2006 VW POLO 1.2, 3 CYL Missfire problem...
raynard08
C?ID=330537
had a little problem with this polo missfireing on cylinder , had a working coil from another car and still no cure.. any advice anyone can off from my scan i see some ecu faults on my scan ? still getting used to vcds so thanks for any advice...
Friday,23,March,2018,09:08:41:24744
VCDS Version: 18.2.0.3 (x64)  HEX-V2 CB: 0.4411.4
VIN: WVWZZZ9NZ6Y095925   License Plate:
Mileage: 176910km-109926mi   Repair Order:
Chassis Type: 9N (9N - VW Polo (2002 > 2010))
Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
VIN: WVWZZZ9NZ6Y095925   Mileage: 176910km-109926miles
   Part No: 03D 906 033 F
   Component: 1,2l/2V SIMOS3  00HS2509
   Coding: 00031
   Shop #: WSC 00788
   VCID: 221C1AA7BDD9FB9744C-5184
   WVWZZZ9NZ6Y095925     VWZ7Z0E1659701
16686 - Cylinder 2
            P0302 - 35-10 - Misfire Detected - Intermittent
Readiness: 0110 0101
Address 03: ABS Brakes        Labels: 6R0-907-37x-ABS80.clb
   Part No SW: 6Q0 907 379 AF    HW: 6Q0 907 379 AF
   Component: ABS 8.0 front   H04 0002
   Shop #: WSC 00788 785 00200
   VCID: 015E752B1D1F008F7D6-50D0
                    Fault Status: 00101101
                    Fault Frequency: 31
                    Reset counter: 22
                    Mileage: 176916 km
18265 - Load Signal
            P1857 - 000 - Error Message from ECU - Intermittent
                    Reset counter: 21
                    Mileage: 176917 km
Address 09: Cent. Elect.        Labels:. 6Qx-937-049-C.lbl
   Part No: 6Q1 937 049 D
   Component: 00AF BN-SG.         1S34
   Coding: 25918
   Shop #: WSC 00788
   VCID: 3C20C4DF3F7DAD676E0-50D0
01598 - Drive Battery Voltage
   Part No: 6Q0 909 601 F
   Component: 05 AIRBAG VW5       0010
   Coding: 12341
   Shop #: WSC 00788
   VCID: 3634D6F701517737984-50D0
Address 17: Instruments        Labels: 6Q0-920-xxx-17.lbl
   Part No: 6Q0 920 903 E
   Coding: 01431
   VCID: 3332EFE31223621FBFA-50D0
   Part No: 6N0 909 901
   Component: 0B7L GATEWAY CAN    1S34
   Coding: 00014
   Shop #: WSC 00788
   VCID: 70B820EF23B51907828-50D0
   Part No: 6Q0 423 156 AB
   Component: LenkhilfeTRW        V270
   Coding: 10140
   Shop #: WSC 00788
   VCID: 6FBA23933E8B06FF9B2-50D0
Address 46: Central Conv.        Labels:. 6Q0-959-433.clb
   Part No: 6Q0 959 433 G
   Component: 41 Komfortgerát     0002
   Coding: 00017
   Shop #: WSC 00788
   VCID: 3FDAB3D32E6BB67F4B2-4B3C
Address 56: Radio        Labels: None
   Part No HW: 6Q0 035 152 A
   Revision: 00005000    Serial number: VWZ1Z5F8990053
   VCID: 55F6717BBD175C2F71E-50D0
            000 -  -
End----(Elapsed Time: 03:07, VBatt start/end: 11.9V/11.9V. VIgn 0.0V)------
At 110,000 miles.. When was the last time this engine got fresh spark plugs?
What do the fuel trims look like?
How much carbon is on the intake valves?
raynard08
C?ID=330537
spark plugs have been swapped today along with a new coil pack.. still no joy. tomorrow i will have my compression test kit back and will test compression then hopefully narrow it down to fuel/pump/injector
as for the fuel trim i found it really difficult to locate much live data , on the mk5 golf i played around with vcds live data i could get all kinds up and then i would hover the mouse over a certain value and it would tell me the range that was ment to be but on this there is nothing like that. can see a load of values for different things but it doesent they are, only RPM and lambder , everything else was just numbers and nothing else telling me what these values where ? if you get me ?
Looks like another one that nobody has ever made an English label file for, but given its vintage, the trims will be in Group 032, field 1 being Idle and field 2 being under load.
Golftwincharged
Guyana
C?ID=320847
check the valves!
raynard08
C?ID=330537
pressure tested mate, cylinder 2 and 3 awful compression exhaust valves knackered... big job broke out yesterday :) anyone know any hosting sites i can host images on and i will put some pics in my thread... thanks..
