Figures it works fine today , ill pay attention if it starts to give me problems , Thanks
I'm not sure you know folks know your product anymore.That strategy will not a darn thing update the firmware in a HEX-NET or HEX-V2 interface.... You'd have to take it to the library and use their computer (or put your computer on their WiFi).
It's not about knowledge of VCDS, but about knowledge of the VW written firmware in the relevant modules - VCDS just communicates with that firmware and passes on only as much as the VW firmware wants to tell the "outside world".I'm not sure you know folks know your product anymore.
consult your real firmware engineers first..just saying..
I’m not sure you grasp the difference between who writes the soft/firmware in the modules and who creates an interface that (you guessed it) interfaces. An interface just translates available data into a different format.I'm not sure you know folks know your product anymore.
who blocked port ? IT supplier ?Hi, seems the port is blocked. Any way to resolve it? I am unable to update the firmware. At work, it seems the port is blocked and at home, my Laptop just hangs while updating and I get the not responding screen. Any advice or tips would be very much appreciated.
Correct me if I'm wrong, but it looks like you're quite close to our distributor in South Africa, maybe 30 minutes? I'm confident they would update it for you and probably also let you try your laptop using their internet connection.Hi, seems the port is blocked. Any way to resolve it? I am unable to update the firmware. At work, it seems the port is blocked and at home, my Laptop just hangs while updating and I get the not responding screen. Any advice or tips would be very much appreciated.
What version of VCIConfig are you using?I can not finish the test because the buttons are gray!
again and again
Preparing Update
No update files received.
Socket timed out (2)
Transfer Complete
Update completed successfully
again and again
Yes, I just saw it.I sent a private message!
V 2.244
