Golf mk6 GTI transmission overtemperature and engine over revving in sports mode
Fredrick Awuor
Kenya
C?ID=309834
Hello guys,below is an enclosed autoscan of an mk6 gti whose dash screams about overheating tranny frequently,but no fault code is logged in ecu memory,I think this might be a common issue with 02E,but someone can chime in,however the engine revolutions at times go past 6000rpm before shifting to the next gear in sports mode which makes me to believe that the car is chipped,is there anyway to tell
Wednesday,14,February,2018,15:52:57:48669
VCDS Version: 18.1.0.2 (x64)  HEX-V2 CB: 0.4411.4
Data version: 20180122 DS285.1
Dealer/Shop Name: FREDRICK'S VWAUDI
VIN: WVWZZZ1KZAW203452   License Plate:
Mileage: 123010km-76434mi   Repair Order:
Chassis Type: 1K-VW36 (1K0)
Scan: 01 02 03 08 09 14 15 16 17 19 25 42 44 46 52 55 56 62 72
VIN: WVWZZZ1KZAW203452   Mileage: 123010km-76434miles
72-Door, Rear Right -- Status: Cannot be reached 1100
Address 01: Engine (CCZ)       Labels:. 06J-907-115-CCZ.clb
   Part No SW: 5K0 907 115     HW: 1K0 907 115 AA
   Component: 2.0l R4/4V TFSI     0050
   Revision: AAH11---    Serial number:
   Coding: 0403000C1C070160
   Shop #: WSC 59398 768 16576
   VCID: 6788B271B36635EFC9F-8032
001056 - Catalyst System; Bank 1
               P0420 - 000 - Efficiency Below Threshold
                    Mileage: 122818 km
                    Date: 2012.07.04
                    Time: 23:01:45
                    RPM: 1885 /min
                    Load: 34.1 %
                    Speed: 64.0 km/h
                    Temperature: 96.0°C
                    Temperature: 33.0°C
                    Absolute Pres.: 810.0 mbar
                    Voltage: 13.208 V
001089 - EVAP Emission Control Sys
               P0441 - 000 - Incorrect Flow
                    Mileage: 122996 km
                    Date: 2012.07.07
                    Time: 09:06:22
                    RPM: 760 /min
                    Load: 25.5 %
                    Temperature: 102.0°C
                    Temperature: 45.0°C
                    Absolute Pres.: 820.0 mbar
                    Voltage: 13.208 V
Readiness: 0010 0001
   Part No SW: 02E 300 051 R    HW: 02E 927 770 AJ
   Component: GSG DSG AG6     440 1932
   Revision: 04844002    Serial number: 00000910231125
   VCID: 221EE36518C410C75E1-8076
   Part No SW: 1K0 907 379 AJ    HW: 1K0 907 379 AJ
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 133B600D092200FDC80F06E9901B0081350800
   VCID: 7AAEFB05DCD4B807261-802E
02781 - ASR/ESP Button (E256)
                    Reset counter: 191
                    Mileage: 121931 km
                    Date: 2012.06.26
                    Time: 10:05:56
                    Count: 16384
                    Count: 32768
                    Count: 12800
                    Count: 156
                    Count: 46849
                    Count: 64768
                    Count: 768
                    Fault Status: 00101101
                    Reset counter: 203
                    Mileage: 122337 km
                    Date: 2012.06.30
                    Time: 08:44:52
                    Count: 4608
                    Count: 8193
                    Count: 50224
                    Count: 518
   Part No SW: 5K0 907 044 BC    HW: 5K0 907 044 BC
   Component: Climatronic   H14 0608
   Revision: 00003001
   Coding: 0000000000
   ASAM Dataset: EV_Climatronic A01001
   VCID: 6D84C0599D1A1FBFB33-8038
13701536 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Türsteuergerät hinten rechts - kein Signal/Kommunikation]
                    Reset counter: 121
                    Mileage: 120984 km
                    Date: 2018.01.22
                    Time: 17:21:25
   Part No SW: 1K0 937 087 F    HW: 1K0 937 087 F
   Component: BCM PQ35  H   103 0573
   Revision: 00103 AF
   Coding: 4E180A7C48231AC0C408008015008B2447550288736D8960648000200000
   VCID: 3432153DBE308E77BCD-8060
   Subsystem 1 - Part No: 1K2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 13100  21  0512
   Coding: 009795
   Component: RLS 291009 05  54  0402
   Coding: 0B30AD
                    Reset counter: 121
                    Mileage: 120984 km
                    Date: 2012.06.14
                    Time: 17:22:34
                    Voltage: 13.60 V
                        Term 50 Off
Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.clb
   Part No SW: 3C0 907 376 A    HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0070
   Revision: 00000000    Serial number: 28100900210002
   Coding: 000180
   VCID: 2708F2717FE6F5EF09F-8072
   Part No SW: 5K0 959 655 A    HW: 5K0 959 655 A
   Component: AirbagVW10G   035 0604
   Serial number: 003C3D0DCM80
   Coding: 00003233
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 382A210DA2D86A17905-806C
   Serial number: 7309464CZZZZZZZZZZZZ
   Serial number: 7824524CZZZZZZZZZZZZ
   Serial number: 2C2B4219ZZZZZZZZZZZZ
   Serial number: 0A0C3923ZZZZZZZZZZZZ
   Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
   Coding: 0001632
   VCID: 76B6EF35E4CCDC67429-8022
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000131
   Part No SW: 5K6 920 870 D    HW: 5K6 920 870 D
   Component: KOMBI         H03 0305
   Coding: 570F00
   VCID: 3432153DBEB08E77BCD-8060
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H07 0111
   Revision:   H07 01    Serial number: 221009F1000109
   Coding: ED897F06000202000003
   VCID: 698CB449A572039FDFB-803C
                    Reset counter: 121
                    Mileage: 120984 km
                    Date: 2012.06.14
                    Time: 17:23:44
                    Reset counter: 201
                    Mileage: 120984 km
                    Date: 2012.06.14
                    Time: 17:23:45
   Component: IMMO          H03 0305
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8ECB45ACF40887D61-803E
   Part No SW: 5K0 959 701 C    HW: 5K0 959 701 C
   Component: Tuer-SG         009 2114
   Coding: 0004790
   VCID: 323E132548248047AE1-8066
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 184    3001
   Revision: 00H17000
   VCID: 313C1C294D22BB5FD7B-8064
   Part No SW: 5K0 959 702 E    HW: 5K0 959 702 E
   Component: Tuer-SG         009 2140
   Coding: 0005046
   VCID: 35342839B94A977F8B3-8060
   Component: AFS-Steuergeraet    0142
   Coding: 1445212
   VCID: 3432153DB2308E77BCD-8060
   Coding: 00000022
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Coding: 00000022
   Part No SW: 6RD 035 187 A    HW: 6RD 035 187 A
   Component: MIB2-S-R-CN   025 0210
   Revision: -----001    Serial number: 01475GD2320936
   Coding: 0000040004000A
   Shop #: WSC 00081 790 00128
   VCID: 45D458F9E5AA07FF1B3-8010
00856 - Radio Antenna
                    Fault Status: 00101011
                    Reset counter: 201
                    Mileage: 122355 km
                    Date: 2012.06.30
                    Time: 16:27:45
   Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
Address 72: Door, Rear Right
End----------(Elapsed Time: 01:04, VBatt start/end: 13.3V/13.2V)-----------
