Cust sts car started surging, idle hunting
ivagp
C?ID=95551
cust sts car was surging while on surface roads cruising around 45 mph. pulled codes 16804,17972,17551 and 16891. cleared codes and did a throttle relearn. while relearn was in process could hear noises stopping and coming back on also would lose data. after adpt checked for codes and got this 17987. after a few more attempts still hear throttle sometimes stopping but got adapt complete. now i have driven about 25 miles with out any issues. I know someone around here always talks about oxygen sensor, but without any codes? or any other suggestions?
Tuesday,27,February,2018,10:41:01:13440
VCDS Version: 17.8.1.0 (x64)  HEX-NET CB: 0.4407.4
Data version: 20171130 DS276.6
Dealer/Shop Name: ivagp
VIN: WVWRL61J95W004870   License Plate:
Mileage: 194360km-120769mi   Repair Order:
          76
VIN: WVWRL61J95W004870   Mileage: 194360km-120769miles
Address 01: Engine        Labels: 06A-906-032-BEV2.clb
   Part No: 06A 906 032 RE
   Component: 2L A4 AT4       G   6193
   Coding: 00003
   Shop #: WSC 01266
   VCID: F2A8B3E3BC9B21D617-5160
   WVWRL61J95W004870     VWZ7Z0D9681276
Address 02: Auto Trans        Labels: 01M-927-733.lbl
   Part No: 01M 927 733 MR
   Component: AG4 Getriebe 01M    5077
   Coding: 00011
   Shop #: WSC 00001
   VCID: 8C54CD1BBE7F57267D-0962
Address 03: ABS Brakes        Labels: 1C0-907-37x-ABS.lbl
   Part No: 1C0 907 379 L
   Component: ABS FRONT MK60      0101
   Coding: 0004097
   Shop #: WSC 01266 785 00200
   VCID: B32676E7D30168DEDC-5184
   Part No: 1C0 909 605 F
   Component: 17 AIRBAG VW61 0108 0003
   Coding: 12599
   Shop #: WSC 01266
   VCID: A71E92B747D9147E70-513C
   Part No: 1J5 920 906 K
   Component: KOMBI+WEGFAHRSP VDO V03
   Coding: 15232
   VCID: B52248FF8D7576EEF2-513C
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 01266
   VCID: F0ACB9EBB29713C6E1-513C
   Part No: 1C0 959 799 C
   Component: 8A Komfortgerát HLO 0004
   Coding: 00259
   Shop #: WSC 01267
   VCID: B73E42F7977984FEE0-4B1E
   Component: 8A Tõrsteuer.FS KLO 0202
   Component: 8A Tõrsteuer.BF KLO 0202
   Component: 8A Tõrsteuer.HL KLO 0202
   Component: 8A Tõrsteuer.HR KLO 0202
Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
   Part No: 3B7 035 180 F
   Component:    Radio PM6        0016
   Coding: 00401
   Shop #: WSC 01266
   VCID: A30686A733E1F85E2C-513C
End----(Elapsed Time: 04:48, VBatt start/end: 11.9V/11.8V. VIgn 11.9V)-----
Gone But Not Forgotten
It could indeed be bad OXS sensors or if corrosion is in a connector and in some cases I have found that idiots that spray the bay with a lubricant such as WD40 to make it shit shine, it will cause this condition to for a run away or unintended acceleration effect, so is it shit shine of some type?
ivagp
C?ID=95551
no shine, charging battery know to test battery. key off 12.45 key on 12.05. voltage drop with full load .06
ivagp
C?ID=95551
battery failed, new battery still losing communication when doing throttle adpt. cust will pickup and drive for a few days and come back for another scan. thanks for the code tags Uwe
Check the 6 wires from TV to ECU and maybe do overlay.
Unplug other consumers, other than to keep alive to isolate a brown out.
