A6 3.2L FSI too rich bank 1
alloyhead
Australia
C?ID=2976
Hi A6 has had spark plugs, fuel filter, both bank 1 lambda sensors, coolant sensor, G410 low pressure fuel sensor replaced since this initial scan. Bank 1 is still twice as rich as bank 2. Logs, bank 1 too rich fault code and bank 1 S2 lambda sensor malfunction fault sometimes, any clues?
Monday,01,September,2014,12:07:51:59759
VIN: WAUZZZ4F18N014470   License Plate: SEB72J
Mileage: 123410km-76683mi   Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 56
          57 61 62 69 72 76 77
VIN: WAUZZZ4F18N014470   Mileage: 123410km/76683miles
Address 01: Engine (AUK)       Labels: 06E-910-559-BKH.lbl
   Part No SW: 4F2 910 559 G    HW: 4F1 907 559 D
   Component: 3.2l V6 FSI         0020
   Revision: --H21---    Serial number:
   Coding: 01050003190F0120
   Shop #: WSC 02325 758 00200
   VCID: 30656C2CA3CA3C9E2BD-8065
004440 - Manifold Pressure Sensor (G71)
               P1158 - 007 - Implausible Signal - Intermittent
                    Fault Frequency: 103
                    Mileage: 121810 km
                    Date: 2014.08.08
                    Time: 18:50:00
                    RPM: 1472 /min
                    Mass Air / Rev.: 92.7 mg/str
                    Temperature: 75.0°C
                        Overrun
                    Voltage: 13.26 V
                    Speed: 59.0 km/h
000104 - MAP/MAF <-> Throttle Position Correlation
               P0068 - 006 -  - Intermittent
                    Fault Status: 00100001
                    Mileage: 121810 km
                    Date: 2014.08.08
                    Time: 18:50:00
                    RPM: 1472 /min
                    Temperature: 75.0°C
                        Overrun
                    Voltage: 13.26 V
                    Bin. Bits: 00000010
004407 - Fuel Trim: Bank 1 (Add)
               P1137 - 007 - System too Rich - MIL ON
                    Fault Status: 10100010
                    Fault Frequency: 11
                    Mileage: 121876 km
                    Date: 2014.08.09
                    Time: 17:09:52
                    RPM: 672 /min
                    Mass Air / Rev.: 185.3 mg/str
                    Temperature: 82.5°C
                        Idle
                    Time: 537.6 s
                    Bin. Bits: 00000010
004506 - Fuel Pressure Sensor (G247)
               P119A - 007 - Malfunction - Intermittent
                    Reset counter: 15
                    Mileage: 122048 km
                    Date: 2014.08.12
                    Time: 15:38:53
                    RPM: 2784 /min
                    Mass Air / Rev.: 250.7 mg/str
                    Temperature: 84.0°C
                        Part Throttle
                    Pressure: 49.7 bar
                    Speed: 40.0 km/h
   Part No SW: 4F5 910 156     HW: 09L 927 156 C
   Component: AG6 09L 3.2 FSI RdW 0010
   Revision: --H03---    Serial number:        4339015
   Coding: 0000001
   VCID: E5CB4D782C88293688B-80B0
Address 03: ABS Brakes        Labels: 4F0-910-517.lbl
   Part No SW: 4F0 910 517 AD    HW: 4F0 614 517 AA
   Component: ESP8 quattro    H01 0070
   Coding: 0004511
   Shop #: WSC 31870 822 66137
   VCID: 66C9CA74518EA22E011-8033
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H31 0230
   Revision: 09010701    Serial number: 10601500802252
   Coding: 0000023
   Shop #: WSC 02323 758 00200
   VCID: E3CF536022BC570666F-80B6
   Subsystem 1 - Part No: 4F0 910 131 C
   Component: FBSAUDIC6 EZS   H45 0080
   Component: FBSAUDIC6 KSG   H27 0080
   Subsystem 3 - Part No: 4F0 910 220 F
   Component: FBSAUDIC6 IDG   H01 0060
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.lbl
   Part No SW: 4F0 910 732 B    HW: 4E0 035 729 A
   Component: Interfacebox    H43 4220
   Revision: 00000000    Serial number: 351F$077549488
   Coding: 0000002
   Shop #: WSC 02335 758 00200
   VCID: 22419664FD269E0EAD9-8077
   Component: Bedienteil MMIC6H01 0060
   Subsystem 2 - Serial number: 00000000788848
   Subsystem 3 - Serial number: 0121.06.070000000100010192ÿ
   Subsystem 4 - Serial number: 010192ÿ
Address 08: Auto HVAC        Labels: 4F0-910-043.lbl
   Part No SW: 4F0 910 043 A    HW: 4F2 820 043 P
   Component: KLIMABETAETIGUNGH30 0020
   Revision: 00000052    Serial number: 00000000409550
   Coding: 0533574
   VCID: 1C3DA89CDF42A8FE675-8049
   Part No SW: 4F0 910 279 L    HW: 4F0 907 279 B
   Component: ILM Fahrer      H17 0240
   Coding: 0000101
   VCID: 32616624ADC60E8E5D9-8067
   Subsystem 1 - Part No: 4F2 910 113 B  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H04 0190
   Coding: 00064784
   Shop #: WSC 02335
   Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0090
   Coding: 00146221
   Shop #: WSC 02335
   Part No SW: 4E0 910 110 C    HW: 4E0 035 110 A
   Component: MP3-Changer     H46 0350
   Revision: 00046005    Serial number: AUZ5ZBG3417464
   VCID: 1835B48C2B7AC4DE43D-804D
Address 15: Airbags        Labels: 4F0-910-655-8R.lbl
   Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
   Component: 4F AIRBAG AUDI8RH30 0280
   Revision: 09H30000    Serial number: 0037LD0SD9JR
   Coding: 0013382
   VCID: 2953814880104D56EC3-807C
   Subsystem 1 - Serial number: 6332CSME17794A054
   Subsystem 2 - Serial number: 6342CSME17794974A
   Subsystem 3 - Serial number: 6352QSME2E291B3BU
   Subsystem 4 - Serial number: 6362QSME30081F7FR
   Subsystem 5 - Serial number: 63734SME2D7178499
   Subsystem 6 - Serial number: 63834SME30392813V
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
   Component: J0527               0410
   Revision: 00H02000    Serial number: 90026071570031
   Coding: 0102141
   VCID: 2757877096047B26FA7-8072
   Component: E0221           H02 0030
Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 C    HW: 4F0 920 933 H
   Component: KOMBIINSTR. M73 H21 0220
   Revision: 00600000    Serial number: 6IP51M067
   Coding: 2305758
   Shop #: WSC 31250 067 57207
   VCID: 234F9360E23C9706A6F-8076
Address 19: CAN Gateway        Labels: 4F0-910-468.lbl
   Part No SW: 4F0 910 468 A    HW: 4F0 907 468 D
   Component: Gateway         H11 0070
   Revision: 11          Serial number: 13008076130034
   Coding: EDFE53C41B3504
   Part No SW: 4E0 910 887 T    HW: 4E0 919 887 M
   Component: MNS ECE         H49 1030
   Revision: 00000000    Serial number: 364F 077690657
   Shop #: WSC 03002 959 06940
   VCID: 3E794214699EDAEEA91-806B
Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
   Part No SW: 4F0 910 793 E    HW: 4F0 959 793 E
   Component: TSG FA          H12 0210
   Revision: 00000000    Serial number: R’„
   Coding: 0016922
   Shop #: WSC 02327 758 00200
   VCID: 2C5D785C8FE2587E175-8079
                    Reset counter: 102
                    Mileage: 99300 km
                    Date: 2013.09.25
                    Time: 12:55:17
Address 46: Central Conv.        Labels: 4F0-910-289.lbl
   Part No SW: 4F0 910 289 J    HW: 4F0 907 289 J
   Component: Komfortgeraet   H25 0200
   Revision: 02000025    Serial number: 01050051390000
   Coding: 0263565
   VCID: 31636928A8C03596243-8064
Address 47: Sound System (J525)       Labels: Redir Fail!
   Part No SW: 4F0 910 223 K    HW: 4F0 035 223 L
   Component: Amp.-ASK-RD   H07 0250
   Revision: 09S00000
   Coding: 070000
   Shop #: WSC 02399 823 56573
   VCID: 26498A74510E622EC11-8073
02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
                    Fault Status: 01111011
                    Reset counter: 254
                    Mileage: 70042 km
                    Date: 2012.03.14
                    Time: 17:13:58
                    Voltage: 11.50 V
                    Temperature: 43.0°C
                    Bin. Bits: 00000011
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
                    Fault Status: 00111011
                    Reset counter: 102
                    Mileage: 117498 km
                    Date: 2014.06.12
                    Time: 10:55:19
                    Voltage: 12.00 V
                    Temperature: 30.0°C
                    Bin. Bits: 00000011
   Part No SW: 4F0 910 280     HW: 4F0 907 280 C
   Component: ILM Beifahrer   H12 0100
   Revision:             Serial number: 00000000024323
   Coding: 0001014
   VCID: DEB9629409DE7AEE491-808B
Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
   Part No SW: 4F0 910 793 E    HW: 4F0 959 792 E
   Component: TSG BF          H12 0210
   Revision: 00000000    Serial number: V„
   Coding: 0016922
                    Fault Status: 01101000
                    Reset counter: 62
                    Mileage: 99842 km
                    Date: 2013.10.06
                    Time: 17:48:06
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801 C    HW: 4F0 907 801 A
   Component: EPB  CDEC0080   H04 0080
   Revision: --H04---
   Coding: 0005021
   Shop #: WSC 00000 758 00200
   VCID: 20459C6CF32A8C1EBBD-8075
   Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 L
   Component: TUNER EU/US/RDW H42 0620
   Revision: 00000000    Serial number: 394FS077781130
   Coding: 0000001
   VCID: 2E597254B9FE2A6E391-807B
Address 57: TV Tuner        Labels: None
   Part No SW: 4E0 910 148 C    HW: 4E0 919 148
   Component: R0078 TVhybridTuner 0400
   Revision: R0H06000    Serial number: 76300800591802
   Coding: 0000007
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
   Component: J0644 BEM       H12 0590
   Revision: 00000000    Serial number: 00000000087708
   Subsystem 1 - Part No: 4F0 915 105 D
   Component: von VA0  2706191803
   Coding: 344630393135313035442056413032373036313931383033
   Shop #: WSC 00000 384 00290
02272 - Quiescent Current Stage 1
                    Fault Frequency: 39
                    Mileage: 70042 km
                    Date: 2012.03.14
                    Time: 16:56:40
02273 - Quiescent Current Stage 2
                    Fault Frequency: 25
                    Mileage: 70042 km
                    Date: 2012.03.14
                    Time: 17:03:06
02276 - Quiescent Current Stage 5
                    Fault Frequency: 17
                    Mileage: 70042 km
                    Date: 2012.03.14
                    Time: 17:03:16
02479 - Partial Consumer Shut-Off Active
                    Mileage: 90563 km
                    Date: 2013.04.13
                    Time: 13:49:00
02277 - Quiescent Current Stage 6
                    Mileage: 119750 km
                    Date: 2014.07.12
                    Time: 17:54:35
Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 E    HW: 4F0 959 795 E
   Component: TSG HL          H21 0210
   Coding: 0016386
                    Fault Frequency: 18
                    Reset counter: 62
                    Mileage: 111160 km
                    Date: 2014.03.19
                    Time: 19:28:11
Address 69: Trailer        Labels: 4F0-910-383.lbl
   Part No SW: 4F0 910 383 B    HW: 4F0 907 383 B
   Component: ANHAENGERELEKTR 003 0060
   Coding: 0000001
   VCID: 244D907CE732903EDF5-8071
Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
   Component: TSG HR          H21 0210
   Coding: 0016386
   Part No SW: 4F0 910 283 H    HW: 4F0 919 283 H
   Component: Parkhilfe 8-Kan H12 0080
   Revision: 00H12000    Serial number: 06330715901839
   Coding: 0231006
   Part No SW: 4E0 910 336 K    HW: 4E0 862 335
   Component: Handyvorb2      H16 0950
   Revision: 00000000    Serial number: 00000007680441
   Coding: 0010920
   VCID: 2A517E448516464EE59-807F
Gone But Not Forgotten
How is air filter and pre screen to air box?
Is the TV adapted?
Check or change G247........... MAP and MAF if out of calibration.
Most importantly check operation of FP/PSI/volume for combination fuel filter regulator.
Check for FOD or incorrect installations.
alloyhead
Australia
C?ID=2976
Air filter ect. is OK, removed upper and lower manifolds, removed carbon from valves, cleaned manifold pressure/temp sensor, spec. is OK and TV adaptation OK. FOD?. Checked voltage at fuel pump, approx. 7.5 V, Audi spec. 4-5 volts, low pressure approx. 5 bar, duty cycle approx. 75%, spec. is under 70%, cannot adapt fuel pump block 103. Both banks run rich but bank 1 is twice as rich, long term idle fuel trim bank 1 max's out to 25%.
Captkrunch
Canada
C?ID=170740
Hey! Have you ever found out what was wrong? Cheers :)
