Audi B7 Parking Sensor Volume Issue
parkfoto
C?ID=93129
Hi all. I have a 2006 B7 S4 Avant and replaced the faulty OEM rear parking sensor speaker with one that I found on eBay (brand new, Chinese). All is good except for the volume of the speaker. It is quite low so I utilized VCDS in an attempt to increase the volume but the value is just stuck on "4". It will not register a new value. So I'm wondering if the problem lies in the fact that the new speaker is not OEM. Or am I doing something wrong within VCDS? Any insight is greatly appreciated. Thank you!
parkfoto
C?ID=93129
Hi Jack, thanks for your reply. After some more investigating, I've decided to purchase the OEM part from Audi (part # 8E0919279). I'll report back after installing the new one. Hopefully that will allow me to adjust the volume via VCDS or at the very least be louder than the one I bought on eBay.
parkfoto
C?ID=93129
OK. So I replaced the eBay purchased speaker with the Audi OEM part # 8E919279 and the default volume appears to be louder (I'll report back once I've put a little more time in the car). Unfortunately VCDS shows the rear buzzer volume is still stuck on 4. I try to change the value and it flashes N/A then shows the current level of 4. Am I doing something wrong here? Or is it just a value that cannot be changed? Thanks.
South Molton, UK
On my previous car, a B7 RS4 Avant, I was able to change both Front and Rear volumes and frequencies (essential when I had a non-resonated exhaust fitted), so it is possible with VCDS.
parkfoto
C?ID=93129
So in VCDS 18.2 I go to "Electronics 1" then to module 76 "Park Assist" and check "Rear Buzzer Volume". The value on the left reads "4". When I type in the input box on the upper right a value greater than 4, it flashes "N/A" quickly then resumes the number 4 (on the left). Am I doing something wrong?
South Molton, UK
How do you get to "Rear Buzzer Volume"? It's an adaptation channel IIRC, so do you click on that button after going to 76?
Just a thought, I can't remember for sure if you need to have entered a security code first (I don't THINK I did...) to be able to change settings?
parkfoto
C?ID=93129
After 76, press "Adv. Meas. Values" and a whole list of values with check boxes comes up on the right. This is where I think I'm making a mistake. I just change the value to something over 4 and less than 8 and nothing happens. Do I need to change some sort of coding instead? And no need for a security code, I believe that you only need that for 01-Engine module.
MasterTommy
Amsterdam
C?ID=295586
Measuring values is exactly that.
If you want to change settings, you go to adaptations or coding.
parkfoto
C?ID=93129
Thank you for pointing me in the right direction. Do you have any guidance on how to change volume values in Adaptation or Coding?
parkfoto
C?ID=93129
Success! The volume can be changed in the Adaptation module. There's a drop down menu with "rear buzzer volume" option. Thanks for all of the help. Although now scratching my head if that option would have been greyed out when I had the non-OEM buzzer installed. I'm definitely not going to open that panel again! Maybe someone who has the non-OEM can comment.
parkfoto
C?ID=93129
Ok. Here's the latest auto scan of my 2006 B7 S4 Avant:
VCDS Version: 18.2.0.3
          67 69 75 76 77
Address 01: Engine        Labels: 079-910-560-BBK.lbl
   Part No SW: 8E2 910 560 A    HW: 8E2 907 560
   Component: 4.2L V8/5V      G   0030
   Revision: --H01---    Serial number:
   Coding: 0007771
   Shop #: WSC 08259 444 58792
   VCID: 254A0940EC2D9D6C4B-8070
   Part No SW: 8E1 910 156 F    HW: 09L 927 156 B
   Component: AG6 09L 4,2 MPI USA 0030
   Revision: --H01---    Serial number:        4104556
   Coding: 0000002
   Shop #: WSC 06325 000 00000
   VCID: 2A50FA7C8533B21466-807E
   Part No SW: 8E0 910 517 E    HW: 8E0 614 517 AL
   Component: ESP8 quattro    H05 0120
   Coding: 0004902
   VCID: 295205708035B90C6F-807C
   Part No: 8E0 820 043 BM
   Component:   A4 Klimaautomat   2832
   Coding: 00000
   VCID: 6DDA3160275D652CC3-5178
   Part No: 8E0 907 279 L
   Component: int. Lastmodul  ECE 0504
   Coding: 11021
   Shop #: WSC 06325
   VCID: 3B7ECF3829A93B9C0D-4B18
   Part No SW: 8E0 035 593 D    HW:
   Component: SDAR SIRIUS
   Revision:             Serial number: AUZ4Z7E0015068
   VCID: 2A50FA7C8633B21466-5196
   Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
   Component:    Airbag 9.41  H11 3540
   Revision: 91H1135    Serial number: 0036N0013V7V
   Coding: 0032607
   VCID: 3C7CCC247FA73CA404-8068
   Subsystem 1 - Part No: 8E0 910 339 B
   Component: BF-Gewichtsens. 002 0070
   Subsystem 2 - Serial number: 35V5Z
   Subsystem 3 - Serial number: 0001.01.000000200000000000ˇÜ63
   Subsystem 4 - Serial number: 000000ˇÜ6332DRB402498920HˇÜ63
   Subsystem 5 - Serial number: 98920HˇÜ6342DRB40248D427OˇÜ63
   Subsystem 6 - Serial number: 8D427OˇÜ6352ARB400B86406HˇÜ63
   Subsystem 7 - Serial number: 86406HˇÜ6362ARB400BC6ED51ˇÜ63
   Subsystem 8 - Serial number: C6ED51ˇÜ63729RB400C6D4ED2ˇÜ63
   Subsystem 9 - Serial number: 6D4ED2ˇÜ63829RB400C6C705Qˇ
   Subsystem 10 - Serial number: 6C705Qˇ
   Part No: 8E0 953 549 Q
   Component: Lenks·ulenmodul     0601
   Coding: 04142
   Shop #: WSC 06325
   VCID: 4182BDD04B45514C57-4B18
   Part No SW: 8E0 920 982 C    HW: 8E0 920 982 C
   Component: KOMBI+WFS 4     H12 0110
   Revision: 0110        Serial number: 00000000000000
   Coding: 0023201
   Shop #: WSC 02314 444 58814
   VCID: 2E58F66CBADBDE34BA-513C
   Coding: 0023201
   VCID: 2E58F66CBADBDE34BA-515A
Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
   Part No: 8E0 959 760
   Component: Sitzmemory R2 F     0305
   Coding: 00002
   VCID: 71E22D103B6581CCE7-4B00
Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
   Part No SW: 8E0 035 192 F    HW: 8E0 035 192 F
   Component: RNS-E US        H70 0260
   Revision:      01S    Serial number: AUZBZ7E2003359
   Coding: 0309637
   Shop #: WSC 00493 128 51639
   VCID: 2756034895218F7C79-5196
   Part No: 8E0 959 433 BT
   Component: Komfortger·t T7B    3332
   Coding: 14204
   Shop #: WSC 06325
   VCID: 040C74C414D784643C-4B18
   Subsystem 1 - Part No: 8E1959801G
   Component: Tırsteuer.FS BRM 0506
   Subsystem 2 - Part No: 8E1959802E
   Component: Tırsteuer.BF BRM 0205
   Component: Tırsteuer.HL BRM 0606
   Subsystem 4 - Part No: 8E0959802E
   Component: Tırsteuer.HR BRM 0606
   Part No SW: 4F0 910 357 E    HW: 4F0 907 357 E
   Coding: 0000019
   VCID: 285400749B3F800470-807C
   Subsystem 1 - Part No: 8E0 941 329
   Component: AFS-Modul links H03 0020
   Subsystem 2 - Part No: 8E0 941 329
   Component: AFS-Modul rechtsH03 0020
Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
   Coding: 0309637
Address 65: Tire Pressure        Labels: 8E0-907-273.lbl
   Part No SW: 8E0 907 273     HW: 8E0 907 273
   Component: Reifendruck 3   H03 0110
   Coding: 0063022
   Shop #: WSC 06435 000 00000
   VCID: 69D2457043B5790CAF-515A
Address 76: Park Assist        Labels: 8E0-919-283-8EC.lbl
   Part No SW: 8E0 919 283 D    HW: 8E0 919 283 D
   Component: Parkhilfe 4-Kan H06 0010
   Revision: 00H06000    Serial number: 00067802020531
   Coding: 0001314
   VCID: 3162ED10ABE5C1CCA7-515A
   Part No SW: 8P0 862 335 G    HW: 8P0 862 335 G
   Component: FSE_255x BT     H21 0190
   Revision: 00000001    Serial number: 00000000341107
   Coding: 0011877
   VCID: 3A70CA3C7693029416-513C
End-------------------------(Elapsed Time: 06:09)--------------------------
NostraJackAss
Component: 4.2L V8/5V G 0030 <<<<<<<<<<<<<<<<<<<<<<<<<<< Update firmware required! 0040 or higher!
Who cares about China aftermarket parts function? :cool:
parkfoto
C?ID=93129
I'm chipped. That's why my firmware is what it is.
Yeah, just curious if it would have been possible to change the volume on the non-OEM.
parkfoto
C?ID=93129
Sorry I'm a bit of a noob and not sure what your response means.
Don't worry about it, it's has nothing to do with the topic of this thread. Jack is just being a good Nazi. ;)
For your parking buzzer volume:
[Select]
[76 - Park Assist]
[Adaptation]
Channel 1 should be: Rear Buzzer Volume
Channel 2 should be: Rear Buzzer Frequency
Channel 3 should be: Front Buzzer Volume
Channel 4 should be: Front Buzzer Frequency
All of them should accept numbers in the range of 1 to 9 in the New Value field.
The Adaptation function is generally described here in the VCDS product manual.
parkfoto
C?ID=93129
Tuna huh.........? :banghead:
Well that explains this, doesn't it?
Why wouldn't it be?
Thanks guys.
What's the deal with "No fault code found.
Readiness: 0000 0000"?
and tuna...haha! Honestly not sure what that means.
