2010 Audi Q5 3.2 (CALB) noise under 1-3 valve cover & #3 misfire
nmcracing
C?ID=316119
I am trying to figure out what the noise is that sounds like a marble rolling around near the #3 cylinder of my 2010 Audi Q5 with the 3.2 (CALB) engine. I also have a misfire on #3 that I have not been able to figure out. I have cleaned the intake valves (walnut blasting) and I have replaced the #3 fuel injector. I have also switched the coil packs around and the problem stays with the #3 cylinder. I have removed the valve cover and looked at the valve train and I have not seen anything that is out of place or broken from what I can tell.
Any help would be great.
Here is a link to the video of the noise. https://youtu.be/gVYgbamOHRI
Thanks in advance.
nmcracing
C?ID=316119
I should also add that I have performed a running compression check and Cyl #2 pumped up to 80 psi and Cyl #3 was from 70-75 psi.
MasterTommy
Amsterdam
C?ID=295586
Well, if cilinder 3 makes a noise, throws a DTC, the valve train and injector of that cilinder are okay and a compression test shows a (although small) difference:
It might actually be cylinder 3.
Visual check with a cam through the spark plug hole?
nmcracing
C?ID=316119
Well I have done a bit more to look into this issue. I removed the valve cover and started the engine so I could look around. See the below video.
https://youtu.be/yN5p-HbSnwY
My running compression check results are Cyl #2 pumped up to 80 psi and Cyl #3 was from 70-75 psi.
I also checked the voltage to the #3 coil pack and pin # 1 -> 2 was 12.26VDC and pin # 1 -> 4 was 12.26VDC as well. I then checked for continuity between pin #3 at the coil pack and pin 8 at the connector and it was good and showed .3 to .4 ohms of resistance (I thin the spec is 0.5 +/-0.3). I am not sure on the next steps for trouble shooting the misfire. I was thinking of checking the voltage at the injector but that requires taking off the intake manifold again. Not the end of the world just trying to limit the on and off of the intake as it is plastic and has plastic threads. Can VCDS tell me if the injector is working properly?
Wednesday,28,March,2018,19:25:58:30945
VCDS Version: 18.2.0.3 (x64)  HEX-V2 CB: 0.4411.4
Workshop Code: 444 03743 000001
VIN: WA1VKBFP5AA066307   License Plate:
Mileage: 178600km-110976mi   Repair Order:
Chassis Type: FP-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3C 42 46 47 52 53 55 56
          5F 62 69 6C 6D 72
VIN: WA1VKBFP5AA066307   Mileage: 178600km-110976miles
Address 01: Engine (J623-CALB)       Labels:| 06E-907-559-CAL.clb
   Part No SW: 8R0 907 559 G    HW: 8F0 907 559 A
   Component: 3.2 SIMOS8.2  H06 0004
   Revision: --------
   Coding: 0121000A190F0921
   Shop #: WSC 03743 444 00001
   ASAM Dataset: EV_ECM32FSI0218R0907559G 001004
   ROD: EV_ECM32FSI.rod
   VCID: 44D244B70E1C5137160-8010
7117 - Cylinder 3
          P0303 00 [236] - Misfire Detected
                    Mileage: 178421 km
                    Date: 2018.03.26
                    Time: 17:23:45
                    Engine speed: 838.00 /min
                    Normed load value: 24.7 %
                    Coolant temperature: 37 °C
                    Intake air temperature: 27 °C
                    Ambient air pressure: 890 mbar
                    Voltage terminal 30: 13.304 V
                    Engine speed: actual: 1504 /min
                    MAF_ENVD: 179.75294 mg/stroke
                    Coolant temperature (unfiltered): 29.3 °C
                    Engine: operating status: PU
                    T_AST_ENVD: 0.00 s
                    Vehicle speed: actual: 19 km/h
7123 - Cylinder 6
          P0306 00 [100] - Misfire Detected
                    Mileage: 178460 km
                    Date: 2018.03.27
                    Time: 05:29:07
                    Engine speed: actual: 832 /min
                    MAF_ENVD: 147.07058 mg/stroke
                    Coolant temperature (unfiltered): 37.5 °C
                    Engine: operating status: IS
                    T_AST_ENVD: 25.70 s
                    Vehicle speed: actual: 0 km/h
Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
   Part No SW: 8R0 927 158 F    HW: 0B6 927 156
   Component: 0B6 32 FSIUSA H05 0005
   Revision: --H05---
   Coding: 001012
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_TCMAL651 A01006
   ROD: EV_TCMAL651.rod
   VCID: 40DA48A71A044D17328-8014
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V1.clb
   Part No SW: 8R0 907 379 M    HW: 8R0 907 379 M
   Component: ESP8 quattro  H06 0020
   Coding: 049D18
   VCID: 4ACE6A8F2CB88747ECC-801E
   Part No SW: 8K0 907 064 CS    HW: 8K0 907 064 CS
   Component: BCM2 2.0      H06 0435
   Coding: 0D0500
   Shop #: WSC 46304 001 1048576
   VCID: 035087AB4B12960F6FA-8056
   Subsystem 1 - Part No SW: 8T0 959 754 G    HW: 8T0 959 754 G
   Component: FBSAUDIB8 IDG  H38 0060
   Serial number: 0509000069518017
   Serial number: 0209000098651002
   Part No SW: 8T1 820 043 AK    HW: 8T1 820 043 AK
   Component: KLIMA 3 ZONEN H08 0171
   Revision: C1000000    Serial number: 01141220091107
   Coding: 46112000
   VCID: 7AAEFA4F3CD8D7C73CC-802E
   Component: BCM1 1.0      H25 0380
   Revision: 10025001    Serial number: 00000000417052
   Coding: 26001091063CAF010000080300001D0D0F1C660800010161000000
   VCID: 3C223C57766C29F76E0-8068
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 091207  H10 0041
   Serial number: 90243014091204014919
   Coding: 01DD13
   Component: RLS  H04 0003
   Serial number: 10714987
   Coding: 024D25
   Component: E1 - LDS  H08 0090
   Serial number: 00000000001202101104
   Subsystem 4 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
   Component: HOMELINK  H01 0010
   Part No SW: 8K0 919 475 J    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0050
   Revision: 11001001    Serial number: 39840934906581
   Coding: 310105
   VCID: 40DA48A71A844D17328-8014
Address 15: Airbags (J234)       Labels:| 8R0-959-655.clb
   Part No SW: 8R0 959 655 D    HW: 8R0 959 655 D
   Component: AirbagVW-AU10 H39 0560
   Serial number: 003FRD056EEB
   Coding: 303333313432303030304A55304C38523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 45D459B30526683F01E-8010
   Subsystem 1 - Part No SW: 8R0 959 339     HW: 8R0 959 339
   Serial number: 5810000R0900002AJJ
   Serial number: 6334MSME4F054A3DR
   Serial number: 6344MSME4E34321FK
   Serial number: 6352QSME3048093AE
   Serial number: 6362QSME344714146
   Serial number: 63732SME7C472F069
   Serial number: 63832SME79472432
   Revision: --------    Serial number: 90315ILC0007Y
   Coding: 000017
   VCID: 3D2431536D7620FF59E-8068
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 980 K    HW: 8R0 920 980 K
   Component: KOMBIINSTR.   H10 0255
   Revision: 00000000    Serial number: CJK267ED9
   Coding: 8B1622000300D705020000
   VCID: 41DC4DA3118E441F3D6-8014
   Part No SW: 8T0 907 468 AA    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0105
   Revision: FB900055    Serial number: 5500F09B278112
   Coding: 00C303
   VCID: 005A88A75A048D17728-8054
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0107
   Serial number: 00000000004140857887
   Part No SW: 8R0 959 760 B    HW: 8R0 959 760 B
   Component: MEM-FS        H06 0074
   Revision: AA000000    Serial number: 00001001375831
   Coding: 00581B00000044440000
   Part No SW: 8R0 907 566     HW: 4L0 907 566 A
   Component: J0769_SWA_MasterH10 0040
   Revision: 00H10000    Serial number: 6PZ 009 014-04
   Coding: 0010009
   VCID: 7BA0FF4B3FE2EECF27A-802E
   Subsystem 1 - Part No: 8R0 907 568
   Component: J0770_SWA_Slave_H08 0040
   Subsystem 2 - Serial number: 6PZ 009 014-24
   Subsystem 3 - Serial number: 5F02.12.0900H080003CL11009ÿ
   Subsystem 4 - Serial number: L11009ÿ
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000009804022
   Coding: 011D13205E00440004
   VCID: 45D459B305A6683F01E-8010
   Revision: 00002001    Serial number: 0188028431
   Coding: 0126023A207A748104B0053200000000
   Component: GTO BF  H06 0050
   Serial number: 00000000000000203357
   Part No SW: 8T0 035 223 AL    HW: 8T0 035 223 H
   Component: DSP Prem      H09 0200
   Revision: 00009001    Serial number: 34890000552402
   VCID: 78AAE04702D4C5D74A8-802C
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Revision:             Serial number: 0000009749916
   VCID: 44D244B70E9C5137160-8010
   Revision: 00000003    Serial number: 10000000396427
   VCID: 343214775E3CE1B7A60-8060
   Part No: 8K0 907 357 B
   Component: Dynamische LWR  H01 0030
   Coding: 0000006
   Shop #: WSC 06334 000 00000
   VCID: 34321477523CE1B7A60-8060
   Part No SW: 4F0 035 082 A    HW: 4F0 035 082
   Component: Radio U SIRIU H45 0021
   Revision: AB001007    Serial number: 335L 097543903
   Coding: 020000010000000001
   VCID: 1D64D1D3CDB640FF79E-8048
02981 - Connection between Radio and Impedance Converter 1
                    Reset counter: 131
                    Mileage: 178371 km
                    Date: 2018.03.24
                    Time: 12:26:19
                    Voltage: 12.10 V
   Part No SW: 8T1 035 664 B    HW: 8T1 035 664 B
   Component: H-BN-NA       H47 0042
   Revision: --------    Serial number: 490L 097541552
   Coding: 010200060005A1EF51000B0E000000030000
   VCID: 3728237B4F4A0AAF832-8062
   Subsystem 1 - Part No: 8R0 060 884 F
   Component: NAR 2009/2010  5304
   Component: DU7 High  H43 0306
   Serial number: 9356B+0A1196977
   Subsystem 3 - Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
   Serial number: 00000000973108
   Component: CD-Database  1293
02244 - Button in Control Head is Stuck
            000 -  -  - Intermittent
                    Reset counter: 173
                    Mileage: 178386 km
                    Date: 2018.03.26
                    Time: 06:29:55
                    Voltage: 14.80 V
                    Bin. Bits: 10000000 00000000
                    Bin. Bits: 00000000 00000000
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Revision:             Serial number: 0000102499665
   Coding: 010C13204000240004
   VCID: 42DE42AF14885F0724C-8016
Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Component: Anhaenger     H12 0100
   Revision: 1A001001    Serial number: 00000401459262
   Coding: 0200000000000000
   Shop #: WSC 09031 002 1048576
   VCID: 36362E7F4840F3A7984-8062
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H03---    Serial number: 525PA8-J9YA1G8
   Coding: 1030010
   Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
   Component: J605  Master  H52 0330
   Revision: --------    Serial number: 8R0827851B
   VCID: 3B203F4B73622ECF67A-806E
   Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
   Component: J756  Slave  H52 0330
   Serial number: 8R0827852B
   Revision:             Serial number: 0000102507495
End----------(Elapsed Time: 02:00, VBatt start/end: 12.3V/12.3V)-----------
NostraJackAss
Maybe carbon holding an intake valve open or a burned/cracked valve seat/valve face interference angle.
Take intake off, Inspect, Remediate, Repair .....
nmcracing
C?ID=316119
When I cleaned the intake valves they all held solvent when closed so I think the valve seat to valve is good.
I took the Q5 to an independent audi/vw shop yesterday morning and told them everything that I have done and they listened to the car and they said it sounds like the upper timing chain has slop in it. They recommended replacing both of the upper tensioners. I guess my next step is to take of the upper chain covers and take a look.
NostraJackAss
Isn't car is a ULEV2 and carries a warranty on this for 10-120K & in some cases 15/150K if related to additional items which induced a related failure?
nmcracing
C?ID=316119
Yes, Audi of America (AoA) covers the issue if there is a code thrown for the secondary air ports but those codes have to be thrown for AoA to pay the dealer for the cleaning. I have not had those codes thrown yet.
Nate-
nmcracing
C?ID=316119
Someone else on one of the forums said that it looked like I had a cam lobe that went flat. I was able to measure that today and I don't think that is the case. From what I can tell the intake cam has two profiles for the lower RPM circuit, one for the fwd valve and one for the aft valve of each cylinder. Here are my results for each lobes lift:
Cyl #1 Fwd - .043" Aft - .127"
Cyl #2 Fwd - .044" Aft - .128"
Cyl #3 Fwd - .044" Aft - .128"
Cyl #4 Fwd - .044" Aft - .126"
I was also able to get the timing chain cover off and look at the tensioner and from what I can tell it looks good and none of the plastic wear pads showed excessive wear. I am going to pull the cams this week and take a look at the rockers and valves for any issues. This will also give me the opportunity to reseal the guide frame from leaking oil into the spark plug holes.
