- Dec 16, 2014
- 10,973
- 10,242
- Westbury, UK
- C?ID=1423
How To Post PicturesI would post a pic but I can’t find the bloody option to do so
I even reinstalled the old version in a desperate attempt to crack on with my van coding.I'm having the same issue as Warren333.
Just updated to 25.3.0 and now I'm stuck with an interface that won't do anything as there is a firmware update but when I use the config there is no update available
If it wasn't for the fact I have ODIS and VCP then I'd have a ruined day today lolI even reinstalled the old version in a desperate attempt to crack on with my van coding.
But there’s no going back.
More details please -- as in an exact description of the LED behavior when you power up the inteface.Also I didn’t mention before the the hex constantly flashes red/yellow
when i initially plug the usb into the laptop it initially flashes green for a millisecond, then flashes yellow red continuously very fast.More details please -- as in an exact description of the LED behavior when you power up the inteface.
Also, what does VCIConfig show on the Update screen?
the initial update notification occurred while i was sat in my vehicle about to do some coding (or attempt to). i thought what the hell ill do the update first. program installed fine. Then as previously stated Pop up box tells me a firmware update recommended and to go to options and test.How did you update? I opened VCDS, the window asking for an update appeared. I updated the software and everything went fine. After that I opened VCDS 25.3, the config file was not present, so I connected the interface (HEX-NET in my case), pressed “Test”, the interface was found and I got a note that an update was necessary. And I updated the interface.
Was your procedure different from mine?
Thats interesting because as i previously mentioned rolling back to a previous version of the program doesnt work for me and unfortunately my "spare" laptop is like me, useless.I have just tested the interface with my unmolested 24.7 on my other PC and it is fully functional. The issue is isolated on my PC with the 25.3 update only.
I wonder if something somewhere else has remained updated and is causing the conflict?Thats interesting because as i previously mentioned rolling back to a previous version of the program doesnt work for me and unfortunately my "spare" laptop is like me, useless.
Yes, but i'm not that tech savvy. Looks like something has updated and i cant reverse it.I wonder if something somewhere else has remained updated and is causing the conflict?
Did you do a fresh 24.7 install?
Yes but not a portable work around LOL... It's working on my AIO PC in my office at home where I do some bench stuff (amongst other questionable things)... Short of getting a 200m USB cable and getting customers to come to my house, it's not a great solution LOLYes, but i'm not that tech savvy. Looks like something has updated and i cant reverse it.
Well at least you've got a work around for your situation.
Mine is showing CFB 0.10For those of you showing CFB 0.0 after the initial update, please get in touch with us via email (Support@Ross-Tech.com). We won't get back to you 'til Monday though.
That said, Shaun has made a change to the version requirements and the problematic CFB update is no longer being pushed. It only effected a limited range of interfaces to begin with, so updating should work fine again for all interfaces/ranges.
You're using a HEX-NET, not a HEX-V2, so this is expected (and your CFB is already latest). The updater should still show you new versions, not like in your screenshot. The proper target versions are showing for your serial number, so the updater should also report/offer those to you. That said, try switching it to the beta channel yourself and see if the proper versions are offered then.Mine is showing CFB 0.10
I can confirm that switching to the Beta channel has worked and I have now updated. Thanks!You're using a HEX-NET, not a HEX-V2, so this is expected (and your CFB is already latest). The updater should still show you new versions, not like in your screenshot. The proper target versions are showing for your serial number, so the updater should also report/offer those to you. That said, try switching it to the beta channel yourself and see if the proper versions are offered then.
You are currently at CB 0.4643 and FW 0.257, which (once properly updated) should be CB 0.4660 and FW 0.258 instead.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
