VCDS Directions for windows UP-Down via Remote 2015 VW Golf Using 14.8.1 Beta
pictureman
C?ID=96888
Has any one seen instructions on how to make this mod on the 2015 VW Golf? Im running the new 14.8.1 Beta
Sunday,28,September,2014,21:41:25:41859
VCDS Version: 14.8.1.0 (x64)
Data version: 20140905
VIN: 3VWRA7AU8FM021986   License Plate:
Mileage: 394km-244mi   Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 03 05 08 09 15 16 17 19 2B 42 44 52 5F 75
VIN: 3VWRA7AU8FM021986   Mileage: 394km-244miles
Address 01: Engine (J623-CRUA)       Labels: None
   Part No SW: 04L 906 021 C    HW: 04L 907 309
   Component: R4 2,0L EDC   H23 8142
   Revision: 85H23---
   Coding: 01190012032410081000
   Shop #: WSC 00066 790 00201
   ASAM Dataset: EV_ECM20TDI01104L906021C 001010
   ROD: EV_ECM20TDI01104L906021C.rod
   VCID: 256F3D0C244285128A-8070
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379.clb
   Part No SW: 5Q0 907 379 K    HW: 5Q0 907 379 F
   Component: ESC           H31 0371
   Revision: 00000000    Serial number: 51744000001348
   Coding: 01FA6AA12422096D0080020881C92580562490004081A4B200630050C002
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
   ROD: EV_Brake1UDSContiMK100ESP.rod
   VCID: 44A98088CF385C1ABD-8011
   Revision: 00021000    Serial number: 0337501864
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB_VW37.rod
   VCID: 3A55FE70BDFC1AEAD7-806F
   Part No SW: 5G0 907 044 AN    HW: 5G0 907 044 AN
   Component: Climatronic   H03 0907
   Revision: 00001K08
   Coding: 00020114200100000005000012111800
   ROD: EV_ACClimaBHBVW37X_VW37.rod
   VCID: 73CB1354DA16ABA2D4-8026
          B10CD 00 [008] - -
                    Reset counter: 46
                    Mileage: 382 km
                    Date: 2014.09.28
                    Time: 10:59:01
   Part No SW: 5Q0 937 087 N    HW: 5Q0 937 087 N
   Component: BCM PQ37BOSCH 028 0105
   Revision: --------    Serial number: 86580108140332
   Coding: 00110846404182E969E44000001407001800000000000000000000000000
   Shop #: WSC 00066 790 00203
   ASAM Dataset: EV_BodyContrModul1UDSBosc 013005
   ROD: EV_BCMBOSCH_SE37.rod
   VCID: 46AD9A80F9046E0AA3-8013
   Subsystem 1 - Part No SW: 5GM 955 119     HW: 5GM 955 119
   Component: WWS    140330  043 0581
   Serial number:         140804215859
   Component: RLHS  037 0059
   Serial number: S4Y14M07D25H18M37S47
   Coding: 00A8DD
   Subsystem 3 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.014  H02 0007
   Serial number:     WOO3007371
   Coding: 181801
329480 - Unknown Error Code
          B1806 F0 [008] - Unknown Error Elaboration
                    Fault Frequency: 37
                    Reset counter: 47
                    Mileage: 10 km
                    Date: 2011.02.10
                    Time: 18:48:11
   Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
   Serial number: 003MHM00M6Y/
   VCID: 5187B9DC004AB9B206-8004
   Seat occupant detection; front passenger side:
   Subsystem 1 - Part No SW: 4M0 959 339 A    HW: 4M0 959 339 A
   Component: BF-Gewichtss.  H05 0016
   Serial number: IBH0000J140000VQDS0$
   Coding: 303337
   Subsystem 2 - Part No SW: -----------    HW: 480 000 206 14
   Serial number: 357000000007520DDF0R
   Subsystem 3 - Part No SW: -----------    HW: 480 003 005 14
   Serial number: 358000000004B1AC7F0X
   Subsystem 4 - Part No SW: -----------    HW: 480 400 406 14
   Serial number: 3510002B5156EA0353A+
   Subsystem 5 - Part No SW: -----------    HW: 480 401 206 14
   Serial number: 3520002A9156EA049396
   Subsystem 6 - Part No SW: -----------    HW: 480 401 006 14
   Serial number: 3550002A31617D23901S
   Subsystem 7 - Part No SW: -----------    HW: 480 401 006 14
   Serial number: 3560002A11617D21919Y
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0155
   Revision: FF028028    Serial number: 20140606400592
   Coding: 0400
   Shop #: WSC 66564 385 16448
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 042940888FB89C1AFD-8051
   Part No SW: 5G1 920 841     HW: 5G1 920 841
   Component: KOMBI         243 4270
   Coding: 0BA41A122180CF05020868001000000000000000
   VCID: 65EF7D0C64C245124A-8030
Address 19: CAN Gateway (J533)       Labels: Redir Fail!
   Part No SW: 5Q0 907 530 S    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2186
   Revision: --------    Serial number: 25071410000413
   Coding: 0101000800087300EF000208080F00000001050000000000000000000000
   Shop #: WSC 00066 790 07030
   ASAM Dataset: EV_GatewConti 011017
   ROD: EV_GatewConti.rod
   VCID: 41A7899CD02A493296-8014
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P
   Component: E221__MFL-DC1  H14 0101
   Serial number: 29140001177100064225
   Coding: 28FFFF
   Revision: 00000000    Serial number: 14000152887005
   Coding: 5500000000000000
   ROD: EV_ELVMarquMQB_AU37.rod
   VCID: 3449D0489F98EC9A0D-8061
   Serial number: 010814060501E8
   Coding: 003A13200000040000000000
   VCID: 40A18C98DB20403A99-8015
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Serial number: 00000000000003032222
   Coding: 011000
   Component: EPS_MQB_ZFLS  122 1043
   Coding: 0102
   ROD: EV_SteerAssisMQB_SE37.rod
   Serial number: 210714060502NX
   VCID: 3FA38F64A6DE3FC2E0-806A
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Serial number: 00000000000003002570
   Coding: 191000
   Part No SW: 5G0 035 876     HW: 5G0 035 876
   Component: MU-S-NS-US    014 0645
   Serial number: V7B01906143699
   Coding: 027300020000000021220002001800001F0100340100010546
   ROD: EV_MUStd4CPASE_SE37.rod
   VCID: 69F7713C88DA61726E-803C
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5G0 919 605 K    HW: 5G0 919 605 K
   Component: ABT_Std_Nav  H60 0030
   Serial number: VWZ8Z9PS6004L2
   Engine Control Module 2:
   Subsystem 2 - Part No SW: 5G0 919 866 H    HW: -----------
   Component:  NAR 2014/15  --- 0020
Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
   Part No SW: 5QE 035 285     HW: 5QE 035 285
   Component: OCULowMQBUS   006 0528
   Shop #: WSC 00066 790 00122
   ROD: EV_OCULowMQB.rod
   VCID: 0225469095AC922ACF-8057
End-------------------------(Elapsed Time: 03:06)--------------------------
Andy
Sector 7G
HC424490
These guys made a handy step by step guide:
http://www.deutscheautoparts.com/newsarticle.aspx?NID=40
Make sure that after you make the VCDS changes, go into the car setup menu on the car's headunit itself and enable comfort functions. I got remotes working to roll the windows up and down, as well as opening and closing the sunroof all the way. I think the remotes only closed (didn't open) until I made the change on the car's display screen.
