2012 Passat CC cruise control retro fit.. not working
akersgarage
C?ID=179893
Hello In need of some help.
Retro fitted Cruise to a 12 Passat CC (correct kit from dealer)
I Run the wire from the steering unit plug (pin 5) up to the engine ECU and fitted it into pin 64 on the 94 pin plug (elsa wiring diagram said pin 94- instructions said refer to elsa)
Then coded the engine ECU telling it now has Cruise, also recoded the steering unit again telling it now has cruise control.
In 01 engine its now coming up with a fault "function restriction due to faults in other modules" and cruise showing fault on dash and doesn't work at all.
my thoughts just now is maybe the steering control unit is not suitable for cruise.
Can anyone shed any light on the problem.
Tuesday,20,February,2018,16:03:02:45930
VCDS Version: 16.8.3.1 (x64)
VIN: WVWZZZ3CZDE522382   License Plate:
Chassis Type: 3C (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 4C 4F 52 53 55 56
          61 62 72
VIN: WVWZZZ3CZDE522382   Mileage: 57350km-35635miles
Address 01: Engine (J623-CFFB)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 PR    HW: 03L 907 309 AE
   Component: R4 2.0l TDI   H28 9979
   Revision: 41H28---    Serial number: 00000000000000
   Coding: 00190012042501080000
   Shop #: WSC 03825 002 104857
   ASAM Dataset: EV_ECM20TDI01103L906018PR 003007
   ROD: EV_ECM20TDI01103L906018PR.rod
   VCID: 091E4C51A88A280AEB-805C
4483 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
                    Mileage: 57359 km
                    Date: 2018.02.20
                    Time: 15:43:34
                    Engine speed: 0.00 /min
                    Coolant temperature: 61 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 12.560 V
                    Cruise Control System (CCS): switch position-Bit 0: 01000000
                    Cruise Control System (CCS): status-Bit 0: 11001100
                    Cruise control switch-off: irreversible-Bit 0: 11111111
                    Cruise control switch-off: reversible-Bit 0: 11111111
                    Cruise Control System: specified speed: 0.00 km/h
                    Engine control module reset status-Bit 0: 00000000
                    Engine control module reset status-Bit 8: 00000000
                    Cruise control switch-off: irreversible w. brake intervention-Bit 0: 00000000
   Part No SW: 3AA 614 109 BK    HW: 3AA 614 109 BK
   Component: J104   C2 450M VDE1 0024
   Revision: --H07---    Serial number: 00000005944877
   Coding: 0004016
   Shop #: WSC 05311 000 00000
   VCID: 77FA3AA9067E2EFA8D-8022
   Part No SW: 3AA 907 044 AF    HW: 3AA 907 044 AF
   Component: Climatronic   H03 0303
   Revision: 00001K02
   Coding: 0010004809
   Shop #: WSC 00015 115 00000
   VCID: 74E00DA5DF0845E2A8-8020
Address 09: Cent. Elect. (J519)       Labels: 3AA-937-087.clb
   Part No SW: 3AA 937 087 J    HW: 3AA 937 087 J
   Component: BCM PQ47 H++  421 0465
   Revision: BD421001
   Coding: 000800000000000000880080940028642355008860220120E484C72000C1
   VCID: 418E9471D83AA04AF3-8014
   Subsystem 1 - Part No SW: 3C8 955 119 G    HW: 3C8 955 119 G  Labels: 1KX-955-119.CLB
   Component: WWS464 090512  010 0604
   Serial number: 090512
   Coding: 00B795
   Subsystem 2 - Part No SW: 7N0 955 559     HW: 7N0 955 559   Labels: 7N0-955-559.CLB
   Component: RLFS  021 0024
   Serial number: Y12M06D14h22m56s08S4
   Coding: 0280DD
   Component: J234__70J VW10 HI   2118
   Revision: 24017000    Serial number: 003L7PCYPLBU
   Coding: 0012362
   VCID: 7CF025853F580DA2E0-8028
   Subsystem 1 - Serial number: 6332MTS658081572
   Subsystem 2 - Serial number: 6342MTS678821522
   Subsystem 3 - Serial number: 6351HTS6NUHN6BKJ
   Subsystem 4 - Serial number: 6361HTS6PEK97BKR
Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
   Part No SW: 3C5 953 501 BF    HW: 5K0 953 569 S
   Revision: FF010041    Serial number: 20120622300317
   Coding: 0182270000
   Shop #: WSC 00015 115 12345
   VCID: 6ADC13DD8DCC831202-803E
   Component: E221__MFL-TK6  H07 0022
   Coding: E20000
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3C8 920 971 A    HW: 3C8 920 971 A
   Component: KOMBI         H05 0705
   Coding: 440F01
   Shop #: WSC 05314 115 00000
   VCID: 2B52D6D942B65A1A39-807E
   Part No SW: 7N0 907 530 AA    HW: 7N0 907 530 G
   Component: J533  Gateway H41 1632
   Revision:   H41       Serial number: 130612F2001216
   Coding: 469007
   Shop #: WSC 05314 000 00000
   VCID: 6FEA02C9BE2E663A55-803A
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    IMMO         045 0400
   Revision: 00045000    Serial number: VWZCZ000000000
   VCID: 76E437AD017457F296-8022
   Revision: A1001003    Serial number: 7662793173
   Coding: 020000
   VCID: 295E2CD1404A480ACB-807C
Address 37: Navigation (J794)       Labels: 1K0-035-27x-37.clb
   Part No SW: 3C0 035 279 M    HW: 3C0 035 279 M
   Component: RNS315-EU   H52 0319
   Serial number: VWZAZ2M5934327
   Coding: 0400040104000F0000019002
   Shop #: WSC 00015 115 08193
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 2D56D8C17CA2542A27-8078
   Component: EUR_W_0038  0038
   Part No SW: 3C8 959 701     HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0552
   Revision: 12110009    Serial number: 0005235191
   Coding: 0202B7
   Shop #: WSC 05311 115 00000
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 6DD618C1BC22942A67-8038
   Slave Driver:
   Subsystem 1 - Part No SW: 3C8 959 704 D    HW: 3C8 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0501
   Serial number: 00000002994478
   Coding: 010090
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 207    3305
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 377AFAA946FEEEFA4D-8062
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ47 ELV 045 0634
   Coding: 01910A0001860E763604941570085FCE105C01
   Component: Neigungssensor  004 0611
   Part No SW: 7N0 907 532     HW: 7N0 907 530 G
   Component: EZE_2         H41 1632
   Coding: 00000008
   Subsystem 1 - Part No SW: 3C8 919 204 A    HW: 3C8 919 204 A
   Component: Analoguhr  005 0004
   Part No SW: 3C8 959 702     HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0552
   Revision: 14110009    Serial number: 0005232121
   Coding: 0202B6
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: 6ED41FCDB1246F325E-803A
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C8 959 703 D    HW: 3C8 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0501
   Serial number: 00000002976883
   Coding: 010090
   Revision:   H19       Serial number: 00000000307775
   Coding: 0022167
   VCID: 3664F7AD41F417F256-8062
Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
   Part No SW: 6R0 907 357 B    HW: 6R0 907 357 A
   Component: LWR-ECU       005 0030
   Coding: 078E000001000000
   ASAM Dataset: EV_HeadlRegulVWLWRCC 002004
   ROD: EV_HeadlRegulVWLWRCC.rod
   VCID: 397EFC91B8EAF88ABB-806C
   Part No SW: 7N0 907 534     HW: 7N0 907 530 G
   Component: Batt.regelung H41 1632
   Coding: 030F1859
   VCID: 71EE04B1A81A70CA43-8024
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900716010
End-------------------------(Elapsed Time: 03:00)--------------------------
akersgarage
C?ID=179893
Thanks for your info mate cant believe i missed this. I was stupidly looking at the 3C number not the 5k
Thanks again for the help on this
m87a
Bosnia and Herzegovina
C?ID=156900
don't worry it's a common mistake
Part No SW: 3C5 953 501 BF this part number is a stalk number (turn signal, high beam stalk, wiper etc...) it depends on what it supports
HW: 5K0 953 569 S this is control steering wheel module ;)
