Passat B8 Halogen -> Led Xenon
IgorMM
Slovenia
C?ID=120764
Hi,
I have a 2015 vw passat highline bmt, fited halogen lights (rear are original led)
Today i fited original front lignts:
3G1 941 035 C
3G1 941 036 C
With led and xenon balasts.
then used a connector
http://www.carsystems.pl/vw-passat-b8-3g0-halogen-full-led-hid-headlights-adapter,id2191.html
Now i need to do some codeing.
Did any one do this on passat?
When car in not running light work as folow:
Position 0 (fog lamps work)
Auto (xenon light work
Park (led stripe and fog lamp work)
Lights on (only xenon works)
Blinkers dont work
When car is running,
Led blink, and xenon starts up and shuts down,
blinkers dont work
Thursday,15,March,2018,17:17:19:07838
VCDS Version: 18.2.0.3 (x64)
VIN: WVWZZZ3CZGE019984   License Plate: LJ12-UDA
Mileage: 123486km-76730mi   Repair Order:
Chassis Type  3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 5E 5F 6C 6D
          BB BC CA
VIN: WVWZZZ3CZGE019984   Mileage: 123486km-76730miles
5E-Ctrl Head LR -- Status: INTERFACE NOT COMPATIBLE
CA-Sunroof -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 ET    HW: 04L 907 309 R
   Component: R4 2,0L EDC   H21 1343
   Revision: B5H21---
   Coding: 011D0032036405083000
   Shop #: WSC 00015 115 08193
   ASAM Dataset: EV_ECM20TDI01104L906026ET 002001
   ROD: EV_ECM20TDI01104L906026FL.rod
   VCID: 000570659B1D9D4418-8054
   Part No SW: 0D9 300 041 A    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4801
   Revision: 06253104    Serial number: TFK01504291986
   Shop #: WSC 05311 115 00069
   ROD: EV_TCMDQ250021.rod
   VCID: 1629363DE99903F4D2-8042
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Revision: 00000000    Serial number: 61565000002255
   Coding: 0FEC6A8F34210B750780060841C749F0562CD0E0608292F13862F078C202
   Shop #: WSC 00015 115 00001
   VCID: 7AF1028DFDC1C79456-802E
   Part No SW: 3Q0 959 435 C    HW: 3Q0 959 435 C
   Component: VWKESSYMQB    036 0709
   Revision: 00036000    Serial number: 0371593737
   Coding: 0F00000703
   Shop #: WSC 05311 115 00318
   VCID: 3A71C28DBD41079416-806E
   Subsystem 1 - Part No SW: 3G0 962 243     HW: 3G0 962 243
   Component: GEB.F.Heckoef  H17 0812
   Serial number: ;8017183
12718085 - Databus
                    Reset counter: 188
                    Mileage: 123485 km
                    Date: 2018.03.15
                    Time: 16:04:05
   Part No SW: 5G0 907 044 BG    HW: 5G0 907 044 BG
   Component: Climatronic   H04 1202
   Revision: 00001K10
   Coding: 12020124202100011015500000101802
   ASAM Dataset: EV_ACClimaBHBVW37X 005137
   VCID: 6DDB39D1BC8F602CC3-8038
   Air quality sensor:
   Part No SW: 5Q0 937 086 AJ    HW: 5Q0 937 086 AJ
   Revision: --------    Serial number: 86580206150997
   Coding: 00911846C2C102FF57C440040014570C1880000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 02017A6D95118F540E-8056
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    150520  042 0607
   Serial number:         150530133507
   Component: RLHS  037 0059
   Serial number: S2Y15M06D15H05M07S30
   Coding: 90A8DD
   Subsystem 3 - Part No SW: 3G0 941 633     HW: 3G0 941 633
   Serial number: 11 04 2015  00000312
   Sun Roof:
5130 - Bulb for Front Left Turn Signal
          B11E8 15 [009] - Open or Short to Plus
                    Reset counter: 148
                    Mileage: 123485 km
                    Date: 2018.03.15
                    Time: 16:07:01
9994 - Bulb for Right Parking Lamp
          B12E9 15 [009] - Open or Short to Plus
                    Reset counter: 147
                    Mileage: 123474 km
                    Date: 2018.03.14
                    Time: 17:33:53
5386 - Bulb for Front Right Turn Signal
          B11EA 15 [009] - Open or Short to Plus
                    Reset counter: 148
                    Mileage: 123485 km
                    Date: 2018.03.15
                    Time: 16:07:03
9738 - Bulb for Left Parking Lamp
          B12E8 15 [009] - Open or Short to Plus
                    Reset counter: 147
                    Mileage: 123474 km
                    Date: 2018.03.14
                    Time: 17:33:53
204290 - Remote key 1
          B1479 18 [009] - Current Too Low
                    Reset counter: 147
                    Mileage: 123474 km
                    Date: 2018.03.14
                    Time: 16:06:41
   Part No SW: 5QA 919 298     HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0161
   Serial number: 000305183615154
   Coding: 0271161851
   ASAM Dataset: EV_EPHVA2CAU3700000 009017
   VCID: 0D1B5951DC4FC02C63-8058
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Coding: 3200670351FFC428949C804D
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 346DECB59F25F1E4CC-8060
10 Faults Found:
0828 - Databus
                    Reset counter: 188
                    Mileage: 123485 km
                    Date: 2018.03.15
                    Time: 16:04:06
                    Control Module temperature: 21 °C
                    Voltage terminal 15: 11.8 V
0822 - Databus
                    Reset counter: 188
                    Mileage: 123485 km
                    Date: 2018.03.15
                    Time: 16:04:06
                    Voltage terminal 15: 11.9 V
1054 - Databus
                    Reset counter: 188
                    Mileage: 123485 km
                    Date: 2018.03.15
                    Time: 16:04:06
1110 - Databus
                    Reset counter: 188
                    Mileage: 123485 km
                    Date: 2018.03.15
                    Time: 16:04:06
1058 - Databus
                    Reset counter: 188
                    Mileage: 123485 km
                    Date: 2018.03.15
                    Time: 16:04:06
1089 - Databus
                    Reset counter: 188
                    Mileage: 123485 km
                    Date: 2018.03.15
                    Time: 16:04:06
1092 - Databus
                    Reset counter: 188
                    Mileage: 123485 km
                    Date: 2018.03.15
                    Time: 16:04:06
1074 - Databus
                    Reset counter: 188
                    Mileage: 123485 km
                    Date: 2018.03.15
                    Time: 16:04:06
1088 - Databus
                    Reset counter: 188
                    Mileage: 123485 km
                    Date: 2018.03.15
                    Time: 16:04:06
2065 - Databus
                    Reset counter: 188
                    Mileage: 123485 km
                    Date: 2018.03.15
                    Time: 16:04:06
   Part No SW: 3Q0 959 655 BB    HW: 3Q0 959 655 BB
   Component: Airbag VW20   013 0195
   Revision: --------    Serial number: 003STPCD3ZZB
   Coding: 88CCC000000000005C5400CC000800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F07F399E6E3E2BC61-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 002 905 15
   Serial number: 3576U00000054235C411
   Subsystem 2 - Part No SW: -----------    HW: 454 002 905 15
   Serial number: 3586U000000E3235C41A
   Subsystem 3 - Part No SW: -----------    HW: 454 800 206 15
   Serial number: 3516R805D2B070000002
   Subsystem 4 - Part No SW: -----------    HW: 454 803 105 15
   Serial number: 3526REC6D2807000000J
   Subsystem 5 - Part No SW: -----------    HW: 454 800 206 15
   Serial number: 3556V399CC706000000M
   Part No SW: 3Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150531500458
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3D7BC991AC6F30AC33-8068
   Part No SW: 3G0 920 751 A    HW: 3G0 920 751 A
   Component: KOMBI         301 6421
   Coding: 07A409182780000800886B011001000000000000
   ROD: EV_DashBoardVDDMQBAB_VW48.rod
   VCID: 234F1FE92ACB665C25-8076
16776993 - Databus
                    Reset counter: 188
                    Mileage: 123485 km
                    Date: 2018.03.15
                    Time: 16:04:05
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2227
   Revision: --------    Serial number: 05061510802367
   Coding: 0B0300045F087300FB0002581C0F00010001070000000000000000000000
   ROD: EV_GatewConti_013_VW37.rod
   VCID: 75EB11B1D4DFA8EC3B-8020
   Component: E221__MFL-DC1  H16 0040
   Serial number: 29150001180620075233
   Coding: 2CFFFF
   Serial number: 1840756803
   Power Converter DC AC:
   Subsystem 4 - Part No SW: 5Q0 907 155 C    HW: 5Q0 907 155 C
   Component: WECHSELRICHTE  H54 0033
   Serial number: 0073960
   Analog clock:
   Subsystem 5 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  209 2002
131668 - Headlight Range Control Module
          U101E 00 [008] - No Communication
                    Reset counter: 188
                    Mileage: 123486 km
                    Date: 2018.03.15
                    Time: 16:53:34
                    Supply voltage: Terminal 30: 12.0 V
                    Terminal 15: On
131752 - No Communications with Undefined Control Module
          U1126 00 [009] - -
                    Reset counter: 148
                    Mileage: 123486 km
                    Date: 2018.03.15
                    Time: 16:58:59
                    Terminal 15: On
   Serial number: 15000034639014
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71E325A1A0B784CCE7-8024
   Serial number: 310515BEU14721
   Coding: 00351B20D000020000001000
   VCID: 438FBF69CA8B465C45-8016
   Part No SW: 5Q0 909 143 K    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2033
   Revision: 00000000    Serial number: 0000264271
   Coding: 01010010005000
   Shop #: WSC 00015 115 00318
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
   ROD: EV_SteerAssisVWBSMQBA_008_VW48.rod
   VCID: 3B7FC789B27B3E9C0D-806E
   Serial number: 150515BEF10058
   Coding: 00351120D000020000001000
   VCID: 4281BA6DD5914F544E-8016
Address 5E: Ctrl Head LR
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
   Part No SW: 3Q0 035 846     HW: 3Q0 035 846
   Component: MU-S-N-ER     820 0627
   Coding: 02840201FF00000051110001000808001F01008401200100CF
   ROD: EV_MUStd4CDELP_VW27.rod
   VCID: 6ED93EDDB1899B34FA-803A
   Subsystem 1 - Part No SW: 3G0 919 605 D    HW: 3G0 919 605 D
   Component: ABT_Std-2_Nav  H43 4064
   Serial number: VWZ6Z9R1630384
   Subsystem 2 - Part No SW: 3G0 919 866 BC    HW: -----------
   Component: ECE1 2017/18  --- 0820
   Part No SW: 5Q0 980 556     HW: 5Q0 980 556
   Component: RVC Compact   H07 0100
   Coding: 0184020162002017000040
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 005007
   ROD: EV_CamSysRVRVCPANAMQBAB_005_VW37.rod
   VCID: 77F71BB9CED3DAFC29-8022
   Part No SW: 5Q0 959 107 E    HW: 5Q0 959 107 E
   Component: HDSG-Modul    H12 0233
   Revision: --------    Serial number: 30050511100000
   Coding: 0208
   ASAM Dataset: EV_DeckLidCONTIAU736 001009
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 300515BEU06283
   Coding: 000011200100020000001000
   Shop #: WSC 63911 001 1048576
   Serial number: 300515BEU06027
Address CA: Sunroof
End-------------------------(Elapsed Time: 05:28)--------------------------
IgorMM
Slovenia
C?ID=120764
for all in the future, bcm on passat b8 cant be modified, so no upgrades are possible (like on golf mk7 and others...)
In the service i was told all new vag cars will come with locked bcm.
downtime
Finland
C?ID=280813
^ I think that is BS.
Your BCM is not suitable for LED/Xenon lights. You'll need Highline BCM which has 087 at the end. Yours is midline and it does not support the upgraded headlights.
Then another thing. B8 has led driving lights, not xenon. So I'm guessing you'll also need the AFS/LED controller unit installed to the car. Module 55 headlight range. That controls and codes the power and AFS modules on the headlights and without it, they won't work.
m87a
Bosnia and Herzegovina
C?ID=156900
in order for these lights to work you need to change adaptation channels to let bcm know that headlights are now led and not halogen, post admap 09 and i'll try to help you.
Also i don't know if your bcm support led lights, it could be, also it could be it doesn't.
RedBool
EU
C?ID=333045
If the car has an automatic transmission, BCM in your car is HIGH.
The settings of the lights you have in the adaptation channels.
downtime
Finland
C?ID=280813
According to label it's midline : Labels:| 5Q0-937-08X-MV1.clb
Higline would be : 5Q0-937-08X-HV1.clb
Edit :
But hmm... Checked from ETKA and for Passat the BCM numbering seems to be a bit off from Golf. 86 is for transmitter frequency 433MHz and 087 is for 315MHz. There's no differentiation between Midline or Highline BCM.
OP needs to try the adaptation instructions given in this thread, if those go in fine then the BCM works and case closed.
