- Oct 24, 2015
- 18
- 6
- Netherlands
- C?ID=259766
Hi all,
When I moved from Texas to the Netherlands I had the good fortune to bring the TREG over. Most functions carry over except for the rear fog light which took some finagling but works fine now. Also swapped out the US receiver hitch style tow bar and control module (7P0-907-383-F) for the electric swiveling euro style tow bar and control module (7P0-907-383-C) that I obtained via a local salvage yard.
After the install (with the tow hook swiveled "in"), I managed to actuate the swiveling mechanism just once and now it is in the "out" position.
This is what I know so far:
- All trailer lights / functions work when connecting to the 13 pin euro style connector, at least with regular style bulbs. Not sure with LED's.
- The swiveling button in the boot lights up as intended when opening the hatch
- When pressing the swiveling button, the tow hook does not move
- Coding for the Euro style control unit 7P0-907-383-C that it came with is 0106040000000000 which seems to be correct according to many VCDS scans that I was able to verify against.
- This coding throws the following error however on my unit:
02588 - Swiveling Trailer Hitch
Fault Status: 11100101
Reset counter: 221
- When I change the coding to 0106000000000000, this error goes away, but the swiveling button in the boot does NOT light up as intended when opening the hatch and the no response when pressing the button either (tow hook does not move).
I am sure that in order for everything to operate as intended, the original coding needs to be reinstated. Just curious for clues as to where to start my fault finding mission.
Attaching full scan for completeness' sake:
Reset counter: 221
Monday,12,March,2018,12:36:43:24496
VCDS Version: 18.2.0.3 (x64)
VIN: WVGEP9BP9DD005238 License Plate: NG-533-P
Mileage: 113952km-70806mi Repair Order: N/A
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F
62 65 69 6C 6D 72
VIN: WVGEP9BP9DD005238 Mileage: 113952km-70806miles
Address 01: Engine (J623-CNRA) Labels:. 059-907-401-V2.clb
Part No SW: 7P0 907 401 K HW: 7P0 907 401 K
Component: 3.0TDI EDC17 H19 0003
Revision: 56H19---
Coding: 292A4032233600050000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM30TDI0117P0907401K 001004
ROD: EV_ECM30TDI0117P0907401K.rod
VCID: 377D73278E1234FCE9-8062
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 AK HW: 0C8 927 750 AK
Component: AL1000 AISIN 001 2269
Coding: 00B168
Shop #: WSC 25720 002 104857
ASAM Dataset: EV_TCMAL991031 002114
ROD: EV_TCMAL991031_002.rod
VCID: 75E1B92FD49E86EC3B-8020
Address 03: ABS Brakes (J104) Labels:* None
Part No SW: 7P0 907 379 M HW: 7P0 907 379 A
Component: MK25A H36 0436
Revision: -------- Serial number: 420720010EC815
Coding: 5B7613C349242558DAF6C89692DAA4407300
ASAM Dataset: EV_MK25AXT 008001
ROD: EV_ESPMK25A00800.rod
VCID: 479D03E7FEF2447C99-8012
Part No SW: 4H0 907 064 CK HW: 4H0 907 064 CK
Component: BCM2 2.0 H32 0421
Coding: 0D860016000000000000
VCID: 74E7842BD7E49FE40C-8020
Subsystem 1 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Serial number: 2312000166468013
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 BK HW: 7P6 907 040 BK
Component: Klima 2 Zonen H20 1305
Coding: B686000A80
VCID: 7EF3A603E1A8C5B46A-802A
Part No SW: 4H0 907 063 BL HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0111
Revision: 15012002 Serial number: 00000001587520
Coding: 26005013D33C5F010021100300005D0C431C660882010361000000020000
VCID: 73E58737D2EA98DC15-8026
Subsystem 1 - Part No SW: 7P0 955 119 HW: 7P0 955 119 Labels: 1KX-955-119.CLB
Component: WWS 120711 31 0020
Serial number: 90243400120719155436
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 D HW: 7P0 955 559 D Labels: 8K0-955-559.CLB
Component: RLFS H09 0011
Serial number: 10422770
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 HW: 7P6 941 431
Component: E1 - LDS H02 X024
Serial number: 00000000000000000074
Subsystem 4 - Part No SW: 4H0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0020
Serial number: 0000001805569R17RD07
Address 10: Park/Steer Assist (J446) Labels:| 7P6-919-475.clb
Part No SW: 7P6 919 475 B HW: 7N0 919 475
Component: PARKHILFE 8K H05 0021
Revision: -------- Serial number: 28201221200066
Coding: 500501
ASAM Dataset: EV_VW526ParkiAssis2 001011
ROD: EV_VW526ParkiAssis2.rod
VCID: 428B12F3D5D061544E-8016
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 C HW: 7P0 959 655 C
Component: VW10Airbag025 H05 0025
Revision: -------- Serial number: 003L0004C2FE
Coding: 000000000000000000000000000000003235
ROD: EV_AirbaVW10BPAVW526_001.rod
VCID: 41891DFFD0D67A4C57-8014
Subsystem 1 - Part No SW: 7P6 959 339 HW: 7P6 959 339
Component: BF-Gewichtss. 003 0005
Serial number: 5850000R1242708SQH
Serial number: 3575LRB405P1G7FCE0IO
Serial number: 3585LRB405N1G7FAG8N-
Serial number: 3515RRB40691BBHAG0D5
Serial number: 3525RRB40631BBHABO5B
Serial number: 3555NRB405H1GCDMK14M
Serial number: 3565NRB405H1GCDMEH4X
Part No SW: 4H0 953 568 H HW: 7P6 953 507 M
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90815LHE0001R
Coding: 000C15
VCID: 387F701B8B0C3B84E0-806C
Subsystem 1 - Part No SW: 7P6 959 542 HW: 7P6 959 542
Component: E221__MFL-TAS H03 0027
Serial number: 0205586
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 981 F HW: 7P6 920 981 F
Component: Kombi H13 0318
Revision: 13240077 Serial number: 658100812592034
Coding: 937F33022B00000D0D0004
ASAM Dataset: EV_KombiUDSRBVW526 001017
ROD: EV_KombiUDSRBVW526.rod
VCID: 408F18FBDBDC734458-8014
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7P6 907 530 F HW: 7P6 907 530 F
Component: GW-CAN-L-MOST H11 6028
Revision: -------- Serial number: 00000000640596
Coding: 0001037500
ASAM Dataset: EV_GatewVW526UDS 001007
ROD: EV_GatewUDS_VW52.rod
VCID: 3B756F17B23A109C0D-806E
Subsystem 1 - Part No SW: 7P0 915 181 A HW: 7P0 915 181
Component: Batt_Sensor H07 0140
Serial number: 00000000005650870006
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00000036097170
Coding: 00581B0000004001000001010101202020202121202020
VCID: 3467442B9764DFE4CC-8060
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4H0 959 793 N HW: 4H0 959 793 F
Component: TSG FA H07 0166
Revision: -------- Serial number: 0000129654031
Coding: 011D17205E00453005080000
VCID: 448714EBC7C46F647C-8010
Revision: 00002001 Serial number: 0181915902
Coding: 01061E3A28B9509581A00620210000000000000000000000000000000000
Subsystem 1 - Part No SW: 7P6 959 719 HW: 7P6 959 719
Component: GTO BT H19 0059
Serial number: 2001216179
Subsystem 3 - Part No SW: 7P0 959 591 B HW: 7P0 959 591 B
Component: J245 PS30.055 H01 0008
Serial number: WOO17569338
Coding: 191100
Subsystem 4 - Part No SW: 7P0 959 591 C HW: 7P0 959 591 C
Component: J394 PS30.055 H01 0008
Serial number: WOO1760203-
Coding: 191100
Part No SW: 7P6 035 466 HW: 7P6 035 466
Component: DSP Prem H01 0090
Revision: 00001001 Serial number: 10811001781006
VCID: 75E1B92FDC9E86EC3B-8020
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4H0 959 792 F HW: 4H0 959 792 F
Component: TSG BF H07 0166
Revision: -------- Serial number: 0000129631771
VCID: 3B756F17BA3A109C0D-806E
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: C1273000265
Coding: 01040200
ROD: EV_ParkbA7.rod
VCID: 36637E238918CDF4F2-8062
Slave 3:
Address 55: Headlight Range (J745) Labels:. 7P6-907-357.clb
Part No SW: 7P6 907 357 HW: 7L6 907 357 C
Component: AFS-ECU H04 0110
Coding: 010A00010F000400
ASAM Dataset: EV_HeadlRegulVWAFS 005006
ROD: EV_HeadlRegulVWAFS_VW52.rod
VCID: 7CF7AC0BF7B4D7A444-8028
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 130000
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 130000
Revision: AB001007 Serial number: 156G30C7618908
Coding: 020007010000000001
VCID: 2447B46B27844F645C-8070
Part No SW: 7P6 035 664 K HW: 7P6 035 664
Component: H-BN-NA H45 0934
Revision: -------- Serial number: 445H00C7539290
Coding: 020100060040E1FF4302BF0E00000003100001000100000000
VCID: 408F18FBD3DC734458-8014
Subsystem 1 - Part No: 7P6 060 884 G
Component: EUR 2017 2402
Subsystem 2 - Part No SW: 7P6 919 603 HW: 7P6 919 603 C
Component: DU8 SV Touch H26 0045
Serial number: VWZ8Z9M7900ET9
Subsystem 3 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: CD-Database 1886
03175 - Invalid Data Set
Reset counter: 220
Mileage: 113896 km
Date: 2018.03.11
Time: 18:43:56
Voltage: 11.90 V
03623 - Invalid Secruity/Release Code
Reset counter: 220
Mileage: 113896 km
Date: 2018.03.11
Time: 18:43:57
Hex Value: 0x0004
Hex Value: 0x0405
Count: 7
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HL H09 0167
Revision: -------- Serial number: 0000129366151
Coding: 011C17200000253005080000
VCID: 3A7B6A13B500299416-806E
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 7P6 907 273 F HW: 7P6 907 273 F
Component: RDKBERU25 H09 0008
Serial number: 10000000089459
ASAM Dataset: EV_RDKBERU25 003006
ROD: EV_RDKBERU25_VW52.rod
VCID: 3F8D1B07A6220CBC21-806A
Address 69: Trailer (J345) Labels: None
Part No SW: 7P0 907 383 C HW: 7P0 907 383 C
Component: Anhaenger H07 0073
Revision: 5H001003 Serial number: 00000125889014
Coding: 0106040000000000
Reset counter: 221
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 7P6 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0020
Revision: 00H06000 Serial number: 525 PA8J271159
Coding: 0130001
VCID: 377D7327461234FCE9-8062
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 A HW: 7P6 959 107
Component: HDSG-Modul H10 0620
Revision: 22010001 Serial number: 215200467
Coding: 0533314003
ASAM Dataset: EV_HeckkTouar 202137
ROD: EV_HeckkTouar.rod
VCID: 3D71610FAC2E1EAC33-8068
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H09 0167
Revision: -------- Serial number: 0000129582522
End-------------------------(Elapsed Time: 05:02)--------------------------
