Audi A3 8P stubborn "service due" warning
Fredrick Awuor
Kenya
C?ID=309834
Hello everyone,below is an autoscan of an audi serviced by a friend a week ago but service warning not reset,he passed at my place and i performed SRI yesterday,but immediately the service now popped up after cycling the ignition,we went for a test drive,came back,switched car off,then on after 15 minutes and the service due accompanied with a wrench symbol lit up,since i have not done this on an audi i do not know if it is normal,on golfs it goes off immediately,today its been the same,anyone experienced this or if i missed a procedure somewhere,any insight will be greatly appreciated.
Wednesday,21,March,2018,12:27:22:48669
VCDS Version: 18.2.0.3 (x64)  HEX-V2 CB: 0.4411.4
Dealer/Shop Name: FREDRICK'S VWAUDI
VIN: WAUZZZ8P6BA107017   License Plate: A3
Mileage: 58000km-36039mi   Repair Order:
Chassis Type: 8P-AU35 (8P0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 47 52 55 62 72
VIN: WAUZZZ8P6BA107017   Mileage: 58000km-36039miles
Address 01: Engine (CAX)       Labels: 03C-906-016-CAX.clb
   Part No SW: 03C 906 016 AN    HW: 03C 906 016 F
   Component: MED17.5.5           9060
   Revision: LCH02---    Serial number: AUX7Z0K0FNA0QJ
   Coding: 0000077
   Shop #: WSC 57643 000 1048576
   VCID: 6B80CE41AF8E118FB7A-803E
               U1017 - 000 -
                    Mileage: 58007 km
                    Date: 2018.03.21
                    Time: 12:19:46
                    RPM: 699 /min
                    Load: 14.5 %
                    Temperature: 87.0°C
                    Temperature: 50.0°C
                    Absolute Pres.: 830.0 mbar
                    Voltage: 13.716 V
Readiness: 1110 0001
   Part No SW: 0AM 300 050 D    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 2669
   Revision: 00043014    Serial number: CU501310155828
   Shop #: WSC 64810 741 139054
   VCID: 2A0E0B4560F4C8870CC-807E
006279 - Wheel-Speed Signal from ABS Control Module
               P1887 - 000 - Implausible Signal
                    Reset counter: 10
                    Mileage: 57550 km
                    Date: 2018.01.31
                    Time: 13:44:59
   Revision: 00H31001
   Coding: 1342401209220001C80B02E590200080390800
   Shop #: WSC 06314 000 00000
   VCID: 76B6EF35E8CCDC67584-8022
                    Reset counter: 230
                    Mileage: 57935 km
                    Date: 2018.03.08
                    Time: 14:54:15
                    Count: 1088
                    Count: 4608
                    Count: 81
                    Count: 49665
                    Count: 769
03842 - RPM Sensor Rear Right: Incorrect Signal
            000 -  -  - Intermittent
                    Reset counter: 231
                    Mileage: 57870 km
                    Date: 2018.02.26
                    Time: 00:13:33
                    Count: 1
                    Count: 14
                    Count: 29184
                    Count: 87
                    Count: 49152
                    Count: 64256
                    Count: 65280
                    Fault Status: 00100011
                    Fault Frequency: 29
                    Reset counter: 239
                    Mileage: 57478 km
                    Date: 2018.01.15
                    Time: 14:18:27
                    Count: 1088
                    Count: 4608
                    Count: 83
                    Count: 49922
                    Count: 255
                    Count: 64005
                    Fault Status: 01101100
                    Fault Frequency: 29
                    Reset counter: 199
                    Mileage: 57099 km
                    Date: 2018.01.12
                    Time: 14:38:34
                    Count: 12800
                    Count: 80
                    Count: 50176
                    Count: 60672
                    Count: 65280
   Part No SW: 8P0 820 043 BM    HW: 8P0 820 043 BM
   Component: KlimavollautomatH09 0170
   Revision: 000361      Serial number: 8P0820043BM
   VCID: 78AAE10DEED8AA174A8-802C
   Part No SW: 8P0 907 063 K    HW: 8P0 907 063 K
   Component: BCM PQ35  M   107 0615
   Revision: 00107 AF
   Coding: 46000A2FA0051AC0207040E00100095C427E2BAA306DD928E40000840040
   Shop #: WSC 06314 123 12345
   VCID: 3C223D1D966046376E0-8068
   Subsystem 1 - Part No SW: 8P2 955 119 F    HW: 8P2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350  H11 0050
   Coding: 00DD13
   Subsystem 2 - Part No SW: 8K0 910 557     HW: 8K0 955 559 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSEN  H04 0003
   Coding: 024C2D
                    Fault Status: 00101110
                    Reset counter: 239
                    Mileage: 58002 km
                    Date: 2018.03.21
                    Time: 08:21:31
                    Voltage: 13.50 V
                        Term 50 Off
                    Reset counter: 239
                    Mileage: 58006 km
                    Date: 2018.03.21
                    Time: 09:53:19
                        Term 15 Off
                    Voltage: 12.55 V
                        Term 50 Off
Address 10: Park/Steer Assist (J446)       Labels:. 8P0-919-475-7X2.clb
   Part No SW: 8P0 919 475 N    HW: 8P0 919 475 N
   Component: PARKHILFE 8K  H01 0140
   Revision: 11001001    Serial number: 12591101356784
   Coding: 000105
   VCID: 49CC54C9C9B2E39FE56-801C
Address 15: Airbags (J234)       Labels:| 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 P    HW: 8P0 959 655 P
   Component: Airbag AU1042 H07 0200
   Revision: --------    Serial number: 003FB00A2LU6
   Coding: 30314238303830303038554A305238503053
   ROD: EV_Airba10AURB4.rod
   VCID: 4FF87AD13756CDAFBB2-801A
   Serial number: 3572DRB40000D30C525Q
   Serial number: 3582DRB40000D30CE893
   Serial number: 35128RB400005F96AFF7
   Serial number: 35228RB400005F95D4C$
   Serial number: 35547RB400003F96078S
   Serial number: 35647RB400003F95F4F4
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Coding: 0012112
   VCID: 46D65FF5D4AC0CE7084-8012
   Component: E0221           H02 0100
01304 - Radio
   Part No SW: 8P0 920 932 K    HW: 8P0 920 932 K
   Component: KOMBIINSTR. VDO H01 0091
   Revision: D0H01004    Serial number: 2240K004043905
   Coding: 0256928
   Shop #: WSC 64820 741 179233
   VCID: 3C223D1D9A6046376E0-8068
   Part No SW: 8P0 907 530 B    HW: 1K0 907 951
   Component: J533  Gateway H42 0311
   Revision:   H42       Serial number: 221110F2000126
   Coding: 352103
   VCID: 323E132544248047B4C-8066
   Revision: D0H01004    Serial number: AUX7Z0K0FNA0QJ
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX3.lbl
   Part No SW: 8P0 959 801 P    HW: 8P0 959 801 P
   Component: Tuer-SG         H04 0101
   Coding: 0004788
   VCID: 48CA51CDDEB81A97FA8-801C
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 232    3201
   Revision: 00H20000
   Shop #: WSC 02069 000 90108
   VCID: 3432153DB2308E77A60-8060
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Fault Frequency: 150
                    Reset counter: 199
                    Mileage: 58007 km
                    Date: 2018.03.21
                    Time: 11:32:19
                    Voltage: 13.63 V
                        DU
                    Temperature: 41.0°C
                    RPM: 701 /min
Address 47: Sound System        Labels: 8Px-035-382.lbl
   Part No SW: 8P4 035 382 E    HW: 8P4 035 382 E
   Component: AB2 SUBWOOFERBOXH07 0180
   Revision: 00006       Serial number: 92158086670882
   VCID: 36362F35A44C9C67984-8062
   Part No SW: 8P0 959 802 P    HW: 8P0 959 802 P
   Coding: 0004788
   VCID: 49CC54C9C5B2E39FE56-801C
   Part No: 8P3 907 357 B
   Coding: 0000013
                    Fault Status: 11101101
                    Reset counter: 199
                    Mileage: 57096 km
                    Date: 2018.01.12
                    Time: 14:38:38
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
   Component: Tuer-SG         H04 0050
   Coding: 0000144
   Shop #: WSC 06314 000 1012544
   VCID: 42DE43E5F88430C724C-8016
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
   Coding: 0000144
   VCID: 43D046E1E79E39CF2FA-8016
End----------(Elapsed Time: 01:11, VBatt start/end: 13.7V/13.8V)-----------
Wednesday,21,March,2018,12:06:23:48669
VIN: WAUZZZ8P6BA107017   License Plate: AUDI A3
VCDS Release 18.2.0:  SRI Reset
Control Module Part Number: 8P0 920 932 K       Labels:  8P0-920-xxx-17-MY8.clb
Component:KOMBIINSTR. VDO H01 0091, Coding:0256928
Channel  	Description                                       	Unit      	Current val.  	New val.
02       	Service Reminder Status                           	          	2             	---
40       	Distance since Service                            	km x100   	50            	---
41       	Time since Service                                	Days      	372           	---
42       	Minimum Distance to Service                       	km x100   	150           	---
43       	Maximum Distance to Service                       	km x100   	300           	---
44       	Maximum Time to Service                           	Days      	730           	---
45       	Oil Quality                                       	          	1             	---
47       	Soot Quantity                                     	km x100   	1             	---
48       	Thermal Load                                      	km x100   	85            	---
49       	Minimum Time to Service                           	Days      	365           	---
50       	Basic Distance Value for Oil Change               	km x100   	160           	---
51       	Basic Time Value for Oil Change                   	Days      	365           	---
52       	Basic Distance Value for Inspection               	km x100   	160           	---
53       	Distance since Inspection                         	km x100   	50            	---
54       	Basic Time Value for Inspection                   	Days      	365           	---
55       	Time since Inspection                             	Days      	372           	---
56       	Day Counter                                       	Days      	2599          	---
Wednesday,21,March,2018,12:10:24:48669
VIN: WAUZZZ8P6BA107017   License Plate: AUDI A3SRI
Operation: Flexible Oil Service Reset (LongLife/Rest of World/Gasoline)
02       	Service Reminder Status                           	          	2             	0
42       	Minimum Distance to Service                       	km x100   	150           	150
43       	Maximum Distance to Service                       	km x100   	300           	300
44       	Maximum Time to Service                           	Days      	730           	730
45       	Oil Quality                                       	          	1             	2
49       	Minimum Time to Service                           	Days      	365           	365
Gone But Not Forgotten
Be sure you are saving the value in cluster as Zero and make sure that VCDS is configured with valid WSC, Tester number and Importer number.
Take a look at the value in Channel 55. See how it is greater than the value in Channel 54? That means an Inspection is due, not just a Service.
One of the jobs in the pull-down should be: "Time based Service Reset (Rest of World & Great Britain)". Select it, then [Perform SRI]
In addition, you may still have to do "Fixed Oil Service Reset (Rest of World)".
Fredrick Awuor
Kenya
C?ID=309834
Hello Jack,I saved new value to Zero,but vcds didn't prompt for WSC or Tester Number,anyway which numbers would be appropriate in those fields,so that I reconfigure it,thanks for the hints
Fredrick Awuor
Kenya
C?ID=309834
Thanks Uwe,I will follow your instructions and post results,and by what @Jack has said,can I copy the WSC,importer and Tester number from the numerous scans I have and configure my interface with them?
Not the interface, but a particular installation of VCDS. See the User Interface and Identification section of this page:
http://www.ross-tech.com/vcds/tour/option_screen.php
Fredrick Awuor
Kenya
C?ID=309834
The only time it's a concern is if the car you're working on is still under warranty. In that case, you probably want to be as stealthy as possible. On anything else, things are probably easier if you have some on-zero numbers in there.
If you put numbers in there, you can revert to Stealth Mode at any time by deleting the VCDS.CFG file...
Fredrick Awuor
Kenya
C?ID=309834
Thanks, understood
