Audi a3 8V HID to LED conversion question
Autokorektas
Lithuania
C?ID=273842
Hello to all. I have almost finished an update for Audi a3 8v 2016(pre facelift) xenon to LED conversion. Changed headlights, range control J431 to J745 AFS unit, did all the wiring and coding. Now i have working drls, parking lights, turn signals, low beam, high beaam and cornering lights. Can not figure out how to make "All weather lighs" working. p.s. I changed light switch also, with "all weather lights" button.
Maybe anyone has an advice? And could anyone confirm that my bcm supports LED lights?
Thanks in advance!
And
Tuesday,13,February,2018,22:25:53:54234
VCDS Version: 17.8.1.0
Data version: 20171130 DS276.6
Workshop Code: 552 08316 000000
VIN: WAUA7GFF1G1026550   License Plate: A3_ALL_WEATHER
Mileage: 34546km-21465mi   Repair Order:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 52 55 5F 6C BB BC
VIN: WAUA7GFF1G1026550   Mileage: 34546km-21465miles
Address 01: Engine (J623-CNSB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 F    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 0A1D00122424000F3000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM18TFS0208V0906264F 001003
   ROD: EV_ECM18TFS0208V0906264F.rod
   VCID: 3F8D31A7A6AE66BEA8-806A
Readiness: 1110 1101
   Part No SW: 0D9 300 042 C    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4906
   Revision: 06253104    Serial number: TFK01506040359
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021_VW37.rod
   VCID: 1939BF3F184A688E76-804C
          P1734 00 [002] - -
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 62015000001070
   Coding: 13FF6A9234220A72017C020581C329C8562C5080408194B4024100548208
   ROD: EV_Brake1UDSContiMK100IPB_034_VW48.rod
   VCID: 79F99FBFF80A888ED6-802C
   Revision: 00021000    Serial number: 0374987175
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB_002_VW37.rod
   VCID: 3A7B40B3BD8C43969F-806E
   Part No SW: 8V0 820 043 C    HW: 8V0 820 043 C
   Component: AC Automat    H13 0060
   Revision: 20027000    Serial number: 00000000695207
   Coding: 03000014010000000000000000001400
   VCID: 326B689365FCBBD657-8066
   Serial number: A2998BB7000000000001
   Part No SW: 5Q0 937 085 AH    HW: 5Q0 937 085 AE
   Component: BCM MQBAB MNA H24 0175
   Serial number: 01061519800050
   Coding: 04151C42C04122FD41C04004511007000800000000000000000000000000
   Shop #: WSC 08316 552 00000
   ROD: EV_BCMBOSCH_015_VW37.rod
   VCID: 7F0D71A7E62EA6BEE8-802A
   Component: WWS371 150710  042 0585
   Serial number:         150715213512
   Coding: 0A47F7
   Serial number: 24098735
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 G    HW: 8V0 941 531 G
   Serial number: 23 11 2012  00000047
   Serial number: 00000000000063211765
   Sun Roof:
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST000FJNI300000
   Coding: 101F00
   Revision: --------    Serial number: 39331519803516
   Coding: 0010150011
   VCID: 43853D57CA46025ECC-8016
   Serial number: 003GCR02UDN/
   VCID: 479D2947FE7E2E7E10-8012
   Belt Pretensioner left:
   Serial number: 34230167A21071571217
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34230168A22071540107
   Coding: 333135
   Occupant Detection:
   Serial number: 694000000000001DCUYN
   Coding: 303332
   Subsystem 4 - Part No SW: -----------    HW: 480 001 507 15
   Serial number: 357000000008F010851A
   Subsystem 5 - Part No SW: -----------    HW: 480 001 507 15
   Serial number: 3580000000026D20851A
   Subsystem 6 - Part No SW: -----------    HW: 480 400 907 15
   Serial number: 3510002A11B7E8F3A39H
   Subsystem 7 - Part No SW: -----------    HW: 480 401 607 15
   Serial number: 3520002B71C52F41C242
   Subsystem 8 - Part No SW: -----------    HW: 480 400 805 15
   Serial number: 3550002BF1A2DCD3712J
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 400 805 15
   Serial number: 3560002A31A91E71633+
   Part No SW: 8V0 953 521 FH    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0110
   Revision: --------    Serial number: 23071508490747
   Coding: A018
   ROD: EV_SMLSKLOMQB_009_AU37.rod
   VCID: 0501E34F84F2FC6EA2-8050
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb
   Part No SW: 8V0 920 960 M    HW: 8V0 920 960 M
   Component: KOMBI         H03 6420
   Coding: 0BED19192B80D7050200A8001800000000000000
   ROD: EV_DashBoardVDDMQBAB_009_AU37.rod
   VCID: 4581234FC4723C6EE2-8010
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2223
   Revision: --------    Serial number: 17071510800707
   Coding: 0101000830085A005B00020C180B00000001010000000000000000000000
   ROD: EV_GatewConti_013_VW37.rod
   VCID: 75E1938FD412ECEEB2-8020
   Subsystem 2 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
   Serial number: 03 07 2015  C0013266
   Revision: 00000000    Serial number: 15000173143005
   Coding: 5D00000000000000
   VCID: 34676E8B9FE8B5E645-8060
   Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
   Serial number: 040715BG317548
   Coding: 00101B204000048000000002
   VCID: 4189375FD05A104EDE-8014
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 0102
   ROD: EV_SteerAssisMQB.rod
   Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
   Serial number: 100715BGA08623
   Coding: 001013204000048000000002
   VCID: 408F325BDB501946D1-8014
   Component: AFS-ECU       H01 0091
   Coding: 011E000020220200
   Subsystem 1 - Part No SW: 7PP 941 472 A    HW: 7PP 941 472 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H06 5050
   Coding: E00100
   Subsystem 2 - Part No SW: 7PP 941 472 A    HW: 7PP 941 472 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H06 5050
   Coding: E00100
   Subsystem 3 - Part No SW: 7PP 941 329 C    HW: 7PP 941 329 C  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 4000
   Coding: E00100
   Subsystem 4 - Part No SW: 7PP 941 329 C    HW: 7PP 941 329 C  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 4000
   Coding: E00100
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-STD1.clb
   Part No SW: 8V0 035 844 C    HW: 8V0 035 844
   Component: MU-S-S-US     013 0660
   Serial number: A7A01207150603
   Coding: 01730100FF0A000011220001001A00002F0001440100010002
   ASAM Dataset: EV_MUStd6C3PASE 002020
   ROD: EV_MUStd6C3PASE_AU37.rod
   VCID: 39795FBFB88A488E96-806C
   Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0014
   Serial number: AUZ8Z9FY30C77Z
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8V0 919 614 Q    HW: 8V0 919 614 Q
   Component: ControlUnit_B  H41 0054
   Serial number: C1000013051500030284
0020 - Tuner for Satelite Radio
          B11CF 53 [009] - Deactivated
                    Reset counter: 8
                    Mileage: 34546 km
                    Date: 2018.02.07
                    Time: 06:33:02
                    Voltage terminal 30: 12.3 V
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
   Coding: 027300010201000300
   ROD: EV_CamSysRearPANAVW428.rod
   VCID: 306F629B6BF089C621-8064
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 020715BG20801B
   Coding: 000013204000048000000002
   ROD: EV_DCURearDriveMAXCONT_VW37.rod
   Serial number: 020715BG208018
   ROD: EV_DCURearPasseMAXCONT_VW37.rod
End-------------------------(Elapsed Time: 04:53)--------------------------
Autokorektas
Lithuania
C?ID=273842
Alredy got email "Dear Autokorektas,
We have now activated your account at the Ross-Tech Forums."
That's not the same thing. Your forum account is indeed active (as evidenced by the fact that you can post at all), but you've never registered your VCDS system with Ross-Tech, and that's a requirement to be a "Verified User" in the forum.
Autokorektas
Lithuania
C?ID=273842
Got e-mail :
Hello -
Thanks for registering! Your information has been added to our customer
file for Tech Support purposes.
Best Regards,
Linda Ross
Ross-Tech
So what's next?
Verified.
Moving to Retrofits.
Autokorektas: It's a slightly different BCM in my screenshot below, and I don't believe that you are using a HEX series cable - but this is what my MQB test bench BCM says about "all weather light" facility:
I'm not sure if Byte 6, Bit 2 is populated on the normal "grey" long coding helper screen on your cable?
He is, but it's an older HEX-USB+CAN and isn't going to get those screens.
Thanks Uwe: then I guess it's a case of trying the tweak the long handed way:
Existing BCM code-string > 04151C42C04122FD41C04004511007000800000000000000000000000000
New BCM code-string > 04151C42C04126FD41C04004511007000800000000000000000000000000
Autokorektas
Lithuania
C?ID=273842
Sorted out myself with vas and odis engineering(it was showing more options than VCDS). DV52 You are right - I got the same code string, and it did the trick.
Thank you anyway!
Now I got fully-working LED headlights.
mexicogdl
C?ID=250121
Anybody In Los Angeles California to help with this mod on my A3? Any response would be appreciate it.
