Golf 5 BAG engine misfire
Fredrick Awuor
Kenya
C?ID=309834
Hello everyone, I have swapped plugs/ coilpacks no1 and 4 to cylinders 2 and 3 then misfire disappears but comes back after a 20 min test drive to cylinders 3 and 2,done compression test,cylinder 2 slightly higher than any cylinder at 210 psi,remaining cylinders average around 185 psi,since I don't have documented compression figures,I'm pretty groping in the dark,I'm suspecting the coilpack wiring harness but I don't have testing procedures or WD,I'd be grateful if someone can open my eyes on this and if the other fault codes are a contributing factor
Friday,09,February,2018,13:02:34:48669
VCDS Version: 18.1.0.2 (x64)  HEX-V2 CB: 0.4411.4
Data version: 20180122 DS285.1
Dealer/Shop Name: FREDRICK'S VWAUDI
VIN: WVWZZZ1KZ4U002156   License Plate:
Mileage: 124090km-77105mi   Repair Order:
Chassis Type: 1K (1K0)
VIN: WVWZZZ1KZ4U002156   Mileage: 124090km-77105miles
Address 01: Engine        Labels: 03C-906-056-BAG.lbl
   Part No SW: 03C 997 056 N    HW: Hardware No
   Component: MED9.5.10        00 9270
   Revision: 00000000    Serial number: VWZ7Z0D9450717
   Coding: 0000075
   Shop #: WSC 73330 981 12795
   VCID: 382A210DAE586A17905-806C
16648 - Fuel Injector #2 (N31)
            P0264 - 002 - Short to Ground - Intermittent - MIL ON
18320 - Pressure Sensor for Brake Boost (G294)
            P1912 - 001 - Short to Plus
17439 - Intake Manifold Tuning Valve (N316)
            P1031 - 004 - Setpoint Not Reached
16684 - Random/Multiple Cylinder Misfire Detected
            P0300 - 001 -
16687 - Cylinder 3
            P0303 - 001 - Misfire Detected
16686 - Cylinder 2
            P0302 - 001 - Misfire Detected
Readiness: 1110 0101
   Part No: 09G 927 750 BN
   Component: AQ 250 6F           0524
   Coding: 0000008
   Shop #: WSC 00046 412 00000
   VCID: 7EA6F715CCFC94271A9-802A
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0103
   Coding: 0019074
   VCID: 3A2E3B0590547807661-806E
   Part No: 1K0 820 047 CB
   Component: Climatic PQ35   080 0201
   VCID: 6696BF75B46C2CE7F29-8032
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
   Part No SW: 1K0 937 049 K    HW: 1K0 937 049 K*
   Component: Bordnetz-SG 1.0 H30 0701
   Revision: 00030000    Serial number: 00000000667936
   Coding: 008D0F0600041800001400001400000000
   VCID: 37282231A346656F99F-8062
   Subsystem 1 - Part No: 1K2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00049109
   Part No SW: 1K0 909 605 F    HW: 1K0 909 605 F
   Component: 03 AIRBAG VW8R  023 5600
   Revision: 07023000    Serial number: 0037RD042WBD
   Coding: 0012339
   VCID: 2F381A515B16ADAFC1F-807A
   Subsystem 1 - Serial number: 6332MSME022F077CG
   Subsystem 2 - Serial number: 6342MSME02307C2FD
   Subsystem 3 - Serial number: 6351HSME0206030F-
   Subsystem 4 - Serial number: 6361HSME01750F501
01217 - Side Airbag Igniter; Driver Side (N199)
   Part No SW: 1K0 953 549     HW: 1K0 953 549
   Component: Lenksäulenmodul 012 0030
   Coding: 0010002
   VCID: 6FB8DA519B96EDAF81F-803A
   Part No: 1K0 920 850 K
   Component: KOMBIINSTRUMENT VDD 3556
   Coding: 0003501
   Shop #: WSC 06402 785 00200
   Part No SW: 1K0 907 530 C    HW: 1K0 907 951
   Component: Gateway         H08 0080
   Revision: 08          Serial number: 2100104304030B
   Coding: 3F3F0340070003
   VCID: 2708F27173E6F5EF09F-8072
   Component: IMMO                3556
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX1.lbl
   Part No: 1K0 959 701 G
   Component: Tuersteuergeraet 09 0124
   Coding: 0000054
   Shop #: WSC 01279 785 00200
   VCID: 323E132548248047AE1-8066
00131 - Outside Door Handle Illumination/mirror Light Driver Side
   Part No: 1K2 909 144 G
   Component: EPS_ZFLS Kl.0       1301
   VCID: 303A192D4628B257D85-8064
   Part No: 1K0 959 433 E
   Component:    KSG              0201
   Coding: 00E802087F2D8404085F0100
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX1.lbl
   Part No: 1K0 959 702 G
   Component: Tuersteuergeraet 09 0116
   Coding: 0000054
   Shop #: WSC 00046 000 00000
   VCID: 33301621B73E894FA57-8066
   Part No: 1K0 035 182 A
   Component: Radio BNO           0012
   Coding: 0040400
   VCID: 201AE96D16C802D7485-8074
00856 - Radio Antenna
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 C
   Component: Tuersteuergeraet 06 0202
   Coding: 0000016
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 C
   Coding: 0000016
   VCID: 313C1C294D22BB5FD7B-8064
End----------(Elapsed Time: 01:00, VBatt start/end: 14.1V/14.1V)-----------
Gone But Not Forgotten
In addition to Uwe's fine suggestion...... :rolleyes:
That and the G294 being a short to + bothers me....
Get ERWIN and WD and trace the bus and all components with a DTC to see what is a shared track.
downtime
Finland
C?ID=280813
This is FSI engine right? If you have original coil pack, I would guess that's the reason for the problems. They are prone to go at some point on these engines.
Or another option, look here : http://www.vwaudiforum.co.uk/forum/showthread.php/74386-A2-1-6-fsi-misfire!!!!
Disconnect the ECU for 2 hours to completely reset it, seems that ECU gets "full" on it's adaptation value table and does not adjust the ignition timing correctly.
Fredrick Awuor
Kenya
C?ID=309834
Hello Jack,client says this particular injector has been replaced, there's this intermittent sharp sound of coil pack leaking current to ground even after swapping coilpacks which puzzles me,
Fredrick Awuor
Kenya
C?ID=309834
Thanks Downtime,Yes,it is FSI,3 coilpacks made in turkey,1 in Italy,they look original,I will try to get different coils to fit and try
What about water ingress inside ECU for FOD?
Two shorts .....very uncommon.......water common!
Fredrick Awuor
Kenya
C?ID=309834
Hello Jack,I think downloading pdfs from erwin is a bit tricky,so i took my time and found out that the wiring harness to fuel injectors was misrouted and passed too close to EGR steel tube near coolant flange,and injector No2 wires insulation was slowly being roasted thereby exposing them to contact ground on EGR tube, I then properly rerouted the harness after applying good insulation.The misfire disappeared for good,we test drove for close to 100kms,it hasn't come back,but new error codes have come up in this autoscan,i also found one broken brake boost sensor wire,soldered back in place,no more problem with it
Friday,16,February,2018,16:01:48:48669
Mileage: 124360km-77273mi   Repair Order:
VIN: WVWZZZ1KZ4U002156   Mileage: 124360km-77273miles
   Coding: 0000075
            P1031 - 008 - Setpoint Not Reached - MIL ON
18702 - Oxygen (Lambda) Sensor Signal B1 S2
            P2270 - 001 - too Lean - Intermittent
18973 - Low Pressure Fuel Sensor (G410)
            P2541 - 001 - Short to Ground - Intermittent
16575 - Fuel Pressure Sensor (G247)
            P0191 - 008 - Implausible Signal - Intermittent
16825 - EVAP Emission Control Sys
            P0441 - 002 - Incorrect Flow - Intermittent
17480 - NOx Sensor (G295) Heater Control
            P1072 - 008 - Circuit Malfunction - MIL ON
Readiness: 1000 0001
   Coding: 0000008
   Coding: 0019074
   Coding: 00049109
01049 - Supply Voltage Term 50
            006 - Short to Plus - Intermittent
   Coding: 0012339
   Coding: 0010002
   Coding: 0003501
   Coding: 0000054
   Component:    KSG              0201
   Coding: 0000054
   Coding: 0040400
   Coding: 0000016
   Coding: 0000016
End----------(Elapsed Time: 01:04, VBatt start/end: 14.1V/14.0V)-----------
