Several times pre-sense has hit the brakes when on a country road with no obstacles, quite frightening! Dealer can find no issue and no DTC codes set.
In the MMI pre-sense can be turned off but will always revert to on once the ignition is cycled...
So trying to work out how to code it off in the MLBevo platform, any ideas?
Scan below:
Scan below:
Tuesday,20,March,2018,17:41:03:22933
VCDS Version: 18.2.0.3 HEX-NET CB: 0.4411.4
VIN: WAUZZZFY0J2040516 License Plate:
Chassis Type: FY-AU49 (8W5)
Scan: 01 02 03 08 09 15 16"]01 02 03 08 09 15 16 17 19 22 29 17 19 22 29 2B 39 42 44 46 52 39 42 44 46 52 5F 6D 81
A5 BB BC
VIN: WAUZZZFY0J2040516 Mileage: 4773km-2965miles
Address 01: Engine (J623-DAXB) Labels: None
Part No SW: 80A 906 259 HW: 06L 907 425 C
Component: 2.0l R4 TFSI H15 0004
Revision: --H15---
Coding: 2A6500322526052B74080000000000000000000000000000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM20TFS02080A906259 001006
ROD: EV_ECM20TFS02080A906259.rod
VCID: E89CF26A132ACE0430-80BC
Readiness: 1010 0001
Address 02: Auto Trans (J217) Labels:* None
Part No SW: 80A 927 155 AG HW: 0CJ 927 156
Component: 0CJ 20TFSIRdW H04 0001
Revision: --H04--- Serial number: 0000000959
ASAM Dataset: EV_TCMDL382021 002027
ROD: EV_TCMDL382021_AU48.rod
VCID: EE90847231CE10347A-80BA
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 K
Component: V553 MTFP 0C4 0572
Serial number: 75117081170144001429
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 80A 907 379 B HW: 80A 907 379
Component: ESP9 Plus H11 0766
Coding: 14AA40BE28A60A9691A3589220835292E4A59228021450891A044A4927A549
ROD: EV_ESP9BOSCHCMP_002.rod
VCID: AE104472F14E50343A-80FA
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 80A 820 043 K HW: 80A 820 043 K
Component: Klima Zone 3 H55 0210
Coding: 640800095544440D02000100080000000000000000000000000000000000
ROD: EV_AirCondiBHTCAU491.rod
VCID: A502BB5EA4B8136CCB-80F0
Subsystem 1 - Part No SW: 4M2 820 021 A HW: 4M2 820 021 A
Component: J126 FLuftV H08 0003
Serial number: 00000000000001606191
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H01 0006
Serial number: B4E11EA880PAG0MUFU02
Subsystem 3 - Part No SW: 80A 919 158 HW: 80A 919 158
Component: E265 Kli Fond H40 0080
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0267
Coding: C2501B42C11A00CD051587149FAE80B9110B3108000000000000000020001A0100410022025601
VCID: 8248C0C2155604548E-80D6
Subsystem 1 - Part No SW: 80C 955 119 HW: 80C 955 119
Component: 426 RL 170417 040 0570
Serial number: 00000001704112102443
Coding: 5FC7F7
Serial number: 20484089X81A955555A0
Coding: 02006E
Subsystem 3 - Part No SW: 4M0 941 531 AA HW: 4M0 941 531 AA
Component: E1 - LDS H06 0008
Serial number: 01 08 2017 72130198
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE117071723510453
Coding: 210000
Interior Light Module:
Subsystem 5 - Part No SW: 80A 947 135 G HW: 80A 947 135
Component: Dachmodul Q5 H31 0310
Serial number: Q00019537
Coding: 0D0104
Subsystem 6 - Part No SW: 8W0 925 301 BD HW: 8W0 925 301 BD
Component: SL-B9/Q5NF H17 0010
Serial number: 2617000148709002
Address 15: Airbags (J234) Labels:| 80A-959-655.clb
Part No SW: 80A 959 655 N HW: 80A 959 655 N
Component: AirbagVW30 031 0513
Serial number: 003WBM01U2P/
Coding: AACCF0C00C800000585400FFF08C40000065
ASAM Dataset: EV_AirbaVW31SMEAU65x 001006
ROD: EV_AirbaVW31SMEAU65x_AU49.rod
VCID: BE307432212EA0B4AA-80EA
Subsystem 1 - Part No SW: ----------- HW: 480 000 906 17
Serial number: 35700000000F88CCB421
Subsystem 2 - Part No SW: ----------- HW: 480 000 906 17
Serial number: 358000000009CB40A42P
Subsystem 3 - Part No SW: ----------- HW: 480 031 705 17
Component: SideSensor_Dr 002 0149
Serial number: 351000C2444090410F5Q
Subsystem 4 - Part No SW: ----------- HW: 480 031 505 17
Component: SideSensor_Pr 002 0149
Serial number: 352000C2480A4C70B947
Subsystem 5 - Part No SW: ----------- HW: 480 031 406 17
Component: FrontSensor_D 002 0149
Serial number: 355000C24ED355D10F9N
Front Sensor Passenger:
Subsystem 6 - Part No SW: ----------- HW: 480 031 406 17
Component: FrontSensor_P 002 0149
Serial number: 356000C24ED350A08FAO
Pedestrian Protection Center:
Subsystem 7 - Part No SW: ----------- HW: 480 031 606 17
Component: PedP_Sensor_C 002 0149
Serial number: 230000C24ED89220F91A
Subsystem 8 - Part No SW: ----------- HW: 480 000 806 17
Serial number: I0M0000000076195C2A6
Subsystem 9 - Part No SW: ----------- HW: 480 000 806 17
Serial number: I0N00000000E3195C2AB
Central Sensor XY:
Subsystem 10 - Part No SW: ----------- HW: 480 022 504 17
Component: CentrSensorXY 000 0108
Serial number: I0O00019924FDE445788
Address 16: Steering wheel (J527) Labels: None
Part No SW: 80A 907 129 AC HW: 80A 907 129 AC
Component: Lenks.Modul H02 0003
ROD: EV_SMLSKLOAU736.rod
VCID: E99AF76E0820F70C2F-80BC
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 80A 920 970 A HW: 80A 920 970 A
Component: MMQ5T18BENUK H04 0512
Revision: 0512v0.2 Serial number: 0B359103XW7T
Coding: 25AD8ED4A88006000103E9601000000000000000
ASAM Dataset: EV_DashBoardAU736 001022
Part No SW: 8W5 907 468 E HW: 8W5 907 468 E
Component: Gateway H42 0116
Revision: 6A010002 Serial number: 0286A758517523
Coding: 03010001000086402907000000590032483A0007100000000175078E10000000
ASAM Dataset: EV_CGateCONTIAU491 003092
ROD: EV_CGateCONTIAU491.rod
VCID: CBD62DE6629C051C3D-809E
Subsystem 1 - Part No SW: 80A 951 523 D HW: 80A 951 523 D
Component: J453 MFL H06 0002
Serial number: 20170705141939 00489
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 3768775200
Address 22: AWD (J492) Labels:* None
Part No SW: 80A 927 755 HW: 0CJ 927 749
Component: Q5_DL3_N_SD4 H18 0004
Serial number: 1716533205
Coding: 11070000
ASAM Dataset: EV_AWDCQUOD31 001048
ROD: EV_AWDCQUOD31.rod
VCID: EC948E7A07D2E22454-80B8
Address 29: Left Light (J1018) Labels: None
Part No SW: 80A 907 397 A HW: 80A 907 397 A
Component: LCM_MLBevo H06 0017
VCID: AD12437EFC482B2C03-80F8
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Part No SW: 3Q0 905 861 A HW: 3Q0 905 861 A
Component: ELV-MLBevo H05 0032
Serial number: 17000123880005
Coding: 8800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: B2285002E57674D45E-80E6
Address 39: Right Light (J1023) Labels: None
Part No SW: 8W1 959 593 HW: 8W1 959 593
Component: TSG FS001 0737
Serial number: CLSM1QFA00G35
Coding: 001F8A004001040000001082
ROD: EV_DCU2DriveSideMAXHCONT.rod
VCID: 885CD2EA336A2E04D0-80DC
Part No SW: 4M0 909 144 H HW: 4M0 909 144 B
Component: EPS_MLBEVO1BS H22 0005
Serial number: 0000957138
Coding: 90002001000100
ASAM Dataset: EV_EPSVWBSAU736 009023
ROD: EV_EPSVWBSAU736_009.rod
VCID: B424561A1F627AE44C-80E0
Part No SW: 8W0 907 064 DM HW: 8W0 907 064 DM
Component: BCM2 MLBevo 019 0366
Coding: 013500006FB100406301A0000600980233020010804304502F00000000040030001F0000000000
ASAM Dataset: EV_BCM2HellaAU736 013013
ROD: EV_BCM2HellaAU736_013_AU49.rod
VCID: 8A58E8E22D665C14C6-80DE
Subsystem 1 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY17163273E
Subsystem 2 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000069810967
Part No SW: 8W1 959 592 HW: 8W1 959 592
Component: TSG BFS001 0737
Serial number: CLSM1QFD006YN
Coding: 001F8A004001040000001080
ROD: EV_DCU2PasseSideMAXHCONT.rod
VCID: 875ED1D63E74217CD9-80D2
Part No SW: 8W0 035 192 C HW: 8W0 035 192 A
Component: MU-HS-LND-EU 050 0211
Coding: 01240601FF0A000053111101000A00102F0019E601F00100CE
ROD: EV_MUHigScl6C3DELP_AU49.rod
VCID: B6206C12091E68F472-80E2
Subsystem 1 - Part No SW: 8W0 919 866 R HW: -----------
Component: ECE 2017/2018 --- 0027
Subsystem 2 - Part No SW: 80A 919 604 HW: 80A 919 604
Component: AU426_DU_STD H42 0008
Serial number: AUZ8Z9HBM00SKG
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 80A 919 614 A HW: 80A 919 614 A
Component: ControlUnit_B H20 0200
Serial number: AMXAM118071700010296
Part No SW: 8W8 959 107 B HW: 8W8 959 107
Component: HDSG-Modul H13 0161
Revision: -------- Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
Coding: 0710
ROD: EV_DeckLidCONTIAU736_AU49.rod
VCID: C8DC12EA73EAEE0410-809C
Address 81: Gear Shift (J587) Labels: None
Part No SW: 80C 713 041 L HW: 80C 713 041 L
Component: GSM-LL H09 0073
Revision: 0L0D5012 Serial number: 20170711000785
ASAM Dataset: EV_GSMWaehlZFAU736 001016
ROD: EV_GSMWaehlZFAU736_AU49.rod
VCID: A71EB156DEB4017CF9-80F2
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 80A 907 217 A HW: 80A 907 217 A
Component: BVS H15 0050
Coding: 0404020600000401024023A0A50000FE00F0C010C000
ROD: EV_BVSMLBevKOSTAAU736.rod
VCID: A404A65AAF82EA64DC-80F0
Part No SW: 8W1 959 595 HW: 8W1 959 595
Component: TSG HFS001 0737
Serial number: CLSM1QGH00MD5
Coding: 000F88000001040000001080
ROD: EV_DCU2RearDriveMAXHCONT.rod
Component: TSG HBFS001 0737
Serial number: CLSM1QGH00PBS
ROD: EV_DCU2RearPasseMAXHCONT.rod
End----------(Elapsed Time: 01:35, VBatt start/end: 13.3V/13.3V)-----------
