02 MK4 GTI VR6 no-start.
DimeGuy
C?ID=224621
I am having some peculiar problems with my GTI. It started with the a/c (climatronic equipped) not operating. heat and fan work normal. I was stupid...VERY stupid and was in a hurry. I wanted to jump the low press. sw. to start the compressor to see if it might be the sw. (I did this before I ordered my KII-USB pigtail). so I shorted it out as I heard a loud snap. The thermometer on the gauge cluster is not reading and the climate control display is blank. The vehicle was still running, but the EPC light came on. It didn't run quite right as I drove around the block for a test drive prior to repair, so I just parked it in my driveway and the MIL also came on as I was driving. Then it didn't start after letting it sit for an hour. I received my pigtail and did an auto-scan and found several codes stored. The next morning I tried to start it again and it started. but it has done the no-start again since.
I know that this is long, but as a technician, I know that the more info. the better I can narrow down the diagnosis. I've never seen this many codes stored in any vehicle I've worked on and any help that could point me in the right direction would be very appreciated. Thanks!
Here is the results of the auto-scan...
Thursday,25,September,2014,15:47:44:54350
VCDS Version: 12.12.3.0 (x64)
Data version: 20140822
VIN: 9BWPG61J224003987   License Plate: 4ULT218
Mileage: 328540km-204145mi   Repair Order:
          76
VIN: 9BWPG61J224003987   Mileage: 328540km/204145miles
Address 01: Engine        Labels: 021-906-018-AFP.lbl
   Part No: 021 906 018 T
   Component: MOTRONIC ME7.1  G   6764
   Coding: 00031
   Shop #: WSC 26004
   VCID: 1F43EBAD9D6992E6827-5178
   9BWPG61J224003987     VWZ7Z0A3885954
13 Faults Found:
16955 - Brake Switch (F)
            P0571 - 35-00 - Implausible Signal
16645 - Fuel Injector #1 (N30)
            P0261 - 35-00 - Short to Ground
16657 - Fuel Injector #5 (N83)
            P0273 - 35-00 - Short to Ground
16651 - Fuel Injector #3 (N32)
            P0267 - 35-00 - Short to Ground
16660 - Fuel Injector #6 (N84)
            P0276 - 35-00 - Short to Ground
16829 - EVAP Purge Control Valve (N80)
            P0445 - 35-00 - Circuit Shorted
17880 - EVAP Leak Detection Pump
            P1472 - 35-00 - Short to Ground
16802 - Relay for Secondary Air Injection Pump (J299)
            P0418 - 35-00 - Malfunction
16798 - Secondary Air Injection System Valve (N112)
            P0414 - 35-00 - Shorted
16654 - Fuel Injector #4 (N33)
            P0270 - 35-00 - Short to Ground
17045 - Intake Manifold Tuning Valve Control Circuit (Bank 1)
            P0661 - 35-00 - Short to GND
16648 - Fuel Injector #2 (N31)
            P0264 - 35-00 - Short to Ground
16421 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
            P0037 - 35-00 - Short to Ground
Readiness: 0000 1100
Address 03: ABS Brakes        Labels: 1C0-907-37x-ASR.lbl
   Part No: 1C0 907 379 D
   Component: ASR FRONT MK60      0103
   Coding: 0021505
   Shop #: WSC 00000 785 00200
   VCID: 2B5B0F7D89D17E461EF-5178
   Part No: 6Q0 909 605 F
   Component: 08 AIRBAG VW6  0202 0004
   Coding: 12344
   VCID: 3A753A39268BD7CE959-513C
   Part No: 1J0 920 926 D
   Coding: 07232
   Shop #: WSC 26101
   VCID: 2B5B0F7DD9D17E461EF-513C
00667 - Ambient Temperature Signal
            30-00 - Open or Short to Plus
   Part No: 6N0 909 901
   Coding: 00006
   VCID: F0E15811B077DD9EEBD-513C
   Part No: 1C0 959 799 C
   Component: 1H Komfortgerát HLO 0003
   Coding: 00258
   Shop #: WSC 00066
   VCID: 3773230D1599CAA66A7-4B32
   Component: 1J Tõrsteuer.FS KLO 0003
   Component: 1J Tõrsteuer.BF KLO 0002
   Subsystem 3 - Part No: Steuerger
   Component: t HL    antwortet nicht
   Subsystem 4 - Part No: Steuerger
   Component: t HR    antwortet nicht
            49-00 - No Communications
Zenerdiode
Newcastle, England
C?ID=24330
With a bit of luck you have just blown a fuse; a blown fuse can manifest itself as 'short to xx'. Uwe had (or still has??) a VR6 so he may be the best to respond for fuse locations etc.
Yep, those faults are indicative of a whole bunch of things not getting power. A blown fuse could certainly cause that, but the culprit is most often a bad Fuel Pump Relay.
My VR6 was an Mk.3, with M5.9 rather than the Mk.4 ME7.1 being discussed here, which is a totally different animal.
DimeGuy
C?ID=224621
Thanks Diode and UWE! I kinda thought it was a fuse or circuit breaker type interruption. I'll re-check the fuses again and inspect that fuel pump relay.
Thanks for the fast reaponse guys. Hope your weekend was great.
NostraJackAss
If the 10 AMP fuse for consumers is blown............be sure to check the ( OXS ) oxygen sensor heater circuits first.
Start with isolating each and unplugging to test each track as they are all shared for supply switched terminal 15 B+.
Don't negate checking the ignition switch or switched ground terminal 31 for such an energizing loss of the FP relay being done by the controller J220 and redundant loops.
Study the current tracks and follow all star-gates for possible cross............
DimeGuy
C?ID=224621
Ok, so I swapped the fuel pump relay with my wife's GTI and BAM!!!.......it fired! I'm gonna buy a new relay and ambient temp sensor (as mine is still inop.) clear the codes, reset readiness and then re-scan. Thanks for the inut guys, I really do appreciate it.
