2012 A4 - Intermittent non start
rhinopower
C?ID=58979
Someone else posted previously having what appears to be identical issues. Car will not start, various faults come up on the dash, headlight range defective, parking brake fault, stability fault etc. Its not all the time though. Previous posted said that a new engine ecu was required. Given VCDS's changes since then the autoscan looks similar but not identical, but whats peoples opinion? For the price of a second hand ecu and getting it cloned i think its worth a shot
Wednesday,28,March,2018,16:17:08:34436
VCDS Version: 18.2.0.3 (x64)
VIN: WAUZZZ4G1CN137347   License Plate: EL60MED
Mileage: 249907km-155285mi   Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 3B 42 44 46 52 53 55 56
          5F 62 72
VIN: WAUZZZ4G1CN137347   Mileage: 249907km-155285miles
Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 LB    HW: 03L 906 018 JL
   Component: R4 2.0l TDI   H24 9977
   Revision: 45H24---
   Coding: 12034012242401080000
   Shop #: WSC 78387 152 452326
   ASAM Dataset: EV_ECM20TDI01103L906018LB 003011
   ROD: EV_ECM20TDI01103L906018HA.rod
   VCID: 75E65F71D447B2EC3B-8020
          U1113 00 [032] - -
                    Mileage: 249806 km
                    Date: 2018.03.25
                    Time: 21:03:17
                    Engine speed: 890.00 /min
                    Normed load value: 21.2 %
                    Coolant temperature: 59 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 11.940 V
                    Unlearning counter according OBD: 37
                    Cruise Control System (CCS): switch position-Bits 0-7: 129
                    Cruise Control System (CCS): status-Bits 0-7: 45
                    Cruise control switch-off: irreversible-Bits 0-7: 255
                    Cruise control switch-off: reversible-Bits 0-7: 255
                    Cruise Control System: specified speed: 0.00 km/h
                    Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
          U1113 00 [032] - -
                    Mileage: 249806 km
                    Date: 2018.03.25
                    Time: 21:03:17
Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
   Part No SW: 4G0 927 155 T    HW: 0AW 927 156 K
   Component: 0AW 20TDI RdW H04 0005
   Revision: --H04---    Serial number: 0000000105
   Shop #: WSC 06795 666 30556
   ASAM Dataset: EV_TCMVL381 A02430
   ROD: EV_TCMVL381.rod
   VCID: 3C708A55B7ED23A404-8068
10077 - Valve for Transmission Fluid Cooler
          P2753 00 [046] - Open Circuit
                    Fault Frequency: 8
                    Mileage: 249765 km
                    Date: 2018.03.25
                    Time: 11:48:19
                    Engine speed: 100.00 /min
                    Transmission input speed: 1 /min
                    Transmission output speed: 1 /min
                    Engine torque: -28 Nm
                    Transmission fluid temperature: 68 °C
                    Accelerator position: 0.0 %
                    Clutch status: 1
                    Occurrence_counter_over_length_of_life: 254
2264 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [044] - -
                    Mileage: 249806 km
                    Date: 2018.03.25
                    Time: 20:57:48
                    Engine torque: 0 Nm
                    Transmission fluid temperature: 47 °C
                    Clutch status: 1
                    Occurrence_counter_over_length_of_life: 7
7066 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [044] - -
                    Mileage: 249806 km
                    Date: 2018.03.25
                    Time: 20:57:48
                    Engine torque: 0 Nm
                    Clutch status: 1
                    Occurrence_counter_over_length_of_life: 6
   Part No SW: 4G0 907 379 H    HW: 4G0 907 379 H
   Component: ESP PREMIUM   H09 0361
   Coding: 06A187016085E180DB00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004028
   VCID: 3664987D89C1F9F4F2-8062
8 Faults Found:
0004 - Brake Switch (F)
          P0571 00 [008] - Implausible Signal
                    Reset counter: 45
                    Mileage: 249806 km
                    Date: 2018.03.25
                    Time: 20:57:48
                    VzRef: 00
                    Bit Info 1: 80
                    Bit Info 2: 0F
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: F6
                    Uz: 9E
0069 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 48
                    Mileage: 249806 km
                    Date: 2018.03.25
                    Time: 20:57:48
                    VzRef: 00
                    Bit Info 1: 80
                    Bit Info 2: 0F
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: E3
                    Uz: 9E
0071 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 48
                    Mileage: 249806 km
                    Date: 2018.03.25
                    Time: 20:57:48
                    VzRef: 00
                    Bit Info 1: 80
                    Bit Info 2: 0F
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: F0
                    Uz: 9E
0073 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 48
                    Mileage: 249806 km
                    Date: 2018.03.25
                    Time: 20:57:48
                    VzRef: 00
                    Bit Info 1: 80
                    Bit Info 2: 0F
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: F5
                    Uz: 9E
0075 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 48
                    Mileage: 249806 km
                    Date: 2018.03.25
                    Time: 20:57:48
                    VzRef: 00
                    Bit Info 1: 80
                    Bit Info 2: 0F
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: F8
                    Uz: 9E
0077 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 48
                    Mileage: 249806 km
                    Date: 2018.03.25
                    Time: 20:57:50
                    VzRef: 00
                    Bit Info 1: 80
                    Bit Info 2: 2F
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: FD
                    Uz: 9F
0091 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 48
                    Mileage: 249806 km
                    Date: 2018.03.25
                    Time: 20:57:48
                    VzRef: 00
                    Bit Info 1: 80
                    Bit Info 2: 0F
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 0C
                    Uz: 9E
0486 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 48
                    Mileage: 249806 km
                    Date: 2018.03.25
                    Time: 20:57:49
                    VzRef: 00
                    Bit Info 1: 80
                    Bit Info 2: 2F
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 04
                    Uz: 9E
   Part No SW: 4H0 907 064 BN    HW: 4H0 907 064 BN
   Component: BCM2 2.0      H31 0333
   Coding: 01B93006000000000000
   VCID: 76E4587DC141B9F432-8022
   Serial number: 2312000010543011
                    Fault Status: 00101101
                    Reset counter: 48
                    Mileage: 249806 km
                    Date: 2018.03.25
                    Time: 20:57:48
   Part No SW: 4G0 820 043 K    HW: 4G0 820 043 K
   Component: KLIMA 4 ZONEN H12 0064
   Serial number: 20021200040518
   Coding: 34220078A0
   ASAM Dataset: EV_AirCondiComfoUDS 002036
   VCID: 275A45395E6B907C79-8072
0278 - Coolant Shut-Off Valve
          B10C8 13 [009] - Open Circuit
                    Fault Frequency: 12
                    Reset counter: 7
                    Mileage: 249765 km
                    Date: 2018.03.25
                    Time: 11:48:04
                    Voltage terminal 30: 12.04 V
                    Outside air temperature: 14.5 °C
                    Interior temperature: 19.85 °C
0331 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Frequency: 11
                    Reset counter: 48
                    Mileage: 249806 km
                    Date: 2018.03.25
                    Time: 20:57:51
                    Voltage terminal 30: 12.30 V
                    Outside air temperature: 9.5 °C
   Part No SW: 4H0 907 063 BN    HW: 4H0 907 063 F
   Component: BCM1 2.0      H12 0111
   Revision: 20012002    Serial number: 00000001410124
   Coding: 2600201040349FE00181008300001D0C0F9DC70827090101000008602100
   VCID: 75E65F71DC47B2EC3B-8020
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 120116  H35 0080
   Serial number:         120130132055
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 12008216
   Coding: 02512B
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Serial number: 17 02 2012  00001329
   Component: AQ_Hum_Sensor  H02 0002
   Serial number: 0D3844E5000000000001
                    Reset counter: 48
                    Mileage: 249806 km
                    Date: 2018.03.25
                    Time: 20:57:00
   Part No SW: 4H0 919 475 N    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0050
   Revision: 11001001    Serial number: 55901204500467
   Coding: 080308
   ASAM Dataset: EV_EPHVA18AU57X0000 002005
   ROD: EV_EPHVA18AU57X0000_002_AU57.rod
   VCID: 3D768751ACF72AAC33-8068
12648448 - Databus
                    Reset counter: 48
                    Mileage: 249806 km
                    Date: 2018.03.25
                    Time: 20:57:50
Address 15: Airbags (J234)       Labels:| 4H0-959-655.clb
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG0074L9-
   Coding: 30323436313230303235554A305234473053
   Serial number: 3575HRB405L12NLA7GMZ
   Serial number: 3585HRB406712NLC9PJX
   Serial number: 3515JRB40530O32K99DY
   Serial number: 3525JRB40184UH6IK0V$
   Serial number: 3554VRB404V14KDMIOGS
   Serial number: 3564VRB405D14KDMAHK1
   Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Component: Lenks.Modul   H05 0201
   Revision: 00000000    Serial number: 20120221000529
   Coding: 000035
   VCID: 3068AE6563A5D7C4A8-8064
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Component: E221 - MFL  H08 0009
Address 17: Instruments (J285)       Labels:. 4H0-920-xxx-17.clb-SRI1
   Part No SW: 4G8 920 982 K    HW: 4G8 920 982 K
   Component: TDieGb        H79 0416
   Revision: 28460177    Serial number: 658270112596033
   Coding: 33AF10000B012600010000
   ASAM Dataset: EV_RBD4K 004045
   ROD: EV_RBD4K.rod
16776971 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 48
                    Mileage: 249806 km
                    Date: 2018.03.25
                    Time: 20:57:50
   Part No SW: 4G0 907 468 G    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0214
   Revision: --------    Serial number: 00000000408726
   Coding: 00CD074400
   ROD: EV_GatewUDS_AU57.rod
   VCID: 3460A2759FBDEBE4CC-8060
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790965767
   Voltage stabilizer:
   Serial number: 12042001025011200181
4224 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [008] - -
                    Reset counter: 48
                    Mileage: 249806 km
                    Date: 2018.03.25
                    Time: 20:57:22
                    Voltage terminal 30: 12.1 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 16 °C
                    System status: Awake_Timer_active
                    IN ESP_standstill flag: no standstill detected
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
   Part No SW: 4G0 919 158 C    HW: 4G0 919 158 C
   Component: KLIMA FOND    H07 0064
   Serial number: 21021200040539
   Coding: 02
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002018
   VCID: 2F6AAD19769BC83CB1-807A
0132 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Frequency: 11
                    Reset counter: 48
                    Mileage: 249806 km
                    Date: 2018.03.25
                    Time: 20:57:51
                    Voltage terminal 30: 12.33 V
                    Engine speed: 0 /min
                    Vehicle speed: 0.00 km/h
   Part No SW: 4G0 907 637     HW: 4G0 907 637
   Component: SARA 3D       H02 0009
   Revision: --------    Serial number: EJ1BPA3201HT7A0
   ASAM Dataset: EV_SARA 009017
   ROD: EV_SARA_009.rod
   VCID: 6BD279098203741CDD-803E
   Part No SW: 4G8 959 793 E    HW: 4G8 959 793 A
   Component: TSG FA        H05 0212
   Coding: 011C16204001620002080002
   VCID: 428CF4ADDD0955544E-8016
                    Reset counter: 48
                    Mileage: 249806 km
                    Date: 2018.03.25
                    Time: 20:57:47
   Component: RCEPS         H35 0010
   Revision: 00001000    Serial number: 0007363549
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 326CA46D65A9E5D4DE-8066
3158274 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Frequency: 27
                    Reset counter: 48
                    Mileage: 249806 km
                    Date: 2018.03.25
                    Time: 20:57:50
                    valid
   Revision: 00002001    Serial number: 0170309120
   Coding: 013B062220B9040083200904000104000000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 5
                    Mileage: 249794 km
                    Date: 2018.03.25
                    Time: 12:38:06
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 5
                    Mileage: 249794 km
                    Date: 2018.03.25
                    Time: 12:40:32
                    Reset counter: 48
                    Mileage: 249806 km
                    Date: 2018.03.25
                    Time: 20:57:48
   Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
   Component: TSG BF        H05 0212
   VCID: 418EFBA1D80F4E4C57-8014
                    Reset counter: 48
                    Mileage: 249806 km
                    Date: 2018.03.25
                    Time: 20:57:47
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000254092
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2A5CBC0D4D79AD1466-807E
333568 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 48
                    Mileage: 249806 km
                    Date: 2018.03.25
                    Time: 20:57:48
                    Voltage terminal 30: 12.2 V
                    Internal Fault ID: 49
                    Function light in parking brake button: On
                    Red operating lamp: On
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    Terminal 15 status: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: static
                    Status ParkingBrake left: Set
                    Status ParkingBrake right: Set
334080 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 48
                    Mileage: 249806 km
                    Date: 2018.03.25
                    Time: 20:57:48
                    Internal Fault ID: 51
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
331264 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 48
                    Mileage: 249806 km
                    Date: 2018.03.25
                    Time: 20:57:48
                    Internal Fault ID: 99
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
331520 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 48
                    Mileage: 249806 km
                    Date: 2018.03.25
                    Time: 20:57:48
                    Internal Fault ID: 100
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
331776 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 48
                    Mileage: 249806 km
                    Date: 2018.03.25
                    Time: 20:57:48
                    Internal Fault ID: 101
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
   Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
   Component: ....LWR12.... H02 0013
   Serial number: 120220-0004-119
   Coding: 112296101000A300
   ROD: EV_HeadlRegulBasic.rod
   VCID: 2C50BA15478DB32494-8078
0095 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 48
                    Mileage: 249806 km
                    Date: 2018.03.25
                    Time: 20:57:50
336388 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 48
                    Mileage: 249806 km
                    Date: 2018.03.25
                    Time: 20:57:50
   Part No SW: 4G0 035 056 E    HW: 4G0 035 056
   Component: Radio U STD   H60 0093
   Revision: AB001007    Serial number: 230BO0C7542029
   Coding: 010003020100000001
   VCID: 2342512922537C5C25-8076
            000 -  -  - Intermittent
                    Reset counter: 48
                    Mileage: 249875 km
                    Date: 2018.03.27
                    Time: 15:40:15
                    Bin. Bits: 00000000 00001000
   Part No SW: 4G0 035 670 G    HW: 4G0 035 670 A
   Component: H-BNT-EU      H48 0484
   Revision: --------    Serial number: 428B-0C7541583
   Coding: 050101010003A1ED05008B3E00000003000001000000000000
   VCID: 275A4539566B907C79-8072
   Subsystem 1 - Part No: 8R0 060 884 AH
   Component: EUR 2012  1308
   Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDB9400R48M
   Subsystem 3 - Part No SW: 4G2 919 610 C    HW: 4G2 919 610 C
   Component: E380 BDT C7  H11 0204
   Serial number: 90349LB9000B7
   Subsystem 4 - Part No: 8R0 060 961 C
   Component: CD-Database  3638
                    Reset counter: 48
                    Mileage: 249875 km
                    Date: 2018.03.27
                    Time: 15:40:20
                    Bin. Bits: 00010000 00000000
                    Bin. Bits: 00000000 00010000
   Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
   Component: TSG HL        H04 0212
   Coding: 010814204001620002080002
   VCID: 4480F2B5C71D5B647C-8010
   Component: TSG HR        H04 0212
End-------------------------(Elapsed Time: 04:40)--------------------------
Looking at that scan, if I were a betting man, I'd put my money on some kind of power problem.
South Molton, UK
6 year old car, still on the original battery? We've had some cold (for the UK) weather recently - 2 x "Beast from the East".
rhinopower
C?ID=58979
that was my exact train of thought, and exactly the case with my dad's TT, new battery sorted that out fine
rhinopower
C?ID=58979
Its not my car so not had chance to do any further investigation yet, but the guy wants it rolled back to pre ea189 fix anyway, which can be done at the same time as trying a different ecu. The fault codes listed from the auto scan that are also on the ross tech wiki all point at faulty ecu
NostraJackAss
But what about the NOx & wildlife?
rhinopower
C?ID=58979
Relay with 645 on it under the scuttle panel. Contacts were sooty and discoloured one disassembled.
rhinopower
C?ID=58979
Not sure how to add pictures so emailed to you. Add if you can, what do you think?
ivagp
C?ID=95551
could you give us the relay part# for 645, because they could have used that relay in many diffrent places and they tend to fail in the same manner.
