Car wont crank
mario01
C?ID=292756
 Friday,09,March,2018,18:33:03:39527
VCDS Version: 18.2.0.3 (x64)  HEX-NET CB: 0.4411.4
Chassis Type: FR-AU48 (8R0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 22 36 3C 42 44 46 47 52 53
          56 5F 6C
VIN: WUAC6AFR5EA90182  Mileage: 13990km-8692miles
Address 01: Engine (------CFSA)       Labels:. 079-907-560-CFS.clb
   Part No SW: 8T2 907 560 F    HW: 8T1 907 560
   Component: 4.2l V8HDZ /  H04 0003
   Revision: NAH04---
   Coding: 1A25003225A6080D3000
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_ECM42FSI0118T2907560F 001002
   ROD: EV_ECM42FSI0118T2907560F.rod
   VCID: 3FCE8F79A6E7DBBC21-806A
4527 - Coolant Fan Control Circuit 1
          P0480 00 [036] - Electrical Malfunction
                    Mileage: 13994 km
                    Date: 2018.03.09
                    Time: 19:17:46
                    Engine speed: 0.00 /min
                    Coolant temperature: 20 °C
                    Intake air temperature: 20 °C
                    Voltage terminal 30: 12.086 V
                    selected gear-Bits 0-7: 0
                    Cruise control switch actuation-Bits 0-7: 0
4528 - Coolant Fan Control Circuit 2
          P0481 00 [036] - Electrical Malfunction
                    Mileage: 13994 km
                    Date: 2018.03.09
                    Time: 19:17:46
5456 - Starter Will Not Turn
          P3054 00 [167] - Jammed or Electrical Malfunction
                    Mileage: 13994 km
                    Date: 2018.03.09
                    Time: 18:29:50
                    Coolant temperature: 21 °C
                    Intake air temperature: 22 °C
                    Voltage terminal 30: 11.614 V
                    AFS dm: 0.0 kg/h
                    Median injection timing: 0.000 ms
                    Engine operating condition: Idling
Readiness: 1110 1101
   Part No SW: 8T0 927 156 H    HW: 0B5 927 156 K
   Component: 0B5 42 FSINAR H02 0003
   Revision: --H02---
   ASAM Dataset: EV_TCMDL501021 001015
   ROD: EV_TCMDL501021.rod
   VCID: 42C8868DD515B6544E-8016
   Part No SW: 8T0 907 379 F    HW: 8T0 907 379 F
   Component: ESP8 quattro  H09 0100
   Coding: 2C1D1A
   VCID: 45C29D91CC3B816C6B-8010
   Part No SW: 8K0 907 064 JM    HW: 8K0 907 064 JM
   Component: BCM2 2.0      H14 0650
   Coding: 0D804040000000000000
   VCID: 04444095878178643C-8050
   Serial number: 0214000007611006
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8T0 959 760 E    HW: 8T0 959 760 E
   Component: MEM-BFS       H10 0077
   Revision: AA000000    Serial number: 00000089867497
   Coding: 00037025002C00000000
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Revision: C1000000    Serial number: 01100220140370
   Coding: 4802200000
   VCID: 393AE161B0C3F58C1F-806C
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 27
                    Mileage: 13994 km
                    Date: 2018.03.09
                    Time: 18:36:14
                    Temperature: 21.0°C
                    Temperature: 21.0°C
                    Absolute Pres.: 1.0 bar
                    Current: 0.000 A
                    Temperature: 31.0°C
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00000058993101
   Coding: 06000091043C9FE0250048C3000039090F9CD388A2090221000008004000010200040034000000
   VCID: 7AB83E6DF5453E9456-802E
   Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 070214  H15 0080
   Serial number: SWF14020075298
   Coding: 00FD11
   Serial number: 22221293
   Coding: 02005D
   Subsystem 3 - Part No SW: 8K0 941 531 AQ    HW: 8K0 941 531 AQ
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002001140470
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R9LA803
   Subsystem 5 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 6 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: AA09CD07000000000001
   Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
   Component: AirbagVW-AU10 H47 0610
   Serial number: 003KJDB12CKF
   Coding: 303343334830303030304A55304C38543053
   VCID: 4AD8AEADED256E1486-801E
   Subsystem 1 - Part No SW: 8K0 959 339 A    HW: 8K0 959 339 A
   Component: BF-Gewichtss.  H02 0060
   Serial number: 5810000R140000HWUA
   Serial number: 6334MSME417E3649L
   Serial number: 6344MSME417D5312A
   Serial number: 6352QSME443A2E5EX
   Serial number: 6362QSME4C3A2644N
   Serial number: 63732SME1F3C237A9
9444115 - Front Passenger's Front Airbag Crash Sensor
          B101B 15 [137] - Open or Short to Plus
                    Mileage: 13994 km
                    Date: 2018.03.09
                    Time: 18:30:20
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Revision: --------    Serial number: 90372NB4000VL
   Coding: 000036
   VCID: 44C48095C701B8647C-8010
   Part No SW: 8T0 920 984 H    HW: 8T0 920 984 H
   Component: KOMBIINSTR.   H35 0564
   Revision: 00000000    Serial number: Z9X29PX1F
   Coding: 8BBF01008B03D705020000
   Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0060
   Revision: 1Z120030    Serial number: 3041Z1412705D9
   Coding: 80E3031600
   VCID: 4CD4A8B5EF517024B4-8018
   Serial number: 8983742403
            000 -  -
                    Reset counter: 27
                    Mileage: 13994 km
                    Date: 2018.03.09
                    Time: 18:37:52
                    Bin. Bits:    10111
                    Voltage: 12.00 V
                    Count: 6
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H14 0100
   Serial number: 002501140001599
   VCID: 2F2EDF3976872B3CB1-807A
   Component: MEM-FS        H10 0077
   Revision: AA000000    Serial number: 00000089930988
   Coding: 001B7B25002C00000000
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Serial number: 0324206826
   Coding: 010211
   Shop #: WSC 06324 000 00000
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0071
   Serial number: 0324161859
   Coding: 010211
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0305
   Coding: 011C13224E00120102
   VCID: 56E04ADD219D3AF412-8002
   Part No SW: 8K0 909 144 G    HW: 8K0 909 144 B
   Component: RCEPS         H40 0508
   Revision: 00001000    Serial number: 0025248314
   Coding: 100000010001
   ASAM Dataset: EV_RCEPSAU48X 008015
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3522ED5194DB11ECFB-8060
   Revision: 00002001    Serial number: 0326763341
   Coding: 0106029A00FAC00580B0003200000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000792288
   Subsystem 3 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J245EE20SKB13  H05 0220
   Subsystem 4 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0029
   Serial number: WA107531000006098953
   Revision: 00005001    Serial number: 94813025485504
   VCID: 2D12C531748B592C83-8078
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0305
   VCID: 55E24DD13C9B31EC1B-8000
   Component: EPB-4         H01 0005
   Revision: --------    Serial number: 30000000166863
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A38FE6DBDC5FE9416-806E
   Revision: AB001007    Serial number: 156B70E7964578
   Coding: 020007010000000001
   VCID: 24042015274198645C-8070
   Part No SW: 8R1 035 746 E    HW: 8R1 035 746 D
   Component: H-BNT-NA      H41 0756
   Revision: --------    Serial number: 204BU0E7639331
   Coding: 150200020306A1EF55028B5E00000403140000000000000000
   Subsystem 1 - Part No: 8R0 060 884 BL
   Component: NAR 2014  0902
   Component: DU7 High  H42 0104
   Serial number: A130A 0E2936698
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000001748213
   Component: CD-Database  5571
   Revision: --H09---    Serial number: 525PA8-J3Y92HB
   Coding: 1020008
   VCID: 383CE4654BC9EC84E0-806C
End----------(Elapsed Time: 01:51, VBatt start/end: 12.3V/12.2V)-----------
Gone But Not Forgotten
mario01
C?ID=292756
i have power to the jump start. is there a way to test the starter without having to remove the front end of the car and the alternator?
Don't you think you could grab the solenoid connection further up and jump out using WD or at the starter relay directly and manually bridge to initiate the starter to crank & if it doesn't click or crank change the starter?
Sometimes things are hard to test but they are needed to be observed right, what if rodent damage?
mario01
C?ID=292756
thank you, for getting back to me. i will try that but do you happen to have a diagram of the wires that go to the solenoid? or the color of the wires i should be looking for?
mario01
C?ID=292756
i don't mind you providing as well?
Don't you think it is morally wrong to request or solicit someone to provide a WD here and when it is frowned upon in the forum collective rules or to engage in acts of copyright infringement & that could hurt others?
Do you hurt people? Good, glad to hear you don't, now go to ERWIN and get it, "right"?
mario01
C?ID=292756
first of all i do not know whats a WD...dude what are you talking about? im just looking for some help here. not asking you to copy right anything.
WD = Wire Diagram and you can hover your cursor over acronyms such as this to see a brief definition.
Repair manuals or RTFB can be found here for a subscription in link below.
http://wiki.ross-tech.com/wiki/index.php/Official_Factory_Repair_Information
I'm afraid that wiring diagrams are copyrighted material. Small snippets are might be an exception, (fair use doctrine), but anyone attempting anything more than the simplest repair really should have a complete set for the car they're working on.
mario01
C?ID=292756
:thumbs::thumbs::thumbs::thumbs::thumbs::vc:vc
