Coming home and leaving home Jetta 2010
mohamed
Egypt
C?ID=211960
Could you tell me how to do the coming home and leaving home light for this jetta
this is a full auto-scan for the car
Saturday,03,March,2018,03:50:34:11183
VCDS Version: 17.8.1.0
Data version: 20171130 DS276.6
VIN: WVWRU11K0AM034337   License Plate: JETTA 2010
Mileage: 91440km-56818mi   Repair Order:
Chassis Type: 1K-VW36 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72
VIN: WVWRU11K0AM034337   Mileage: 91440km-56818miles
Address 01: Engine (BSF)       Labels: 06A-906-033-BGU.lbl
   Part No SW: 06A 906 033 NH    HW: 06A 906 033 JF
   Component:  BSF S71 1.6 2V     9549
   Revision: --H01---    Serial number:
   Coding: 0060077
   Shop #: WSC 00999 444 64523
   VCID: 72EE58876D848ED697-8026
16414 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
            P0030 - 000 - Malfunction / Open Circuit - Intermittent
                    Bin. Bits: 00000100
                    Resistance: 16.38 kOhm
                    Voltage: 2.100 V
                    Load: 5.1 %
                    Mass Air / Rev.: 103.6 mg/str
                    RPM: 736 /min
Readiness: 0010 0001
   Part No SW: 0AM 300 048 Q    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 9059
   Revision: 00043014    Serial number: CU501208105895
   Shop #: WSC 22197 001 1048576
   VCID: 3E76BCB7695C1AB6A3-806A
Address 03: ABS Brakes        Labels:. 1K0-907-379-MK70M.clb
   Part No SW: 1K0 907 379 AQ    HW: 1K0 907 379 AQ
   Component: MABS MK70M          0105
   Revision: 00H32001
   Coding: 0016641
   Shop #: WSC 00066 000 00000
   VCID: 010C074B5822A54E9E-8054
   Part No SW: 5K0 907 044 BC    HW: 5K0 907 044 BC
   Component: Climatronic   H14 0608
   Revision: 00003001
   Coding: 0000000000
   Shop #: WSC 00066 000 00187
   ASAM Dataset: EV_Climatronic A01001
   VCID: 6DD44BFBBCBA512E4A-8038
   Part No SW: 5K0 937 087     HW: 5K0 937 087
   Component: BCM PQ35 H    008 0019
   Revision: BE008001
   Coding: 40000A3E902D02E0400800800500092003700088700089605CC000000000
   Shop #: WSC 00066 123 12345
   VCID: 72EE5887AD848ED697-8026
   Component: Wischer 08090  21  0501
   Coding: 009795
01495 - Bulb for High-Beams; Left (M30)
                    Fault Status: 00100111
                    Reset counter: 124
                    Mileage: 90640 km
                    Date: 2012.06.30
                    Time: 14:56:37
                    Voltage: 13.55 V
                    Reset counter: 123
                    Mileage: 91341 km
                    Date: 2012.07.22
                    Time: 05:50:50
                    Voltage: 13.40 V
                    Fault Status: 00101010
                    Reset counter: 123
                    Mileage: 90964 km
                    Date: 2012.07.21
                    Time: 09:27:54
                    Voltage: 13.95 V
   Component: 2J AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD2ESGS8
   Coding: 0012874
   VCID: 3D74BBBB645A01AEBA-8068
   Subsystem 1 - Serial number: 6332MSME49536908F
   Subsystem 2 - Serial number: 6342MSME4822760AB
   Subsystem 3 - Serial number: 6351HSME1C0C62167
   Subsystem 4 - Serial number: 6361HSME1C0C56138
   Part No SW: 1K0 953 549 CE    HW: 1K0 953 549 CE
   Component: J0527           055 0111
   Coding: 0001601
   VCID: 77F8699306E6EBFEA0-8022
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000131
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 5M0 920 870 A    HW: 5M0 920 870 A
   Component: KOMBI         H08 0021
   Revision: V0008011    Serial number:
   Coding: 671E00
   Shop #: WSC 00066 000 00148
   ASAM Dataset: EV_KombiUDSMM9RM10 A04010
   ROD: EV_KombiUDSMM9RM10_A04_VW32.rod
   VCID: 2D548BFB7C3A912E0A-8078
13701120 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
                    Reset counter: 129
                    Mileage: 83257 km
                    Date: 2017.06.28
                    Time: 11:03:52
   Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
   Component: J533  Gateway   H07 0081
   Revision:   H07 01    Serial number: 100709F2002722
   Coding: ED817F06000202001002
   VCID: 66C634D7514C62760B-8032
01304 - Radio
                    Reset counter: 129
                    Mileage: 83257 km
                    Date: 2011.11.19
                    Time: 11:30:09
   Component: IMMO          H08 0021
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01010
   ROD: EV_ImmoUDSMM9RM10_VW21.rod
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1525
   Revision: 72009005    Serial number: 00000878598820
   Coding: 0000180
   VCID: 6FE851F37EB6A33E78-803A
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 69     2901
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
   VCID: 2F6891F3BE36E33E38-807A
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1519
   Revision: 72009005    Serial number: 09052309000604
   Coding: 0000180
   VCID: 70EA528F6388BCC661-8024
                    Fault Status: 00100101
                    Reset counter: 112
                    Mileage: 90588 km
                    Date: 2012.06.30
                    Time: 13:26:51
00110 - Right Mirror Turn Signal Lamp (L132)
                    Fault Status: 01101100
                    Reset counter: 89
                    Mileage: 83274 km
                    Date: 2011.11.20
                    Time: 00:09:50
   Part No: 1T0 907 357
   Coding: 0000003
   VCID: 74E25E9F179080E685-8020
Address 56: Radio
   Part No SW: 1K0 959 703 AG    HW: 1K0 959 795 R
   Component: J388   TUER-SG HL   1401
   Revision: 11006001    Serial number: 00000004198984
   Coding: 0000144
   VCID: 75E4639B1CEA99EEB2-8020
   Part No SW: 1K0 959 704 AG    HW: 1K0 959 794 R
   Component: J389   TUER-SG HR   1401
   Revision: 11006001    Serial number: 00000004201957
   Coding: 0000144
   VCID: 76E6649701EC92F6BB-8022
End-------------------------(Elapsed Time: 02:25)--------------------------
iichel
Netherlands, eastern part
C?ID=284912
don't you need RLS / RLHS and auto light switch for CH/LH?
mohamed
Egypt
C?ID=211960
I Think i didnt need them , but iam not sure
Westbury, UK
On some models (MQB Octavia et al) there is a semi-manual CH/LH possible that requires you to use the headlamp stalk to initiate the CH but the LH will come on even when it is light (as there is no RLS/RLHS). Might be worth a Google...
