Audi A3 8V Retrofit Facelift Headlights LED
vastechnics
C?ID=143747
I have facelifted an Audi A3 with FULL LED headlights to the facelift model with also LED headlights. No matrix, just the ones without the matrix. I have replaced the 55 xenon range module and everything works ok, exept for the turn signals in front, when the car is unlocked by remote or locked by remote.
This because the headlights from facelift model are totally triggered by the 55 xenon range module. This module has an ignition + so when the ignition is off the turn signals don't work.
Now I know that these headlights work with the 29 39 and D6 D7 module. This needs to be selected in the 55 xenon range module. To change this there is an acces code needed. Does someone knows the acces code for this?
Below is the scan of a car with OEM these headlights, here you can see that the channels are all on YES. With the module from the car from retrofit all is set to NO.
Regards
	SW:8V0-907-357-A   HW:7P6-907-357-B ---  Headlight Range
	Component:MxB-ECU       001 0230, Coding:0EDA00102B230200
	EV_HeadlRegulAUDIMXBAU64X,005014,EV_HeadlRegulAUDIMXBAU64X_005_AU37.rod
	Saturday,03,March,2018,16:23:33:45638
	VCDS Version: Release 18.2.0 (x64)  Data version: 20180212 DS287.0
	VCID: 3E74BB44A1C5F3B42A-806A
IDE01996-SFT00041-Installation list: specified installations-Light Control Left,Yes ,1
IDE01996-SFT00057-Installation list: specified installations-Light Control Right,Yes ,1
IDE01996-SFT00085-Installation list: specified installations-Headlight Regulation,Yes ,1
IDE01996-SFT00214-Installation list: specified installations-Light Control Left 2,Yes ,1
IDE01996-SFT00215-Installation list: specified installations-Light Control Right 2,Yes ,1
IDE03641-Presentation run dynamic AFS light,not active ,1
IDE08418-Matrix light: total dimming,100.8 ,1
IDE09156-Matrix headlamp: function at standstill,not active ,1
IDE09568-MAS09833-Bit pattern of individual segment activation: left headlight-LED 1,OFF ,6
IDE09568-MAS09834-Bit pattern of individual segment activation: left headlight-LED 2,OFF ,6
IDE09568-MAS09835-Bit pattern of individual segment activation: left headlight-LED 3,OFF ,6
IDE09568-MAS09836-Bit pattern of individual segment activation: left headlight-LED 4,OFF ,6
IDE09568-MAS09837-Bit pattern of individual segment activation: left headlight-LED 5,OFF ,6
IDE09568-MAS09838-Bit pattern of individual segment activation: left headlight-LED 6,OFF ,6
IDE09568-MAS09839-Bit pattern of individual segment activation: left headlight-LED 7,OFF ,6
IDE09568-MAS09840-Bit pattern of individual segment activation: left headlight-LED 8,OFF ,6
IDE09568-MAS09841-Bit pattern of individual segment activation: left headlight-LED 9,OFF ,6
IDE09568-MAS09842-Bit pattern of individual segment activation: left headlight-LED 10,OFF ,6
IDE09568-MAS09843-Bit pattern of individual segment activation: left headlight-LED 11,OFF ,6
IDE09568-MAS09844-Bit pattern of individual segment activation: left headlight-LED 12,OFF ,6
IDE09568-MAS09845-Bit pattern of individual segment activation: left headlight-LED 13,OFF ,6
IDE09568-MAS09846-Bit pattern of individual segment activation: left headlight-LED 14,OFF ,6
IDE09568-MAS09847-Bit pattern of individual segment activation: left headlight-LED 15,OFF ,6
IDE09568-MAS09848-Bit pattern of individual segment activation: left headlight-LED 16,OFF ,6
IDE09568-MAS09849-Bit pattern of individual segment activation: left headlight-LED 17,OFF ,6
IDE09568-MAS09850-Bit pattern of individual segment activation: left headlight-LED 18,OFF ,6
IDE09568-MAS09851-Bit pattern of individual segment activation: left headlight-LED 19,OFF ,6
IDE09568-MAS09852-Bit pattern of individual segment activation: left headlight-LED 20,OFF ,6
IDE09568-MAS09853-Bit pattern of individual segment activation: left headlight-LED 21,OFF ,6
IDE09568-MAS09854-Bit pattern of individual segment activation: left headlight-LED 22,OFF ,6
IDE09568-MAS09855-Bit pattern of individual segment activation: left headlight-LED 23,OFF ,6
IDE09568-MAS09856-Bit pattern of individual segment activation: left headlight-LED 24,OFF ,6
IDE09568-MAS09857-Bit pattern of individual segment activation: left headlight-LED 25,OFF ,6
IDE09568-MAS09858-Bit pattern of individual segment activation: left headlight-LED 26,OFF ,6
IDE09568-MAS09859-Bit pattern of individual segment activation: left headlight-LED 27,OFF ,6
IDE09568-MAS09860-Bit pattern of individual segment activation: left headlight-LED 28,OFF ,6
IDE09568-MAS09861-Bit pattern of individual segment activation: left headlight-LED 29,OFF ,6
IDE09568-MAS09862-Bit pattern of individual segment activation: left headlight-LED 30,OFF ,6
IDE09568-MAS09863-Bit pattern of individual segment activation: left headlight-LED 31,OFF ,6
IDE09568-MAS09864-Bit pattern of individual segment activation: left headlight-LED 32,OFF ,6
IDE09568-MAS09865-Bit pattern of individual segment activation: left headlight-LED 33,OFF ,6
IDE09568-MAS09866-Bit pattern of individual segment activation: left headlight-LED 34,OFF ,6
IDE09568-MAS09867-Bit pattern of individual segment activation: left headlight-LED 35,OFF ,6
IDE09568-MAS09868-Bit pattern of individual segment activation: left headlight-LED 36,OFF ,6
IDE09568-MAS09869-Bit pattern of individual segment activation: left headlight-LED 37,OFF ,6
IDE09568-MAS09870-Bit pattern of individual segment activation: left headlight-LED 38,OFF ,6
IDE09568-MAS09871-Bit pattern of individual segment activation: left headlight-LED 39,OFF ,6
IDE09568-MAS09872-Bit pattern of individual segment activation: left headlight-LED 40,OFF ,6
IDE09568-MAS09873-Bit pattern of individual segment activation: left headlight-LED 41,OFF ,6
IDE09568-MAS09874-Bit pattern of individual segment activation: left headlight-LED 42,OFF ,6
IDE09568-MAS09875-Bit pattern of individual segment activation: left headlight-LED 43,OFF ,6
IDE09568-MAS09876-Bit pattern of individual segment activation: left headlight-LED 44,OFF ,6
IDE09568-MAS09877-Bit pattern of individual segment activation: left headlight-LED 45,OFF ,6
IDE09569-MAS09833-Bit pattern of individual segment activation: right headlight-LED 1,OFF ,6
IDE09569-MAS09834-Bit pattern of individual segment activation: right headlight-LED 2,OFF ,6
IDE09569-MAS09835-Bit pattern of individual segment activation: right headlight-LED 3,OFF ,6
IDE09569-MAS09836-Bit pattern of individual segment activation: right headlight-LED 4,OFF ,6
IDE09569-MAS09837-Bit pattern of individual segment activation: right headlight-LED 5,OFF ,6
IDE09569-MAS09838-Bit pattern of individual segment activation: right headlight-LED 6,OFF ,6
IDE09569-MAS09839-Bit pattern of individual segment activation: right headlight-LED 7,OFF ,6
IDE09569-MAS09840-Bit pattern of individual segment activation: right headlight-LED 8,OFF ,6
IDE09569-MAS09841-Bit pattern of individual segment activation: right headlight-LED 9,OFF ,6
IDE09569-MAS09842-Bit pattern of individual segment activation: right headlight-LED 10,OFF ,6
IDE09569-MAS09843-Bit pattern of individual segment activation: right headlight-LED 11,OFF ,6
IDE09569-MAS09844-Bit pattern of individual segment activation: right headlight-LED 12,OFF ,6
IDE09569-MAS09845-Bit pattern of individual segment activation: right headlight-LED 13,OFF ,6
IDE09569-MAS09846-Bit pattern of individual segment activation: right headlight-LED 14,OFF ,6
IDE09569-MAS09847-Bit pattern of individual segment activation: right headlight-LED 15,OFF ,6
IDE09569-MAS09848-Bit pattern of individual segment activation: right headlight-LED 16,OFF ,6
IDE09569-MAS09849-Bit pattern of individual segment activation: right headlight-LED 17,OFF ,6
IDE09569-MAS09850-Bit pattern of individual segment activation: right headlight-LED 18,OFF ,6
IDE09569-MAS09851-Bit pattern of individual segment activation: right headlight-LED 19,OFF ,6
IDE09569-MAS09852-Bit pattern of individual segment activation: right headlight-LED 20,OFF ,6
IDE09569-MAS09853-Bit pattern of individual segment activation: right headlight-LED 21,OFF ,6
IDE09569-MAS09854-Bit pattern of individual segment activation: right headlight-LED 22,OFF ,6
IDE09569-MAS09855-Bit pattern of individual segment activation: right headlight-LED 23,OFF ,6
IDE09569-MAS09856-Bit pattern of individual segment activation: right headlight-LED 24,OFF ,6
IDE09569-MAS09857-Bit pattern of individual segment activation: right headlight-LED 25,OFF ,6
IDE09569-MAS09858-Bit pattern of individual segment activation: right headlight-LED 26,OFF ,6
IDE09569-MAS09859-Bit pattern of individual segment activation: right headlight-LED 27,OFF ,6
IDE09569-MAS09860-Bit pattern of individual segment activation: right headlight-LED 28,OFF ,6
IDE09569-MAS09861-Bit pattern of individual segment activation: right headlight-LED 29,OFF ,6
IDE09569-MAS09862-Bit pattern of individual segment activation: right headlight-LED 30,OFF ,6
IDE09569-MAS09863-Bit pattern of individual segment activation: right headlight-LED 31,OFF ,6
IDE09569-MAS09864-Bit pattern of individual segment activation: right headlight-LED 32,OFF ,6
IDE09569-MAS09865-Bit pattern of individual segment activation: right headlight-LED 33,OFF ,6
IDE09569-MAS09866-Bit pattern of individual segment activation: right headlight-LED 34,OFF ,6
IDE09569-MAS09867-Bit pattern of individual segment activation: right headlight-LED 35,OFF ,6
IDE09569-MAS09868-Bit pattern of individual segment activation: right headlight-LED 36,OFF ,6
IDE09569-MAS09869-Bit pattern of individual segment activation: right headlight-LED 37,OFF ,6
IDE09569-MAS09870-Bit pattern of individual segment activation: right headlight-LED 38,OFF ,6
IDE09569-MAS09871-Bit pattern of individual segment activation: right headlight-LED 39,OFF ,6
IDE09569-MAS09872-Bit pattern of individual segment activation: right headlight-LED 40,OFF ,6
IDE09569-MAS09873-Bit pattern of individual segment activation: right headlight-LED 41,OFF ,6
IDE09569-MAS09874-Bit pattern of individual segment activation: right headlight-LED 42,OFF ,6
IDE09569-MAS09875-Bit pattern of individual segment activation: right headlight-LED 43,OFF ,6
IDE09569-MAS09876-Bit pattern of individual segment activation: right headlight-LED 44,OFF ,6
IDE09569-MAS09877-Bit pattern of individual segment activation: right headlight-LED 45,OFF ,6
ENG124608-Order_Reference_Run_Activation_Effect,No dependency ,1
ENG100660-PWM to Level Scaling Factor Front,3.30 mm/%,2
ENG103748-PWM to Level Scaling Factor Rear,5.30 mm/%,2
ENG124607-Reference_Run_Activation_Effect,Activation effect enabled by motor start ,1
ENG103979-Reference_Run_Start_Condition,Engine start ,1
MasterTommy
Amsterdam
C?ID=295586
If its MQB based, you could try 20103 or 15284
vastechnics
C?ID=143747
Yes it's MQB. I will try this thanks! I will let you know.
cilitkas
LT
hello people, doing the same retrofit, done wiring, replaced BCM, Gateway, AFS module and done all possible coding / adaptation.
i got low and high beam working, no DRL or indicator.
any advice what im missing?
Tuesday,02,April,2019,17:39:20:52461
VCDS Version: 18.9.1.0 (x64)
VIN: weee      License Plate: RS3
Mileage: 1824km-1133mi   Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 2B 3C 42 44 47 52 55 5F
          6C BB BC
VIN: weeee        Mileage: 1824km-1133miles
BB-Door Rear Drv -- Status: Malfunction 0010
Address 01: Engine (------CZGB)       Labels:. 07K-907-309-V1.clb
   Part No SW: 8V0 907 404     HW: 07K 907 309 C
   Component: 2.5l R5/4V TF H52 0005
   Revision: NKH52---
   Coding: 12250032252601033600
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_ECM25TFS0118V0907404 001006
   ROD: EV_ECM25TFS0118V0907404.rod
   VCID: 76E46A5CC90BD0FAF7-8022
9 Faults Found:
17158 - Databus
          U1123 00 [039] - Received Error Message
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:57:39
                    Engine speed: 0.00 /min
                    Coolant temperature: 35 °C
                    Intake air temperature: 9 °C
                    Voltage terminal 30: 12.740 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 5
                    Acceleration: 0.000 m/s²
17149 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [175] - -
                    Fault Frequency: 15
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:56
                    Coolant temperature: 7 °C
                    Intake air temperature: 8 °C
                    Voltage terminal 30: 11.340 V
                    ACC variants-Bits 0-7: 0
                    CCS Switch-Bits 0-7: 1
                    Cruise control switch actuation-Bits 0-7: 0
                    Cruise control switch actuation-Bits 0-7: 49
                    ACC variants (coding)-Bits 0-7: 1
28212 - Exhaust Pressure Control Valve 2
          P049F 00 [047] - Malfunction
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:55
                    Engine status: COENG_READY
19305 - Exhaust Pressure Control Valve
          P0475 00 [047] - Electrical Malfunction
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:55
          U0428 00 [047] - -
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:55
4713 - No Communication with ABS Brake Control Module
          U0121 00 [172] - -
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:31
                    Engine speed: 1508.50 /min
                    Normed load value: 14.9 %
                    Coolant temperature: 6 °C
                    Intake air temperature: 7 °C
                    Voltage terminal 30: 10.380 V
                    selected gear-Bits 0-7: 0
4716 - No Communications with Parking Brake Control Module
          U0128 00 [044] - -
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:54
4651 - Implausible Data Received from ESP Control Module
          U0416 00 [032] - -
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:55
7786 - Sensor for Ambient Air Temperature (G17)
          P0070 00 [036] - Malfunction
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:55
                    Vehicle speed: 255 km/h
                    Coolant temperature: 36 °C
                    Intake air temperature: 29 °C
                    Voltage terminal 30: 11.520 V
Readiness: 1110 0001
   Part No SW: 0DL 300 011 D    HW: 0BH 927 711 F
   Component: GSG DQ500     H10 5210
   Revision: 00H10V01
   ROD: EV_TCMDQ500021.rod
   VCID: 295E71204835CF02AA-807C
10680 - Databus
          U1121 00 [044] - Missing Message
                    Fault Frequency: 14
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:32
                    Engine speed: 1466.00 /min
                    Clutch: primary stat: New
                    selected gear: GANG_R
                    Driving position: P
                    Engine torque: 4 Nm
                    Control Module temperature: 9 °C
                    Accelerator position: 15.2 %
                    DTC memory status: 68
10685 - Databus
                    Fault Frequency: 17
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:54:54
                    Engine speed: 1441.00 /min
                    Clutch: primary stat: Neutral
                    Driving position: P
                    Engine torque: 0 Nm
                    Control Module temperature: 12 °C
                    DTC memory status: 73
   Part No SW: 8V0 907 379 A    HW: 8V0 907 379 A
   Component: ESC           H42 0030
   Revision: 00000000    Serial number: 60956000000021
   Coding: 999CF08DBA9915AF40960068C391920644990F5DA80200C3496022
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 061006
   ROD: EV_Brake1UDSContiMK100IPB_061.rod
   VCID: 428CC68CD5433C5A8B-8016
8 Faults Found:
          C1017 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 53
                    Date: 2019.04.02
                    Time: 19:30:42
          C1079 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 53
                    Date: 2019.04.02
                    Time: 19:30:42
0279 - Brake Pressure Sensor 1
          C107A 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 53
                    Date: 2019.04.02
                    Time: 19:30:42
0295 - Steering angle sensor
          B1168 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 53
                    Date: 2019.04.02
                    Time: 19:30:42
8277 - Databus
                    Reset counter: 53
                    Date: 2019.04.02
                    Time: 19:30:42
8309 - Engine Control Module Incorrectly Coded
          P1612 00 [009] - -
                    Reset counter: 53
                    Date: 2019.04.02
                    Time: 19:30:42
          C1146 02 [137] - Signal Failure
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 19:30:51
33000 - Longitudinal Acceleration
          C10B1 29 [137] - Signal Implausible
                    Reset counter: 53
                    Date: 2019.04.02
                    Time: 19:30:42
   Revision: 00021000    Serial number: 0347604164
   Coding: 030C0C
   VCID: 3A7CBE6CBD93749AD3-806E
1069319 - Wake-Up Signal from Control Module for Access/Start Authorization
          U1093 00 [008] - Short to GND
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:23:27
12713984 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:37:02
   Part No SW: 8V0 820 043 Q    HW: 8V0 820 043 Q
   Component: AC Automat    H03 0110
   Revision: 20001000    Serial number: 00000001021564
   Coding: 03100014000000011000000000001100
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008021
   VCID: 4088CC84DB4F2E4A9D-8014
   Serial number: C6B84057000000000001
131074 - Supply voltage
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:43:20
                    Voltage terminal 30: 8.9 V
                    Outside air temperature: 8 °C
131076 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:43:22
                    Voltage terminal 30: 8.4 V
459012 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:31
459020 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:37:02
459527 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:54
   Part No SW: 5Q0 937 084 CF    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H34 0236
   Serial number: 02001627500223
   Shop #: WSC 06745 128 28888
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7EF4727CE13B98BAAF-802A
   Component: WWS371 140912  042 0585
   Serial number:         140924215426
   Coding: 0A47F7
   Serial number: 23250614
   Coding: 02006C
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Serial number: 26 05 2016  00000710
   Serial number: 00000000000060677680
   Sun Roof:
   Subsystem 5 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.014  H02 0007
   Serial number:     WOO32929111
   Coding: 101F00
264452 - No Communications with Anti-Theft Sensor
          U10F4 00 [009] - -
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 19:31:40
534549 - Databus
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 19:31:41
568836 - Databus
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 19:31:39
   Part No SW: 5Q0 919 294 J    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0051
   Revision: --------    Serial number: 39331426305299
   Coding: 0030150011
7 Faults Found:
13635840 - Supply voltage
                    Reset counter: 93
          U1400 00 [008] - -
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:43:21
12658704 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:54
12656913 - Databus
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:32
12656920 - Databus
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:32
13637426 - Databus
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:54
13637888 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:54
   Serial number: 003GCR00T9BL
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 479AD798FE6119725C-8012
   Belt Pretensioner left:
   Serial number: 34178311B07101440487
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34178312B07101470723
   Coding: 333135
   Occupant Detection:
   Serial number: 6940000Y1400017NV00Y
   Coding: 303230
   Subsystem 4 - Part No SW: -----------    HW: 480 002 909 14
   Serial number: 35700000000F7A34F01R
   Subsystem 5 - Part No SW: -----------    HW: 480 002 909 14
   Serial number: 358000000007AA34F01N
   Subsystem 6 - Part No SW: -----------    HW: 480 402 909 14
   Serial number: 3510002BB175A90091B0
   Subsystem 7 - Part No SW: -----------    HW: 480 401 909 14
   Serial number: 3520002A9176A6C17230
   Subsystem 8 - Part No SW: -----------    HW: 480 400 311 12
   Serial number: 3550002B30CC5BF032AD
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 400 808 14
   Serial number: 35600029916FC22340B4
16 Faults Found:
          B10B3 00 [008] - Function Restriction due to Implausible Message(s)
                    Fault Frequency: 9
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:49
9482752 - Seat Occupied Recognition
          B10B2 00 [008] - Function Restriction due to Missing Message(s)
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:49
          B13BC F2 [008] - No function
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:55
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:15:40
9634838 - Control Module for Front Left Belt Tensioner
          B1304 16 [008] - Voltage Too Low
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:43:31
9635094 - Control Module for Front Right Belt Tensioner
          B1305 16 [008] - Voltage Too Low
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:43:29
1055232 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:34
1054981 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:50:00
1052928 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:34
1049088 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:34
1049093 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:58
1052416 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:34
1052672 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:34
1050117 - Databus
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:55
1049094 - Databus
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:58
1049095 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:58
   Part No SW: 8V0 953 521 CP    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 03101408490168
   Coding: A018
   ROD: EV_SMLSKLOMQB_012_AU37.rod
   VCID: 0A1C2EACADF3A41A83-805E
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
   Part No SW: 8V0 920 790     HW: 8V0 920 790
   Component: FBenRDW       H11 0041
   Coding: 00AD1840EB9000080104EE001000000000000000
   Shop #: WSC 01531 128 28888
   ASAM Dataset: EV_DashBoardFPKAU37X 001023
   ROD: EV_DashBoardFPKAU37X.rod
   VCID: 79FE6160F815BF829A-802C
10 Faults Found:
10485835 - Internal Control Module Memory Check Sum Error
          B2000 41 [009] - General checksum failure
                    Mileage: 24 km
                    Date: 2016.03.17
                    Time: 00:00:01
          U1014 00 [009] - -
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:54
9582600 - Switch for Instrument Cluster
          B1893 13 [009] - Open Circuit
                    Fault Frequency: 18
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:54
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:44:50
16776968 - Databus
                    Fault Frequency: 25
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:31
16776969 - Databus
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:54
16776973 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:58
16776980 - Databus
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:54
16777103 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:23:40
13639936 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:55
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2265
   Revision: --------    Serial number: 11091610802548
   Coding: 01010008200860005B00022C180B00000001010000000000000000000000
   Shop #: WSC 33361 790 00114
   ROD: EV_GatewConti_013_VW37.rod
   VCID: 7CF07874F7278AAA81-8028
   Subsystem 2 - Part No SW: 4S0 951 523 E    HW: 4S0 951 523 E
   Component: J453 MFL  H06 0002
   Serial number: 20151222074848 RD132
131598 - Body Control Module (Central Electric)
          U0140 00 [008] - No Communications
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:23:41
                    Supply voltage: Terminal 30: 12.1 V
                    Terminal 15: OFF
131603 - No Communication with ABS Brake Control Module
          U0121 00 [008] - -
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:19:09
                    Supply voltage: Terminal 30: 10.1 V
                    Terminal 15: OFF
1282 - Supply voltage
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:58:53
                    Supply voltage: Terminal 30: 8.4 V
                    Terminal 15: On
67072 - Local Databus
          U1125 00 [009] - Additional Installations Detected
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:08:01
                    Supply voltage: Terminal 30: 9.7 V
                    Terminal 15: OFF
          U1101 00 [009] - Active
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:25:11
                    Supply voltage: Terminal 30: 10.9 V
                    Terminal 15: On
   Part No SW: 0CQ 907 554 C    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7754
   Serial number: HA1-00017.02.16
   Coding: 0601
   Shop #: WSC 06314 790 00021
   VCID: 4586DD90C46D0B62AE-8010
10 Faults Found:
16655 - Databus
                    Fault Frequency: 15
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:30
17468 - Databus
                    Fault Frequency: 15
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:30
17495 - Databus
                    Fault Frequency: 11
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:30
17501 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:52:25
17471 - Databus
                    Fault Frequency: 11
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:35
17502 - Databus
                    Fault Frequency: 15
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:30
17469 - Databus
                    Fault Frequency: 15
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:30
17470 - Databus
                    Fault Frequency: 15
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:30
17504 - Databus
                    Fault Frequency: 11
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:30
17505 - Databus
                    Fault Frequency: 8
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:31:26
   Revision: 00000000    Serial number: 14000270884002
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 346090549FF782EA09-8060
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:57:45
                    ELV State: 04
                    Information Clamps: 77 60
                    CoCo State: E0 01
                    WFS State: 17 06
                    Vehicle speed: 655.34 km/h
                    Voltage: 47
                    AD-Value H-bridge: 23
                    Clamp15 flip flop: SSTx: button contacts: 06
                    CAN signals: 05
          U1400 00 [008] - -
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:43:20
                    ELV State: 04
                    CoCo State: E0 01
                    WFS State: 17 06
                    Voltage: 4C
                    AD-Value H-bridge: 25
                    CAN signals: 05
12665088 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:23:38
                    ELV State: 04
                    Information Clamps: 00 00
                    CoCo State: E0 01
                    WFS State: 00 06
                    Voltage: 67
                    AD-Value H-bridge: 33
                    CAN signals: 05
12665089 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:23:38
                    ELV State: 04
                    CoCo State: E0 01
                    WFS State: 00 06
                    Voltage: 66
                    CAN signals: 05
12666370 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:33
                    ELV State: 04
                    CoCo State: E0 01
                    WFS State: 1F 06
                    Voltage: 72
                    AD-Value H-bridge: 37
                    CAN signals: 05
   Part No SW: 5Q0 907 566 A    HW: 8T0 907 566 B
   Serial number: 0346835485
   Coding: 030211
   ROD: EV_LaneChangAssis_VW51.rod
   VCID: 3878A464839F668A25-806C
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 5Q0 907 568 A    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0071
   Serial number: 0346892700
   Coding: 030211
336901 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:31
   Serial number: 19091406070881
   Coding: 005D1F205C00048000000002
65548 - Supply voltage
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:46:47
65571 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:37:02
65573 - Local Data Bus
          U10BA 00 [008] - No Communication
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:37:02
458776 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:32
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Coding: 0002
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 3566AD50948D9BE23E-8060
8 Faults Found:
15873 - Steering angle sensor
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:53
                    Motor status: 00
                    Supply voltage: 11.25 V
                    Temperature: 15.0 °C
                    KFC: 3E
                    KFA: 00 01
                    Environmental conditions: 5B
                    uioUdNotFilt_xdu16: 11.30 V
                    uAdSensI_SwitchedKl30_xdu16: 11.29 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
19200 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:54:54
                    Motor status: 01
                    System status: Driving mode
                    Supply voltage: 11.00 V
                    Temperature: 17.0 °C
                    KFC: 4B
                    KFA: 00 00
                    Environmental conditions: 21
                    uioUdNotFilt_xdu16: 11.27 V
                    uAdSensI_SwitchedKl30_xdu16: 11.27 V
19712 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:32
                    Motor status: 01
                    Supply voltage: 10.50 V
                    Temperature: 8.0 °C
                    KFC: 4D
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 10.73 V
                    uAdSensI_SwitchedKl30_xdu16: 10.74 V
20224 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:32
                    Motor status: 01
                    Temperature: 8.0 °C
                    KFC: 4F
                    KFA: 00 00
20992 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:32
                    Motor status: 01
                    Temperature: 8.0 °C
                    KFC: 52
                    KFA: 00 00
19456 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:32
                    Motor status: 01
                    Temperature: 8.0 °C
                    KFC: 4C
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 10.45 V
                    uAdSensI_SwitchedKl30_xdu16: 10.44 V
20736 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:32
                    Motor status: 01
                    Temperature: 8.0 °C
                    KFC: 51
                    KFA: 00 00
20480 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:36
                    Motor status: 02
                    Supply voltage: 14.00 V
                    Temperature: 8.0 °C
                    KFC: 50
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 14.09 V
                    uAdSensI_SwitchedKl30_xdu16: 14.08 V
   Part No SW: 8V0 035 465 C    HW: 8V0 035 465
   Component: MIBAMP1ALPINE H11 0410
   Serial number: AUZ8ZAEN900QK6B
   Coding: 01030300AAAA2AAA01
   ASAM Dataset: EV_AMPMst16C1ALPI 004024
   ROD: EV_AMPMst16C1ALPI_004_AU37.rod
6693 - Databus
                    Fault Frequency: 14
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:36
                    Voltage terminal 30: 13.2 V
          U1400 00 [008] - -
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:38:13
                    Voltage terminal 30: 8.0 V
   Serial number: 21091401100625
   Coding: 005D17205E00048000000002
   VCID: 3F8ACF78A6B151B2E4-806A
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:46:49
65604 - Door Warning Lamp
          B1326 01 [009] - Electrical Failure
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 16:46:03
458776 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:32
   Component: AFS-ECU       H01 0091
   Coding: 012E000123200400
   ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
9 Faults Found:
13705472 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:25:08
          U1014 00 [137] - -
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:54:58
5276145 - Power Output Module for Left Headlamp
          C1081 F1 [137] - Incorrectly Coded
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:54:58
5276401 - Power Output Module for Right Headlamp
          C1082 F1 [137] - Incorrectly Coded
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:54:58
5545009 - LED Headlamp Power Output Stage; Left
          B149C 31 [137] - No Signal
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:25:09
5544753 - LED Headlamp Power Output Stage; Right
          B149B 31 [137] - No Signal
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:25:09
5275953 - Power Output Module for Left Headlamp
          C1081 31 [137] - No Signal
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:25:08
5276209 - Power Output Module for Right Headlamp
          C1082 31 [137] - No Signal
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:25:08
13705992 - Databus
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:25:08
   Part No SW: 8V1 035 035     HW: 8V1 035 035
   Component: MU-P-LND-EU   052 1168
   Serial number: A698G0G7505904
   Coding: 017351010000000011111102000A00332F0028E701700100DE
   VCID: 6FEA5F38B651E13234-803A
   Subsystem 1 - Part No SW: V03 959 801 FD    HW: -----------
   Component: ECE 2017/2018  --- 0161
   Component: DU High  H49 0013
   Serial number: AUZ8Z9EY201S6F
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 BJ    HW: 8V0 919 614 BJ
   Component: ControlUnit_H  H85 0855
   Serial number: ALJAL131051600010388
   Compact Disc Database:
   Component: Gracenote2  --- 1013
11 Faults Found:
1537 - Supply voltage
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:46:42
                    Voltage terminal 30: 8.7 V
          U1400 00 [008] - -
                    Fault Frequency: 13
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:43:24
          B201A 00 [009] -  -
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:50:01
                    Voltage terminal 30: 11.4 V
                    Status_Software_Version_Management-module_name: MFC2H37xE/HREU
          B2000 87 [009] - Missing message
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:50:13
                    Software module: status-SW_Status_Consistency: 00 00 12
                    Software module: status-SW_Status_Device:
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:56
                    Voltage terminal 30: 11.5 V
1637 - Interface for External Media
          U11B8 00 [009] - No Communications
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:56
                    Interface for external media: status-Status: Open circuit
0012 - Digital Radio Antenna
          B1103 11 [009] - Short to Ground
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:56
                    Status of digital radio antenna 1-Antenna current: 0 mA
                    Status of digital radio antenna 1-Connection between radio and antenna amplifier: Short circuit
                    Status of digital radio antenna 1-Connection between antenna amplifier and antenna: Not available
                    Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC: 16.777215
                    Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC: 16.777215
3077 - Telephone baseplate
          B1051 13 [009] - Open Circuit
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:55
6702 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:40
                    Voltage terminal 30: 14.2 V
                    Network diagnosis-Status: Enabled
          U1111 00 [008] - -
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:58
                    BAP-BAP_Function_ID: 02
7191 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:58
   Coding: 027300010201000300
   ROD: EV_2CamSysRearPASE_AU37.rod
   VCID: 30689C446BEFBECA6D-8064
7 Faults Found:
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:54:09
                    CAN communication
13705476 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:32
                    CAN communication
13705491 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:32
                    CAN communication
13705492 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:33
                    CAN communication
13705493 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:32
                    CAN communication
9529428 - Steering angle sensor
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:54
                    passive
327936 - Vehicle Speed Sensor
          P0501 00 [008] - Implausible Signal
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:32
                    CAN communication
   Part No SW: 5Q0 959 395 B    HW: 5Q0 959 395 B
   Component: TSG HFS       020 0025
   Serial number: 01101402090316
   Coding: 004D17204000048000000002
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:46:50
   Component: TSG HBFS      020 0025
   Serial number: 01101401100323
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:46:50
;SW:5Q0-937-084-CF   HW:5Q0-937-084-CF ---  Cent. Elect.
;Component:BCM MQBAB M+  H34 0236, Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BCMMQB,017001,EV_BCMBOSCH_017.rod
;Thursday,04,April,2019,17:12:53:52461
;VCDS Version: Release 18.9.1 (x64)  Data version: 20190114 DS296.0
;VCID: 7EF4727CE13B98BAAF-802A
IDE00001-ENG115730-Production mode-Aussenbeleuchtung,not active ,3
IDE01550-Service position,133.296571 °,2
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal ,10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,not active ,10
IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit,300 ms,10
IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit,300 ms,10
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit,300 ms,10
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,not active ,8
IDE02711-ENG133397-Rear Window Wiper-Einzelansteuerung Heckintervallwischen,not active ,8
IDE02711-ENG133395-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1,8 s,8
IDE02711-ENG133396-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2,16 s,8
IDE02711-ENG112304-Rear Window Wiper-Heckwischer,logikgesteuert ,8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,3 s,8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,1 s,8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,5 s,8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,5 s,8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,not active ,8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,not active ,8
IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck,1000 ms,8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,-0.3 °,16
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s,16
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,OFF ,16
IDE03638-ENG116675-static AFS light-Lower speed threshold,0.0 km/h,16
IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.0 °C,16
IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.0 °C,16
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,90 °,16
IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.0 °C,16
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,30 °,16
IDE03638-ENG116676-static AFS light-Upper speed threshold,32.0 km/h,16
IDE03638-ENG116674-static AFS light-Vorschrift,OFF ,16
IDE03638-ENG115830-static AFS light-Zeitwert Einschaltzeit Abbiegelicht,15 min,16
IDE03787-Activate left/right hand drive switch-over,active ,1
IDE04927-IDE01446-Window heater-Running time of heated front window,600 s,11
IDE04927-ENG126845-Window heater-FSH Automatik,not active ,11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,not active ,11
IDE04928-MAS01577-Anti-theft device-Parking heater,not installed ,8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,8
IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated ,8
IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system,active ,8
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,driver door contact thatcham ,8
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,8
IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder,Sounder_verbaut ,8
IDE04928-ENG141961-Anti-theft device-Heckscheibenbruchsensor,not installed ,8
IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet,No ,8
IDE04928-ENG142249-Anti-theft device-OBD Alarm,not_active ,8
IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv),No ,8
IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung,Yes ,8
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,8
IDE04928-ENG142008-Anti-theft device-tilt_sensor,Yes ,8
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel,not active ,8
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,8
IDE05145-Light configuration,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2E 00 00 04 2E 00 64 00 00 00 00 00 00 00 00 00 24 00 00 61 49 00 7F 00 00 00 00 00 00 00 00 00 24 00 00 62 4A 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 36 00 1A 0B 00 7F 1E 00 7F 00 00 00 00 00 00 06 40 00 1B 0C 00 7F 1E 00 7F 00 00 00 00 00 00 06 44 00 4B 46 00 7F 08 0A 7F 00 00 00 00 00 00 06 3A 00 49 46 00 7F 08 09 7F 00 00 00 00 00 00 04 45 00 1E 46 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 36 00 5D 28 1E 7F 00 00 00 00 00 00 00 00 00 06 40 00 5E 28 1E 7F 00 00 00 00 00 00 00 00 00 ,224
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,28.00 °C,30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,27.50 °C,30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,28.00 °C,30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,27.50 °C,30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,41.00 °C,30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,40.50 °C,30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,41.00 °C,30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,40.50 °C,30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,63.00 °C,30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,62.50 °C,30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,63.00 °C,30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,62.50 °C,30
IDE06507-MAS13132-Button in center console-Function of button 3,Driving program ,8
IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED,LED not installed ,8
IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich,active ,8
IDE07007-ENG142252-A/C heater function via remote control-Abbruch_Hupen_RSt,not active ,8
IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige,active ,8
IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik,active ,8
IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active ,8
IDE07007-ENG115720-A/C heater function via remote control-Remote Start,not installed ,8
IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung,active ,8
IDE07356-Position during interval mode,21.692286 °,2
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein,not active ,6
IDE08786-ENG124476-Assistance light functions-Sunlight Sensor,not installed ,9
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.00 s,19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,0 ,19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,0 ,19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,0 ,19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,0 %,19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,0 ,19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,0 %,19
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,0 %,19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,0 %,19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,0 %,19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,not active ,19
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,not active ,19
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen,active ,19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten,not active ,19
IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM,active ,19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,not active ,19
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI,not active ,5
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,not installed ,5
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher,installed ,5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,5
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,installed ,5
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,installed ,5
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %,17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %,17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %,17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %,17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %,17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %,17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %,17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %,17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %,17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,not installed ,17
IDE10298-Alternating park position 1,18.692289 °,2
IDE10299-Alternating park position 2,21.692286 °,2
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,1.00 ,256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,1.00 ,256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,1.00 ,256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000000  ,256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00000000  ,256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00000000  ,256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,100 %,256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,100 %,256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,100 %,256
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum,100 %,256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,100 %,256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,100 %,256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,100 %,256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,100 %,256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,100 %,256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,100 %,256
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,100 %,256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,100 %,256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,126 %,256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,100 %,256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,100 %,256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,100 %,256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,100 %,256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,100 %,256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,100 %,256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,100 %,256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,100 %,256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,100 %,256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,100 %,256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,100 %,256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,100 %,256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,0.0 s,256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1,225 ,30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,225 ,30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2,225 ,30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3,225 ,30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,225 ,30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,225 ,30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,225 ,30
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7,225 ,30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,225 ,30
IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9,225 ,30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1,225 ,30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,225 ,30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2,225 ,30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3,225 ,30
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4,225 ,30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,225 ,30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,225 ,30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,225 ,30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,225 ,30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,225 ,30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1,225 ,30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,225 ,30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2,225 ,30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3,225 ,30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,225 ,30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,225 ,30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,225 ,30
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7,225 ,30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,225 ,30
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9,225 ,30
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung,active ,3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung,active ,3
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin,0 ,30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin,0 ,30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin,0 ,30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin,0 ,30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin,0 ,30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin,0 ,30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin,0 ,30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin,0 ,30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin,0 ,30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin,0 ,30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin,0 ,30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin,0 ,30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin,0 ,30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin,0 ,30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin,0 ,30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin,0 ,30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin,0 ,30
MAS05055-lower turn position,27.692280 °,2
MAS05056-upper turn position,166.296538 °,2
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,1000 lx,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,2000 lx,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,4500 mV,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,2000 mV,24
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,4
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,0.00 ,30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,0.00 ,30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,0.00 ,30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,0.00 ,30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,0.00 ,30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,0.00 ,30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,0.00 ,30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,0.00 ,30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,0.00 ,30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,0.00 ,30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,0.00 ,30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,0.00 ,30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,0.00 ,30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,0.00 ,30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,0.00 ,30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,NOT-DEFINED ,30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,NOT-DEFINED ,30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,NOT-DEFINED ,30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,NOT-DEFINED ,30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,NOT-DEFINED ,30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,NOT-DEFINED ,30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,NOT-DEFINED ,30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,NOT-DEFINED ,30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,NOT-DEFINED ,30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,NOT-DEFINED ,30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,NOT-DEFINED ,30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,NOT-DEFINED ,30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,NOT-DEFINED ,30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,NOT-DEFINED ,30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,NOT-DEFINED ,30
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,00 ,60
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken,active ,10
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken,active ,10
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung,active ,10
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing,active ,10
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,active ,10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,active ,10
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken,active ,10
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing,active ,10
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,active ,10
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken,active ,10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,active ,10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,active ,10
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf,active ,10
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu,active ,10
ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL,4 km/h,9
ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,active ,9
ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument,active ,9
ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,active ,9
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,60 km/h,5
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights,installed ,18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,not active ,18
ENG141656-ENG133382-Außenlicht_uebergreifend-Faktor fuer Verfügbarkeitstimer,Faktor fuer x1 Stunden ,18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,6400 lx,18
ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht,separate ,18
ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS),LIN ,18
ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO,Menuesteuerung aktivieren ,18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome,20 seconds ,18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,60 seconds ,18
ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit,8 s,18
ENG122934-erase_error_table,55 00 00 ,3
ENG122933-error_mask,0 bit,2
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,AFS: FLA: Fernlicht ueber AFS ,6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,Not Present ,6
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung,Not Present ,6
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA,active ,6
ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung,500 ms,6
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf,not active ,6
ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer,2000 ms,6
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status,active ,6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung,not active ,6
ENG99457-ENG117394-Head area heater-blower_speed,0 ,2
ENG99457-ENG98971-Head area heater-Temperature,-3 ,2
ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15,not active ,8
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0,-0.00 %,30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,-0.10 %,30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,-0.60 %,30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,-1.10 %,30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,-1.60 %,30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,-2.10 %,30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,-2.60 %,30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,-3.10 ,30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,-3.60 %,30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9,-4.10 %,30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,100.0 %,30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,89.5 %,30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,83.0 %,30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,75.5 %,30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,68.0 %,30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,61.0 %,30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,56.5 %,30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,47.0 %,30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,40.0 %,30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,33.0 %,30
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,63 ,16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15,Unknown (76),16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,127 ,16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,1E ,16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,45 ,16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,4 - LED Tagfahrlichtmodul Signal ,16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,Versorgungsbedarf der LCM Module ,16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,127 ,16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,5D ,16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,36 ,16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,6 - LED Lichtmodul ,16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Klemme 15 mit Nachlauf bis Fahrzeugstillstand ,16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,Coming Home oder Leaving Home aktiv ,16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,127 ,16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,5E ,16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,40 ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,6 - LED Lichtmodul ,16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Klemme 15 mit Nachlauf bis Fahrzeugstillstand ,16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,Coming Home oder Leaving Home aktiv ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,41 ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00 ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,38 - LED Blinkleuchten ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Blinken links Hellphase ,16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,Blinken links Dunkelphase ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,127 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,42 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00 ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,38 - LED Blinkleuchten ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Blinken rechts Hellphase ,16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,Blinken rechts Dunkelphase ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,127 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,Blinken links Dunkelphase ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,127 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,Blinken rechts Dunkelphase ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,100 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,04 ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,46 - LED Kleinleistung ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Ambientelicht 2 ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,0 ,16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,127 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,39 - LED Bremsleuchten ,16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,not active ,16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,Brake light ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,0 ,16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,127 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,39 - LED Bremsleuchten ,16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,not active ,16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,Brake light ,16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,127 ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,127 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,127 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,37 - allgemeine LED bis 12W ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Coming Home oder Leaving Home aktiv ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,127 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,37 - allgemeine LED bis 12W ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Coming Home oder Leaving Home aktiv ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Parking light right ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,100 ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,37 - allgemeine LED bis 12W ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,100 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,2F ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,1C ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,37 - allgemeine LED bis 12W ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,37 - allgemeine LED bis 12W ,16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,127 ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,37 - allgemeine LED bis 12W ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,127 ,16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,61 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,36 - LED Kleinleistung ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Unknown (73),16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,46 - LED Kleinleistung ,16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,100 ,16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,100 ,16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,Ambientelicht 2 ,16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,100 ,16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,Ambientelicht 3 ,16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,100 ,16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,Ambientelicht 4 ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,127 ,16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,62 ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,36 - LED Kleinleistung ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Unknown (74),16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,0 ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,not active ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,not active ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,0 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,not active ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,not active ,16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,6 - LED Lichtmodul ,16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,6 - LED Lichtmodul ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,4B ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,44 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,6 - LED Lichtmodul ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,Parking light right ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,49 ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,3A ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,6 - LED Lichtmodul ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,26 08 00 16 02 00 7F 03 00 00 00 00 00 00 00 00 26 18 00 18 04 00 7F 05 00 00 00 00 00 00 00 00 27 09 00 2B 00 00 00 00 00 00 18 00 7F 00 00 00 27 19 00 2D 00 00 00 00 00 00 18 00 7F 00 00 00 2A 29 00 2C 18 00 7F 00 00 00 00 00 00 00 00 00 25 0A 00 29 08 1E 7F 09 00 7F 00 00 00 00 00 00 25 1A 00 2A 08 1E 7F 0A 00 7F 00 00 00 00 00 00 2B 28 00 30 08 1E 7F 00 00 00 00 00 00 00 00 00 25 0C 00 2E 1A 00 64 00 00 00 00 00 00 00 00 00 25 1C 00 2F 1A 00 64 00 00 00 00 00 00 00 00 00 25 0B 00 31 19 00 7F 00 00 00 00 00 00 00 00 00 25 1B 00 32 19 00 7F 00 00 00 00 00 00 00 00 00 ,192
ENG141662-Leuchtenkonfiguration_Sonstiges,26 00 00 41 02 00 7F 03 00 00 00 00 00 00 00 00 26 00 00 42 04 00 7F 05 00 00 00 00 00 00 00 00 2E 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 03 2D 00 64 00 00 00 00 00 00 00 00 00 00 00 00 04 2E 00 64 00 00 00 00 00 00 00 00 00 00 00 00 05 2F 00 64 00 00 00 00 00 00 00 00 00 00 00 00 06 30 00 64 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,2650 mm,62
ENG141658-ENG142218-Leuchtweitenregulierung-Achssensor_PWM_Wert_Einfederung_Sensor_H4,4.50 mm/%,62
ENG141658-ENG142217-Leuchtweitenregulierung-Achssensor_PWM_Wert_Einfederung_Sensor_vorn,3.30 mm/%,62
ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe,active ,62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,84.0 %,62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,20.0 %,62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,4.10 mm/%,62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,4.70 mm/%,62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,3.30 mm/%,62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,3.30 mm/%,62
ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante,2: Variante 3 (Mehrlenkerhinterachse 4-Motion ,62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR,70.0 %,62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf,0.10 Hz,62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung,1 ,62
ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1,10 mm,62
ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2,10 mm,62
ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3,10 mm,62
ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4,10 mm,62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,5 km/h,62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung,10.00 Hz,62
ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte,CAN_Daempferregelung ,62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,not installed ,62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,not active ,62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,60.0 %,62
ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart,active ,62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,5.0 %/s,62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht,20.0 %,62
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0,-0.00 %,20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1,-0.30 %,20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2,-0.80 %,20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3,-1.80 %,20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4,-2.10 %,20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0,0.30 ,20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1,-0.00 ,20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2,0.62 ,20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3,0.80 ,20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-0.70 ,20
ENG124714-ENG142261-OCU-Remote HuF Abbruch,0 km/h,8
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz,0 ,8
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1,0 s,8
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3,0.0 ms,8
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten,0 ,16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_inactive ,16
ENG98831-ENG142030-Personalization-Profil_Variante,Schluessel ,16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1,not active ,16
ENG141646-MAS01065-Querschnitts_funktionen-Brand,Audi ,5
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung,not active ,5
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus,Pin 31 ,5
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme,installed ,5
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,100 lx,1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,200 lx,1
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,8 ,10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system,installed ,10
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel,active ,10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,1000 ms,10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,1200 ms,10
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit,1000 ms,10
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit,1000 ms,10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,1200 ms,10
ENG141684-SFT271873-Slave_systems_identification-Control Unit For Wiper Motor,Not available ,6
ENG141684-SFT271874-Slave_systems_identification-Rain Light Recognition Sensor,Not available ,6
ENG141684-SFT271877-Slave_systems_identification-Garage Door Opener Operating Unit,Not available ,6
ENG141684-SFT271894-Slave_systems_identification-Sensor For Anti Theft Alarm System,Not available ,6
ENG141684-SFT271904-Slave_systems_identification-Sun Roof,Not available ,6
ENG141684-SFT271910-Slave_systems_identification-Ceiling Light Module,Not available ,6
ENG141684-SFT271928-Slave_systems_identification-Roof Blind,Not available ,6
ENG141684-SFT271947-Slave_systems_identification-Relative Air Humidity Interior Sender,Not available ,6
ENG141684-SFT271966-Slave_systems_identification-Neck Heating Left,Not available ,6
ENG141684-SFT271967-Slave_systems_identification-Neck Heating Right,Not available ,6
ENG141684-SFT272065-Slave_systems_identification-Seat Backrest Fan 1 Front Left,Not available ,6
ENG141684-SFT272067-Slave_systems_identification-Seat Cushion Fan 1 Front Left,Not available ,6
ENG141684-SFT272069-Slave_systems_identification-Seat Backrest Fan 1 Front Right,Not available ,6
ENG141684-SFT272071-Slave_systems_identification-Seat Cushion Fan 1 Front Right,Not available ,6
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen,not active ,5
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,not active ,5
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung,not active ,5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,not active ,5
ENG141663-ENG142236-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xs PWM,0.00 s,21
ENG141663-ENG142238-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xt PWM,0.00 s,21
ENG141663-ENG142239-Suchbeleuchtung_allgemein-Daempfung Aufdimmen KL 58xd PWM,0.00 s,21
ENG141663-ENG142237-Suchbeleuchtung_allgemein-Daempfung Aufdimmen KL 58xt PWM,0.00 s,21
ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung,Potentiometer ,21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,0.0 s,21
ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten,active ,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,5 ,21
ENG141663-ENG142235-Suchbeleuchtung_allgemein-PWM Daempfung Aufdimmen KL58xs PWM,0.00 s,21
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert,50 %,21
ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor,0.248 ,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,1.0 %,21
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,6.0 %,12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,6.0 %,12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,16.0 %,12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,30.0 %,12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,60.0 %,12
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen,active ,4
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,active ,4
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1,installed ,4
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck,not active ,9
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb,active ,9
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf,active ,9
ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden,nur wenn freigegeben ,9
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung,not active ,9
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy,not active ,9
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung,not active ,9
ENG141634-ENG142258-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba,not active ,9
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,42 ,3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,62 ,3
ENG141651-ENG115755-ZV allgemein-Notschließfunktion,not active ,7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion,not installed ,7
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,active ,4
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash,active ,4
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,via_CAN ,7
ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste,No ,7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Pulse control ,7
ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,active ,7
ENG141681-IDE02022-ZV Komfort-Comfort opening,not active ,8
ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen,not active ,8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,not active ,8
ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss,Tuersteuergeraet im Fond verbaut oder keine Fondtuer ,5
Elapsed Time: 02:04
cilitkas
LT
;SW:8V0-907-357-A   HW:7P6-907-357-B ---  Headlight Range
;Component:MxB-ECU       001 0230, Coding:0EDE00102B200200
;EV_HeadlRegulAUDIMXBAU64X,005014,EV_HeadlRegulAUDIMXBAU64X_005_AU37.rod
;Thursday,04,April,2019,17:29:40:52461
;VCDS Version: Release 18.9.1 (x64)  Data version: 20190114 DS296.0
;VCID: 3E74B27CA1BB58BAEF-806A
IDE01996-SFT00041-Installation list: specified installations-Light Control Left,Yes ,1
IDE01996-SFT00057-Installation list: specified installations-Light Control Right,Yes ,1
IDE01996-SFT00085-Installation list: specified installations-Headlight Regulation,Yes ,1
IDE01996-SFT00214-Installation list: specified installations-Light Control Left 2,Yes ,1
IDE01996-SFT00215-Installation list: specified installations-Light Control Right 2,Yes ,1
IDE03641-Presentation run dynamic AFS light,not active ,1
IDE03787-Activate left/right hand drive switch-over,active ,1
IDE08418-Matrix light: total dimming,100.8 ,1
IDE09156-Matrix headlamp: function at standstill,not active ,1
IDE09568-MAS09833-Bit pattern of individual segment activation: left headlight-LED 1,OFF ,6
IDE09568-MAS09834-Bit pattern of individual segment activation: left headlight-LED 2,OFF ,6
IDE09568-MAS09835-Bit pattern of individual segment activation: left headlight-LED 3,OFF ,6
IDE09568-MAS09836-Bit pattern of individual segment activation: left headlight-LED 4,OFF ,6
IDE09568-MAS09837-Bit pattern of individual segment activation: left headlight-LED 5,OFF ,6
IDE09568-MAS09838-Bit pattern of individual segment activation: left headlight-LED 6,OFF ,6
IDE09568-MAS09839-Bit pattern of individual segment activation: left headlight-LED 7,OFF ,6
IDE09568-MAS09840-Bit pattern of individual segment activation: left headlight-LED 8,OFF ,6
IDE09568-MAS09841-Bit pattern of individual segment activation: left headlight-LED 9,OFF ,6
IDE09568-MAS09842-Bit pattern of individual segment activation: left headlight-LED 10,OFF ,6
IDE09568-MAS09843-Bit pattern of individual segment activation: left headlight-LED 11,OFF ,6
IDE09568-MAS09844-Bit pattern of individual segment activation: left headlight-LED 12,OFF ,6
IDE09568-MAS09845-Bit pattern of individual segment activation: left headlight-LED 13,OFF ,6
IDE09568-MAS09846-Bit pattern of individual segment activation: left headlight-LED 14,OFF ,6
IDE09568-MAS09847-Bit pattern of individual segment activation: left headlight-LED 15,OFF ,6
IDE09568-MAS09848-Bit pattern of individual segment activation: left headlight-LED 16,OFF ,6
IDE09568-MAS09849-Bit pattern of individual segment activation: left headlight-LED 17,OFF ,6
IDE09568-MAS09850-Bit pattern of individual segment activation: left headlight-LED 18,OFF ,6
IDE09568-MAS09851-Bit pattern of individual segment activation: left headlight-LED 19,OFF ,6
IDE09568-MAS09852-Bit pattern of individual segment activation: left headlight-LED 20,OFF ,6
IDE09568-MAS09853-Bit pattern of individual segment activation: left headlight-LED 21,OFF ,6
IDE09568-MAS09854-Bit pattern of individual segment activation: left headlight-LED 22,OFF ,6
IDE09568-MAS09855-Bit pattern of individual segment activation: left headlight-LED 23,OFF ,6
IDE09568-MAS09856-Bit pattern of individual segment activation: left headlight-LED 24,OFF ,6
IDE09568-MAS09857-Bit pattern of individual segment activation: left headlight-LED 25,OFF ,6
IDE09568-MAS09858-Bit pattern of individual segment activation: left headlight-LED 26,OFF ,6
IDE09568-MAS09859-Bit pattern of individual segment activation: left headlight-LED 27,OFF ,6
IDE09568-MAS09860-Bit pattern of individual segment activation: left headlight-LED 28,OFF ,6
IDE09568-MAS09861-Bit pattern of individual segment activation: left headlight-LED 29,OFF ,6
IDE09568-MAS09862-Bit pattern of individual segment activation: left headlight-LED 30,OFF ,6
IDE09568-MAS09863-Bit pattern of individual segment activation: left headlight-LED 31,OFF ,6
IDE09568-MAS09864-Bit pattern of individual segment activation: left headlight-LED 32,OFF ,6
IDE09568-MAS09865-Bit pattern of individual segment activation: left headlight-LED 33,OFF ,6
IDE09568-MAS09866-Bit pattern of individual segment activation: left headlight-LED 34,OFF ,6
IDE09568-MAS09867-Bit pattern of individual segment activation: left headlight-LED 35,OFF ,6
IDE09568-MAS09868-Bit pattern of individual segment activation: left headlight-LED 36,OFF ,6
IDE09568-MAS09869-Bit pattern of individual segment activation: left headlight-LED 37,OFF ,6
IDE09568-MAS09870-Bit pattern of individual segment activation: left headlight-LED 38,OFF ,6
IDE09568-MAS09871-Bit pattern of individual segment activation: left headlight-LED 39,OFF ,6
IDE09568-MAS09872-Bit pattern of individual segment activation: left headlight-LED 40,OFF ,6
IDE09568-MAS09873-Bit pattern of individual segment activation: left headlight-LED 41,OFF ,6
IDE09568-MAS09874-Bit pattern of individual segment activation: left headlight-LED 42,OFF ,6
IDE09568-MAS09875-Bit pattern of individual segment activation: left headlight-LED 43,OFF ,6
IDE09568-MAS09876-Bit pattern of individual segment activation: left headlight-LED 44,OFF ,6
IDE09568-MAS09877-Bit pattern of individual segment activation: left headlight-LED 45,OFF ,6
IDE09569-MAS09833-Bit pattern of individual segment activation: right headlight-LED 1,OFF ,6
IDE09569-MAS09834-Bit pattern of individual segment activation: right headlight-LED 2,OFF ,6
IDE09569-MAS09835-Bit pattern of individual segment activation: right headlight-LED 3,OFF ,6
IDE09569-MAS09836-Bit pattern of individual segment activation: right headlight-LED 4,OFF ,6
IDE09569-MAS09837-Bit pattern of individual segment activation: right headlight-LED 5,OFF ,6
IDE09569-MAS09838-Bit pattern of individual segment activation: right headlight-LED 6,OFF ,6
IDE09569-MAS09839-Bit pattern of individual segment activation: right headlight-LED 7,OFF ,6
IDE09569-MAS09840-Bit pattern of individual segment activation: right headlight-LED 8,OFF ,6
IDE09569-MAS09841-Bit pattern of individual segment activation: right headlight-LED 9,OFF ,6
IDE09569-MAS09842-Bit pattern of individual segment activation: right headlight-LED 10,OFF ,6
IDE09569-MAS09843-Bit pattern of individual segment activation: right headlight-LED 11,OFF ,6
IDE09569-MAS09844-Bit pattern of individual segment activation: right headlight-LED 12,OFF ,6
IDE09569-MAS09845-Bit pattern of individual segment activation: right headlight-LED 13,OFF ,6
IDE09569-MAS09846-Bit pattern of individual segment activation: right headlight-LED 14,OFF ,6
IDE09569-MAS09847-Bit pattern of individual segment activation: right headlight-LED 15,OFF ,6
IDE09569-MAS09848-Bit pattern of individual segment activation: right headlight-LED 16,OFF ,6
IDE09569-MAS09849-Bit pattern of individual segment activation: right headlight-LED 17,OFF ,6
IDE09569-MAS09850-Bit pattern of individual segment activation: right headlight-LED 18,OFF ,6
IDE09569-MAS09851-Bit pattern of individual segment activation: right headlight-LED 19,OFF ,6
IDE09569-MAS09852-Bit pattern of individual segment activation: right headlight-LED 20,OFF ,6
IDE09569-MAS09853-Bit pattern of individual segment activation: right headlight-LED 21,OFF ,6
IDE09569-MAS09854-Bit pattern of individual segment activation: right headlight-LED 22,OFF ,6
IDE09569-MAS09855-Bit pattern of individual segment activation: right headlight-LED 23,OFF ,6
IDE09569-MAS09856-Bit pattern of individual segment activation: right headlight-LED 24,OFF ,6
IDE09569-MAS09857-Bit pattern of individual segment activation: right headlight-LED 25,OFF ,6
IDE09569-MAS09858-Bit pattern of individual segment activation: right headlight-LED 26,OFF ,6
IDE09569-MAS09859-Bit pattern of individual segment activation: right headlight-LED 27,OFF ,6
IDE09569-MAS09860-Bit pattern of individual segment activation: right headlight-LED 28,OFF ,6
IDE09569-MAS09861-Bit pattern of individual segment activation: right headlight-LED 29,OFF ,6
IDE09569-MAS09862-Bit pattern of individual segment activation: right headlight-LED 30,OFF ,6
IDE09569-MAS09863-Bit pattern of individual segment activation: right headlight-LED 31,OFF ,6
IDE09569-MAS09864-Bit pattern of individual segment activation: right headlight-LED 32,OFF ,6
IDE09569-MAS09865-Bit pattern of individual segment activation: right headlight-LED 33,OFF ,6
IDE09569-MAS09866-Bit pattern of individual segment activation: right headlight-LED 34,OFF ,6
IDE09569-MAS09867-Bit pattern of individual segment activation: right headlight-LED 35,OFF ,6
IDE09569-MAS09868-Bit pattern of individual segment activation: right headlight-LED 36,OFF ,6
IDE09569-MAS09869-Bit pattern of individual segment activation: right headlight-LED 37,OFF ,6
IDE09569-MAS09870-Bit pattern of individual segment activation: right headlight-LED 38,OFF ,6
IDE09569-MAS09871-Bit pattern of individual segment activation: right headlight-LED 39,OFF ,6
IDE09569-MAS09872-Bit pattern of individual segment activation: right headlight-LED 40,OFF ,6
IDE09569-MAS09873-Bit pattern of individual segment activation: right headlight-LED 41,OFF ,6
IDE09569-MAS09874-Bit pattern of individual segment activation: right headlight-LED 42,OFF ,6
IDE09569-MAS09875-Bit pattern of individual segment activation: right headlight-LED 43,OFF ,6
IDE09569-MAS09876-Bit pattern of individual segment activation: right headlight-LED 44,OFF ,6
IDE09569-MAS09877-Bit pattern of individual segment activation: right headlight-LED 45,OFF ,6
ENG124608-Order_Reference_Run_Activation_Effect,No dependency ,1
ENG100660-PWM to Level Scaling Factor Front,3.30 mm/%,2
ENG103748-PWM to Level Scaling Factor Rear,5.30 mm/%,2
ENG124607-Reference_Run_Activation_Effect,Activation effect enabled by motor start ,1
ENG103979-Reference_Run_Start_Condition,Engine start ,1
Elapsed Time: 00:06
;SW:5Q0-907-530-AM   HW:5Q0-907-530-M ---  CAN Gateway
;Component:GW MQB High   212 2265, Coding:01010008200860005B008268BC0B00000001010000000000000000000000
;EV_GatewConti,013020,EV_GatewConti_013_VW37.rod
;Thursday,04,April,2019,17:28:56:52461
;VCID: 7CF07874F7278AAA81-8028
IDE00945-ENG118688-Hysteresis voltage-Voltage_elevation,12.1 V,2
IDE00945-ENG118687-Hysteresis voltage-Voltage_lowering,12.1 V,2
IDE01457-Energy management deactivation stage,Mode not active ,1
IDE01844-Increase idle speed request,Mode not active ,1
IDE01996-SFT00001-Installation list: specified installations-Engine Control Module 1,coded ,32
IDE01996-SFT00002-Installation list: specified installations-Transmission Control Module,coded ,32
IDE01996-SFT00003-Installation list: specified installations-Brakes 1,coded ,32
IDE01996-SFT00006-Installation list: specified installations-Seat Adjustment Passenger Side,Not coded ,32
IDE01996-SFT00008-Installation list: specified installations-Air Conditioning,coded ,32
IDE01996-SFT00009-Installation list: specified installations-Central Electrics,coded ,32
IDE01996-SFT00014-Installation list: specified installations-Media Player Position 1,Not coded ,32
IDE01996-SFT00019-Installation list: specified installations-Adaptive Cruise Control,Not coded ,32
IDE01996-SFT00020-Installation list: specified installations-Wheel Dampening Electronics,Not coded ,32
IDE01996-SFT00022-Installation list: specified installations-Steering Column Electronics,coded ,32
IDE01996-SFT00023-Installation list: specified installations-Dash Board,coded ,32
IDE01996-SFT00024-Installation list: specified installations-Auxiliary Parking Heater,Not coded ,32
IDE01996-SFT00025-Installation list: specified installations-Gateway,1 ,32
IDE01996-SFT00032-Installation list: specified installations-High Beam Assistance,Not coded ,32
IDE01996-SFT00033-Installation list: specified installations-Battery Energy Control Module 2,Not coded ,32
IDE01996-SFT00034-Installation list: specified installations-All Wheel Control,coded ,32
IDE01996-SFT00038-Installation list: specified installations-Electronic Roof Control,Not coded ,32
IDE01996-SFT00043-Installation list: specified installations-Steering Column Locking,coded ,32
IDE01996-SFT00050-Installation list: specified installations-Lock Electronics,Not coded ,32
IDE01996-SFT00054-Installation list: specified installations-Seat Adjustment Driver Side,Not coded ,32
IDE01996-SFT00060-Installation list: specified installations-Lane Change Assistant,coded ,32
IDE01996-SFT00064-Installation list: specified installations-Air Conditioning Compressor,Not coded ,32
IDE01996-SFT00066-Installation list: specified installations-Door Electronics Driver Side,coded ,32
IDE01996-SFT00068-Installation list: specified installations-Steering Assistance,coded ,32
IDE01996-SFT00071-Installation list: specified installations-Sound System,Not coded ,32
IDE01996-SFT00075-Installation list: specified installations-Multifunction module,Not coded ,32
IDE01996-SFT00081-Installation list: specified installations-Drive Motor Control Module,Not coded ,32
IDE01996-SFT00082-Installation list: specified installations-Door Electronics Passenger Side,coded ,32
IDE01996-SFT00085-Installation list: specified installations-Headlight Regulation,coded ,32
IDE01996-SFT00095-Installation list: specified installations-Information Control Unit 1,coded ,32
IDE01996-SFT00096-Installation list: specified installations-Tachograph,Not coded ,32
IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring 1,Not coded ,32
IDE01996-SFT00108-Installation list: specified installations-Camera System Rear View,coded ,32
IDE01996-SFT00109-Installation list: specified installations-Deck Lid Control Unit,Not coded ,32
IDE01996-SFT00117-Installation list: specified installations-Telematics Communication Unit,Not coded ,32
IDE01996-SFT00118-Installation list: specified installations-Parking Assistance,coded ,32
IDE01996-SFT00128-Installation list: specified installations-Battery Regulation Auxiliary Accumulator 1,Not coded ,32
IDE01996-SFT00130-Installation list: specified installations-Head Up Display,Not coded ,32
IDE01996-SFT00140-Installation list: specified installations-Battery Energy Control Module,Not coded ,32
IDE01996-SFT00165-Installation list: specified installations-Front Sensors Driver Assistance System,Not coded ,32
IDE01996-SFT00166-Installation list: specified installations-Microphone Control Unit,Not coded ,32
IDE01996-SFT00169-Installation list: specified installations-Actuator For Structure-borne Sound,Not coded ,32
IDE01996-SFT00183-Installation list: specified installations-Access Startsystem Interface,coded ,32
IDE01996-SFT00187-Installation list: specified installations-Door Electronics Rear Driver Side,Not coded ,32
IDE01996-SFT00188-Installation list: specified installations-Door Electronics Rear Passenger Side,Not coded ,32
IDE01996-SFT00189-Installation list: specified installations-High Voltage Battery Charge Management,Not coded ,32
IDE01996-SFT00190-Installation list: specified installations-Sliding Door Rear Left,Not coded ,32
IDE01996-SFT00191-Installation list: specified installations-Sliding Door Rear Right,Not coded ,32
IDE01996-SFT00198-Installation list: specified installations-Battery Charger Control Module,Not coded ,32
IDE01996-SFT00202-Installation list: specified installations-Control module for sunroof,Not coded ,32
IDE01996-SFT00204-Installation list: specified installations-Starter / Generator Control Module,Not coded ,32
IDE01996-SFT00207-Installation list: specified installations-Control Unit Lane Change Assistant 2,Not coded ,32
IDE01996-ENG118300-Installation list: specified installations-Node_0x82,coded ,32
IDE01996-ENG118301-Installation list: specified installations-Node_0x83,coded ,32
IDE01996-ENG118318-Installation list: specified installations-Node_0x96,coded ,32
IDE01996-ENG118319-Installation list: specified installations-Node_0x97,coded ,32
IDE02200-Component protection showroom mode,not active ,1
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,72 Ah,15
IDE03256-MAS06106-Battery adaptation-Battery technology,Wet ,15
IDE03256-MAS06107-Battery adaptation-Battery manufacturer,BA2 ,15
IDE03256-MAS06108-Battery adaptation-Battery Serial Number,140927R6O8 ,15
IDE03903-Production process data 1,FF CA ,2
IDE04159-Deactivation of start-stop function,Mode not active ,1
IDE06425-MAS06026-Roller test bench mode: functional-Activation stages,not activated ,1
IDE06425-MAS06277-Roller test bench mode: functional-Malfunction states,no error ,1
IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM,activated ,4
IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start,activated ,4
IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch),activated ,4
IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system,activated ,4
IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system,activated ,4
IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill,activated ,4
IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button),activated ,4
IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill,activated ,4
IDE06753-MAS06294-Efficiency program display-Comfort use rear heater,activated ,4
IDE06753-MAS06295-Efficiency program display-Comfort use fog light,not activated ,4
IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light,activated ,4
IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater,not activated ,4
IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater,not activated ,4
IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation,not activated ,4
IDE06753-MAS14430-Efficiency program display-Dependence of ECO tips on driver profile selection,ECO tips independent of driver profile selection ,4
IDE06753-MAS19094-Efficiency program display-Rear A/C System blower convenience consumption,not activated ,4
IDE06753-MAS19095-Efficiency program display-Convenience consumption outer mirror heater dependency,Until temperature threshold: with after-run: with switch ,4
IDE08348-Start/stop start voltage limit,7.6 V,1
IDE08624-MKE Check box,not activated ,1
IDE10735-Number requests autonomous recharging,3 ,1
IDE10748-MAS11262-Range gain-Range gain AC system,not activated ,3
IDE10748-MAS11263-Range gain-Range gain auxiliary heater,not activated ,3
IDE10748-MAS11264-Range gain-Range gain window defogger,not activated ,3
IDE10748-MAS11265-Range gain-Range gain seat heater front,not activated ,3
IDE10748-MAS11266-Range gain-Range gain front set ventilation,not activated ,3
IDE10748-MAS11267-Range gain-Range gain rear heater,not activated ,3
IDE10748-MAS11268-Range gain-Range gain fog light,not activated ,3
IDE10748-MAS11269-Range gain-Range gain rear fog light,not activated ,3
IDE10748-MAS11270-Range gain-Range gain windshield heating,not activated ,3
IDE10748-MAS11271-Range gain-Range gain steering wheel heater,not activated ,3
IDE10748-MAS11272-Range gain-Range gain mirror heater,not activated ,3
IDE10748-MAS11273-Range gain-Range gain rear seat heater,not activated ,3
IDE10748-MAS11274-Range gain-Range gain rear seat heater,not activated ,3
IDE10748-MAS11275-Range gain-Windshield heater consumption in AC system,not activated ,3
IDE10748-MAS11276-Range gain-Windshield heater range gain in AC system,not activated ,3
IDE10748-MAS11277-Range gain-PTC(low voltage) consumption,activated ,3
IDE10748-MAS11278-Range gain-PTC(low voltage) range gain,activated ,3
IDE10748-MAS11279-Range gain-List at engine still stand,not activated ,3
IDE10748-MAS12689-Range gain-Catalogue range display,not activated ,3
IDE10748-MAS12690-Range gain-Loading condition catalogue range display,not activated ,3
IDE10748-MAS13161-Range gain-List display absolute values ??with weighting,not activated ,3
IDE10748-MAS19099-Range gain-Convenience consumption socket,not activated ,3
IDE10748-MAS19100-Range gain-A/C System blower manual convenience consumption,not activated ,3
IDE10748-MAS19132-Range gain-Outer mirror heater consumption in rear window heating,not activated ,3
ENG125878-ENG125896-AGW_Calibration-AGW_Brightness_Start_Sequence,100 %,10
ENG125878-ENG126255-AGW_Calibration-AGW_fade_in_deactivation_threshold,100 ,10
ENG125878-ENG125890-AGW_Calibration-AGW_Time_Fade_In,0 ms,10
ENG125878-ENG125892-AGW_Calibration-AGW_Time_Fade_In_Start,0 ms,10
ENG125878-ENG125891-AGW_Calibration-AGW_Time_Fade_Out,0 ms,10
ENG125878-ENG125893-AGW_Calibration-AGW_Time_Fade_Out_Start,0 ms,10
ENG125878-ENG125895-AGW_Calibration-AGW_Time_Start_Delay,0 ms,10
ENG125878-ENG125894-AGW_Calibration-AGW_Time_Start_Sequence,0 ms,10
ENG125879-ENG125897-AGW_Function_Releases-AGW_Enabling_Brightness,active ,3
ENG125879-ENG125898-AGW_Function_Releases-AGW_Enabling_Flash_Frequency,active ,3
ENG125879-ENG125899-AGW_Function_Releases-AGW_Enabling_Supression_Symbol,active ,3
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,180000 ms,12
ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,800 ms,12
ENG137060-ENG113874-EM_energy_management_warning_displays-Batteriemeldungen,Mode not active ,4
ENG137060-ENG98711-EM_energy_management_warning_displays-Charge level,Mode not active ,4
ENG137075-EM_heating_power_quota_adjustment,1000 W,1
ENG137062-ENG100689-EM_start_stop_requirement_ambient_temperature-Maximum_temperature,-50.0 °C,2
ENG137062-ENG137099-EM_start_stop_requirement_ambient_temperature-Minimum_temperature,-50.0 °C,2
ENG137058-SFT00001-GW_Enable_CAN_Timeout_DTC-Engine Control Module 1,Enabled ,32
ENG137058-SFT00002-GW_Enable_CAN_Timeout_DTC-Transmission Control Module,Enabled ,32
ENG137058-SFT00003-GW_Enable_CAN_Timeout_DTC-Brakes 1,not enabled ,32
ENG137058-SFT00006-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Passenger Side,Enabled ,32
ENG137058-SFT00008-GW_Enable_CAN_Timeout_DTC-Air Conditioning,Enabled ,32
ENG137058-SFT00009-GW_Enable_CAN_Timeout_DTC-Central Electrics,Enabled ,32
ENG137058-SFT00011-GW_Enable_CAN_Timeout_DTC-Auxiliary Air Heater,Enabled ,32
ENG137058-SFT00014-GW_Enable_CAN_Timeout_DTC-Media Player Position 1,Enabled ,32
ENG137058-SFT00019-GW_Enable_CAN_Timeout_DTC-Adaptive Cruise Control,Enabled ,32
ENG137058-SFT00020-GW_Enable_CAN_Timeout_DTC-Wheel Dampening Electronics,Enabled ,32
ENG137058-SFT00021-GW_Enable_CAN_Timeout_DTC-Airbag,not enabled ,32
ENG137058-SFT00022-GW_Enable_CAN_Timeout_DTC-Steering Column Electronics,Enabled ,32
ENG137058-SFT00023-GW_Enable_CAN_Timeout_DTC-Dash Board,Enabled ,32
ENG137058-SFT00024-GW_Enable_CAN_Timeout_DTC-Auxiliary Parking Heater,Enabled ,32
ENG137058-SFT00025-GW_Enable_CAN_Timeout_DTC-Gateway,Enabled ,32
ENG137058-SFT00028-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detection,Enabled ,32
ENG137058-SFT00032-GW_Enable_CAN_Timeout_DTC-High Beam Assistance,Enabled ,32
ENG137058-SFT00033-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module 2,Enabled ,32
ENG137058-SFT00034-GW_Enable_CAN_Timeout_DTC-All Wheel Control,Enabled ,32
ENG137058-SFT00035-GW_Enable_CAN_Timeout_DTC-Brake Boost,Enabled ,32
ENG137058-SFT00038-GW_Enable_CAN_Timeout_DTC-Electronic Roof Control,Enabled ,32
ENG137058-SFT00043-GW_Enable_CAN_Timeout_DTC-Steering Column Locking,Enabled ,32
ENG137058-SFT00048-GW_Enable_CAN_Timeout_DTC-Special Function 2,Enabled ,32
ENG137058-SFT00050-GW_Enable_CAN_Timeout_DTC-Lock Electronics,Enabled ,32
ENG137058-SFT00054-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Driver Side,Enabled ,32
ENG137058-SFT00060-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant,Enabled ,32
ENG137058-SFT00061-GW_Enable_CAN_Timeout_DTC-Special Function,Enabled ,32
ENG137058-SFT00064-GW_Enable_CAN_Timeout_DTC-Air Conditioning Compressor,Enabled ,32
ENG137058-SFT00066-GW_Enable_CAN_Timeout_DTC-Door Electronics Driver Side,Enabled ,32
ENG137058-SFT00068-GW_Enable_CAN_Timeout_DTC-Steering Assistance,Enabled ,32
ENG137058-SFT00071-GW_Enable_CAN_Timeout_DTC-Sound System,Enabled ,32
ENG137058-SFT00075-GW_Enable_CAN_Timeout_DTC-Multifunction module,Enabled ,32
ENG137058-SFT00081-GW_Enable_CAN_Timeout_DTC-Drive Motor Control Module,Enabled ,32
ENG137058-SFT00082-GW_Enable_CAN_Timeout_DTC-Door Electronics Passenger Side,Enabled ,32
ENG137058-SFT00085-GW_Enable_CAN_Timeout_DTC-Headlight Regulation,Enabled ,32
ENG137058-SFT00086-GW_Enable_CAN_Timeout_DTC-Radio,Enabled ,32
ENG137058-SFT00087-GW_Enable_CAN_Timeout_DTC-TV Tuner,Enabled ,32
ENG137058-SFT00095-GW_Enable_CAN_Timeout_DTC-Information Control Unit 1,Enabled ,32
ENG137058-SFT00096-GW_Enable_CAN_Timeout_DTC-Tachograph,Enabled ,32
ENG137058-SFT00101-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring 1,Enabled ,32
ENG137058-SFT00105-GW_Enable_CAN_Timeout_DTC-Trailer Function,Enabled ,32
ENG137058-SFT00108-GW_Enable_CAN_Timeout_DTC-Camera System Rear View,Enabled ,32
ENG137058-SFT00109-GW_Enable_CAN_Timeout_DTC-Deck Lid Control Unit,Enabled ,32
ENG137058-SFT00117-GW_Enable_CAN_Timeout_DTC-Telematics Communication Unit,Enabled ,32
ENG137058-SFT00118-GW_Enable_CAN_Timeout_DTC-Parking Assistance,Enabled ,32
ENG137058-SFT00128-GW_Enable_CAN_Timeout_DTC-Battery Regulation Auxiliary Accumulator 1,Enabled ,32
ENG137058-SFT00130-GW_Enable_CAN_Timeout_DTC-Head Up Display,Enabled ,32
ENG137058-SFT00140-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module,Enabled ,32
ENG137058-SFT00165-GW_Enable_CAN_Timeout_DTC-Front Sensors Driver Assistance System,Enabled ,32
ENG137058-SFT00166-GW_Enable_CAN_Timeout_DTC-Microphone Control Unit,Enabled ,32
ENG137058-SFT00169-GW_Enable_CAN_Timeout_DTC-Actuator For Structure-borne Sound,Enabled ,32
ENG137058-SFT00183-GW_Enable_CAN_Timeout_DTC-Access Startsystem Interface,Enabled ,32
ENG137058-SFT00187-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Driver Side,Enabled ,32
ENG137058-SFT00188-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Passenger Side,Enabled ,32
ENG137058-SFT00189-GW_Enable_CAN_Timeout_DTC-High Voltage Battery Charge Management,Enabled ,32
ENG137058-SFT00190-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Left,Enabled ,32
ENG137058-SFT00191-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Right,Enabled ,32
ENG137058-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise,Enabled ,32
ENG137058-SFT00197-GW_Enable_CAN_Timeout_DTC-Thermal management,Enabled ,32
ENG137058-SFT00198-GW_Enable_CAN_Timeout_DTC-Battery Charger Control Module,Enabled ,32
ENG137058-SFT00202-GW_Enable_CAN_Timeout_DTC-Control module for sunroof,Enabled ,32
ENG137058-SFT00204-GW_Enable_CAN_Timeout_DTC-Starter / Generator Control Module,Enabled ,32
ENG137058-SFT00207-GW_Enable_CAN_Timeout_DTC-Control Unit Lane Change Assistant 2,Enabled ,32
ENG137058-ENG118664-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00,Enabled ,32
ENG137058-ENG118466-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01,Enabled ,32
ENG137058-ENG118467-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02,Enabled ,32
ENG137058-ENG118468-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03,Enabled ,32
ENG137058-ENG118469-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04,Enabled ,32
ENG137058-ENG118470-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05,Enabled ,32
ENG137058-ENG118471-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06,Enabled ,32
ENG137058-ENG118472-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07,Enabled ,32
ENG137058-ENG118473-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08,Enabled ,32
ENG137058-ENG118475-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D,Enabled ,32
ENG137058-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11,Enabled ,32
ENG137058-ENG118477-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16,Enabled ,32
ENG137058-ENG118478-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17,Enabled ,32
ENG137058-ENG118479-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A,Enabled ,32
ENG137058-ENG118481-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D,Enabled ,32
ENG137058-ENG118482-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F,Enabled ,32
ENG137058-ENG118483-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20,Enabled ,32
ENG137058-ENG118484-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21,Enabled ,32
ENG137058-ENG118485-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22,Enabled ,32
ENG137058-ENG118486-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24,Enabled ,32
ENG137058-ENG118487-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25,Enabled ,32
ENG137058-ENG118488-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26,Enabled ,32
ENG137058-ENG118489-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27,Enabled ,32
ENG137058-ENG118490-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28,Enabled ,32
ENG137058-ENG118491-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29,Enabled ,32
ENG137058-ENG118492-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A,Enabled ,32
ENG137058-ENG118493-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E,Enabled ,32
ENG137058-ENG118494-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F,Enabled ,32
ENG137058-ENG118495-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35,Enabled ,32
ENG137058-ENG118496-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36,Enabled ,32
ENG137058-ENG118497-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37,Enabled ,32
ENG137058-ENG118498-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38,Enabled ,32
ENG137058-ENG118499-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39,Enabled ,32
ENG137058-ENG118500-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A,Enabled ,32
ENG137058-ENG118501-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C,Enabled ,32
ENG137058-ENG118502-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D,Enabled ,32
ENG137058-ENG118503-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40,Enabled ,32
ENG137058-ENG118504-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41,Enabled ,32
ENG137058-ENG118505-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43,Enabled ,32
ENG137058-ENG118506-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45,Enabled ,32
ENG137058-ENG118507-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48,Enabled ,32
ENG137058-ENG118508-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49,Enabled ,32
ENG137058-ENG118509-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51,Enabled ,32
ENG137058-ENG118510-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52,Enabled ,32
ENG137058-ENG118511-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53,Enabled ,32
ENG137058-ENG118512-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55,Enabled ,32
ENG137058-ENG118513-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56,Enabled ,32
ENG137058-ENG118514-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58,Enabled ,32
ENG137058-ENG118515-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59,Enabled ,32
ENG137058-ENG118516-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A,Enabled ,32
ENG137058-ENG118517-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B,Enabled ,32
ENG137058-ENG118518-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C,Enabled ,32
ENG137058-ENG118519-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D,Enabled ,32
ENG137058-ENG118520-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E,Enabled ,32
ENG137058-ENG118521-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F,Enabled ,32
ENG137058-ENG118522-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60,Enabled ,32
ENG137058-ENG118523-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61,Enabled ,32
ENG137058-ENG118524-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62,Enabled ,32
ENG137058-ENG118525-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66,Enabled ,32
ENG137058-ENG118526-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68,Enabled ,32
ENG137058-ENG118527-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B,Enabled ,32
ENG137058-ENG118528-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C,Enabled ,32
ENG137058-ENG118529-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E,Enabled ,32
ENG137058-ENG118530-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74,Enabled ,32
ENG137058-ENG118531-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75,Enabled ,32
ENG137058-ENG118532-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78,Enabled ,32
ENG137058-ENG118533-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79,Enabled ,32
ENG137058-ENG118534-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A,Enabled ,32
ENG137058-ENG118535-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D,Enabled ,32
ENG137058-ENG118536-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E,Enabled ,32
ENG137058-ENG118537-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F,Enabled ,32
ENG137058-ENG118538-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80,Enabled ,32
ENG137058-ENG118539-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81,Enabled ,32
ENG137058-ENG118540-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82,Enabled ,32
ENG137058-ENG118541-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83,Enabled ,32
ENG137058-ENG118543-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86,Enabled ,32
ENG137058-ENG118544-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87,Enabled ,32
ENG137058-ENG118545-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88,Enabled ,32
ENG137058-ENG118546-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89,Enabled ,32
ENG137058-ENG118547-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B,Enabled ,32
ENG137058-ENG118548-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C,Enabled ,32
ENG137058-ENG118549-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D,Enabled ,32
ENG137058-ENG118550-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E,Enabled ,32
ENG137058-ENG118551-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F,Enabled ,32
ENG137058-ENG118552-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90,Enabled ,32
ENG137058-ENG118553-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91,Enabled ,32
ENG137058-ENG118554-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92,Enabled ,32
ENG137058-ENG118555-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93,Enabled ,32
ENG137058-ENG118556-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94,Enabled ,32
ENG137058-ENG118557-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95,Enabled ,32
ENG137058-ENG118558-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96,Enabled ,32
ENG137058-ENG118559-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97,Enabled ,32
ENG137058-ENG118560-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98,Enabled ,32
ENG137058-ENG118561-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99,Enabled ,32
ENG137058-ENG118562-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A,Enabled ,32
ENG137058-ENG118563-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B,Enabled ,32
ENG137058-ENG118565-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D,Enabled ,32
ENG137058-ENG118566-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E,Enabled ,32
ENG137058-ENG118567-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F,Enabled ,32
ENG137058-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0,Enabled ,32
ENG137058-ENG118569-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1,Enabled ,32
ENG137058-ENG118570-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2,Enabled ,32
ENG137058-ENG118571-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3,Enabled ,32
ENG137058-ENG118573-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5,Enabled ,32
ENG137058-ENG118574-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6,Enabled ,32
ENG137058-ENG118575-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7,Enabled ,32
ENG137058-ENG118576-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8,Enabled ,32
ENG137058-ENG118578-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA,Enabled ,32
ENG137058-ENG118579-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB,Enabled ,32
ENG137058-ENG118580-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC,Enabled ,32
ENG137058-ENG118581-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD,Enabled ,32
ENG137058-ENG118583-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF,Enabled ,32
ENG137058-ENG118584-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0,Enabled ,32
ENG137058-ENG118585-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1,Enabled ,32
ENG137058-ENG118586-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2,Enabled ,32
ENG137058-ENG118587-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3,Enabled ,32
ENG137058-ENG118588-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4,Enabled ,32
ENG137058-ENG118589-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5,Enabled ,32
ENG137058-ENG118590-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6,Enabled ,32
ENG137058-ENG118591-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7,Enabled ,32
ENG137058-ENG118592-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8,Enabled ,32
ENG137058-ENG118593-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9,Enabled ,32
ENG137058-ENG118594-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA,Enabled ,32
ENG137058-ENG118595-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB,Enabled ,32
ENG137058-ENG118596-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC,Enabled ,32
ENG137058-ENG118597-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD,Enabled ,32
ENG137058-ENG118598-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE,Enabled ,32
ENG137058-ENG118599-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF,Enabled ,32
ENG137058-ENG118600-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0,Enabled ,32
ENG137058-ENG118601-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1,Enabled ,32
ENG137058-ENG118602-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2,Enabled ,32
ENG137058-ENG118603-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3,Enabled ,32
ENG137058-ENG118604-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4,Enabled ,32
ENG137058-ENG118605-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5,Enabled ,32
ENG137058-ENG118606-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6,Enabled ,32
ENG137058-ENG118607-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7,Enabled ,32
ENG137058-ENG118608-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8,Enabled ,32
ENG137058-ENG118609-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9,Enabled ,32
ENG137058-ENG118610-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA,Enabled ,32
ENG137058-ENG118611-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB,Enabled ,32
ENG137058-ENG118612-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC,Enabled ,32
ENG137058-ENG118613-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD,Enabled ,32
ENG137058-ENG118614-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE,Enabled ,32
ENG137058-ENG118615-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF,Enabled ,32
ENG137058-ENG118616-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0,Enabled ,32
ENG137058-ENG118617-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1,Enabled ,32
ENG137058-ENG118618-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2,Enabled ,32
ENG137058-ENG118619-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3,Enabled ,32
ENG137058-ENG118620-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4,Enabled ,32
ENG137058-ENG118621-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5,Enabled ,32
ENG137058-ENG118622-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6,Enabled ,32
ENG137058-ENG118623-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7,Enabled ,32
ENG137058-ENG118624-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8,Enabled ,32
ENG137058-ENG118625-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9,Enabled ,32
ENG137058-ENG118626-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA,Enabled ,32
ENG137058-ENG118627-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB,Enabled ,32
ENG137058-ENG118628-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC,Enabled ,32
ENG137058-ENG118629-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD,Enabled ,32
ENG137058-ENG118630-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE,Enabled ,32
ENG137058-ENG118631-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF,Enabled ,32
ENG137058-ENG118632-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0,Enabled ,32
ENG137058-ENG118633-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1,Enabled ,32
ENG137058-ENG118634-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2,Enabled ,32
ENG137058-ENG118635-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3,Enabled ,32
ENG137058-ENG118636-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4,Enabled ,32
ENG137058-ENG118637-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5,Enabled ,32
ENG137058-ENG118638-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6,Enabled ,32
ENG137058-ENG118639-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7,Enabled ,32
ENG137058-ENG118640-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8,Enabled ,32
ENG137058-ENG118641-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9,Enabled ,32
ENG137058-ENG118642-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA,Enabled ,32
ENG137058-ENG118643-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB,Enabled ,32
ENG137058-ENG118644-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC,Enabled ,32
ENG137058-ENG118645-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED,Enabled ,32
ENG137058-ENG118646-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE,Enabled ,32
ENG137058-ENG118647-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF,Enabled ,32
ENG137058-ENG118648-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0,Enabled ,32
ENG137058-ENG118649-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1,Enabled ,32
ENG137058-ENG118650-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2,Enabled ,32
ENG137058-ENG118651-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3,Enabled ,32
ENG137058-ENG118652-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4,Enabled ,32
ENG137058-ENG118653-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5,Enabled ,32
ENG137058-ENG118654-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6,Enabled ,32
ENG137058-ENG118655-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7,Enabled ,32
ENG137058-ENG118656-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8,Enabled ,32
ENG137058-ENG118657-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9,Enabled ,32
ENG137058-ENG118658-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA,Enabled ,32
ENG137058-ENG118659-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB,Enabled ,32
ENG137058-ENG118660-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC,Enabled ,32
ENG137058-ENG118661-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD,Enabled ,32
ENG137058-ENG118662-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE,Enabled ,32
ENG137058-ENG118663-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF,Enabled ,32
ENG137059-ENG118464-GW_mirror_mode-mirror_mode_bus,Databus drivetrain ,2
ENG137065-GW_routing_0,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137066-GW_routing_1,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137067-GW_routing_2,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137068-GW_routing_3,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137069-GW_routing_4,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137070-GW_routing_5,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137071-GW_routing_6,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137072-GW_routing_7,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137073-GW_routing_8,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137074-GW_routing_9,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG118774-ENG152567-WakeUpMonitor_Activation-Open_Filter_Activate,not activated ,1
ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100 ,5
ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s,5
ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s,5
Elapsed Time: 00:27
Here's how the Leuchte-sets for the left/right DRLs are programmed for the following BCM on my MY18 A3 8V (RoW)
;SW:5Q0-937-084-CQ   HW:5Q0-937-084-CG ---  Cent. Elect. --- SA: 31347
;Component:BCM MQBAB H   H36 0253
;EV_BCMMQB
 Coding:000000000000000000000000000000000000000000000000000000000000
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3	>	maximize
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3	>	maximize
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3	>	minimize
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3	>	26
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3	>	26
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3	>	127
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3	>	26
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3	>	4C
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3	>	4C
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3	>	4 - LED Tagfahrlichtmodul Signal
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3	>	Always
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3	>	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3	>	Parking light right
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3	>	Coming Home oder Leaving Home aktiv
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3	>	not active
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3	>	Daytime running lights
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3	>	not active
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3	>	Blinken rechts aktiv (beide Phasen)
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3	>	not active
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2	>	maximize
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2	>	maximize
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2	>	minimize
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2	>	26
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2	>	26
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2	>	127
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2	>	26
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2	>	4A
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2	>	48
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2	>	4 - LED Tagfahrlichtmodul Signal
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2	>	Always
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2	>	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2	>	Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2	>	Coming Home oder Leaving Home aktiv
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2	>	not active
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2	>	Daytime running lights
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2	>	not active
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2	>	Blinken links aktiv (beide Phasen)
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2	>	not active
cilitkas
LT
Thanks, is that xenon or full led front lights?
^^ ^^ the headlamp fittings are HID, but as you can see from the setting for the Lasttyp channel in each of the Leuchte-sets, the DRL/Parking lights are LED
cilitkas
LT
Yes but do you understand that my Drl on full led lights are totally different thing? Its dynamic indicator etc...
vastechnics
C?ID=143747
Hello. Your headlight range module is not ok. You can use 2 types of modules:
- 8V0 907 357 with or without index A
- or 3Q0 907 338
I use normally the first one. This module controls the LED and indicators.
First use the good modules.
cilitkas
LT
So thats the range module im using 8V0907357A
Second number you mention is for gateway...
Bogdan.audi
Ukraine
C?ID=90275
Good day to all. Can someone share the protocol and adaptation channels of block 09 and 4b from auto audi a3 2018 with LED optics or help with programming? I'm trying to install LED instead of xenon. thanks
