Octavia II 2.0 TDI CR 103KW
berki
Czech Republic
C?ID=329420
Please help friends.
Address 08: Climate / Heating (J255) Labels: * not selected
***Control unit SW: ----------- HW: -----------
***Part: Climatronic 0709
***Revision: --------
***Coding: 0000000000
***Workshop #: WSC 00000 000 00000
***ASAM Dataset: EV_Climatronic A01010
***ROD: EV_ClimaAutoBasis_SK35.rod
***VCID: 6FBA23712717B04FB3B-803A
1 error found:
13636352 - The control unit is not coded
**********U1013 00 [009] - -
**********Confirmed - Tested from memory deletion
*************fault info:
********************Status of faults: 00000001
********************Fault priority: 6
********************Frequency of defects: 1
********************Reset counter: 191
********************Mileage: 248539 km
Address 19: CAN Gateway (J533) Labels :. SVO \ 7N0-907-530-V2.clb
***SW control unit: 7N0 907 530 AF HW: 7N0 907 530 AF
***Part: J533 Gateway H52 1634
***Revision: H52 Serial number: 080113F2001515
***Coding: 352302
***Workshop #: WSC 22675 401 00000
***VCID: 74B02C1D4EB193974E9-8020
1 error found:
00469 - Data bus display runs one guide
************011 - Preruses
********************Status of faults: 01101011
********************Fault priority: 3
********************Frequency of faults: 29
********************Reset counter: 208
********************Time indication: 0
********************Date: 2018.02.24
********************Time: 13:50:25
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Please post an Auto-Scan so people can see exactly how this vehicle is equipped and configured.
berki
Czech Republic
C?ID=329420
Fixed, thank you for your help
Friday, 23, March, 2018,18: 32: 53: 43971
VCDS - Windows VAG / VAS Emulator Running on Windows 8.1 x64
VCDS version: SVO 17.8.1.0 HEX-V2 CB: 0.4411.4
Data version: 20170224 DS276.6
www.vag-com.com
Service name: IT-PB
VIN: TMBGE61Z8D2124303 Production plate:
Mileage: 249420km Order Nr.:
Model: 1Z-SK35 (7N0)
Scan: 01 03 08 09 10 15 16 17 18 19 25 37 42 44 46 52 55 56 62 69
          72 77
VIN: TMBGE61Z8D2124303 Mileage: 249420km
01-Engine - Status: OK 0000
03-ABS Brakes - Status: OK 0000
04-Steering angle sensor - Status: OK 0000
08-Climate / Heating - Status: Inoperative 0010
09-Central Electricity - Status: OK 0000
10-Asist Park./Command - Status: OK 0000
15-Airbags - Condition: OK 0000
16-Steering Wheel - Status: OK 0000
17-instrument panel - status: OK 0000
18-Auxiliary Heating - Status: OK 0000
19-CAN Gateway - Status: Inoperative 0010
25-Immobilizer - Status: OK 0000
37-Navigation - Status: OK 0000
42-El. driver's door - Status: OK 0000
44-Power Steering - Status: OK 0000
46-Comfort System - Status: OK 0000
52-El. PP door - status: OK 0000
55-Reg. Lights indicator - status: OK 0000
56-Radio - Status: OK 0000
62-El.LZ Door - Status: OK 0000
69-Trailer Function - Status: OK 0000
72-El.PZ Door - Status: OK 0000
77-Phone - Status: OK 0000
Address 01: Engine (J623-CFHC) Labels :. SVO \ 03L-906-018-CFF.clb
   Control unit SW: 03L 906 018 C HW: 03L 906 018 BR
   Part: R4 2.0L EDC H25 9813
   Revision: 42H25 --- Serial Number:
   Coding: 0019001A042400080000
   Workshop #: WSC 73430 031 00093
   ASAM Dataset: EV_ECM20TDI01103L906018C 003006
   ROD: EV_ECM20TDI01103L906018C.rod
   VCID: 2A0CF265DC759567245-807E
No error found.
Address 03: ABS Brakes (J104) Labels :. User \ 1K0-907-379-60EC1F.clb
   Control unit SW: 1K0 907 379 BL HW: 1K0 907 379 BL
   Part: ESP MK60EC1 H31 0152
   Revision: 00H31001
   Coding: 113B401C092400FE880E02E4901C0042350000
   Workshop #: WSC 73430 790 00093
   VCID: 7DA609397DFBD2DF317-8028
No error found.
   Revision: --------
   Coding: 0000000000
1 error found:
          U1013 00 [009] - -
             fault info:
                    Fault priority: 6
                    Reset counter: 213
                    Mileage: 249163 km
                    Date: 2018.03.13
                    Time: 17:34:44
Address 09: Central Electricity (J519) Labels :. SVO \ 1K0-937-08x-09.clb
   SW control unit: 1K0 937 087 AD HW: 1K0 937 087 AD
   Part: BCM PQ35 H 111 0709
   Revision: AC111709
   Coding: 46000AB8E85BF1C040080080510091E4437000AE726DA5605C8540000040
   VCID: 73B22F014BBF94AF573-8026
   Subsystem 1 - Controller: 1Z1 955 119 D Labels: SVO \ 1KX-955-119.CLB
   Part: Wischer 19011 26 0601
   Coding: 00D7B7
   Subsystem 2 - Controller: 1K0 955 559 AH Labels: SVO \ 1K0-955-559-AG.CLB
   Part: RLS 140113 05 54 0403
   Coding: 0630ED
   Subsystem 3 - Controller: 5J0 951 172
   Part: DWA-Sensor H0 H03 1211
   Subsystem 4 - Controller: 1K0 951 605 C
   Part: LIN BACKUP HO H05 1501
No error found.
Address 10: Asist Park / Facility (J446) Labels: SVO \ 1Z0-919-475-V2.clb
   Control unit SW: 1Z0 919 475 E HW: 7N0 919 475
   Part: PARKHILFE 8K H06 0005
   Revision: --H06 --- Serial number: 28261301102228
   Coding: 118001
   ASAM Dataset: EV_EPHVA18SKxxx0000 001001
   ROD: EV_EPHVA18SKxxx0000_001.rod
   VCID: 43D2BFC15B1F642F073-8016
No error found.
Address 15: Airbags Labels: User \ 1K0-909-605.clb
   Controller SW: 1K0 909 605 T HW: 1K0 909 605 T
   Part: Q6 AIRBAG VW8 020 2300
   Revision: 05020000 Serial number: 0038PC2DD6FB
   Coding: 0020790
   VCID: 3D26C939317B12DF717-8068
   Subsystem 1 - Serial Number: 6332MSME75425A6FP
   Subsystem 2 - Serial Number: 6342MSME77346F29P
  Subsystem 3 - Serial Number: 6351HSME2F0C5F4CW
   Subsystem 4 - Serial Number: 6361HSME2F0B043DG
No error found.
Address 16: Steering wheel electronics (J527) Labels: SVO \ 5K0-953-569.clb
   Control unit SW: 5K0 953 521 BN HW: 5K0 953 569 E
   Part: LENKS.MODUL 016 0140
   Revision: FF010041 Serial number: 20130118800117
   Coding: 108A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 79AE1D296953EEFF1DF-802C
   Multifunction steering wheel control:
   Subsystem 1 - Controller SW: 3T0 959 537 HW: 3T0 959 537 Labels: SVO \ 3C8-959-537.CLB
   Part: E221__MFL-URO H07 0012
   Coding: 820000
No error found.
Address 17: Instrument panel (J285) Labels: SVO \ 5K0-920-xxx-17.clb
   Control unit SW: 1Z0 920 843 S HW: 1Z0 920 843 S
   Part: KOMBI H06 0608
   Coding: 110E01
   ROD: EV_Kombi_UDS_VDD_RM09_A04_VW32.rod
   VCID: 48C8A8ED62394777D21-801C
No error found.
Address 18: Additional heating Labels: SVO \ 1K0-815-007.clb
   Control unit: 7N0 963 272 E
   Part: Standheizer 044 4941
   Revision: 00044000 Serial number: 09028239000000
   Coding: 0031012
   Workshop #: WSC 25757 002 1048576
   VCID: 372ADB111347388FABB-8062
No error found.
   Coding: 352302
1 error found:
            011 - Preruses
             fault info:
                    Fault priority: 3
                    Frequency of defects: 15
                    Reset counter: 226
                    Mileage: 249252 km
                    Time indication: 0
                    Date: 2018.03.17
                    Time: 15:49:11
Address 25: Immobilizer (J334) Labels: SVO \ 5K0-920-xxx-25.clb
   Control unit SW: 5K0 953 234 HW: 5K0 953 234
   Part: IMMO H06 0608
   VCID: 6A8C32651CF55567E45-803E
No error found.
Address 37: Navigation (J0506) Labels :. SVO \ 1T0-035-680.clb
   Controller SW: 3T0 035 686 C HW: 3T0 035 686 C
   Part: RNS-MID H09 5238
   Revision: AB001001 Serial number: SKZ6Z7N7021059
   Coding: 04000402000100810000
   VCID: 3634D615184DC187B0D-8062
   Subsystem 1 - Controller: 3T0 051 859 AM
   Part: EU East V13 8350
No error found.
Address 42: El. Driver's door Labels :. SVO \ 1K0-959-701-MAX3.clb
   SW control unit: 1T0 959 701 AA HW: 1T0 959 701 AA
   Part: Tuer-SG 009 2113
   Coding: 0004342
   Workshop #: WSC 27171 260 69740
   VCID: 76B4161554CD818770D-8022
No error found.
Address 44: Label Controller: SVO \ 1K0-909-14x-GEN3.clb
   Control unit: 1K0 909 144 P
   Part: EPS_ZFLS Kl. 69 3305
   Revision: 00H22000
No error found.
Address 52: El. PP Door Labels :. SVO \ 1K0-959-702-MAX3.clb
   Controller SW: 1T0 959 702 S HW: 1T0 959 702 S
   Part: Tuer-SG 009 2119
   Coding: 0004342
   VCID: 48C8A8ED6EB94777D21-801C
No error found.
Address 55: Registry of Lamp Labels: User \ 5M0-907-357-V2.clb
   Control unit SW: 5M0 907 357 C HW: 5M0 907 357 C
   Part: AFS-Steuergeraet 0148
   Revision: 00H04000 Serial Number:
   Coding: 1507354
   VCID: 3430EC1D0231D3978E9-8060
   Subsystem 1 - Controller: 7L6 941 329 B Labels: SVO \ 3D0-941-329.CLB
   Part: AFS-Lst.-Module l 0004
   Coding: 00000023
   Subsystem 2 - Controller: 7L6 941 329 B Labels: SVO \ 3D0-941-329.CLB
   Part: AFS-Lst.-Module r 0004
   Coding: 00000023
No error found.
Address 56: Radio (J0506) Labels :. SVO \ 1T0-035-680.clb
No error found.
Address 62: El.LZ Door Labels :. SVO \ 1K0-959-703-GEN3.clb
   Control unit SW: 5K0 959 703 A HW: 5K0 959 703 A
   Part: Tuer-SG 007 2101
   Coding: 0000144
   Workshop #: WSC 27171 260 1012556
   VCID: 323CEA05F825DDA79C5-8066
No error found.
Address 69: Trailer Functions (J345) Labels :. SVO \ 1K0-907-383-V2.clb
   Control unit SW: 1K0 907 383 F HW: 1K0 907 383 F
   Part: ConWysTrailer H07 0100
   Revision: 3A001001 Serial number: 00000132425721
   Coding: 0100000100000000
   Workshop #: WSC 00007 223 174336
   VCID: 3038E00DFA29EFB7EA1-8064
No error found.
Address 72: El.PZ Door Labels :. SVO \ 1K0-959-704-GEN3.clb
   Control unit SW: 5K0 959 704 A HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 3332EF01073FD4AF973-8066
No error found.
Address 77: Phone (J412) Labels: SVO \ 7P6-035-730.clb
   Controller SW: 7P6 035 730 K HW: 7P6 035 730 K
   Part: PHONE H15 3200
   Revision: 1B001001 Serial number: 00007664108495
   Coding: 0701000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3A2CC2252CD525E7545-806E
No error found.
End ------- (Elapsed Time: 01:22, VBat Start / End: 12.2V / 12.2V) ---------
Thank you for your help
berki
Czech Republic
C?ID=329420
Thank you for your friend's efforts, I need to deal with the fault at 08 and 19, I do not need a beta version of VCDS !!!
Thank you
18.2 is a full Release, not a Beta version. :)
Also, you can install it in parallel with the Czech version you are currently using and then you can post English-language data directly, instead of having some translation program mangle your scans.
As for your faults:
- I'm wondering why your 08-HVAC module identifies as "Control unit SW: ----------- HW: -----------" ????
Is this module a replacement or a retrofit?
- Databus in single-wire mode is usually an indication of a broken CAN wire.
berki
Czech Republic
C?ID=329420
Hello. I bought the car with this defect and I think it's all original. Unfortunately, I too can not speak English and I use a translator.
berki
Czech Republic
C?ID=329420
Sunday,25,March,2018,15:34:01:43971
VCDS Version: 18.2.0.3 (x64)  HEX-V2 CB: 0.4411.4
VIN: TMBGE61Z8D2124303   License Plate:
Mileage: 249500km-155032mi   Repair Order:
Chassis Type: 1Z-SK35 (7N0)
          72 77
VIN: TMBGE61Z8D2124303   Mileage: 249500km-155032miles
Address 01: Engine (J623-CFHC)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 C    HW: 03L 906 018 BR
   Component: R4 2,0L EDC   H25 9813
   Revision: 42H25---    Serial number:
   Shop #: WSC 73430 031 00093
   VCID: 2A0CF265DC7595670CC-807E
   Revision: 00H31001
   Shop #: WSC 73430 790 00093
   VCID: 7DA609397DFBD2DF19E-8028
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: -----------    HW: -----------
   Component: Climatronic   0709
   Revision: --------
   Coding: 0000000000
   VCID: 6FBA23712717B04F9B2-803A
13636352 - Control module not coded
          U1013 00 [009] - -
          [Steuergerät nicht codiert - keine Anzeige]
                    Reset counter: 230
                    Mileage: 249503 km
                    Date: 2018.03.25
                    Time: 14:26:16
   Part No SW: 1K0 937 087 AD    HW: 1K0 937 087 AD
   Component: BCM PQ35  H   111 0709
   Revision: AC111709
   VCID: 73B22F014BBF94AF7FA-8026
   Subsystem 1 - Part No: 1Z1 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 19011  26  0601
   Coding: 00D7B7
   Component: RLS 140113 05  54  0403
   Coding: 0630ED
   Subsystem 3 - Part No: 5J0 951 172
   Component: DWA-Sensor H0  H03 1211
Address 10: Park/Steer Assist (J446)       Labels:| 1Z0-919-475-V2.clb
   Part No SW: 1Z0 919 475 E    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0005
   Revision: --H06---    Serial number: 28261301102228
   Coding: 118001
   Shop #: WSC 22675 401 00000
   VCID: 43D2BFC15B1F642F2FA-8016
   Component: Q6 AIRBAG VW8   020 2300
   Coding: 0020790
   VCID: 3D26C939317B12DF59E-8068
   Subsystem 1 - Serial number: 6332MSME75425A6FP
   Subsystem 2 - Serial number: 6342MSME77346F29P
   Subsystem 3 - Serial number: 6351HSME2F0C5F4CW
   Subsystem 4 - Serial number: 6361HSME2F0B043DG
   Part No SW: 5K0 953 521 BN    HW: 5K0 953 569 E
   Coding: 108A140000
   VCID: 79AE1D296953EEFF356-802C
   Subsystem 1 - Part No SW: 3T0 959 537     HW: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0012
   Coding: 820000
   Part No SW: 1Z0 920 843 S    HW: 1Z0 920 843 S
   Component: KOMBI         H06 0608
   Coding: 110E01
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK34.rod
   VCID: 48C8A8ED62394777FA8-801C
Address 18: Aux. Heat        Labels: 1K0-815-007.clb
   Part No: 7N0 963 272 E
   Component: Standheizer     044 4941
   Coding: 0031012
   Shop #: WSC 25757 002 1048576
   VCID: 372ADB111347388F832-8062
   Part No SW: 7N0 907 530 AF    HW: 7N0 907 530 AF
   Component: J533  Gateway H52 1634
   Coding: 352302
   VCID: 74B02C1D4EB19397660-8020
00469 - Infotainment Databus in Single Wire Operation
                    Fault Frequency: 9
                    Reset counter: 230
                    Mileage: 249425 km
                    Date: 2018.03.23
                    Time: 18:46:45
   Component: IMMO          H06 0608
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8C32651CF55567CCC-803E
   Part No SW: 3T0 035 686 C    HW: 3T0 035 686 C
   Component: RNS-MID       H09 5238
   VCID: 3634D615184DC187984-8062
   Subsystem 1 - Part No: 3T0 051 859 AM
   Component: EU East V13  8350
   Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
   Component: Tuer-SG         009 2113
   Coding: 0004342
   Shop #: WSC 27171 260 69740
   VCID: 76B4161554CD8187584-8022
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 69     3305
   Revision: 00H22000
   Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
   Component: Tuer-SG         009 2119
   Coding: 0004342
   VCID: 48C8A8ED6EB94777FA8-801C
   Coding: 1507354
   VCID: 3430EC1D0231D397A60-8060
   Coding: 00000023
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Coding: 00000023
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Coding: 0000144
   Shop #: WSC 27171 260 1012556
   VCID: 323CEA05F825DDA7B4C-8066
   Component: ConWysTrailer H07 0100
   Shop #: WSC 00007 223 174336
   VCID: 3038E00DFA29EFB7C28-8064
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 3332EF01073FD4AFBFA-8066
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   VCID: 3A2CC2252CD525E77CC-806E
End----(Elapsed Time: 01:22, VBatt start/end: 11.8V/11.7V. VIgn 11.8V)-----
VCDS 18.2 English version
Address 19: CAN Gateway (J533) 00469 - Infotainment Databus in Single Wire Operation
This error is in the driver between the Gateway and the diagnostics. It was finished with a towing device, is not it possible to miss here ???
Error Address 08: Auto HVAC (J255) 13636352 - Control module not coded
can you enter a long code and if so, where do I find it ????
thank you very much for your help
This is not right:
   Revision: --------
It's difficult for anyone to try to find an appropriate coding for this module when the module won't report any part numbers. ;)
berki
Czech Republic
C?ID=329420
Can I find a part number without diagnostics?
Sure. Remove the Climatronic from the dashboard. The part number will be printed on it somewhere.
But the real question here is: Will it every work correctly? The software in it is clearly either damaged or has been altered intentionally.
berki
Czech Republic
C?ID=329420
Interesting, can you recommend a solution to buy another climatronic? When it's warm, I'll take it off and figure out the number. Gateway error is a broken wire between navigation and gateway? What color should it have? Thanks for your help, I really appreciate my friend.
berki
Czech Republic
C?ID=329420
Today I found the number of the climatronik control 3T0907044CA that is according to ETKA correctly.
Buy a new driver?
I took off the navigation and here is the photo of the wires, is it okay?
Brown, Black and White Linked ???
https://s31.postimg.org/wtbi247vv/IMG_0248.jpg
