DRL Taillights coding Yeti 2016
Henrik Eldholm
Sweden
C?ID=186092
Hello
I have a 2016 Yeti Monte Carlo and would like my taillights to come on automatically with the light assist. Is that possible to code using VCDS? I Have tried to search but i can´t find anything.
hadez16
C?ID=289891
Please post a full Auto-Scan of your car
langers2k
C?ID=224085
VCDS probably won't help you with this.
You're going to need VCP or ODIS to directly edit the lighting configuration. I believe there is even a guided function if you find a knowledgeable and friendly local dealer.
An autoscan will confirm.
Henrik Eldholm
Sweden
C?ID=186092
Sorry for not posting the full scan from the beginning. But here it is.
VCDS Version: 18.2.0.3 (x64)
VIN: TMBJJ75L7G6067814   License Plate: NGX492
Mileage: 71700km-44552mi   Repair Order:
Chassis Type: 5L-SK35 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 4F 52 55 5F 61 62
          69 72
VIN: TMBJJ75L7G6067814   Mileage: 71700km-44552miles
Address 01: Engine (J623-CZCA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HM    HW: 04E 907 309 BK
   Component: R4 1.4l TFS   H23 3180
   Revision: R9H23---
   Coding: 00250032243401080000
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_ECM14TFS01104E906027HM 001004
   ROD: EV_ECM14TFS01104E906027HM.rod
   VCID: 76DBD8F1C9A2B4F432-8022
   Part No SW: 0AM 300 065 Q    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 6509
   Revision: 00043014    Serial number: CU501604146948
   VCID: 3D4907DD641427AC33-8068
   Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
   Component: ESP MK60EC1   H46 0175
   Revision: 00H46001
   Coding: 913F200E11280501891304E5881DA050A1000021
   VCID: 75D9DFFDDCA4BFEC3B-8020
   Part No SW: 3T0 907 044 CL    HW: 3T0 907 044 CL
   Component: Climatronic   H19 0809
   Revision: 00001010
   Coding: 0010000003
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 7ECBC0D1E192FCB46A-802A
   Part No SW: 1K0 937 087 AR    HW: 1K0 937 087 AR
   Component: BCM PQ35  H   112 0903
   Revision: AC112903
   Coding: 66000ABFA00518C4400800C0510089E44B7000AE626D8D608081C7040041
   VCID: 0131BB2D986C834C17-8054
   Subsystem 1 - Part No: 5L1 955 119 B  Labels: 1KX-955-119.CLB
   Component: SK356  26  0610
   Coding: 00F7B5
   Subsystem 2 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 140416 03  37  0059
   Coding: 02085D
Address 10: Park/Steer Assist (J446)       Labels:| 1Z0-919-475-V2.clb
   Part No SW: 1Z0 919 475 G    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0011
   Revision: --H06---    Serial number: 28261608300453
   Coding: 318106
   ASAM Dataset: EV_EPHVA18SKxxx0000 002001
   ROD: EV_EPHVA18SKxxx0000_002.rod
   VCID: 45B96F3DC4C46F6C6B-8010
   Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
   Component: AirbagVW10    014 0613
   Serial number: 003G5RAVZFFS
   Coding: 00004E31
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 31512BED604CD3CCA7-8064
   Serial number: 3572MSME6A206B57ZZZ/
   Serial number: 3582MSME06567A56ZZZ$
   Serial number: 3516KSME0B063C3DZZZ.
   Serial number: 3526KSME022C463DZZZW
   Part No SW: 5K0 953 521 FL    HW: 5K0 953 569 BD
   Revision: FF010042    Serial number: 20160418301069
   Coding: 1882140000
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 7BCDC9C5F280E99C4D-802E
   Subsystem 1 - Part No SW: 5E0 919 719 L    HW: 5E0 919 719 L
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000D0665140316
   Coding: 820000
   Part No SW: 5L0 920 841     HW: 5L0 920 841
   Component: KOMBI         H03 1007
   Coding: 120E010200
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
   VCID: 69E1838D881C6B0CAF-803C
   Part No SW: 7N0 907 530 BF    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1673
   Revision:   H55       Serial number: 060416F1001032
   Coding: 356332
   Component: IMMO          H03 1007
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6AE3FC818D1A6014A6-803E
   Part No SW: 7N0 959 793 J    HW: 7N0 959 793 G
   Component: TSG FA        H05 0561
   Revision:             Serial number: 0000195275182
   Coding: 01150320D000231003
   VCID: 49A1630DE0DC8B0C8F-801C
00109 - Left Mirror Turn Signal Lamp (L131)
                    Fault Status: 00101100
                    Reset counter: 57
                    Mileage: 71309 km
                    Date: 2017.12.19
                    Time: 08:34:04
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 69     3501
   Revision: 00H22000
   VCID: 394113CD703C1B8C1F-806C
   Component: EZE_2         H55 1673
   Coding: 050B0500
   VCID: 6FD5ED95BEF8853CF1-803A
   Subsystem 1 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H04 0090
   Subsystem 2 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H04 0090
   Part No SW: 7N0 959 792 J    HW: 7N0 959 792 G
   Component: TSG BF        H05 0561
   Revision:             Serial number: 0000194196593
   Coding: 01150120D000231003
   VCID: 48A76609FBD6720490-801C
   Component: AFS-ECU       H05 0111
   Coding: 03D200003F000000
   VCID: 374515F58E280DFCE9-8062
   Subsystem 1 - Part No: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Subsystem 2 - Part No: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Part No SW: 5L0 035 680 B    HW: 5L0 035 680 B
   Component: MU-S-N-ER     H22 0245
   Serial number: SKZAZ2S5038750
   Coding: 03130601FF00000011110001000800002F0007D40120010046
   ROD: EV_MUStd4CTSAT_SK35.rod
   VCID: 2961C38D489CAB0C6F-807C
   Subsystem 1 - Part No SW: 5L0 051 236 H    HW: -----------
   Component: ECE 2016  --- 0521
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AM
   Component: Batt.regelung H55 1673
   Coding: 332F7857
   VCID: 71D1EBEDA8CC93CCE7-8024
   Component: J367-BDM  H07 0180
   Serial number: 43102948141491911990
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-795.clb
   Part No SW: 7N0 959 795 F    HW: 7N0 959 795 E
   Component: TSG HL        H05 0561
   Revision:             Serial number: 0000195310270
   Coding: 010001200000531003
   VCID: 47A56535F6C87D7C99-8012
   Component: Anhaenger     H12 0100
   Revision: 3A001001    Serial number: 00000401292823
   Coding: 410D000100000000
   VCID: 30572EE96346DAC4A8-8064
Address 72: Door, Rear Right (J389)       Labels:. 7N0-959-795.clb
   Component: TSG HR        H05 0561
   Revision:             Serial number: 0000195310269
hadez16
C?ID=289891
Not possible with VCDS for your Car
