Mk7 Golf - 'Fault Vehicle Lighting' warning
mrhudson
C?ID=173117
Good morning,
We have a 2015 Golf in the workshop today and the instrument panel display shows a warning 'Fault: Vehicle Lighting' - all the external lights are working as are headlamp adjusters etc. We've replaced each bulb one-by-one and checked the bulb carriers and connectors to find no physical fault with no fault codes either?
Has anyone come across this before, if so any solutions?
Thanks in advance!
Tuesday,20,March,2018,10:23:39:19998
VCDS Version: 18.2.0.3 (x64)
VIN: WVWZZZAUZEP034933   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZEP034933   Mileage: 43682km-27142miles
Address 01: Engine (J623-CLHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 M    HW: 04L 907 309 B
   Component: R4 1,6L EDC   H22 5517
   Revision: 84H22---
   Coding: 01110012034505092000
   Shop #: WSC 00028 028 00075
   ASAM Dataset: EV_ECM16TDI01104L906021M 002009
   ROD: EV_ECM16TDI01104L906021P.rod
   VCID: 2F6B561D7653523CB1-807A
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Revision: 00000000    Serial number: 62443000000053
   Coding: 01FA8AA1242309700380060341C62580512490C06082A4F3F440F074C002
   Shop #: WSC 00028 028 00024
   VCID: 7BF3B24DF2AB7E9C4D-802E
   Part No SW: 5G0 907 044 AA    HW: 5G0 907 044 AA
   Component: Climatronic   H02 0705
   Revision: 00001K06
   Coding: 00120104202100011005000000101000
   VCID: 66C5F3399929D37482-8032
   Air quality sensor:
1048834 - Functional Limitation due to Energy Management
          B10CD 00 [008] -  -
                    Reset counter: 189
                    Mileage: 43044 km
                    Date: 2018.02.27
                    Time: 09:06:16
                    Voltage terminal 30: 14.0 V
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: No enabling
                    Auxiliary heater: in stages-Act.val.: 1
                    Auxiliary heater: in stages-Specified value: 3
                    Auxiliary heater: in stages-Specified value for control: 3
1048835 - Functionality limited due to Engine Control Module
          P1719 00 [008] - -
                    Fault Frequency: 54
                    Reset counter: 193
                    Mileage: 43020 km
                    Date: 2018.02.26
                    Time: 11:12:00
                    Voltage terminal 30: 14.1 V
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
   Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 AA
   Component: BCM MQBAB H   H14 0112
   Serial number: 00011323401405
   Coding: 03000846C24102FB0BA44080B11C07281000000000000000000000000000
   ROD: EV_BCMBOSCH_011.rod
   VCID: 77FBAE7DCE835AFC29-8022
   Component: WWS    130816  042 0551
   Serial number:         130828093659
   Component: RLFS  024 0042
   Serial number: Y13M09D05H20M50S12S1
   Coding: 00A8DD
   Serial number: 000000000ZY132111X12
   Serial number: 00000000000057572582
   Part No SW: 5Q0 907 572 A    HW: 5Q0 907 572 A
   Component: ACC Bosch MQB H04 0150
   Serial number: 01091376510116
   Coding: 00000300FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001013
   VCID: 35676475940F68ECFB-8060
1542 - Sensor for Automatic Distance Control
          C110B F0 [008] - Limited Visibility
                    Fault Frequency: 9
                    Reset counter: 192
                    Mileage: 43021 km
                    Date: 2018.02.26
                    Time: 14:37:05
                    Control Module temperature: 13 °C
                    Voltage terminal 15: 14.4 V
                    Vehicle speed: 5.44 m/s
                    Acceleration: -0.41 m/s²
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR004E16
   Shop #: WSC 00028 028 00061
   VCID: 7F0B465DE6B362BC61-802A
   Belt Pretensioner left:
   Component: BeltPretRevFL  H35 0340
   Serial number: 34169677B04091350266
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H35 0340
   Serial number: 34169676B02091371565
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 208 13
   Serial number: 3576700000071579AD0.
   Subsystem 4 - Part No SW: -----------    HW: 480 002 208 13
   Serial number: 35867000000A13E86D0+
   Subsystem 5 - Part No SW: -----------    HW: 480 402 908 13
   Serial number: 3516502BD10EDE42A1CV
   Subsystem 6 - Part No SW: -----------    HW: 480 402 908 13
   Serial number: 3526502BD10EDE4200AJ
   Subsystem 7 - Part No SW: -----------    HW: 480 402 408 13
   Serial number: 3556502C510EDE45D29W
   Part No SW: 5Q0 953 507 AG    HW: 5Q0 953 549 A
   Revision: --------    Serial number: 06091304220753
   Coding: 0D00
   Shop #: WSC 40195 333 37120
   ROD: EV_SMLSKLOMQB_013_AU37.rod
   Part No SW: 5G0 920 961 A    HW: 5G0 920 961 A
   Component: KOMBI         252 2210
   Coding: 27A41A002780260001882A01040000
   VCID: 2859BD0153BD050470-807C
   Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2147
   Revision: --------    Serial number: 28081310801815
   Coding: 030100040B087300EF00025C080F00010001000000000000000000000000
   ASAM Dataset: EV_GatewConti 009011
   ROD: EV_GatewConti_009_VW37.rod
   VCID: 3B73724DB22BBE9C0D-806E
   Component: E221__MFL-DC1  H14 0035
   Serial number: 27130001361090053335
   Coding: 2CFFFF
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 9215151203
   Part No SW: 5Q4 959 393     HW: 5Q4 959 393
   Component: TSG FS        007 0006
   Serial number: 0000072072753
   Coding: 003002208001028000001000
   VCID: 55A7C4F5344F48EC1B-8000
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000002590390
   Coding: 0D0000
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 M
   Component: EPS_MQB_ZFLS  127 1021
   Coding: 81
   ROD: EV_SteerAssisMQB_008.rod
   VCID: 3D777C55AC3FB0AC33-8068
   Part No SW: 5Q4 959 392     HW: 5Q4 959 392
   Component: TSG BFS       007 0006
   Serial number: 0000072293339
   Coding: 003000208001028000801000
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000002234036
   Coding: 050000
   Part No SW: 5G0 035 820 A    HW: 5G0 035 820 A
   Component: MU-S-D-ER     040 0421
   Serial number: V5C00709131763
   Coding: 02730000FF00000021111201002800001F0100060100010001
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 1F4BA6DD06F3C2BC01-804A
   Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
   Component: ABT_Std_Radio  H51 0022
   Serial number: VWZ8Z9NJ701DFU
6145 - Display and Control Head 1 for Information Electronics
          B129E 07 [009] - Mechanical Failure
                    Reset counter: 146
                    Mileage: 43394 km
                    Date: 2018.03.09
                    Time: 08:57:56
                    Voltage terminal 30: 14.4 V
End-------------------------(Elapsed Time: 03:23)--------------------------
	0UJ%P)ðµ˜;rªý®·*S(>¨¯Ñ0QUJ0H¤F0D10
UAOC1402U+229887+89615e09-bdee-4446-861e-87e013958b250U#0€Að!Çíćúƒuÿ
Ü-ì¨j«Y0YUR0P0N*L*J†Hhttp://crl.microsoft.com/pki/crl/products/MicCerLisCA2011_2011-03-29.crl0]+Q0O0M+0†Ahttp://www.microsoft.com/pki/certs/MicCerLisCA2011_2011-03-29.crt0Uÿ00
	*†H†÷
‚q0R$Ð*D‹�<ÃAãÙ®„?V¸Ý•)WY=÷iXˆér¡�ŸÎßäsŸ~0ˆÜò§£–d9fŒ*iÜ®¥â»»i¢™¢ÊËï4¬iHa³XÁE9lU*@g†¶|¡pÖÒb‰¥”Ý–ðyÎ\çÞñtU
¨eÅdôœ@
ŠaB‰€Fz&Æ�ó<?ÎUQ£-dÅRQ}8íãºFýÈ}²ù!á¦ÊÆ+õ …ô—áå–˜sûÅîâD+Ç*K_º™Äø# ÐØÙÚZd‡ÁŒÀ‚£xŽzCµƒK)hÜd$�ü4û*F¿5zU[àÊ‘^³�‰±jcZH~…F�è&b¬«éâ&`°ÇKùëa0,pÒ®—Õé£^Þ[TCîá½GÿL»jýÐ~iKF,¨í�žj³qS639”ó—Yï…Ô¸˜Æ£ËFŸ´ªšóŸMJKBÅ©o‘Ë^zafö}•W¥Ÿv£ôXWkæ™K®
�¤¨ÁrŸ²�þ*a#xzv×›VU-á†RƒØbĵIy¢ÑfÎü�-$Ý89Ôœàv	Û±TO
},ʺїۂø£NÆ�â-Θ6¼¸äXáZ©^áIf¿°ªØþ|!ð_K±öþÏ3:º±›²9ÓÞâð‘CíLüçä*Š)`‘И0‚
0‚õ*
al’0
	*†H†÷
0�ˆ10	UUS10U
Washington10URedmond10U
Microsoft Corporation1200U)Microsoft Root Certificate Authority 20100
110329185839Z
260329190839Z0��10	UUS10U
Microsoft Corporation1+0)U"Microsoft Certificate List CA 20110‚"0
	*†H†÷
‚0‚
‚¸„z€ýM'§Òï‚6ñS�¾BmŽ1GËͳƒ
KN3.|Ýr��Î�ü<Ë/4…8�<hm`QRM¬Úm+~³sG«ÒÜ•qJ1�Z¡«‚&E-Œè„x½ ð
Æõ®&‡VŽU<02””"“¥°Æ]æ-�9ÍéÇ®èØIqI«‘t¸O�/G³?Гƒ\ÞK¸²<7é“êr[˜Çã¬àæ~JÁ�,ý"vsáhÜ 	ÀóFÍ#&ÈE"ÊǼtü‰ÿWàϽŽ°+ï&Öw«ôgAñ^qª^À‚ª	‹ì‰ˆAõBiÙEÙW>–JÕ2·Ña&hÇÁ±*àzNµm‚à.¶çdŸ}•*†2Ð!È]øË0¹˜l³“kȃg!]Öe˜ dÝË¿G›ÿúñ�Þ§xÍ{†~'Š·•œ&ݱ–üOà@ ƒhÝì3ò**§ë‘ú¬QAˆñŇAL‡Gb�XÀž»}ÞÓŸýÁǽ˜ÐW›áãlWáe_ðÜ+œ¡TÂV*d˪NäýÃèwˆÿÛ
¯�Ÿ×h�/”á¯ÆäÆvÛuÚßÐLò‰6oH€�XÝ	(+U¬“#åŽ1e*
Ž“Óq§�˜é¬ªXî×DC0mǺÂõHÄå*ŽUŽ´	ÀÃ�FõþFµ:ˆ#µðÊAÍ;
ÆöÊ@ê›åˆ6Ÿ£‚|0‚x0	+‚70UAð!Çíćúƒuÿ
Ü-ì¨j«Y0	+‚7
SubCA0U†0Uÿ0ÿ0U#0€ÕöVË�è¢\bhÑ=”�[×ΚÄ0VUO0M0K*I*G†Ehttp://crl.microsoft.com/pki/crl/products/MicRooCerAut_2010-06-23.crl0Z+N0L0J+0†>[url]http://www.microsoft.com/pki/certs/MicRooCerAut_2010-06-23.crt07U%00.+[/url]
+‚7
+‚7
+‚7
	*†H†÷
‚‚÷©¥³¿åÈYA'4bœAð«+}ù§¨È¨]C¾*ò™øÿûöyPDPêBÛ�é¥Iy()>@6tÛ� Ì�-QÜ+A6|¶Ð@›7L�ih±‚–;iuÇå4Ø>ÜZ	«Ó¿©¯ÄoãGÆ2ï%éU”ï‡Òá!Þ7Ï®¦4]#)mmçÝD0yt�ŒÁù>ù*0k£´jtI9[7-î)Ý®J/ù‚¯Hšœ=%1Vê:§M·ý‹?þ¿w6‹Uå³PîTÔ¿kØ*ò3x.¿1ù6ï0ùLCƒã[©\[¦v¸ðuOé¸6D¦fÐK
Ut.''å&Bƒn»¤ï{ù䘽Õ;‰ÓX’¸ÑÍ9~f%
ÛƒY¿W›Òér']k3Ñþ¢’LQ=ÆÌ”:VÿëA.Ý’SÍñ6ëÛ5Ù‘¶™`à¬gDœGË·F–Iß±**H6á-?»Zà”Ô—’é>æë%Ë3ñß“`�¦¹Vö(éBÇ[¦.¹Û©d׎å3Ò�C‚Kn7f¹
gWTZHãŠûí
&¼
4Ò
G…a*#±àTŠPV…Àÿ-÷i™D}ôM|áî	fRJzb¤å‹Ï…¢†Šq�±}ÖÓQÚ\çÌÖv¨®O“µdɽíÜû1‚µ0‚±0�™0��10	UUS10U
Microsoft Corporation1+0)U"Microsoft Certificate List CA 20113)*kƒ«Þ€”)0
	`†He*�í0
*†H†÷
	10	*†H†÷
	1	*†H†÷
0/	*†H†÷
	1" !8Á‘j—�~"lBà{:<"ç^YaÃ
ÿæO1n0�Œ
+‚71~0|*V€TMicrosoft Certificate Trust List Publisher¡"€ [url]http://www.microsoft.com/windows0[/url]
	*†H†÷
‚“¬ŒÔÇO$ÒÓÝ<sXñ÷3G0Ì}îtÛÌ
µ¢e]€1nÕv/=–98�–YØïüKÐ’[Ë(Áã
âÅ7ž•Éxy¢Üø‡"9µ®§�èˆÉã¥(fË4*ßN7½é4ó
ës?¯úÖÔ7PË·½‹1<tõ‡WFÊ*vטchåN{¹^Jt˜Òø:ärý\Ëol_Ïs³¬,ÓV½·¸®IìÝkîÄyH~®ÑòðíiÝUÜaÕ¦y–œ/4Šƒô)T&D©yíû¾$Ë–ÌI×*
áj߇ŸÅª§[«¦Œ{YÀÈ3S¦ÁžjɯWt/½pJýç„gþÿÿH‹D$Pƒ*È 6xœòQº°{¼ Sº@|¼5TºÐ|¼JUº`}¼hVºØ}¼wWºP~¼«XºÈ~¼ôYºX¼9[ºè¼†\º�€¼Â]º8�¼–^º°�¼�_º@‚¼*aºƒ¼'bº�ƒ¼¯cº „¼eº°„¼Qfº@…¼Zgº¸…¼„hº0†¼›iº¨†¼´jº ‡¼¼kº˜‡¼µlºˆ¼nº*ˆ¼koº0‰¼ÌpºÀ‰¼ÝqºPŠ¼=sºøŠ¼ntº*‹¼®uº0Œ¼âvºÀŒ¼VxºP�¼
iichel
Eindhoven, NB, NL
C?ID=284912
the BCM seems to be very happy with its current state. does any error show up if you try out all the lights, both internal and external, with engine on and off?
deducing from the autoscan, it doesn't have LED/Xenon headlights or LED DRL.
the more worrying error is in the 5F (radio/navigation) where it says the control head (display unit) has a mechanical failure.
mrhudson
C?ID=173117
When you turn the ignition on with all lights turned off the message comes up on the display, if I clear it it'll come straight back on again.
Yeah you're right, just standard halogens on this one.
One thing i haven't checked are the interior courtesy lights or puddle lights, I'll get those looked at first.
Thanks!
Jim Beagley
C?ID=349735
Did you have any luck solving this fault? I have had a car in the workshop with similar issues - all lights work fine, no fault codes, but a persistent "fault: vehicle lighting" on the dash.
