Terminal 15 - MK5 2l Golf Fsi - No mill light?
ak77
Singapore
C?ID=232348
Hi guys,
I bought second hand golf Mk5 2l Fsi and it keeps going in the limp mode. Also it seems when that happens the mill light (engine check light) does not come up on dash.. It seems the mill light has been disconnected (it never comes up or is it visible). The car starts and engine runs fine until you turn the car/key off. After that it can not be started until it has 1 hour break. There are other issues below listed and they have all been addressed, but Im stuck on :
00576 - Terminal 15
Also from address 46 on-wards , including Cent and doors can not be reached? dont know why?
Any help is appreciated.
Al
_________________________________________
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
   Part No SW: 06F 906 056 DE    HW: Hardware No
   Component: MED9.5.10       G00 7224
   Revision: 00000000    Serial number: VWZ7Z0D9987816
   Coding: 0000072
   Shop #: WSC 00046 412 00000
   VCID: 6FEDE09C7E3E273E78-803B
   Subsystem 1 - Part No: 06F 907 807 F
   Component: NOX  1007100055 002 0409
   06F907807F  NOX  1007100055 002 0409
17811 - EGR System
            P1403 - 008 - Regulation Deviation
16725 - Camshaft Position Sensor (G40)
            P0341 - 004 - Implausible Signal - Intermittent
16414 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
            P0030 - 004 - Malfunction / Open Circuit - Intermittent
16453 - Intake Manifold Pressure <-> Ambient Air Pressure
            P0069 - 008 - Incorrect Correlation - Intermittent
Readiness: 1110 0101
   Part No: 1K0 907 379 N
   Component: ASR FRONT MK70      0103
   Coding: 0017025
   VCID: 3D710AD464D285AEBA-8069
   Part No: 1K0 820 047 CR
   Component: Climatic PQ35   081 0404
   VCID: 76E3D5F8016416F6BB-8023
   Part No SW: 1K0 937 049 S    HW: 1K0 937 049 S*
   Component: Bordnetz-SG 1.0 H30 0704
   Revision: 00030000    Serial number: 00000000759775
   Coding: E48D0F0600041800001400001400000000
   VCID: 3F8D70DC6EDE97BEA8-806B
   Subsystem 1 - Part No: 1K2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00049109
   Subsystem 2 - Part No: 1K0 955 559 AE  Labels: 1K0-955-559-AF.CLB
   Component: RLS     270306 014  1201
   Coding: 00208933
00576 - Terminal 15
01049 - Supply Voltage Term 50
            006 - Short to Plus - Intermittent
01800 - Light Switch (E1)
   Part No SW: 1K0 909 605 D    HW: 1K0 909 605 D
   Component: 04 AIRBAG VW8   022 0600
   Revision: 05022000    Serial number: 0033JD0CPKZ1
   Coding: 0012340
   VCID: 2D513A94B4B2152E0A-8079
   Subsystem 1 - Serial number: 6332MSME7D7D7C02
   Subsystem 2 - Serial number: 6342MSME353D5C02
   Subsystem 3 - Serial number: 6351HSME360E6201
   Subsystem 4 - Serial number: 6361HSME464C2602
   Part No SW: 1K0 953 549 B    HW: 1K0 953 549 B
   Component: Lenksäulenmodul 013 0010
   Coding: 0002042
   VCID: 316926E4A88A71CE2E-8065
   Component: Lenkradmodul    004 0030
   Part No: 1K0 920 861 A
   Component: KOMBIINSTRUMENT VDD 0814
   Coding: 0003703
   Shop #: WSC 44300 067 57207
   VCID: 275DC8BC964E3F7EF0-8073
   Part No SW: 1K0 907 530 C    HW: 1K0 907 951
   Component: Gateway         H08 0080
   Revision: 08          Serial number: 21001043318B74
   Coding: 3D3F0340070003
Address 25: Immobilizer
   Part No: 1K2 909 144 F
   Component: EPS_ZFLS Kl.0       1301
   VCID: 2F6D209CBEBE673E38-807B
            000 -  -
Address 46: Central Conv.
Address 52: Door Elect, Pass.
Address 56: Radio
Address 62: Door, Rear Left
Address 72: Door, Rear Right
End-------------------------(Elapsed Time: 02:21)--------------------------
Gone But Not Forgotten
ak77
Singapore
C?ID=232348
I have done 80% of those checks, : all the fuses and Relays followed all the components with electrical guide in ELSA. Replaced the ignition switch and found the same error repeating.
Mainly error 15 and EGR issue. I have done the same testing with blocked EGR. Same result.
Convenience module cannot be reached. This and the last 46, 52, 56, 62, 72 , can not be reached .... not sure why.
Im not getting the engine MIl light comming on at all, but do get some PCB light come on
Also below codes are recorded every time I re-connect battery and start the engine. Its starts like new every time I reconnect the battery. Engine runs perfect until I turn it off.
All the errors clear in the VCD but the 3 in bold . EGR system is the reacquiring one. It seams the flaps dont stay either clothes or open in position.
After you turn the engine off you wont start it again without disconnecting battery and waiting 30min. Only once starts. It seems the limp mode somehow starves the engine and suffocates it then shuts off.
I have not looked at the Alternator relay . It didn't give me a cause to ? I didn't find anything on my codes from VCDs forum. Im waiting for teh Rossteck guys to get back to me...
I can clear all but ones in bold. What should I be looking into next. EGR valve , exhaust oxygen sensor?
more help required, thanks :)
Al
13 Faults Found:
17811 - EGR System
P1403 - 008 - Regulation Deviation - MIL ON
18058 - Powertrain Data Bus
P1650 - 008 - Missing Message from Instrument Cluster - Intermittent
P0341 - 004 - Implausible Signal - MIL ON
17978 - Engine Start Blocked by Immobilizer
P1570 - 008 - - Intermittent
P0030 - 004 - Malfunction / Open Circuit - MIL ON
 Wiring/Connector(s) from/to Alternator Relay (J53) faulty.
P1442 - 001 - Signal too High - Intermittent
17951 - Angle Sensor 1 for Throttle Actuator (G187)
P1543 - 002 - Signal too Small - Intermittent
17580 - Angle Sensor 2 for Throttle Actuator (G188) Signal too Low
P1172 - 002 - - Intermittent
18038 - Accelerator Position Sensor (G79)
P1630 - 002 - Signal too Low - Intermittent
17082 - Sensor Reference Voltage C
P0698 - 002 - Too Low - Intermittent
17953 - Throttle Valve Controller
P1545 - 008 - Malfunction - Intermittent
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0106 - 008 - Implausible Signal - Intermittent
17976 - Throttle Actuator (J338)
P1568 - 001 - Mechanical Failure - Intermittent
Readiness: 0110 0101
Coding: 0017025
VCID: 3D710AD464D285AC33-8069
00668 - Supply Voltage Terminal 30 (this one turns into Voltage Term 50, after second starting....flip flops back and front)
Well finish the other 20%........
Isolate stuff to track it down.
ak77
Singapore
C?ID=232348
Yeah, job for tomorrow.
Not sure why alternator control module would be throwing error 15? And why the rest of the modules ( convenience ) cant be reached.
For some reason, I'm suspecting the ECU...
cheers
al
ak77
Singapore
C?ID=232348
That's interesting as I have replaced both.
Again the interesting thing is ignition and engine will behave perfectly and run smooth , but only once.
It seems to log this error I thing in ECU.
My VCD output tests Give me 4 DTC sported codes
DTC02195 - Failure Mode 009 MIL triggered: NO Active YES Stored:YES
DTC02403 - Failure Mode 012 MIL triggered: NO Active YES Stored:YES
DTC02576 - Failure Mode 012 MIL triggered: NO Active YES Stored:YES
DTC02061 - Failure Mode 012 MIL triggered: NO Active YES Stored:YES
ak77
Singapore
C?ID=232348
I have completed all the test suggested and the ones I know off. Thia is the most difficult issue I ever had diagnosed with no answer
Not sure If I should be looking in to something else
What have you done for this ?
ak77
Singapore
C?ID=232348
Replaced the sensor ...but spits out the identical error 15, can not clear DTS.
ak77
Singapore
C?ID=232348
what do you mean by that?
sorry not sure what your abbreviation is for, me being from Australia and all....
Check the Throttle valve and wiring + ECU for damage or water ingress causing an undefined condition for a terminal 15 back feed.
Does you MIL work during bulb check & before starting car or with VCDS outputs?
ak77
Singapore
C?ID=232348
Hey,
no MIL light on at all , just the PCB light .
ak77
Singapore
C?ID=232348
I'm at this stage thinking someone unplugged, not from the 16 pin connector as I did check that when I was replacing ignition.
Dash console looks bit damaged on the edges. I don't know whats to gain by removing it ?! It just my guess until I take it apart.
ak77
Singapore
C?ID=232348
Sorry about asking, but what is FOD abbreviated for?
MasterTommy
Amsterdam
C?ID=295586
Foreign Object Damage. You can hover your mouse over such abbreviations to see the meaning.
Jack just tends to use FOD as much as possible (I like it but I can understand if it's confusing). In this case he means to check for actual FOD such as water damage, but also tampering or other 'it didnt leave the factory like that' conditions. The MIL should work and it doesnt, so even if you dont think that could be related, its an obvious fault and should be repaired or cluster replaced first.
