I had changed the instrument of this car and the lamp of ABS appeared and in the old instrument the ABS was not appear , is this code of the instrument is right ???
I checked the WD and it is ok
Saturday,24,March,2018,06:15:12:11183
VCDS Version: 17.8.1.0
Data version: 20171130 DS276.6
VIN: WVWZZZ1JZ4W181324 License Plate:
Mileage: 250710km-155783mi Repair Order:
76
VIN: WVWZZZ1JZ4W181324 Mileage: 250710km-155783miles
Address 01: Engine Labels: 06A-906-018-AQY.lbl
Part No: 06A 906 018 FK
Component: 2.0l R4/2V MOTR AT V05
Coding: 00033
Shop #: WSC 58320
VCID: 70EA528F3088BCC661-4AB4
18044 - Powertrain Data Bus
P1636 - 35-00 - Missing Message from Airbag Controller
18090 - Powertrain Data Bus
P1682 - 35-00 - Implausible Message from ABS Controller
Readiness: 0010 0100
Address 02: Auto Trans Labels: 01M-927-733.lbl
Part No: 01M 927 733 HS
Component: AG4 Getriebe 01M 4469
Coding: 00000
VCID: 081A1A6F28189406D9-0954
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 G
Component: ABS 20 IE CAN 0001
Coding: 03604
Shop #: WSC 31414
VCID: 3564A39B0F6AD9EE72-4A9C
Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
Part No: 1J0 909 603 AN
Component: AIRBAG VW3 - V04
Coding: 16718
Shop #: WSC 31414
VCID: 75E4639B4FEA99EEB2-4ACE
00-00 - -
32-10 - Resistance Too High - Intermittent
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J5 920 806 C
Component: KOMBI+WEGFAHRSP VDO V20
Coding: 00101
VCID: 2C5286FFDC2098261D-50C8
WVWZZZ1JZ4W181324 VWZ7Z0D9151544
49-00 - No Communications
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 01266
VCID: 70EA528F3088BCC661-50C8
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 Q
Component: 4C Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 31414
VCID: 4C92E67F7CE0B8263D-4AB4
Subsystem 1 - Part No: 1J1959801C
Component: 4C Tõrsteuerger. FS0001F
Subsystem 2 - Part No: 1J1959802D
Component: 4C Tõrsteuerger. BF0001r
Subsystem 3 - Part No: 1J4959811C
Component: 4C Tõrsteuerger. HL0001r
Subsystem 4 - Part No: 1J4959812C
Component: 4C Tõrsteuerger. HR0001r
00952 - Signal; Drivers Door Open
28-10 - Short to Plus - Intermittent
35-00 - -
35-00 - -
27-00 - Implausible Signal
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1J0 035 186 E
Component: Radio BNO 0004
Coding: 01401
Shop #: WSC 01317
VCID: 275879D3C5C6BB7EF0-4A9C
07-00 - Signal too Low
00856 - Radio Antenna
36-00 - Open Circuit
00853 - Loudspeaker(s); Rear
End-------------------------(Elapsed Time: 05:29)--------------------------
