Interface firmware update from V2.248 to something newer
Previous versions worked connecting to my AUDI in February of this year 2019.
19.6.1 version is downloaded now.
I run it with cable connected to car when car NOT running, key on.
I am connected to the internet.
ANTI-VIRUS software is disabled.
Windows firewall is OFF.
Windows 7 laptop that I have been using for past 6 months successfully to connect to my car.
*****I don't know how to post images, so I will just put the information from each screen on here ***
I get this message:
PORT TEST
Type: HEX-V2
version:
: 0.4437.4
: 0.251
status: firmware update required!
CAN: OK, K1: OK, K2
K
vbat: 12.39V, VIgn 12.35V
VIN(s) used: 1/3
Press OK to open config utililty.
So, I press the OK button and the config utility launches....
Interface Config V2.248
Select interface shows : H11-017597
We are on the UPDATE tab.
The HOURGLASS is running.
Then I get a small windows that says:
Network Error!
Unable to contact server. check your internet connection.
Couldn't connect to server
Outgoing TCP port 11000
Test result: Fail.
***** So I tried on a totally different laptop. Windows 7.
Same exact result.
So I tried on a network at work instead of at home...both laptops.
Same exact result.
So I don't know what else to do.
While the HOURGLASS was running, I did try to run a CMD: netstat
and I did NOT see anything on TCP port 11000.
I hope someone can help me.
thanks
