- Mar 9, 2015
- 413
- 274
- Australia
- C?ID=241363
*update
There is a possible issue with the harness pinout that I need to look at over the weekend if I can see the car again.
Hi All,
Today I tried to install some dynamic (sweeping) indicators in a MY 2015 Mk7 R.
So the original tail lights are full LED.
The adapter harnesses are from a company called 'Vag Diagnose'.
I've previously used the same adapters in an RS3 and had no issues at all. Was plug and play. Had to adjust the little screw on the adapter a little so that the indicators kept sweeping rather than indicating as a solid blink.
In this Golf however I couldn't get any of the inner lights to illuminate at all.
There are a couple of BCM adaptations which need to be performed to correctly configure the leutche channels however I had no success in getting any of the inner tail lights (reverse, indicator or tail lights) to illuminate with either the modified or factory settings. the new outer dynamic tail lights work perfectly at all times.
I put the factory inner LED tail lights back in and they work fine. So the car now has sweeping outer tails and solid inners
Just wondering if anyone has had any odd experiences with this particular retrofit?
I can't find any info on the harness manufacturer.
I made sure that the boot was closed as I know this disables the RVC and inner lights by default.
New inner tail lights are PN 5G0945307Q and 5G0945308Q.
This is RHD vehicle.
Unfortunately I don't have another set of adapters or tail lights to swap though I doubt that there are 2 DOA harnesses and/or tail lights.
This is the autoscan
BCM admap prior to changes
Hi All,
Wednesday,21,February,2018,13:30:09:58930
VCDS Version: 18.2.0.3 (x64) HEX-V2 CB: 0.4411.4
VIN: WVWZZZAUZFW09 License Plate:
Mileage: 18825km-11697mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 42 44 52 55 5F
A9
VIN: WVWZZZAUZFW09 Mileage: 18825km-11697miles
Address 01: Engine (J623-CJXB) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 E HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0006
Revision: --H13---
Coding: 091D00322466050B3004
Shop #: WSC 08512 002 1048576
ASAM Dataset: EV_ECM20TFS0205G0906259E 001006
ROD: EV_ECM20TFS0205G0906259E.rod
VCID: 3039EE0B6AAD30A7C28-8064
21388 - Valve for Exhaust Flap 1 (N321)
P3019 00 [109] - Open Circuit
Mileage: 18824 km
Date: 2018.02.20
Time: 00:06:21
Engine speed: 714.25 /min
Normed load value: 8.2 %
Coolant temperature: 73 °C
Intake air temperature: 29 °C
Voltage terminal 30: 14.179 V
Engine: operating status: IS
STATE_LS_SAE[1]: OL_INTR
T_AST_SAE: 0 s
MAP_MES_SAE: 29 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.963 V
FAC_TPS_1_SAE: 11.718750 %
FUP_H_SAE: 8010.0 kPa
21399 - Valve for Exhaust Flap 2 (N322)
P3023 00 [109] - Open Circuit
Mileage: 18824 km
Date: 2018.02.20
Time: 00:06:21
T_AST_SAE: 0 s
MAP_MES_SAE: 29 kPa
Readiness: 0010 0001
Part No SW: 0D9 300 012 L HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4516
Revision: 03253104 Serial number: TFK01408031327
ROD: EV_TCMDQ250021.rod
VCID: 1F1B1DB70733BFDF6B2-804A
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 M HW: 5Q0 907 379 H
Component: ESC H31 0571
Revision: 00000000 Serial number: 62294000000976
Coding: 01FA93A154292975037F070041C46980C92A94C0E08296F7F84250B8C208
Shop #: WSC 52104 002 104857
VCID: 46D5A8D3F8298E17084-8012
8299 - Databus
[FCAN: Anhaenger_01_alt veraltet bit is set]
Reset counter: 31
Date: 2018.02.21
Time: 13:24:49
Revision: 00021000 Serial number: 0344530835
Coding: 030C0C
VCID: 3A2DCC23BCD1FAF77CC-806E
Part No SW: 5G0 907 044 AN HW: 5G0 907 044 AN
Component: Climatronic H03 0907
Revision: 00001K08
Coding: 00120014200100001005000012101800
VCID: 73B32107DB3B4BBF7FA-8026
Air quality sensor:
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0134
Serial number: 01011423301001
Coding: 03111A46C24122F30BA44080B10C07281800000000000000000000000000
ROD: EV_BCMBOSCH_013.rod
VCID: 00597ECB9A8D6027728-8054
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 140808 042 0551
Serial number: 140813091333
Component: RLHS 037 0059
Serial number: S4Y14M09D02H01M36S19
Coding: 00A8DD
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY141901XVS
Serial number: 00000000000059515560
Sun Roof:
Subsystem 5 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.014 H02 0007
Serial number: WOO3176985D
Coding: 181801
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 E HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0048
Revision: -------- Serial number: 39311421305617
Coding: 0071151011
ROD: EV_EPHVA18AU3700000_002_VW27.rod
VCID: 3D27C73FADFFCDCF59E-8068
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 D
Serial number: 22081403210278
Coding: 001C1300FE0739
VCID: 3829D62B82DDE8E78A8-806C
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 HW: 5Q0 907 376
Component: DAEMPFUNGS-SG H15 0115
Serial number: 22071441350091
ROD: EV_DRCONTITEMIC_VW27.rod
VCID: 76B51813C8495E97584-8022
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 014 0386
Serial number: 003MLR087W4
Coding: 98CCC000000000005C00000000C800000065
VCID: 7F5BFD37E7731FDF0B2-802A
Belt Pretensioner left:
Component: BeltPretRevFL H35 0341
Serial number: 34169677B28081470963
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H35 0341
Serial number: 34169676B28081470590
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 002 608 14
Serial number: 357670000004427D001G
Subsystem 4 - Part No SW: ----------- HW: 480 002 608 14
Serial number: 35867000000B6A440F0-
Subsystem 5 - Part No SW: ----------- HW: 480 402 208 14
Serial number: 3516502B316FC2251240
Subsystem 6 - Part No SW: ----------- HW: 480 402 208 14
Serial number: 3526502B316FC2246122
Subsystem 7 - Part No SW: ----------- HW: 480 401 608 14
Serial number: 3556502BB16C6CE572F%
Part No SW: 5Q0 953 507 EC HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 21081408490693
Coding: 0C10
ROD: EV_SMLSKLOMQB_013_AU37.rod
VCID: 7BA30927F36B03FF27A-802E
Part No SW: 5G1 920 791 HW: 5G1 920 791
Component: KOMBI 410 2180
Coding: 27AD0818BF80000801886A011400000000000000
Shop #: WSC 01545 995 12345
ASAM Dataset: EV_DashBoardVDDMQBAB 009052
VCID: 698F436F89F7816FC56-803C
Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 F
Component: GW MQB High 128 1188
Revision: -------- Serial number: 0002417488
Coding: 030100042B085900EF00027E9C0F00010001050000000000000000000000
ASAM Dataset: EV_GatewLear 011016
ROD: EV_GatewLear_011_VW37.rod
VCID: 42DDB4C3D401B23724C-8016
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H10 0038
Serial number: 27140002111710034344
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 4365794203
U1101 00 [009] - Active
Reset counter: 31
Mileage: 18824 km
Date: 2018.02.20
Time: 00:06:18
Supply voltage: Terminal 30: 14.1 V
Terminal 15: On
Part No SW: 0CQ 907 554 D HW: 0CQ 525 130
Component: Haldex4Motion H52 7081
Serial number: HA1-00004.07.14
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 002011
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 14000223719004
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 3431E21B9EB50C87A60-8060
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 12081401101595
Coding: 003E12208001048000000000
VCID: 40D9BECBDA0DA027328-8014
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000003589140
Coding: 1D0000
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 8103
ROD: EV_SteerAssisMQB_010.rod
VCID: 3537DF1F95CF158F91E-8060
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 08081403110184
Coding: 003E12208E01048000800000
VCID: 3FDBBD37A7F3DFDF4B2-806A
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000003424961
Coding: 050000
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 02A602000B000200
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
Part No SW: 5G0 907 159 B HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0006
Serial number: 140722201411
VCID: 2D07F77F7D9F5D4FE9E-8078
End----(Elapsed Time: 02:02, VBatt start/end: 12.1V/12.1V. VIgn 12.0V)-----
;SW:5Q0-937-084-AJ HW:5Q0-937-084-AJ --- Cent. Elect. --- SA: 31347
;Component:BCM MQBAB H H18 0134 Coding:03111A46C24122F30BA44080B10C07281800000000000000000000000000
;EV_BCMCONTI 13000
;Tuesday 20
;VCDS Version: Release 18.2.0 (x64) Data version: 20180212 DS287.0
;VCID: 00597ECB9A8D6027728-8054
IDE00001-ENG99061-Production mode-Access control not active
IDE00001-ENG115730-Production mode-Aussenbeleuchtung not active
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren not active
IDE00001-ENG112304-Production mode-Heckwischer not active
IDE00001-ENG98647-Production mode-Interior lighting not active
IDE00001-ENG115729-Production mode-Scheinwerferreinigung not active
IDE00001-ENG115731-Production mode-Virtuel_pedal not active
IDE00002-Transport mode active
IDE00820-Activating and deactivating all development messages not active
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA not active
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung 5
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm active
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf active
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung active
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer not active
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren Deactivating
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel not active
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit 2000 ms
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit 320 ms
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit 0 ms
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit 0 ms
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit 320 ms
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz active
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status not active
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung not active
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant 0
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube not active
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus not active
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube not active
IDE01550-Service position 170.49 °
IDE02152-Characteristics in production mode 2000 ms
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking Decelerate
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln not active
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global not active
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn not active
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln not active
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn short
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung not active
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte not active
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen active
IDE02332-Deactivate production mode 0
IDE02488-DWA Interior monitoring 100%
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen not active
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf not active
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken not active
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck active
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1 5 s
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2 3 s
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik 7 s
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall 7 s
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW active
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck active
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum 50%
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer 50%
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn 50%
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung Enabled
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel not installed
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel not installed
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset -63.75 °
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit 50.00 %/s
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt double sided
IDE03638-ENG116675-static AFS light-Lower speed threshold 0.00 km/h
IDE03638-ENG116682-static AFS light-Maximaltemperatur 100.00 °C
IDE03638-ENG116679-static AFS light-obere Grenztemperatur 95.00 °C
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel 120 °
IDE03638-ENG116680-static AFS light-untere Grenztemperatur 80.00 °C
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel 180 °
IDE03638-ENG116676-static AFS light-Upper speed threshold 40.00 km/h
IDE03638-ENG116674-static AFS light-Vorschrift ECE R119
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger separte
IDE04923-ENG115774-Turn signal control-Komfortblinken active
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen 3
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker MFG
IDE04923-ENG116588-Turn signal control-Sonderfunktionen not enabled
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung not active
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung Always active
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor 0.1
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert 10.00%
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze 350 km/h
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze 350 km/h
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht integriert in Suchbeleuchtung
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich active
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten klemmenabhaengig
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO Menuesteuerung Zeit aktivieren
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit 0 km/h
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert One-sided
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion active
IDE04924-ENG126816-Driving light and parking light-Standlicht aus active
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht active
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht not active
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren in Betrieb lassen
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht 15 min
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten Low beam
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus manual
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis Driver door
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung 46400 lx
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung 12 lx
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus Enabled
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome 10 seconds
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP 10 seconds
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung active
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP active
IDE04927-IDE01446-Window heater-Running time of heated front window 240 s
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung 35.00 °C
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung 35.00 °C
IDE04927-ENG126845-Window heater-FSH Automatik active
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert 600 s
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH active
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH not active
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn not active
IDE04928-ENG115864-Anti-theft device-Alarmsignal frequency modulated
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung driver door contact thatcham
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus not active
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl 10 Alarme
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel not active
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm keine verzoegerung
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck active
IDE05142-ENG116621-Access control-automatisches Entriegeln active
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit not active
IDE05142-ENG116706-Access control-Autounlock NAR not active
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB not active
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung active
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster active
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels active
IDE05142-ENG115722-Access control-Electrical rear lid not active
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang not active
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein not active
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster not active
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein not active
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung not active
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren active
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung not active
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung active
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock adjustable
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt not active
IDE05142-ENG115755-Access control-Notschließfunktion active
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung not active
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe not active
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung Always
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden Always
IDE05142-ENG115758-Access control-Valet Parking not active
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe not active
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT not active
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer not active
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel active
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen not active
IDE05142-ENG116623-Access control-ZV Tuerentriegelung Globale Entriegelung
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash not active
IDE05144-Read parameter address 00 00 00
IDE05145-ENG115874-Light configuration-BAP Bitposition 0 34
IDE05145-ENG115893-Light configuration-BAP Bitposition 1 3E
IDE05145-ENG116063-Light configuration-BAP Bitposition 10 37
IDE05145-ENG116082-Light configuration-BAP Bitposition 11 41
IDE05145-ENG116101-Light configuration-BAP Bitposition 12 0
IDE05145-ENG116120-Light configuration-BAP Bitposition 13 0
IDE05145-ENG116139-Light configuration-BAP Bitposition 14 0
IDE05145-ENG116158-Light configuration-BAP Bitposition 15 0
IDE05145-ENG116177-Light configuration-BAP Bitposition 16 0
IDE05145-ENG116196-Light configuration-BAP Bitposition 17 0
IDE05145-ENG116215-Light configuration-BAP Bitposition 18 8
IDE05145-ENG116234-Light configuration-BAP Bitposition 19 18
IDE05145-ENG115911-Light configuration-BAP Bitposition 2 48
IDE05145-ENG116253-Light configuration-BAP Bitposition 20 10
IDE05145-ENG116272-Light configuration-BAP Bitposition 21 20
IDE05145-ENG116291-Light configuration-BAP Bitposition 22 29
IDE05145-ENG116310-Light configuration-BAP Bitposition 23 0
IDE05145-ENG116329-Light configuration-BAP Bitposition 24 0
IDE05145-ENG116348-Light configuration-BAP Bitposition 25 28
IDE05145-ENG116367-Light configuration-BAP Bitposition 26 1C
IDE05145-ENG116386-Light configuration-BAP Bitposition 27 1A
IDE05145-ENG116405-Light configuration-BAP Bitposition 28 0B
IDE05145-ENG116424-Light configuration-BAP Bitposition 29 1B
IDE05145-ENG115930-Light configuration-BAP Bitposition 3 4C
IDE05145-ENG116443-Light configuration-BAP Bitposition 30 0
IDE05145-ENG116462-Light configuration-BAP Bitposition 31 0
IDE05145-ENG116481-Light configuration-BAP Bitposition 32 0
IDE05145-ENG116500-Light configuration-BAP Bitposition 33 0
IDE05145-ENG116519-Light configuration-BAP Bitposition 34 0
IDE05145-ENG115949-Light configuration-BAP Bitposition 4 3A
IDE05145-ENG115968-Light configuration-BAP Bitposition 5 44
IDE05145-ENG115987-Light configuration-BAP Bitposition 6 36
IDE05145-ENG116006-Light configuration-BAP Bitposition 7 40
IDE05145-ENG116025-Light configuration-BAP Bitposition 8 35
IDE05145-ENG116044-Light configuration-BAP Bitposition 9 3F
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0 maximize
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1 maximize
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10 maximize
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11 maximize
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12 maximize
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13 maximize
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14 maximize
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15 maximize
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16 maximize
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17 maximize
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18 maximize
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19 maximize
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2 maximize
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20 maximize
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21 maximize
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22 maximize
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23 maximize
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24 maximize
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25 maximize
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26 maximize
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27 maximize
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28 maximize
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29 maximize
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3 maximize
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30 maximize
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31 maximize
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32 maximize
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33 maximize
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34 maximize
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4 maximize
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5 maximize
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6 maximize
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7 maximize
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8 maximize
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9 maximize
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0 maximize
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1 maximize
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10 maximize
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11 maximize
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12 maximize
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13 maximize
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14 maximize
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15 maximize
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16 maximize
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17 maximize
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18 maximize
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19 maximize
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2 maximize
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20 maximize
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21 maximize
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22 maximize
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23 minimize
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24 minimize
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25 maximize
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26 maximize
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27 maximize
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28 maximize
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29 maximize
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3 maximize
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30 maximize
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31 maximize
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32 maximize
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33 maximize
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34 maximize
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4 maximize
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5 maximize
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6 maximize
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7 maximize
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8 maximize
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9 maximize
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0 maximize
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1 maximize
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10 maximize
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11 maximize
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12 maximize
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13 maximize
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14 maximize
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15 maximize
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16 maximize
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17 maximize
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18 maximize
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19 maximize
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2 maximize
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20 maximize
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21 maximize
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22 maximize
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23 maximize
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24 maximize
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25 maximize
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26 maximize
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27 maximize
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28 maximize
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29 maximize
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3 maximize
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30 maximize
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31 maximize
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32 maximize
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33 maximize
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34 maximize
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4 maximize
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5 maximize
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6 maximize
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7 maximize
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8 maximize
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9 maximize
IDE05145-ENG115878-Light configuration-Dimmwert AB 0 127
IDE05145-ENG115897-Light configuration-Dimmwert AB 1 127
IDE05145-ENG116067-Light configuration-Dimmwert AB 10 127
IDE05145-ENG116086-Light configuration-Dimmwert AB 11 127
IDE05145-ENG116105-Light configuration-Dimmwert AB 12 0
IDE05145-ENG116124-Light configuration-Dimmwert AB 13 0
IDE05145-ENG116143-Light configuration-Dimmwert AB 14 0
IDE05145-ENG116162-Light configuration-Dimmwert AB 15 0
IDE05145-ENG116181-Light configuration-Dimmwert AB 16 100
IDE05145-ENG116200-Light configuration-Dimmwert AB 17 100
IDE05145-ENG116219-Light configuration-Dimmwert AB 18 100
IDE05145-ENG116238-Light configuration-Dimmwert AB 19 100
IDE05145-ENG115915-Light configuration-Dimmwert AB 2 100
IDE05145-ENG116257-Light configuration-Dimmwert AB 20 100
IDE05145-ENG116276-Light configuration-Dimmwert AB 21 100
IDE05145-ENG116295-Light configuration-Dimmwert AB 22 100
IDE05145-ENG116314-Light configuration-Dimmwert AB 23 100
IDE05145-ENG116333-Light configuration-Dimmwert AB 24 100
IDE05145-ENG116352-Light configuration-Dimmwert AB 25 127
IDE05145-ENG116371-Light configuration-Dimmwert AB 26 100
IDE05145-ENG116390-Light configuration-Dimmwert AB 27 10
IDE05145-ENG116409-Light configuration-Dimmwert AB 28 86
IDE05145-ENG116428-Light configuration-Dimmwert AB 29 86
IDE05145-ENG115934-Light configuration-Dimmwert AB 3 100
IDE05145-ENG116447-Light configuration-Dimmwert AB 30 89
IDE05145-ENG116466-Light configuration-Dimmwert AB 31 0
IDE05145-ENG116485-Light configuration-Dimmwert AB 32 0
IDE05145-ENG116504-Light configuration-Dimmwert AB 33 0
IDE05145-ENG116523-Light configuration-Dimmwert AB 34 0
IDE05145-ENG115953-Light configuration-Dimmwert AB 4 127
IDE05145-ENG115972-Light configuration-Dimmwert AB 5 127
IDE05145-ENG115991-Light configuration-Dimmwert AB 6 127
IDE05145-ENG116010-Light configuration-Dimmwert AB 7 127
IDE05145-ENG116029-Light configuration-Dimmwert AB 8 127
IDE05145-ENG116048-Light configuration-Dimmwert AB 9 127
IDE05145-ENG115882-Light configuration-Dimmwert CD 0 0
IDE05145-ENG115901-Light configuration-Dimmwert CD 1 0
IDE05145-ENG116071-Light configuration-Dimmwert CD 10 0
IDE05145-ENG116090-Light configuration-Dimmwert CD 11 0
IDE05145-ENG116109-Light configuration-Dimmwert CD 12 0
IDE05145-ENG116128-Light configuration-Dimmwert CD 13 0
IDE05145-ENG116147-Light configuration-Dimmwert CD 14 0
IDE05145-ENG116166-Light configuration-Dimmwert CD 15 0
IDE05145-ENG116185-Light configuration-Dimmwert CD 16 0
IDE05145-ENG116204-Light configuration-Dimmwert CD 17 0
IDE05145-ENG116223-Light configuration-Dimmwert CD 18 0
IDE05145-ENG116242-Light configuration-Dimmwert CD 19 0
IDE05145-ENG115919-Light configuration-Dimmwert CD 2 26
IDE05145-ENG116261-Light configuration-Dimmwert CD 20 10
IDE05145-ENG116280-Light configuration-Dimmwert CD 21 10
IDE05145-ENG116299-Light configuration-Dimmwert CD 22 0
IDE05145-ENG116318-Light configuration-Dimmwert CD 23 10
IDE05145-ENG116337-Light configuration-Dimmwert CD 24 10
IDE05145-ENG116356-Light configuration-Dimmwert CD 25 0
IDE05145-ENG116375-Light configuration-Dimmwert CD 26 0
IDE05145-ENG116394-Light configuration-Dimmwert CD 27 0
IDE05145-ENG116413-Light configuration-Dimmwert CD 28 0
IDE05145-ENG116432-Light configuration-Dimmwert CD 29 0
IDE05145-ENG115938-Light configuration-Dimmwert CD 3 26
IDE05145-ENG116451-Light configuration-Dimmwert CD 30 0
IDE05145-ENG116470-Light configuration-Dimmwert CD 31 0
IDE05145-ENG116489-Light configuration-Dimmwert CD 32 0
IDE05145-ENG116508-Light configuration-Dimmwert CD 33 0
IDE05145-ENG116527-Light configuration-Dimmwert CD 34 0
IDE05145-ENG115957-Light configuration-Dimmwert CD 4 127
IDE05145-ENG115976-Light configuration-Dimmwert CD 5 127
IDE05145-ENG115995-Light configuration-Dimmwert CD 6 0
IDE05145-ENG116014-Light configuration-Dimmwert CD 7 0
IDE05145-ENG116033-Light configuration-Dimmwert CD 8 0
IDE05145-ENG116052-Light configuration-Dimmwert CD 9 0
IDE05145-ENG115886-Light configuration-Dimmwert EF 0 0
IDE05145-ENG115905-Light configuration-Dimmwert EF 1 0
IDE05145-ENG116075-Light configuration-Dimmwert EF 10 0
IDE05145-ENG116094-Light configuration-Dimmwert EF 11 0
IDE05145-ENG116113-Light configuration-Dimmwert EF 12 0
IDE05145-ENG116132-Light configuration-Dimmwert EF 13 0
IDE05145-ENG116151-Light configuration-Dimmwert EF 14 0
IDE05145-ENG116170-Light configuration-Dimmwert EF 15 0
IDE05145-ENG116189-Light configuration-Dimmwert EF 16 0
IDE05145-ENG116208-Light configuration-Dimmwert EF 17 0
IDE05145-ENG116227-Light configuration-Dimmwert EF 18 0
IDE05145-ENG116246-Light configuration-Dimmwert EF 19 0
IDE05145-ENG115923-Light configuration-Dimmwert EF 2 0
IDE05145-ENG116265-Light configuration-Dimmwert EF 20 0
IDE05145-ENG116284-Light configuration-Dimmwert EF 21 0
IDE05145-ENG116303-Light configuration-Dimmwert EF 22 0
IDE05145-ENG116322-Light configuration-Dimmwert EF 23 0
IDE05145-ENG116341-Light configuration-Dimmwert EF 24 0
IDE05145-ENG116360-Light configuration-Dimmwert EF 25 0
IDE05145-ENG116379-Light configuration-Dimmwert EF 26 0
IDE05145-ENG116398-Light configuration-Dimmwert EF 27 0
IDE05145-ENG116417-Light configuration-Dimmwert EF 28 0
IDE05145-ENG116436-Light configuration-Dimmwert EF 29 0
IDE05145-ENG115942-Light configuration-Dimmwert EF 3 0
IDE05145-ENG116455-Light configuration-Dimmwert EF 30 0
IDE05145-ENG116474-Light configuration-Dimmwert EF 31 0
IDE05145-ENG116493-Light configuration-Dimmwert EF 32 0
IDE05145-ENG116512-Light configuration-Dimmwert EF 33 0
IDE05145-ENG116531-Light configuration-Dimmwert EF 34 0
IDE05145-ENG115961-Light configuration-Dimmwert EF 4 0
IDE05145-ENG115980-Light configuration-Dimmwert EF 5 0
IDE05145-ENG115999-Light configuration-Dimmwert EF 6 0
IDE05145-ENG116018-Light configuration-Dimmwert EF 7 0
IDE05145-ENG116037-Light configuration-Dimmwert EF 8 0
IDE05145-ENG116056-Light configuration-Dimmwert EF 9 0
IDE05145-ENG115890-Light configuration-Dimmwert GH 0 0
IDE05145-ENG115908-Light configuration-Dimmwert GH 1 0
IDE05145-ENG116079-Light configuration-Dimmwert GH 10 0
IDE05145-ENG116098-Light configuration-Dimmwert GH 11 0
IDE05145-ENG116117-Light configuration-Dimmwert GH 12 0
IDE05145-ENG116136-Light configuration-Dimmwert GH 13 0
IDE05145-ENG116155-Light configuration-Dimmwert GH 14 0
IDE05145-ENG116174-Light configuration-Dimmwert GH 15 0
IDE05145-ENG116193-Light configuration-Dimmwert GH 16 0
IDE05145-ENG116212-Light configuration-Dimmwert GH 17 0
IDE05145-ENG116231-Light configuration-Dimmwert GH 18 0
IDE05145-ENG116250-Light configuration-Dimmwert GH 19 0
IDE05145-ENG115927-Light configuration-Dimmwert GH 2 0
IDE05145-ENG116269-Light configuration-Dimmwert GH 20 0
IDE05145-ENG116288-Light configuration-Dimmwert GH 21 0
IDE05145-ENG116307-Light configuration-Dimmwert GH 22 0
IDE05145-ENG116326-Light configuration-Dimmwert GH 23 0
IDE05145-ENG116345-Light configuration-Dimmwert GH 24 0
IDE05145-ENG116364-Light configuration-Dimmwert GH 25 0
IDE05145-ENG116383-Light configuration-Dimmwert GH 26 0
IDE05145-ENG116402-Light configuration-Dimmwert GH 27 0
IDE05145-ENG116421-Light configuration-Dimmwert GH 28 0
IDE05145-ENG116440-Light configuration-Dimmwert GH 29 0
IDE05145-ENG115946-Light configuration-Dimmwert GH 3 0
IDE05145-ENG116459-Light configuration-Dimmwert GH 30 0
IDE05145-ENG116478-Light configuration-Dimmwert GH 31 0
IDE05145-ENG116497-Light configuration-Dimmwert GH 32 0
IDE05145-ENG116516-Light configuration-Dimmwert GH 33 0
IDE05145-ENG116535-Light configuration-Dimmwert GH 34 0
IDE05145-ENG115965-Light configuration-Dimmwert GH 4 0
IDE05145-ENG115984-Light configuration-Dimmwert GH 5 0
IDE05145-ENG116003-Light configuration-Dimmwert GH 6 0
IDE05145-ENG116022-Light configuration-Dimmwert GH 7 0
IDE05145-ENG116041-Light configuration-Dimmwert GH 8 0
IDE05145-ENG116060-Light configuration-Dimmwert GH 9 0
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0 14
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1 15
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10 1E
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11 1F
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12 0
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13 0
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14 0
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15 0
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16 41
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17 42
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18 16
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19 18
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2 4A
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20 39
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21 3A
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22 2C
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23 0
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24 0
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25 30
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26 2F
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27 2A
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28 31
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29 32
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3 4C
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30 2
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31 0
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32 0
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33 0
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34 0
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4 49
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5 4B
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6 1A
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7 1B
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8 26
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9 27
IDE05145-ENG115873-Light configuration-Lasttyp 0 33 - LED-Modul Blinkleuchten
IDE05145-ENG115892-Light configuration-Lasttyp 1 33 - LED-Modul Blinkleuchten
IDE05145-ENG116062-Light configuration-Lasttyp 10 2 - Shutter: Diagnosesensierung für 'LED low'
IDE05145-ENG116081-Light configuration-Lasttyp 11 2 - Shutter: Diagnosesensierung für 'LED low'
IDE05145-ENG116100-Light configuration-Lasttyp 12 not active
IDE05145-ENG116119-Light configuration-Lasttyp 13 not active
IDE05145-ENG116138-Light configuration-Lasttyp 14 not active
IDE05145-ENG116157-Light configuration-Lasttyp 15 not active
IDE05145-ENG116176-Light configuration-Lasttyp 16 37 - allgemeine LED bis 12W
IDE05145-ENG116195-Light configuration-Lasttyp 17 37 - allgemeine LED bis 12W
IDE05145-ENG116214-Light configuration-Lasttyp 18 38 - LED Blinkleuchten
IDE05145-ENG116233-Light configuration-Lasttyp 19 38 - LED Blinkleuchten
IDE05145-ENG115910-Light configuration-Lasttyp 2 4 - LED Tagfahrlichtmodul Signal
IDE05145-ENG116252-Light configuration-Lasttyp 20 34 - LED Bremsleuchten
IDE05145-ENG116271-Light configuration-Lasttyp 21 34 - LED Bremsleuchten
IDE05145-ENG116290-Light configuration-Lasttyp 22 42 - LED dritte Bremsleuchte
IDE05145-ENG116309-Light configuration-Lasttyp 23 34 - LED Bremsleuchten
IDE05145-ENG116328-Light configuration-Lasttyp 24 34 - LED Bremsleuchten
IDE05145-ENG116347-Light configuration-Lasttyp 25 43 - allgemeine LED
IDE05145-ENG116366-Light configuration-Lasttyp 26 1 - LED Tagfahrlichtmodul Versorgung
IDE05145-ENG116385-Light configuration-Lasttyp 27 32 - allgemeine LED bis 12W
IDE05145-ENG116404-Light configuration-Lasttyp 28 9 - allgemeine Glühlampe 27W: auch H15
IDE05145-ENG116423-Light configuration-Lasttyp 29 9 - allgemeine Glühlampe 27W: auch H15
IDE05145-ENG115929-Light configuration-Lasttyp 3 4 - LED Tagfahrlichtmodul Signal
IDE05145-ENG116442-Light configuration-Lasttyp 30 36 - LED Kleinleistung
IDE05145-ENG116461-Light configuration-Lasttyp 31 not active
IDE05145-ENG116480-Light configuration-Lasttyp 32 not active
IDE05145-ENG116499-Light configuration-Lasttyp 33 not active
IDE05145-ENG116518-Light configuration-Lasttyp 34 not active
IDE05145-ENG115948-Light configuration-Lasttyp 4 6 - LED Lichtmodul
IDE05145-ENG115967-Light configuration-Lasttyp 5 6 - LED Lichtmodul
IDE05145-ENG115986-Light configuration-Lasttyp 6 3 - Xenon Abblendlicht
IDE05145-ENG116005-Light configuration-Lasttyp 7 3 - Xenon Abblendlicht
IDE05145-ENG116024-Light configuration-Lasttyp 8 36 - LED Kleinleistung
IDE05145-ENG116043-Light configuration-Lasttyp 9 36 - LED Kleinleistung
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0 Always
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1 Always
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10 Always
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11 Always
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12 Always
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13 Always
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14 Always
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15 Always
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16 only_if_closed
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17 only_if_closed
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18 Always
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19 Always
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2 Always
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20 Always
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21 Always
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22 Always
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23 Always
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24 Always
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25 Always
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26 only_if_closed
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27 only_if_closed
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28 only_if_closed
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29 only_if_closed
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3 Always
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30 Always
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31 Always
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32 Always
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33 Always
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34 Always
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4 Always
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5 Always
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6 Always
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7 Always
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8 Always
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9 Always
IDE05145-ENG116199-Light configuration-Lichtfunktion B 17 0
IDE05145-ENG116126-Light configuration-Lichtfunktion C 13 0
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0 2
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1 4
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10 13
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11 14
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12 0
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13 0
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14 0
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15 0
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16 2
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17 4
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18 2
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19 4
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2 20
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20 24
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21 24
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22 24
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23 24
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24 24
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25 8
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26 28
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27 8
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28 25
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29 25
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3 20
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30 43
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31 0
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32 0
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33 0
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34 0
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4 20
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5 20
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6 11
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7 12
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8 8
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9 8
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0 0
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1 0
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10 15
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11 15
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12 0
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13 0
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14 0
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15 0
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16 0
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18 0
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19 0
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2 0
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20 0
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21 0
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22 0
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23 0
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24 0
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25 0
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26 0
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27 0
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28 0
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29 0
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3 0
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30 0
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31 0
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32 0
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33 0
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34 0
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4 0
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5 0
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6 15
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7 15
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8 9
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9 10
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0 0
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1 0
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10 0
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11 0
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12 0
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14 0
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15 0
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16 0
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17 0
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18 0
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19 0
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2 8
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20 8
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21 8
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22 0
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23 8
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24 8
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25 0
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26 0
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27 0
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28 0
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29 0
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3 8
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30 0
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31 0
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32 0
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33 0
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34 0
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4 8
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5 8
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6 0
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7 0
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8 0
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9 0
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0 0
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1 0
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10 0
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11 0
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12 0
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13 0
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14 0
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15 0
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16 0
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17 0
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18 0
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19 0
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2 9
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20 9
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21 10
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22 0
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23 9
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24 10
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25 0
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26 0
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27 0
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28 0
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29 0
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3 10
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30 0
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31 0
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32 0
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33 0
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34 0
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4 9
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5 10
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6 0
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7 0
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8 0
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9 0
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0 0
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1 0
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10 0
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11 0
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12 0
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13 0
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14 0
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15 0
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16 0
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17 0
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18 0
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19 0
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2 0
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20 0
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21 0
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22 0
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23 6
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24 7
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25 0
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26 0
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27 0
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28 0
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29 0
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3 0
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30 0
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31 0
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32 0
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33 0
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34 0
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4 0
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5 0
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6 0
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7 0
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8 0
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9 0
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0 0
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1 0
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10 0
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11 0
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12 0
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13 0
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14 0
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15 0
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16 0
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17 0
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18 0
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19 0
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2 0
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20 0
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21 0
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22 0
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23 0
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24 0
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25 0
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26 0
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27 0
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28 0
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29 0
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30 0
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31 0
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32 0
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33 0
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34 0
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4 0
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6 0
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7 0
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8 0
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9 0
IDE05145-ENG115941-Light configuration-Lichtfunktion F3 0
IDE05145-ENG115979-Light configuration-Lichtfunktion F5 0
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0 0
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1 0
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10 0
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11 0
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12 0
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13 0
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14 0
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15 0
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16 0
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17 0
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18 0
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19 0
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2 0
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20 0
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21 0
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22 0
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23 0
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24 0
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25 0
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26 0
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27 0
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28 0
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29 0
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3 0
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30 0
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31 0
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32 0
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33 0
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34 0
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4 0
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5 0
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6 0
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7 0
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8 0
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9 0
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0 0
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1 0
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10 0
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11 0
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12 0
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13 0
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14 0
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15 0
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16 0
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17 0
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18 0
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19 0
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2 0
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20 0
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21 0
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22 0
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23 0
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24 0
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25 0
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26 0
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27 0
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28 0
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29 0
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3 0
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30 0
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31 0
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32 0
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33 0
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34 0
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4 0
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5 0
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6 0
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7 0
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8 0
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9 0
IDE05145-ENG154438-Light configuration-Reserved 0 0
IDE05145-ENG99841-Light configuration-Reserved 1 0
IDE05145-ENG154357-Light configuration-Reserved 10 0
IDE05145-ENG154352-Light configuration-Reserved 11 0
IDE05145-ENG154182-Light configuration-Reserved 12 0
IDE05145-ENG154265-Light configuration-Reserved 13 0
IDE05145-ENG154334-Light configuration-Reserved 14 0
IDE05145-ENG154340-Light configuration-Reserved 15 0
IDE05145-ENG154204-Light configuration-Reserved 16 0
IDE05145-ENG154344-Light configuration-Reserved 17 0
IDE05145-ENG154195-Light configuration-Reserved 18 0
IDE05145-ENG154190-Light configuration-Reserved 19 0
IDE05145-ENG99862-Light configuration-Reserved 2 0
IDE05145-ENG154300-Light configuration-Reserved 20 0
IDE05145-ENG154439-Light configuration-Reserved 21 0
IDE05145-ENG154440-Light configuration-Reserved 22 0
IDE05145-ENG154441-Light configuration-Reserved 23 0
IDE05145-ENG154442-Light configuration-Reserved 24 0
IDE05145-ENG154443-Light configuration-Reserved 25 0
IDE05145-ENG154444-Light configuration-Reserved 26 0
IDE05145-ENG154445-Light configuration-Reserved 27 0
IDE05145-ENG154446-Light configuration-Reserved 28 0
IDE05145-ENG154447-Light configuration-Reserved 29 0
IDE05145-ENG101107-Light configuration-Reserved 3 0
IDE05145-ENG154448-Light configuration-Reserved 30 0
IDE05145-ENG154449-Light configuration-Reserved 31 0
IDE05145-ENG154450-Light configuration-Reserved 32 0
IDE05145-ENG154451-Light configuration-Reserved 33 0
IDE05145-ENG154452-Light configuration-Reserved 34 0
IDE05145-ENG154267-Light configuration-Reserved 4 0
IDE05145-ENG154291-Light configuration-Reserved 5 0
IDE05145-ENG154239-Light configuration-Reserved 6 0
IDE05145-ENG154308-Light configuration-Reserved 7 0
IDE05145-ENG154184-Light configuration-Reserved 8 0
IDE05145-ENG154255-Light configuration-Reserved 9 0
IDE05822-DWA Vehicle inclination sensor 100%
IDE05823-DWA Interior monitoring parameter set 01 0A 08 00 43 63 0A 78 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 24 42 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 03 32 3F 3A 69 58 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 03 22 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 03 22 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 45 42 57 9B 24 22 0C FA 0A 34 95 0D 09 A3 21 43 34 02 02 02 02 02 02 B1 10 22 29 67
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss 1 s
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss 0.00 °C
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle 22.50 °C
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle 21.50 °C
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle 22.50 °C
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle 21.50 °C
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle 36.00 °C
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle 35.00 °C
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle 36.00 °C
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle 35.00 °C
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle 53.50 °C
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle 52.50 °C
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle 53.50 °C
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle 52.50 °C
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten active
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM not active
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe not active
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten not active
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung active
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert 100%
IDE06425-Roller test bench mode: functional not active
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag Daytime running lights
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht not active
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht not active
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich not active
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten not active
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO not active
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht not active
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte not active
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge active
IDE07356-Position during interval mode 31.49 °
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs abschalten nach der Nachlaufzeit
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit 30 min
IDE08542-IDE02021-Access control 2-Comfort closing active
IDE08542-IDE02022-Access control 2-Comfort opening not active
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen active
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen active
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit 600 s
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus active
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen active
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen active
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen active
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen not active
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus by convenience operation via remote control key
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen not active
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen active
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung not active
IDE08542-ENG115670-Access control 2-Komfortbedienung global active
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer not active
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen not active
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar adjustable
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen not active
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung active
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung active
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf not active
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel active
IDE08542-ENG125656-Access control 2-Regenschliessen_art once
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus not active
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock not active
IDE08542-ENG154261-Access control 2-Reserved_4 not active
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen active
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen active
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen active
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen tilting
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen not active
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen not active
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung active
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt active
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron active
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal not active
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar not active
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung 2000 ms
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen active
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach not active
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig kein_Hinweis
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset not active
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert 0 ms
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit normal
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe not active
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent Not Present
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung present
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA active
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte not active
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben active
IDE08787-ENG101416-Auxiliary functions-Reserved_1 not active
IDE08787-ENG99458-Auxiliary functions-Reserved_2 not active
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15 active
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren not active
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT not active
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken not active
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing not active
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken not active
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung not active
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken not active
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken not active
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2 not active
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing not active
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links not active
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts not active
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken not active
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing not active
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken not active
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken not active
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS not active
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN not active
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf not active
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu not active
IDE09595-ENG115658-Characteristic curve-x0 0 lx
IDE09595-ENG101574-Characteristic curve-X1 2000 lx
IDE09595-ENG99557-Characteristic curve-X2 4000 lx
IDE09595-ENG102140-Characteristic curve-X3 6000 lx
IDE09595-ENG102936-Characteristic curve-X4 8000 lx
IDE09595-ENG103548-Characteristic curve-X5 10200 lx
IDE09595-ENG148955-Characteristic curve-y1_0 0
IDE09595-ENG148956-Characteristic curve-y1_1 40
IDE09595-ENG148957-Characteristic curve-y1_2 90
IDE09595-ENG148958-Characteristic curve-y1_3 140
IDE09595-ENG148959-Characteristic curve-y1_4 190
IDE09595-ENG148960-Characteristic curve-y1_5 245
IDE09595-ENG148961-Characteristic curve-y2_0 0
IDE09595-ENG148962-Characteristic curve-y2_1 60
IDE09595-ENG148963-Characteristic curve-y2_2 110
IDE09595-ENG148964-Characteristic curve-y2_3 160
IDE09595-ENG148965-Characteristic curve-y2_4 210
IDE09595-ENG148966-Characteristic curve-y2_5 255
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit 0.10 s
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1 2
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2 3
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3 1
IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1 225
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2 225
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3 225
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig not active
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig not active
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach 80%
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe 2
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole 80%
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen active
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen active
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen active
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen active
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen active
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen active
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen not active
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1 225
IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2 225
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3 225
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen not active
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen active
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen not active
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen not active
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen active
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen active
IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen not active
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig not active
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig not active
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig not active
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren not active
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig not active
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1 225
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2 225
IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3 225
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig active
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel not active
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel not installed
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel installed
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher not installed
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen not active
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus not active
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung not installed
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung not installed
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil not installed
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI not installed
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting installed
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar not active
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung not installed
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung not installed
IDE09733-ENG147407-LED bar setting values-Filterzeit Anpassung 3000 ms
IDE09733-ENG147406-LED bar setting values-Filterzeit Umgebungshelligkeit 1000 ms
IDE09733-ENG148967-LED bar setting values-Maximale Dauer fuer konstante Anzeige 0 s
IDE09733-ENG148968-LED bar setting values-Maximale Helligkeitsdifferenz 25
IDE09733-ENG148971-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor 0
IDE09733-ENG148969-LED bar setting values-Schwellwert Plausibilisierung RLS 393210 lx
IDE09733-ENG148970-LED bar setting values-Schwellwert Plausibilisierung SLS 393210 lx
IDE09733-ENG147405-LED bar setting values-Sperrzeit 0 s
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne 30%
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz 25%
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne 30%
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz 25%
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne 58%
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz 53%
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne 58%
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz 53%
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne 85%
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz 80%
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne 85%
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz 80%
IDE10298-Alternating park position 1 7.49 °
IDE10299-Alternating park position 2 29.49 °
MAS01490-Energy management active
MAS05055-lower turn position 31.49 °
MAS05056-upper turn position 170.49 °
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck active
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb not active
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG not active
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global active
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen active
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen active
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen not active
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach not active
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung active
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy active
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder active
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung active
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy active
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder active
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein not active
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1 1
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10 1
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11 1
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12 1
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13 1
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14 1
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15 1
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2 1
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3 1
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4 1
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5 1
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6 1
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7 1
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8 1
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9 1
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1 door
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10 door
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11 door
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12 door
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13 door
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14 door
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15 door
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2 door
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3 door
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4 door
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5 door
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6 door
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7 door
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8 door
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9 door
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1 not installed
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10 not installed
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11 not installed
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12 not installed
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13 not installed
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14 not installed
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15 not installed
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2 not installed
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3 not installed
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4 not installed
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5 not installed
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6 not installed
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7 not installed
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8 not installed
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9 not installed
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12 0
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1 0
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10 0
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11 0
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13 0
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14 0
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15 0
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16 0
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17 0
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18 0
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19 0
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2 0
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20 0
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3 0
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4 0
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5 0
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6 0
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7 0
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8 0
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9 0
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1 0
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10 0
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11 0
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12 0
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13 0
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14 0
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15 0
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16 0
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17 0
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18 0
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19 0
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2 0
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20 0
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3 0
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4 0
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5 0
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6 0
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7 0
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9 0
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8 0
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1 not installed
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10 not installed
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11 not installed
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12 not installed
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13 not installed
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14 not installed
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15 not installed
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16 not installed
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17 not installed
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18 not installed
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19 not installed
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2 not installed
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20 not installed
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3 not installed
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4 not installed
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5 not installed
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6 not installed
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7 not installed
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9 not installed
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8 not installed
ENG126647-ENG98399-debug_light_function-Activation 0
ENG126647-ENG101417-debug_light_function-Adresse 0
ENG126647-ENG126820-debug_light_function-Bitmask 0
ENG126647-ENG126821-debug_light_function-Divisor 0
ENG126647-ENG98827-debug_light_function-Offset 0
ENG126647-ENG126822-debug_light_function-Polaritaet 0
ENG126647-ENG126823-debug_light_function-WBT-Ausgabe 0
ENG122925-DWA_Interior_Monitoring_Data_Set_Development FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
ENG122934-erase_error_table 55 00 00
ENG122933-error_mask 0 bit
ENG117283-ENG122998-Frontwaschfunktion-factor_washing_delay 10
ENG117283-ENG108451-Frontwaschfunktion-reserve 0
ENG99457-ENG117394-Head area heater-blower_speed 1
ENG99457-ENG98971-Head area heater-Temperature -2
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0 0 ms
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1 200 ms
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10 2000 ms
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2 400 ms
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3 600 ms
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4 800 ms
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5 1000 ms
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6 1200 ms
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7 1400 ms
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8 1600 ms
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9 1800 ms
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0 100.00%
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1 72.00%
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10 0.00%
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2 48.00%
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3 33.00%
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4 18.00%
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5 12.00%
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6 8.00%
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7 6.00%
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8 4.00%
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9 2.00%
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0 0
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1 50
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10 0
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2 100
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3 200
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4 253
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5 0
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6 0
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7 0
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8 0
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9 0
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0 0 lx
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1 50 lx
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10 0 lx
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2 100 lx
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3 200
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4 500
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5 0
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6 0 lx
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7 0 lx
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8 0 lx
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9 0 lx
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0 0 ms
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1 200 ms
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10 2000 ms
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2 400 ms
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3 600 ms
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4 800 ms
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5 1000 ms
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6 1200 ms
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7 1400 ms
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8 1600 ms
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9 1800 ms
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0 0.00%
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1 1.00%
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10 100.00%
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2 3.00%
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3 5.00%
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4 11.00%
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5 22.00%
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6 40.00%
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7 80.00%
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8 95.00%
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9 100.00%
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0 0.00%
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1 6.00%
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2 16.00%
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3 30.00%
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4 60.00%
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5 100.00%
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0 10
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1 10
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2 100
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3 150
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4 220
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5 253
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0 0 lx
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1 8 lx
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2 200 lx
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3 300 lx
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4 500 lx
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0 16
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1 16
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2 100
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3 100
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4 100
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0 0 lx
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1 8 lx
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2 220 lx
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3 300 lx
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4 500 lx
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0 6
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1 6
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2 100
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3 100
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4 100
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0 0
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1 10
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2 50
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3 100
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4 220
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5 253
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0 2.00%
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1 2.00%
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2 6.00%
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3 10.00%
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4 80.00%
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5 100.00%
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0 0 lx
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1 8 lx
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2 50 lx
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3 500 lx
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0 100
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1 100
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2 100
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3 100
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0 0 lx
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1 8 lx
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2 50 lx
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3 500 lx
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0 6
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1 6
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2 100
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3 100
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0 0.00%
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1 50.00%
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2 100.00%
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0 0.00%
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1 50.00%
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2 100.00%
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0 0 lx
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1 8 lx
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2 50 lx
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3 500 lx
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0 100
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1 100
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2 100
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3 100
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0 0 lx
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1 8 lx
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2 50 lx
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3 500 lx
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0 6
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1 6
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2 100
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3 100
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0 0.00%
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1 50.00%
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2 100.00%
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0 0.00%
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1 50.00%
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2 100.00%
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0 0 ms
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1 100 ms
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2 160 ms
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3 200 ms
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4 260 ms
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0 1.00%
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1 5
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2 15
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3 10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4 100
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0 maximize
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0 maximize
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0 maximize
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0 127
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0 0
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0 0
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0 0
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0 14
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0 34
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0 33 - LED-Modul Blinkleuchten
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0 Always
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0 Blinken links Hellphase
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0 not active
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0 not active
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0 not active
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0 not active
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0 not active
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0 not active
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0 not active
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10 maximize
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10 maximize
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10 maximize
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10 127
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10 0
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10 0
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10 0
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10 1E
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10 37
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10 2 - Shutter: Diagnosesensierung für 'LED low'
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10 Always
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10 Left high beam
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10 Lichthupe generell
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10 not active
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10 not active
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10 not active
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10 not active
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10 not active
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10 not active
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11 maximize
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11 maximize
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11 maximize
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11 127
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11 0
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11 0
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11 0
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11 1F
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11 41
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11 2 - Shutter: Diagnosesensierung für 'LED low'
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11 Always
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11 Right high beam
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11 Lichthupe generell
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11 not active
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11 not active
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11 not active
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11 not active
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11 not active
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11 not active
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12 maximize
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12 maximize
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12 maximize
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12 0
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12 0
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12 0
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12 0
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12 0
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12 0
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12 not active
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12 Always
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12 not active
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12 not active
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12 not active
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12 not active
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12 not active
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12 not active
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12 not active
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12 not active
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13 maximize
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13 maximize
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13 maximize
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13 0
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13 0
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13 0
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13 0
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13 0
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13 0
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13 not active
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13 Always
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13 not active
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13 not active
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13 not active
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13 not active
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13 not active
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13 not active
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13 not active
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13 not active
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15 maximize
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15 maximize
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15 maximize
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15 0
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15 0
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15 0
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15 0
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15 0
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15 0
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15 not active
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15 Always
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15 not active
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15 not active
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15 not active
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15 not active
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15 not active
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15 not active
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15 not active
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15 not active
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16 maximize
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16 maximize
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16 maximize
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16 100
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16 0
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16 0
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16 0
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16 41
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16 0
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16 37 - allgemeine LED bis 12W
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16 only_if_closed
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16 Blinken links Hellphase
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16 not active
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16 not active
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16 not active
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16 not active
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16 not active
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16 not active
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16 not active
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17 maximize
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17 maximize
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17 maximize
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17 100
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17 0
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17 0
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17 0
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17 42
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17 0
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17 37 - allgemeine LED bis 12W
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17 only_if_closed
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17 Blinken rechts Hellphase
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17 not active
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17 not active
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17 not active
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17 not active
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17 not active
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17 not active
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17 not active
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18 maximize
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18 maximize
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18 maximize
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18 100
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18 0
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18 0
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18 0
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18 16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18 8
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18 38 - LED Blinkleuchten
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18 Always
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18 Blinken links Hellphase
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18 not active
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18 not active
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18 not active
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18 not active
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18 not active
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18 not active
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18 not active
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19 maximize
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19 maximize
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19 maximize
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19 100
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19 0
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19 0
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19 0
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19 18
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19 18
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19 38 - LED Blinkleuchten
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19 Always
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19 Blinken rechts Hellphase
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19 not active
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19 not active
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19 not active
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19 not active
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19 not active
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19 not active
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19 not active
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1 maximize
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1 maximize
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1 maximize
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1 127
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1 0
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1 0
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1 0
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1 15
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1 3E
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1 33 - LED-Modul Blinkleuchten
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1 Always
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1 Blinken rechts Hellphase
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1 not active
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1 not active
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1 not active
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1 not active
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1 not active
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1 not active
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1 not active
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20 maximize
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20 maximize
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20 maximize
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20 100
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20 10
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20 0
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20 0
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20 39
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20 10
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20 34 - LED Bremsleuchten
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20 Always
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20 Brake light
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20 not active
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20 Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20 not active
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20 not active
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20 not active
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20 not active
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21 maximize
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21 maximize
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21 maximize
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21 100
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21 10
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21 0
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21 0
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21 3A
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21 20
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21 34 - LED Bremsleuchten
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21 Always
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21 Brake light
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21 not active
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21 Parking light right
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21 not active
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21 not active
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21 not active
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21 not active
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22 maximize
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22 maximize
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22 maximize
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22 100
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22 0
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22 0
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22 0
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22 2C
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22 29
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22 42 - LED dritte Bremsleuchte
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22 Always
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22 Brake light
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22 not active
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22 not active
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22 not active
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22 not active
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22 not active
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22 not active
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22 not active
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23 maximize
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23 minimize
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23 maximize
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23 100
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23 10
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23 0
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23 0
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23 0
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23 0
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23 34 - LED Bremsleuchten
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23 Always
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23 Brake light
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23 not active
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23 Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23 Blinken links aktiv (beide Phasen)
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23 not active
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23 not active
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23 not active
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24 maximize
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24 minimize
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24 maximize
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24 100
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24 10
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24 0
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24 0
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24 0
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24 0
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24 34 - LED Bremsleuchten
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24 Always
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24 Brake light
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24 not active
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24 Parking light right
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24 Blinken rechts aktiv (beide Phasen)
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24 not active
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24 not active
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24 not active
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25 maximize
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25 maximize
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25 maximize
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25 127
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25 0
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25 0
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25 0
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25 30
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25 28
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25 43 - allgemeine LED
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25 Always
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25 not active
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25 not active
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25 not active
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25 not active
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25 not active
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25 not active
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25 not active
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26 maximize
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26 maximize
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26 maximize
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26 100
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26 0
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26 0
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26 0
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26 2F
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26 1C
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26 1 - LED Tagfahrlichtmodul Versorgung
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26 only_if_closed
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26 Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26 not active
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26 not active
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26 not active
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26 not active
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26 not active
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26 not active
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26 not active
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27 maximize
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27 maximize
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27 maximize
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27 10
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27 0
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27 0
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27 0
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27 2A
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27 1A
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27 32 - allgemeine LED bis 12W
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27 only_if_closed
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27 not active
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27 not active
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27 not active
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27 not active
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27 not active
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27 not active
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27 not active
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28 maximize
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28 maximize
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28 maximize
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28 86
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28 0
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28 0
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28 0
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28 31
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28 0B
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28 9 - allgemeine Glühlampe 27W: auch H15
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28 only_if_closed
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28 Rueckfahrlicht
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28 not active
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28 not active
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28 not active
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28 not active
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28 not active
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28 not active
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28 not active
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29 maximize
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29 maximize
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29 maximize
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29 86
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29 0
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29 0
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29 0
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29 32
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29 1B
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29 9 - allgemeine Glühlampe 27W: auch H15
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29 only_if_closed
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29 Rueckfahrlicht
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29 not active
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29 not active
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29 not active
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29 not active
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29 not active
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29 not active
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29 not active
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2 maximize
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2 maximize
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2 maximize
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2 100
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2 26
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2 0
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2 0
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2 4A
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2 48
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2 4 - LED Tagfahrlichtmodul Signal
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2 Always
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2 Daytime running lights
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2 not active
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2 Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2 not active
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2 not active
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2 not active
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2 not active
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30 maximize
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30 maximize
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30 maximize
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30 89
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30 0
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30 0
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30 0
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30 2
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30 0
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30 36 - LED Kleinleistung
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30 Always
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30 Footwell light
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30 not active
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30 not active
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30 not active
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30 not active
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30 not active
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30 not active
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30 not active
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31 maximize
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31 maximize
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31 maximize
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31 0
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31 0
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31 0
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31 0
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31 0
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31 0
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31 not active
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31 Always
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31 not active
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31 not active
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31 not active
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31 not active
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31 not active
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31 not active
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31 not active
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31 not active
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32 maximize
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32 maximize
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32 maximize
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32 0
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32 0
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32 0
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32 0
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32 0
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32 0
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32 not active
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32 Always
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32 not active
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32 not active
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32 not active
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32 not active
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32 not active
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32 not active
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32 not active
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32 not active
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33 maximize
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33 maximize
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33 maximize
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33 0
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33 0
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33 0
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33 0
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33 0
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33 0
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33 not active
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33 Always
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33 not active
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33 not active
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33 not active
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33 not active
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33 not active
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33 not active
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33 not active
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33 not active
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34 maximize
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34 maximize
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34 maximize
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34 0
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34 0
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34 0
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34 0
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34 0
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34 0
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34 not active
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34 Always
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34 not active
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34 not active
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34 not active
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34 not active
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34 not active
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34 not active
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34 not active
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34 not active
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3 maximize
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3 maximize
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3 maximize
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3 100
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3 26
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3 0
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3 0
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3 4C
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3 4C
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3 4 - LED Tagfahrlichtmodul Signal
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3 Always
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3 Daytime running lights
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3 not active
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3 Parking light right
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3 not active
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3 not active
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3 not active
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3 not active
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4 maximize
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4 maximize
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4 maximize
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4 127
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4 127
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4 0
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4 0
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4 49
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4 3A
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4 6 - LED Lichtmodul
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4 Always
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4 Daytime running lights
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4 not active
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4 Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4 not active
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4 not active
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4 not active
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4 not active
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5 maximize
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5 maximize
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5 maximize
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5 127
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5 127
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5 0
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5 0
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5 4B
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5 44
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5 6 - LED Lichtmodul
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5 Always
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5 Daytime running lights
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5 not active
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5 Parking light right
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5 not active
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5 not active
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5 not active
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5 not active
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6 maximize
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6 maximize
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6 maximize
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6 127
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6 0
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6 0
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6 0
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6 1A
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6 36
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6 3 - Xenon Abblendlicht
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6 Always
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6 Abblendlicht links
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6 Lichthupe generell
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6 not active
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6 not active
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6 not active
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6 not active
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6 not active
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6 not active
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7 maximize
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7 maximize
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7 maximize
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7 127
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7 0
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7 0
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7 0
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7 1B
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7 40
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7 3 - Xenon Abblendlicht
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7 Always
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7 Abblendlicht rechts
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7 Lichthupe generell
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7 not active
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7 not active
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7 not active
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7 not active
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7 not active
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7 not active
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8 maximize
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8 maximize
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8 maximize
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8 127
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8 0
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8 0
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8 0
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8 26
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8 35
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8 36 - LED Kleinleistung
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8 Always
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8 Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8 not active
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8 not active
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8 not active
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8 not active
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8 not active
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8 not active
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9 maximize
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9 maximize
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9 maximize
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9 127
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9 0
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9 0
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9 0
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9 27
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9 3F
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9 36 - LED Kleinleistung
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9 Always
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9 Parking light right
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9 not active
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9 not active
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9 not active
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9 not active
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9 not active
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9 not active
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14 maximize
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14 maximize
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14 maximize
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14 0
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14 0
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14 0
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14 0
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14 0
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14 0
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14 not active
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14 Always
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14 not active
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14 not active
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14 not active
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14 not active
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14 not active
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14 not active
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14 not active
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14 not active
ENG126648-ENG149012-LIN-Mirrormode-Bitmaske 63
ENG126648-ENG148864-LIN-Mirrormode-Stage 0
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0 0.00%
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1 5.00%
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2 50.00%
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3 75.00%
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4 110
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5 126.5
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0 0.00%
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1 6.00%
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2 16.00%
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3 30.00%
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4 60.00%
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5 100.00%
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar not active
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar not active
ENG98831-ENG126848-Personalization-Personalisierung_aktiv not active
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar not active
ENG122976-ENG148891-Remote_Start_Adaption-Anzahl zulaessiger Remotestarts 2
ENG122976-ENG148876-Remote_Start_Adaption-RemoteStart Betrieb Dauer 10 min
ENG122927-RLS_close_glazing 2.00 s
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off 120 s
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on 10 s
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off 65 km/h
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on 140 km/h
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle 6000 lx
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high 12
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low 6
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht 30 s
ENG122929-RLS_LIN_Communication 4 s
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn 200 lx
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day 500 lx
ENG122930-RLS_tunel_gateway_recognize 5 s
ENG122935-RLS_Washer_Front 15 s
ENG122926-RLS_wiper_position_parking 15 s
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1 00 00
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2 00 00
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3 00 00
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4 00 00
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1 00 00
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2 00 00
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3 00 00
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4 00 00
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5 00 00
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6 00 00
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute 40
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute 60
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute 30
