Hello In need of some help.
Retro fitted Cruise to a 12 Passat CC (correct kit from dealer)
I Run the wire from the steering unit plug (pin 5) up to the engine ECU and fitted it into pin 64 on the 94 pin plug (elsa wiring diagram said pin 94- instructions said refer to elsa)
Then coded the engine ECU telling it now has Cruise, also recoded the steering unit again telling it now has cruise control.
In 01 engine its now coming up with a fault "function restriction due to faults in other modules" and cruise showing fault on dash and doesn't work at all.
my thoughts just now is maybe the steering control unit is not suitable for cruise.
Can anyone shed any light on the problem.
Tuesday,20,February,2018,16:03:02:45930
VCDS Version: 16.8.3.1 (x64)
Data version: 20161010 DS267.0
VIN: WVWZZZ3CZDE522382 License Plate:
Chassis Type: 3C (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 4C 4F 52 53 55 56
61 62 72
VIN: WVWZZZ3CZDE522382 Mileage: 57350km-35635miles
Address 01: Engine (J623-CFFB) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 PR HW: 03L 907 309 AE
Component: R4 2.0l TDI H28 9979
Revision: 41H28--- Serial number: 00000000000000
Coding: 00190012042501080000
Shop #: WSC 03825 002 104857
ASAM Dataset: EV_ECM20TDI01103L906018PR 003007
ROD: EV_ECM20TDI01103L906018PR.rod
VCID: 091E4C51A88A280AEB-805C
4483 - Function Restriction due to Faults in Other Modules
U1113 00 [039] - -
Mileage: 57359 km
Date: 2018.02.20
Time: 15:43:34
Coolant temperature: 61 °C
Intake air temperature: 26 °C
Voltage terminal 30: 12.560 V
Cruise Control System (CCS): switch position-Bit 0: 01000000
Cruise Control System (CCS): status-Bit 0: 11001100
Cruise control switch-off: irreversible-Bit 0: 11111111
Cruise control switch-off: reversible-Bit 0: 11111111
Engine control module reset status-Bit 0: 00000000
Engine control module reset status-Bit 8: 00000000
Cruise control switch-off: irreversible w. brake intervention-Bit 0: 00000000
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 BK HW: 3AA 614 109 BK
Component: J104 C2 450M VDE1 0024
Revision: --H07--- Serial number: 00000005944877
Coding: 0004016
Shop #: WSC 05311 000 00000
VCID: 77FA3AA9067E2EFA8D-8022
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3AA 907 044 AF HW: 3AA 907 044 AF
Component: Climatronic H03 0303
Revision: 00001K02
Coding: 0010004809
Shop #: WSC 00015 115 00000
VCID: 74E00DA5DF0845E2A8-8020
Address 09: Cent. Elect. (J519) Labels: 3AA-937-087.clb
Part No SW: 3AA 937 087 J HW: 3AA 937 087 J
Component: BCM PQ47 H++ 421 0465
Revision: BD421001
Coding: 000800000000000000880080940028642355008860220120E484C72000C1
VCID: 418E9471D83AA04AF3-8014
Subsystem 1 - Part No SW: 3C8 955 119 G HW: 3C8 955 119 G Labels: 1KX-955-119.CLB
Component: WWS464 090512 010 0604
Serial number: 090512
Coding: 00B795
Subsystem 2 - Part No SW: 7N0 955 559 HW: 7N0 955 559 Labels: 7N0-955-559.CLB
Component: RLFS 021 0024
Serial number: Y12M06D14h22m56s08S4
Coding: 0280DD
Part No SW: 5N0 959 655 AA HW: 5N0 959 655 AA
Component: J234__70J VW10 HI 2118
Revision: 24017000 Serial number: 003L7PCYPLBU
Coding: 0012362
VCID: 7CF025853F580DA2E0-8028
Subsystem 1 - Serial number: 6332MTS658081572
Subsystem 2 - Serial number: 6342MTS678821522
Subsystem 3 - Serial number: 6351HTS6NUHN6BKJ
Subsystem 4 - Serial number: 6361HTS6PEK97BKR
Address 16: Steering wheel (J527) Labels: 3C0-953-569.clb
Part No SW: 3C5 953 501 BF HW: 5K0 953 569 S
Revision: FF010041 Serial number: 20120622300317
Coding: 0182270000
Shop #: WSC 00015 115 12345
VCID: 6ADC13DD8DCC831202-803E
Component: E221__MFL-TK6 H07 0022
Coding: E20000
Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
Part No SW: 3C8 920 971 A HW: 3C8 920 971 A
Component: KOMBI H05 0705
Coding: 440F01
Shop #: WSC 05314 115 00000
VCID: 2B52D6D942B65A1A39-807E
Part No SW: 7N0 907 530 AA HW: 7N0 907 530 G
Component: J533 Gateway H41 1632
Revision: H41 Serial number: 130612F2001216
Coding: 469007
Shop #: WSC 05314 000 00000
VCID: 6FEA02C9BE2E663A55-803A
Part No SW: 3AA 959 433 HW: 3AA 959 433
Component: IMMO 045 0400
Revision: 00045000 Serial number: VWZCZ000000000
VCID: 76E437AD017457F296-8022
Component: ELV 029 0380
3C0905861J ELV 029 0380
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7662793173
Coding: 020000
VCID: 295E2CD1404A480ACB-807C
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 3C0 035 279 M HW: 3C0 035 279 M
Component: RNS315-EU H52 0319
Serial number: VWZAZ2M5934327
Coding: 0400040104000F0000019002
Shop #: WSC 00015 115 08193
ASAM Dataset: EV_RNS315EUV2UDS 001705
ROD: EV_RNS315EUV2UDS.rod
VCID: 2D56D8C17CA2542A27-8078
Component: EUR_W_0038 0038
Part No SW: 3C8 959 701 HW: 3C0 959 793 C
Component: TUER-SG FT 002 0552
Revision: 12110009 Serial number: 0005235191
Coding: 0202B7
Shop #: WSC 05311 115 00000
ROD: EV_TSGFPQ35BRFVW46X.rod
VCID: 6DD618C1BC22942A67-8038
Slave Driver:
Subsystem 1 - Part No SW: 3C8 959 704 D HW: 3C8 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0501
Serial number: 00000002994478
Coding: 010090
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 207 3305
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 377AFAA946FEEEFA4D-8062
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ47 ELV 045 0634
Coding: 01910A0001860E763604941570085FCE105C01
Component: Neigungssensor 004 0611
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 G
Component: EZE_2 H41 1632
Coding: 00000008
Subsystem 1 - Part No SW: 3C8 919 204 A HW: 3C8 919 204 A
Component: Analoguhr 005 0004
Part No SW: 3C8 959 702 HW: 3C0 959 792 C
Component: TUER-SG BT 002 0552
Revision: 14110009 Serial number: 0005232121
Coding: 0202B6
ROD: EV_TSGBPQ35BRFVW46X.rod
VCID: 6ED41FCDB1246F325E-803A
Slave Passenger:
Subsystem 1 - Part No SW: 3C8 959 703 D HW: 3C8 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0501
Serial number: 00000002976883
Coding: 010090
Revision: H19 Serial number: 00000000307775
Coding: 0022167
VCID: 3664F7AD41F417F256-8062
Address 55: Headlight Range (J431) Labels: 6R0-907-357.clb
Part No SW: 6R0 907 357 B HW: 6R0 907 357 A
Component: LWR-ECU 005 0030
Coding: 078E000001000000
ASAM Dataset: EV_HeadlRegulVWLWRCC 002004
ROD: EV_HeadlRegulVWLWRCC.rod
VCID: 397EFC91B8EAF88ABB-806C
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 7N0 907 530 G
Component: Batt.regelung H41 1632
Coding: 030F1859
VCID: 71EE04B1A81A70CA43-8024
Component: J367-BDM H07 0180
Serial number: 00000000008900716010
End-------------------------(Elapsed Time: 03:00)--------------------------
