Sticky HEX-NET or HEX-V2 Firmware Update Failed?
Sticky
   #161
ef1tuning
C?ID=441701
I have a HEX-Net tool that i have had for a few years. It failed during a firmware update.
In VCDS selecting USB then TEST. I get:
Port status: OK
Interface: Found!
Type: HEX-NET
Version:
CB: 0.4643.5
FW: 1.71
WiFi: 0472
Status: Questionable
CAN: Testing, K1: NO POWER, K2: NO POWER
VBat: 0.01v VIgn: 0.02V
However, when i click on config i get the following error
Unable to open interface, it may be in use by another program.
If you see this message repeatedly, you may want to try disabling startup programs.
OS windows 11. Tried on multiple laptops.
Disabled firewall and virus protection.
lights on the tool are steady yellow with a flashing green light on the right
I have tried via wifi NET of which the test option recognizes port though in config option it fails.
Please advise.
Is there a force firmware update or some way to salvage this?
   #162
billeuz
France
C?ID=40427
   #164
Shaun
This most likely means that another piece of software is grabbing control of the device, some frequent candidates are antivirus and mouse/trackpad software. Try booting the laptop into safe mode with networking and see if the utility works there. If so, then you need to try to disable startup services and see if you can narrow down what piece of software is causing the issue.
billeuz
France
C?ID=40427
Hi,
With old firmware (23) all worked fine!!
   #166
Shaun
Was anything else updated on the PC?
billeuz
France
C?ID=40427
Nothing!!!! Only updated VCDS to 24.
So no Windows updates, no antivirus updates? Why do I find this hard to believe?
Try a using a different PC to update the HEX-NET.
billeuz
France
C?ID=40427
No hardware added, no softwware added ONLY VCDS to 24.
   #170
Shaun
Have you tried using a different PC to update the interface and get around this issue?
   #171
billeuz
France
C?ID=40427
I have no other PC... I search for one...
   #172
andrei91gl
Romania
C?ID=432224
I have hexnet and on 24.7.1 it died, none of 3 pc's recognizes it, literally 8 cables tested. vcds mobile kinda works, but shows critical sd error and prompts for update, which i tried doing and it never ends, the timer constantly goes longer (8-12h remaining) with no progress being made(stuck at 40%)
   #173
Shaun
What does the updates tab in VCIConfig show, have you tried to update like that with PC and interface connected via USB or is it not found by VCIConfig either?
   #174
andrei91gl
Romania
C?ID=432224
To begin with , a few days ago , when i tried to use it I heard that the laptop doesn t prompt a sound when i plugged it into usb.
When I tried to search it in test usb , it prompted this message
Ross tech usb interface not found
USB library version 03.02.07
Interface not found.
The fact is that the leds appeared when plugged it into usb , but no communication , even in device manager it wasn t detected.
I managed to connect to it via VCDS mobile , and tried to update it that way. But always stopped at 40% for hours . After i tried the update , now the leds don't appear anymore when i plug the usb.
I can use it now with vcds mobile , but only powered by the obd of the car. In vciconfig i cannot see it.
   #175
Sounds like the USB comms have been damaged by a ground-loop.
Spacewalker
Poland
C?ID=159607
Guy, any advice ?Did update on my Hex Net - all is fine , inc Mobile update.
with WiFi connection - I can not connect to 17th and 25th
with USB connection - I can connect them
all other are fine
over WiFi - GW installation list see 17th and 25th with malfunction
Manually type 17 and 25 - still no response
anyway to make a LOG so you can look ?
   #177
AP mode or Infrastucture?
In VCDS, [Options] -> set Debug Level to 1024 -> [Apply]. Reproduce problem. Check Debug sub-folder. Send DEBUG17 and DEBUG25.DLM files to Support.
Spacewalker
Poland
C?ID=159607
Infrastucture mode
mobile phone with WiFi - 15 min still not able to load installation list ......only "redering"...I force close this , but device s/n was recognize at first
with AP mode APP can read cluster data, only no ASAM , but is know well part number
I sent files
   #179
Shaun
Have you tried this with VCDS on a PC? Also if you need ASAM data for mobile, you should try connecting the interface with USB and checking for updates via VCIConfig it should download the rod files.
   #180
Warren333
Hull, UK
C?ID=604450
Just done a software update 25.3.0 just before attempting to code my towbar electrics. I wish I hadn’t.
So the program works fine. Pop up box tells me a firmware update recommended and to go to options and test.
I then get a warning saying port status ok. Interface not found. Currently connected via USB. Press ok and open config utility for a firmware update. (I would post a pic but I can’t find the bloody option to do so).
It look for an update. States old version details and new version details.
I click download and update and get a message on the right saying preparing update.
Long wait then a message saying “socket timed out (2)” and it continues saying preparing update followed by the message socket etc… and this continues forever.
Tried pc reboots. Different USB ports. Unplugging the HEX V2 dongle for periods of times etc.
No joy.
Apart from a Time Machine and not pressing update has anyone got a solution please
Update: I found the old version 24.7.1 and installed that, but there is no going back. Same issue now no matter what program I run.
Also I didn’t mention before the the hex constantly flashes red/yellow
