Coding: 00CD074400
ROD: EV_GatewUDS_AU57.rod
VCID: 3460A2759FBDEBE4CC-8060
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790965767
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Serial number: 12042001025011200181
4224 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [008] - -
Reset counter: 48
Mileage: 249806 km
Date: 2018.03.25
Time: 20:57:22
Voltage terminal 30: 12.1 V
Voltage terminal 15: 0.0 V
Control Module temperature: 16 °C
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status: OFF
Datenfeld: 0
Part No SW: 4G0 919 158 C HW: 4G0 919 158 C
Component: KLIMA FOND H07 0064
Serial number: 21021200040539
Coding: 02
ASAM Dataset: EV_ClimaContrUnitRearUDS 002018
VCID: 2F6AAD19769BC83CB1-807A
0132 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 11
Reset counter: 48
Mileage: 249806 km
Date: 2018.03.25
Time: 20:57:51
Voltage terminal 30: 12.33 V
Engine speed: 0 /min
Vehicle speed: 0.00 km/h
Part No SW: 4G0 907 637 HW: 4G0 907 637
Component: SARA 3D H02 0009
Revision: -------- Serial number: EJ1BPA3201HT7A0
ASAM Dataset: EV_SARA 009017
ROD: EV_SARA_009.rod
VCID: 6BD279098203741CDD-803E
Part No SW: 4G8 959 793 E HW: 4G8 959 793 A
Component: TSG FA H05 0212
Coding: 011C16204001620002080002
VCID: 428CF4ADDD0955544E-8016
Reset counter: 48
Mileage: 249806 km
Date: 2018.03.25
Time: 20:57:47
Component: RCEPS H35 0010
Revision: 00001000 Serial number: 0007363549
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 326CA46D65A9E5D4DE-8066
3158274 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 27
Reset counter: 48
Mileage: 249806 km
Date: 2018.03.25
Time: 20:57:50
valid
Revision: 00002001 Serial number: 0170309120
Coding: 013B062220B9040083200904000104000000000000000000000000000000
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 5
Mileage: 249794 km
Date: 2018.03.25
Time: 12:38:06
02616 - Fuel Tank Cap; Unlock
Reset counter: 5
Mileage: 249794 km
Date: 2018.03.25
Time: 12:40:32
Reset counter: 48
Mileage: 249806 km
Date: 2018.03.25
Time: 20:57:48
Part No SW: 4G8 959 792 E HW: 4G8 959 792 A
Component: TSG BF H05 0212
VCID: 418EFBA1D80F4E4C57-8014
Reset counter: 48
Mileage: 249806 km
Date: 2018.03.25
Time: 20:57:47
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000254092
ROD: EV_ParkiBrake_VW51.rod
VCID: 2A5CBC0D4D79AD1466-807E
333568 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 48
Mileage: 249806 km
Date: 2018.03.25
Time: 20:57:48
Voltage terminal 30: 12.2 V
Internal Fault ID: 49
Network management state: normal
Function light in parking brake button: On
Red operating lamp: On
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
Terminal 15 status: On
RWU: not active
DSD: not active
HTR: not active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
General Inspection Function: not active
Internal Parking Brake state: static
Status of parking brake button: Not operated
Status ParkingBrake left: Set
Status ParkingBrake right: Set
334080 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 48
Mileage: 249806 km
Date: 2018.03.25
Time: 20:57:48
Internal Fault ID: 51
RWU: not active
DSD: not active
HTR: not active
ECD: not active
331264 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 48
Mileage: 249806 km
Date: 2018.03.25
Time: 20:57:48
Internal Fault ID: 99
RWU: not active
DSD: not active
HTR: not active
ECD: not active
331520 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 48
Mileage: 249806 km
Date: 2018.03.25
Time: 20:57:48
Internal Fault ID: 100
RWU: not active
DSD: not active
HTR: not active
ECD: not active
331776 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 48
Mileage: 249806 km
Date: 2018.03.25
Time: 20:57:48
Internal Fault ID: 101
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
Serial number: 120220-0004-119
Coding: 112296101000A300
ROD: EV_HeadlRegulBasic.rod
VCID: 2C50BA15478DB32494-8078
0095 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 48
Mileage: 249806 km
Date: 2018.03.25
Time: 20:57:50
336388 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 48
Mileage: 249806 km
Date: 2018.03.25
Time: 20:57:50
Part No SW: 4G0 035 056 E HW: 4G0 035 056
Component: Radio U STD H60 0093
Revision: AB001007 Serial number: 230BO0C7542029
Coding: 010003020100000001
VCID: 2342512922537C5C25-8076
Reset counter: 48
Mileage: 249875 km
Date: 2018.03.27
Time: 15:40:15
Bin. Bits: 00000000 00001000
Part No SW: 4G0 035 670 G HW: 4G0 035 670 A
Component: H-BNT-EU H48 0484
Revision: -------- Serial number: 428B-0C7541583
Coding: 050101010003A1ED05008B3E00000003000001000000000000
VCID: 275A4539566B907C79-8072
Subsystem 1 - Part No: 8R0 060 884 AH
Component: EUR 2012 1308
Subsystem 2 - Part No SW: 4G0 919 605 B HW: 4G0 919 605 B
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDB9400R48M
Subsystem 3 - Part No SW: 4G2 919 610 C HW: 4G2 919 610 C
Serial number: 90349LB9000B7
Subsystem 4 - Part No: 8R0 060 961 C
Component: CD-Database 3638
Reset counter: 48
Mileage: 249875 km
Date: 2018.03.27
Time: 15:40:20
Bin. Bits: 00010000 00000000
Bin. Bits: 00000000 00010000
Part No SW: 4G8 959 795 E HW: 4G8 959 795 A
Component: TSG HL H04 0212
Coding: 010814204001620002080002
VCID: 4480F2B5C71D5B647C-8010
Component: TSG HR H04 0212
End-------------------------(Elapsed Time: 04:40)--------------------------
