High Tickover
Sully
C?ID=236110
Hi Folks.
My T5 2.5l has a high tickover. It started to climb some time ago, and is now just under 1000 rpm. I will post scans later, but do you guys have any obvious things I can check first please?
Intake air leaks.
Sully
C?ID=236110
ah, OK. Those probably wan't show up on a scan anyway I'd guess. I'll take a look, thanks
Wait, you said T5. That's presumably a diesel. My head is in Petrol land...
Please post a scan so we're not guessing what you've got.
Sully
C?ID=236110
Yes, 5 pot diesel. Do you need a full vehicle scan or just engine?
Sully
C?ID=236110
Tuesday,13,March,2018,14:35:39:63214
VCDS Version: 18.2.0.3 (x64)
VIN: WV2ZZZ7HZ9H020288   License Plate: T5 MARCH 18
Mileage: 145660km-90508mi   Repair Order:
          57 6E 76 77 78 7D
VIN: WV2ZZZ7HZ9H020288   Mileage: 145660km-90508miles
Address 01: Engine        Labels: 070-906-016-BPC.clb
   Part No SW: 070 906 016 EC    HW: 070 906 016 EC
   Component: R5 2,5L EDC  000SG  2539
   Revision: --H06---    Serial number: VWZ7Z0H6748741
   Coding: 0000072
   Shop #: WSC 02736 790 00000
   VCID: 55A1B411FFF7B8EC1B-5140
005662 - Glowplug for Cylinder 5 (Q15)
               P161E - 000 - Open Circuit
                    Fault Status: 01110000
                    Mileage: 125490 km
                    RPM: 777 /min
                    Voltage: 13.00 V
                    Bin. Bits: 00000000
                    Temperature: 18.0°C
                    Bin. Bits: 10110000
Readiness: 1 1 0 0 0
Address 03: ABS Brakes        Labels: 7H0-907-37x-ABS.clb
   Part No SW: 7H0 907 379 S    HW: 7H0 907 379 S
   Component: (M)ABS MK25E        0103
   Revision: 00H21001
   Coding: 0000552
   VCID: 458164510F57086C6B-5106
                    Reset counter: 27
                    Mileage: 145548 km
                    Count: 12289
                    Count: 128
Address 08: Auto HVAC        Labels: Redir Fail!
   Part No: 7H0 820 045 AM
   Component: CLIMA/AC            0303
   VCID: 70EFE5856055FDC4E8-5124
Address 09: Cent. Elect.        Labels:. 7H0-937-049.lbl
   Part No: 7H0 937 049 AD
   Component: BORDNETZ SGVER 1.0  2101
   Coding: 0000101
   VCID: 74E7E995144DC1E40C-5124
01598 - Drive Battery Voltage
01117 - Generator Terminal DF Load Signal
00991 - Interior Lights
   Part No: 1C0 909 605 T
   Component: 3C AIRBAG VW51      0015
   Coding: 13123
   VCID: 356114910FB798ECFB-5106
Address 17: Instruments        Labels: 7Hx-920-xxx-17.lbl
   Part No: 7H0 920 951 T
   Component: KOMBI+WEGFAHRSP VDO V03
   Coding: 00413
   Shop #: WSC 00001
   VCID: 3D710CB1378740AC33-5124
   WV2ZZZ7HZ9H020288     VWZ7Z0H6748741
01304 - Radio
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 02736
   VCID: 70EFE5853055FDC4E8-5124
01304 - Radio
Address 46: Central Conv.        Labels: 7H0-959-433.lbl
   Part No: 7H0 959 433 B
   Component: C1W Komfortgerát     0004
   Coding: 00031
   Shop #: WSC 02736
   VCID: 326B2F8DFED98FD4DE-4B00
   Part No SW: 7H0 035 152 H    HW: 7H0 035 152 H
   Component: Radio LG3           0014
   Revision: 00008000    Serial number: VWZCZ5H0020485
   Coding: 0010200
   VCID: 275DCED9951BFA7C79-5124
Address 76: Park Assist        Labels: 7H0-919-283.lbl
   Part No: 7H0 919 283
   Component: Parkingsyst. T5 T5N 401
   Coding: 00137
   Shop #: WSC 02736
   VCID: 6FEDE6F92D6BE23CF1-5140
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
            31-00 - Open or Short to Ground
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
            30-00 - Open or Short to Plus
End-------------------------(Elapsed Time: 05:58)--------------------------
Sully
C?ID=236110
I know about the glowplug, the connector is damaged. Also the rear park assist!
Sully
C?ID=236110
Alternator problem? is the engine trying to compensate?
Sully
C?ID=236110
Bump....any any advice please? thanks Sean.
NostraJackAss
Diesels can have false air leaks too or fuel.
Verify the EGR circuits are not stuck open or anything else like a TV control with carbon.
You could also have faulty injectors where more fuel is administered than needed and raises the idle.
Indeed a weak battery maybe being tried to be compensated for as aforementioned.
Are any loads on but not actually on such as air conditioning or a regen from high ash/soot?
Sully
C?ID=236110
OK thanks, I will check EGR first. If Stephen Hawkings managed to succeed, then so will I..eventually. :-)
NostraJackAss
Yes, but I would not expect an air leak on a diesel to increase the idle RPM...
Oh no we are showing our age Uwe! :p
All depends if it is open traditional manifold or being controlled with a TV and or "control off" assistance flap.
Side note!
When playing experimental HCCI or CF gasoline, I can tell you, you want that shut off device or control of air!
RUN AWAY!
Guitarman
C?ID=56603
I'd be interested in how you get on with this. :) I have T5 Transporter too, but no DPF on my old '04. Mine had started doing some odd things at idle that to me sounded like a load had been applied. So in a way it was almost the opposite to yours in that the idle was normal most of the time but then would dip. If you are happy experimenting with VCDS and at your risk you could try what I did and code out the load sensing function in the J519 just to see if it makes a difference. On mine this stopped the alternator DF code being set and stopped the idle speed dipping.
I'm absolutely not saying this is a cure, I think I may need a J519 or an alternator but I do seem to have a temporary fix. It would be interesting to know what battery voltages are showing in the J519 on your van, mine was showing 17.7v! But this mad voltage wasn't duplicated in any other controller.
http://forums.ross-tech.com/showthread.php?8041-Transporter-T5-2-5-load-management-fault
NostraJackAss
http://forums.ross-tech.com/showthre...nagement-fault
That qualifies as a defeat device if done...........
Sully
C?ID=236110
^^^^^ All a bit techy for me at this stage :-) I'll stick to my toothbrush and carbon cleaner first! Hoping to take off EGR this weekend. I will report back.
Guitarman
C?ID=56603
NostraJackAss
Altering all aforementioned is altering an emission's device & since the DF load circuit is calculated or compensated for SMOG output.
