Octavia MKiii 2017 tweaks help
tomer
Israel
C?ID=324798
Hia,
I recently picked up Octavia RS mk3 , could use some help with some adaptations I haven't figured out how to do -
VCDS ver 18.2.0 using Hex-V2 cable
Recent scan (before updating VCDS):
Saturday,03,March,2018,17:52:31:12953
VCDS Version: 18.1.0.2  HEX-V2 CB: 0.4411.4
Data version: 20180122 DS285.1
VIN: TMBAE7NE4H01XXXXX  License Plate:
Mileage: 3729km-2317mi   Repair Order:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F A9
VIN: TMBAE7NE4H01xxxxx   Mileage: 3729km-2317miles
Address 01: Engine (J623-CHHB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 C    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 0C1D00124424010B0000
   Shop #: WSC 19383 002 1048576
   ASAM Dataset: EV_ECM20TFS0205G0906259C 001005
   ROD: EV_ECM20TFS0205G0906259C.rod
   VCID: 2E05F397B0946CE7CA9-807A
Readiness: 1110 0001
   Part No SW: 0D9 300 042 S    HW: 02E 927 770 AS
   Component: DQ250-6F MQB  H54 5010
   Revision: 06454104    Serial number: TFK01610120525
   Shop #: WSC 73430 031 00063
   ROD: EV_TCMDQ250021.rod
   VCID: 290F008B897A0BDF1FB-807C
          P1734 00 [002] - -
Address 03: ABS Brakes (J104)       Labels:| 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 AF    HW: 5Q0 614 517 AF
   Component: ESC           H62 0398
   Revision: 00000000    Serial number: 63006000001556
   Coding: 1A076B91542119704078060241CB2958D62A98026082947600410070C00903
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 035019
   ROD: EV_Brake1UDSContiMK100ESP_035_SK37.rod
   VCID: 75B71CFB15421F3F4B3-8020
   Part No SW: 5E0 907 044 AB    HW: 5E0 907 044 AB
   Component: Climatronic   H04 1601
   Revision: 00001K07
   Coding: 01010004000110011005000000101002
   ASAM Dataset: EV_ACClimaBHBVW37X 006142
   ROD: EV_ACClimaBHBVW37X_006_SK37.rod
   VCID: 65974CBBA5E2EFBFFB3-8030
   Air quality sensor:
   Part No SW: 5Q0 937 084 CL    HW: 5Q0 937 084 AN
   Serial number: 01061629000275
   Coding: 0C101A42C24722FB47E04000000C07280000000000000000000000000000
   Shop #: WSC 73430 790 00000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 0451713F4E9836B74CD-8050
   Subsystem 1 - Part No SW: 5E1 955 119     HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 161004  041 0570
   Serial number:         161018094438
   Coding: 065DDD
   Component: RLHS  042 0105
   Serial number: S3Y16M10D31H09M51S07
   Coding: 00885D
   Sun Roof:
   Subsystem 3 - Part No SW: 6R0 959 591 D    HW: 6R0 959 591 D
   Component: J245 PS72.403  H03 0004
   Serial number: 0000FST0018NRYL00000
   Coding: 981803
   Part No SW: 5Q0 919 283 F    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0054
   Revision: --------    Serial number: 39261629502863
   Coding: 0001050011
   ROD: EV_EPHVA14AU3700000_002_VW27.rod
   VCID: 3C21C9DF76E88E7774D-8068
   Part No SW: 3Q0 959 655 AS    HW: 3Q0 959 655 AS
   Component: Airbag VW20   013 0200
   Revision: --------    Serial number: 003SQPMWG67-
   Coding: 98CCC000000000005C5400CC000800000065
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 0F7B4E1317DE45EFE1F-805A
   Subsystem 1 - Part No SW: -----------    HW: 454 000 710 16
   Serial number: 3576U000000241E8BD1J
   Subsystem 2 - Part No SW: -----------    HW: 454 000 310 16
   Serial number: 3586U000000235244E11
   Subsystem 3 - Part No SW: -----------    HW: 454 800 610 16
   Serial number: 3516REB80310D0000006
   Subsystem 4 - Part No SW: -----------    HW: 454 801 310 16
   Serial number: 3526RF8242F0C000000F
   Subsystem 5 - Part No SW: -----------    HW: 454 800 810 16
   Serial number: 3556V422EF90C000000M
10492928 - Supply Voltage
          B201C 00 [008] - Implausible Signal
          [Powersupply implausible signal]
                    Reset counter: 63
                    Mileage: 3729 km
                    Date: 2018.03.03
                    Time: 17:49:23
   Part No SW: 5Q0 953 521 T    HW: 5Q0 953 569 A
   Revision: FF034034    Serial number: 20161026500471
   Coding: 1410
   Shop #: WSC 73430 031 00000
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 43D3B2230B16F18F357-8016
   Part No SW: 5E0 920 746 C    HW: 5E0 920 746 C
   Component: KOMBI         205 8311
   Coding: 07A5010829800008010A2A001000000000000000
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1265
   Revision: --------    Serial number: 0005454104
   Coding: 030100047F085900EB00026A1C0F00010001050000000000000000000000
   ROD: EV_GatewLear_013_SK37.rod
   VCID: 7CA109DF36684E7734D-8028
   Subsystem 2 - Part No SW: 3V0 919 719 B    HW: 3V0 919 719 B
   Serial number: 000000000A0320111016
   Serial number: 75410803001610260561
131699 - Control unit for information electronics 1
          U1054 00 [009] - No Communication
          [Timeout Knoten 0x73 / 5F - Steuerger\E4t f\FCr Informationselektronik 1]
                    Reset counter: 23
                    Mileage: 3729 km
                    Date: 2018.03.03
                    Time: 17:41:00
                    Supply voltage: Terminal 30: 12.1 V
                    Terminal 15: On
   Component: TSG FS        010 0032
   Serial number: 0000223728077
   Coding: 001D0120D000040000001100
   VCID: 47CBA6333F2EDDAFE9F-8012
   Serial number: 00000000000011987022
   Coding: 010200
   Coding: 8107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2DCFC77CDCB047661-806E
   Component: TSG BFS       010 0032
   Serial number: 0000225193883
   VCID: 46D5AB373824C4A7129-8012
   Serial number: 00000000000012042926
   Coding: 190200
   Coding: 03DA00003F000000
   Shop #: WSC 73430 790 00063
   VCID: 40D9BD2F1A00EA97285-8014
   Subsystem 1 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0009
   Coding: 3E0000
   Subsystem 2 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0009
   Coding: 3E0000
   Part No SW: 5E0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0001
   Serial number: 161008200130
   VCID: 698F408B49FACBDFDFB-803C
End----------(Elapsed Time: 01:29, VBatt start/end: 12.6V/12.4V)-----------
1. Wipers park after switch close - tried using the info on Briskoda thread but the coding is different in my car - no bit 4 on byte 1
https://www.briskoda.net/forums/top...ions-tried-and-tested/?page=2#comment-4544426
2. Start/Stop button disable memory , so I won't have to press the button each time
3. Close windows from remote without holding the lock button (single press)
I've saved Central Electronics, CAN Gateway, and Instruments channel maps , be happy to post them
thanks
hadez16
C?ID=289891
1) I think you did not select the sub-system WWS for coding in the dropdown after clicking "Coding" in your BCM
2) Memory is not possible in MQB cars. Only "always-off"
3) I didn't know that this tweak exists?
hadez16
C?ID=289891
To my knowledge, not possible with your car.
Please do not try to adapt codings for completely different cars.
