Audi S5 2008 4.2 issues at startup
2.8L
Canada
C?ID=324466
I have a 2008 S5 4.2 in the shop witch im having issues figuring out.
Every single time you start the car it idles like crap ... Missfires ( CEL flashing sometimes, sometimes not ) runs really rough ... The customer even said he saw the EPC light come on ( I havent ) ... Sometyimes the CEL comes on sometimes not
Heres the deal ... I dont have any significant codes in the ECU memory
The second you clear the codes ... the car runs like a charm ... The customer bought a cheap code reader off ebay and he literally has to turn the key ON .. clear the codes ... every single time he wants to drive the car or else the cars feels like its running on 4 out of 8 cylinders
The only hint i have so far is this ... If i start the car without clearing the codes .. the car is running like crap ... the maf readings are 10+g/sec as opposed to ~4g/sec when the car is running normaly
Also the cars starts up are runs relatively well with the MAF disconnected ... ESP, parking brake, etc light come on but you DO NOT have to clear the codes to get the car to run
I dont have a spare maf handy to test ... and the new maf is non returnable
Any inputs would be really appreciated
P.S: I will post autoscan in a few minutes
MasterTommy
Amsterdam
C?ID=295586
Nice OP (sincere), but you really need to post a complete auto-scan before we can give you some helpful advice...
Gone But Not Forgotten
P.S: I will post autoscan in a few minutes​
Time to learn your basics and troubleshoot stuff correctly and not guess things like this.
Post a scan to see firmware levels and post logs with VCDS of the long and short term trim.u
FYI: When you reset the DTC's you are erasing the deviation learned of trim adaptions!
JPPSG and read the how to threads.......
Check wiring to MAF, al fuses and for obstructions of FOD!
http://forums.ross-tech.com/showthr...essional-Problem-Solver-Guide-quot-JPPSG-quot
http://forums.ross-tech.com/forumdisplay.php?24-How-To-s-and-Tips
2.8L
Canada
C?ID=324466
Thanks Jack
Ill study tonight!
In the meantime here is the logs of the autoscan
Thursday,08,February,2018,17:04:07:24481
VCDS Version: 18.1.0.2 (x64)  HEX-NET CB: 0.4411.4
Data version: 20180122 DS285.1
VIN: WAURV68T38A010499   License Plate:
Chassis Type: 8T-AU48 (8T0)
Scan: 01 03 05 06 07 08 09 0E 0F 10 15 16 17 19 1E 36 37 42 46 47
          52 53 55 56 65 6C 77
VIN: WAURV68T38A010499   Mileage: 175600km-109112miles
65-Tire Pressure -- Status: Not registered 0011
Address 01: Engine (J623-CAUB)       Labels:. 079-907-560-CAU.clb
   Part No SW: 8T0 907 560 G    HW: 8T0 907 560
   Component: 4.2l V8/4V    H10 0008
   Revision: 76H10---
   Coding: 01140009180F0120
   Shop #: WSC 94007 999 99243
   VCID: 3E30D15AA92814B587-806A
004200 - Intake Air Switch-Over Valve (N335)
               P1068 - 004 - Open Circuit
                    Mileage: 175605 km
                    RPM: 1106 /min
                    Load: 68.2 %
                    Temperature: 96.0°C
                    Temperature: 24.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 11.557 V
005491 - Left Engine Mount Solenoid Valve (N144)
               P1573 - 004 - Open Circuit
                    Mileage: 175605 km
                    RPM: 1106 /min
                    Load: 68.2 %
                    Temperature: 96.0°C
                    Temperature: 24.0°C
                    Voltage: 11.557 V
Readiness: 0110 1101
   Part No SW: 8K0 907 379 J    HW: 8K0 907 379 J
   Component: ESP8 quattro  H03 0190
   Coding: 110500
   Shop #: WSC 06325 000 00000
   VCID: 40CCAFA2D3DC6245F5-8014
   Part No SW: 8T0 907 064 H    HW: 8T0 907 064 H
   Component: BCM2 2.0      H05 0440
   Coding: 0F2000
   Shop #: WSC 94754 999 13601
   Subsystem 1 - Part No SW: 8K0 905 852 A    HW: 8K0 905 852 A
   Component: ELVAUDIB8  H33 0039
   Serial number: 0107000060783007
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8T0 959 760     HW: 8T0 959 760
   Component: MEM-BFS       H08 0027
   Revision: AA000000    Serial number: 00001001016678
   Coding: 00017025002C44440000
   VCID: 55E26EF63C5EF7EDB6-8000
Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
   Part No SW: 8T0 035 729 M    HW: 4E0 035 729 A
   Component: Interfacebox    H43 4610
   Revision: 00000000    Serial number: 340GR077503649
   Coding: 0025003
   VCID: 43C6A0AE02CA795DE8-8016
   Subsystem 1 - Part No: 8T0 919 609 D
   Component: E0380 BedienteilH07 0100
   Subsystem 2 - Serial number: 00000000010083
   Subsystem 3 - Serial number: 0129.06.070000000100010055ÿ
   Subsystem 4 - Serial number: 010055ÿ
   Part No SW: 8T1 820 043 R    HW: 8T1 820 043 R
   Component: KLIMA 3 ZONEN H05 0110
   Revision: C1000000    Serial number: 0113.08.070104
   Coding: 48022000
   Component: BCM1 1.0      H20 0253
   Revision: 05020001    Serial number: 00000000029568
   Coding: 26009013001CAF010000080300003D3D0F1C138800010161000000
   Shop #: WSC 95982 999 84216
   VCID: 302CFF62637CF2C505-8064
   Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 180111  H14 0070
   Serial number: SWF11010180267
   Coding: 005914
   Subsystem 2 - Part No SW: 8T0 955 559     HW: 4E0 955 559 B
   Component: RLS  H12 0001
   Serial number: 10013012
   Coding: 02532C
   Subsystem 3 - Part No SW: 8K0 941 531 J    HW: 8K0 941 531 J
   Component: E1 - LDS  H07 0070
   Serial number: 00000000001307070439
02258 - Door Opener Transmitter
                    Reset counter: 24
                    Mileage: 175605 km
                    Date: 2007.06.05
                    Time: 23:59:00
   Part No SW: 8T1 035 110 C    HW: 8T1 035 110 A
   Component: MP3-Changer     H41 0390
   Revision: 00041003    Serial number: AUZ5ZBG4018407
   VCID: 2A18ED0A85A08815CB-807E
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 M    HW: 4E0 035 593 F
   Component: SDAR SIRIUS     H07 0160
   Revision: 00000000    Serial number: AUZ4Z7G0122870
   Coding: 0000102
   Shop #: WSC 06435 000 00000
   VCID: 312AFA66A876FBCD0A-8064
            000 -  -
                    Reset counter: 24
                    Mileage: 175605 km
                    Date: 2007.06.05
                    Time: 23:59:29
   Part No SW: 8K0 919 475     HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0003
   Revision: 11001001    Serial number: 46130719903244
   Coding: 200002
   VCID: 76A0097AC1989CF59F-8022
   Part No SW: 8K0 959 655 C    HW: 8K0 959 655 C
   Component: AirbagVW-AU10 H23 0409
   Serial number: 0039GD1004AD
   Coding: 30413333373030303030554A304C38543053
   ASAM Dataset: EV_AirbaECUVWAUDI010 A02001
   VCID: 3D32D656AC2E0FAD9E-8068
   Serial number: 6334LSME147E3974L
   Serial number: 6344LSME147F5C0EV
   Serial number: 6352QSME31782059C
   Serial number: 6362QSME387A393F-
   Serial number: 63732SME5E293C1DF
   Serial number: 63832SME5F57414DB
   Component: Lenks.Modul   H10 0012
   Revision: --------    Serial number: 90304GHA00006
   Coding: 000016
   VCID: 3D32D656A42E0FAD9E-8068
   Part No SW: 8T0 920 930 Q    HW: 8T0 920 930 Q
   Component: KOMBIINSTR.   H21 0212
   Revision: 00000000    Serial number: 6C210U087
   Coding: 830D01000A001008030300
   Shop #: WSC 06435 123 12345
   VCID: 44C4A3B2C7C47E65D1-8010
            000 -  -
                    Reset counter: 24
                    Mileage: 175605 km
                    Date: 2007.06.05
                    Time: 23:59:19
   Part No SW: 8T0 907 468 F    HW: 8T0 907 468 F
   Component: GW-BEM 4CAN-M H07 0084
   Revision: EB002032    Serial number: 3200E077258094
   Coding: 000003
   Shop #: WSC 00001 067 57207
   Subsystem 1 - Part No SW: 8K0 915 181     HW: 8K0 915 181
   Component: J367-BDM  H06 0150
   Serial number: 17002C38230707
            000 -  -
                    Reset counter: 24
                    Mileage: 175605 km
                    Date: 2007.06.05
                    Time: 23:59:23
Address 1E: Media Player 2 (R199)       Labels:. 4E0-035-785.lbl
   Part No SW: 4E0 035 785 F    HW: 4E0 035 785 B
   Component: SG ext.Player H09 0850
   Revision: 00000000
   VCID: 2B16E80E4A5A911D30-807E
   Component: MEM-FS        H08 0027
   Revision: AA000000    Serial number: 00001001016666
   Coding: 00197B25002C44440000
   Part No SW: 4E0 910 888 F    HW: 4E0 919 887 M
   Component: MNS US          H50 0990
   Revision: 00000000    Serial number: 341Z2077502585
   Shop #: WSC 54441 321 99999
   Part No SW: 8K0 959 793     HW: 8K0 959 793
   Component: TSG FA        H09 0149
   Revision:             Serial number: 0ixa
   Coding: 011C13225E002201
   VCID: 7DB21656E4AECFADDE-8028
   Revision: 00002001    Serial number: 0136873645
   Coding: 0106069A003A44C500B0000400000000
   Component: GTO BF  H06 0040
   Serial number: 00000000000000004049
   Subsystem 3 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J245EE16SKB09  H01 0170
   Part No SW: 8T0 035 223 T    HW: 8T0 035 223 F
   Component: DSP Prem      H14 0400
   Revision: 00H14003    Serial number: 34814006132304
   Coding: 020101
   Shop #: WSC 12336 024 394758
   VCID: 3FCEAC5EAE221DBD8C-806A
   Part No SW: 8K0 959 792     HW: 8K0 959 792
   Component: TSG BF        H09 0149
   Revision:             Serial number: 00b
   VCID: 7CB41B52FFB4C6A5E9-8028
                    Fault Status: 01101100
                    Reset counter: 24
                    Mileage: 175605 km
                    Date: 2007.06.06
                    Time: 00:04:37
   Part No SW: 8K0 907 801 C    HW: 8K0 907 801 C
   Component: EPB Audi B8   H03 0040
   Revision: 00000003    Serial number: 00000000013572
   VCID: 2F2EFC1E7E42ED3D1C-807A
Address 55: Headlight Range        Labels: 8T0-907-357.clb
   Part No SW: 8T0 907 357 A    HW: 4F0 907 357 F
   Coding: 0000017
   VCID: 3C34DB527F3406A5A9-8068
   Component: AFS-Modul links H06 0002
   Part No SW: 4E0 910 541 T    HW: 4F0 035 541 L
   Component: TUNER EU/US/RDW H42 0630
   Revision: 00000000    Serial number: 336HT077513950
   Coding: 0000002
Address 65: Tire Pressure (J502)       Labels:. 8K0-907-273.clb
   Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
   Component: J502-RDK      H03 0240
   Revision: 00001001    Serial number: 12822707120390
   Coding: 0CD154
            002 - Lower Limit Exceeded - MIL ON
                    Fault Status: 11100010
                    Reset counter: 24
                    Mileage: 175605 km
                    Date: 2007.06.05
                    Time: 23:59:18
                    Bin. Bits: 00000000 00001000
                    Voltage: 12.00 V
                    Text:  06,0°C;n.erkannt;     n.erkannt
   Part No SW: 8T0 907 441     HW: 4L0 907 441 A
   Revision: --H12---    Serial number: 525PA8-J77503L
   Coding: 1000008
   VCID: 75A20E761C9E97ED96-8020
   Part No SW: 4F0 910 336 H    HW: 4E0 862 335
   Component: Handyvorb2      H18 1130
   Revision: 00000000    Serial number: 00000005003875
   Coding: 0010900
   VCID: 281C17029BACBA05DD-807C
End----------(Elapsed Time: 01:57, VBatt start/end: 12.8V/12.6V)-----------
Battery voltage is SHIT! correct it immediately.
Component: 4.2l V8/4V H10 0008 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Firmware update required 0009 or higher!
Now do a log of trims............
2.8L
Canada
C?ID=324466
Thanks jack for the help!
Ill post trim logs later today ... ill also post info on batt / batt coding
Pardon my ignorance ... do you have any info on how to update firmware
thanks
2.8L
Canada
C?ID=324466
Here are some logs of fuel trim and other data log i tough could be helpful
The customer told me he started having issues after he changed the battery ... It is NOT an OEM battery .. it is an AGM aftermarket replacement ... i coded : Address 19 channel 004 to the best of my knowledge ... you can find the current status of battery at the end of my log
the log was taken with car idling and running rough
If you need more logs/info let me know
thanks for your time
Friday,09,February,2018,14:47:10:24481
VIN: WAURV68T38A010499   License Plate: YANICK
                Address 01: Engine  (8T0 907 560 G)
14:46:57 Group 002: General
  680 /min  Engine Speed (G28)
  32.3 %  Engine Load
  5.10 ms  Injection Timing
  10.14 g/s  Mass Air Flow Sensor (G70)
14:47:44 Group 004: General
  720 /min  Engine Speed (G28)
  14.570 V  Battery Voltage (Terminal 30)
  34.0°C  Coolant Temperature (G62)
  17.0°C  Intake Air Temperature (G42)
14:49:16 Group 026: Ignition (Knock Control Cylinder 1-4)
  0.156 V  Knock Sensor Voltage Cylinder 1
  0.468 V  Knock Sensor Voltage Cylinder 2
  0.468 V  Knock Sensor Voltage Cylinder 3
  0.780 V  Knock Sensor Voltage Cylinder 4
14:49:22 Group 027: Ignition (Knock Control Cylinder 5-8)
  0.780 V  Knock Sensor Voltage Cylinder 5
  0.312 V  Knock Sensor Voltage Cylinder 6
  0.624 V  Knock Sensor Voltage Cylinder 7
  1.248 V  Knock Sensor Voltage Cylinder 8
14:49:40 Group 030: Lambda Control (Sensor Status)
     00111  Bank 1 Sensor 1
      1110  Bank 1 Sensor 2
     00111  Bank 2 Sensor 1
      1110  Bank 2 Sensor 2
14:49:49 Group 031: Lambda Control (Lambda Sensor Voltages)
  1.00  Lambda Control Bank 1 (actual)
  1.00  Lambda Control Bank 1 (specified)
  1.01  Lambda Control Bank 2 (actual)
  1.00  Lambda Control Bank 2 (specified)
14:50:06 Group 033: Lambda Control
  12.5 %  Lambda Control Bank 1 Sensor 1
  1.56 V  Sensor Voltage Bank 1 Sensor 1
  22.7 %  Lambda Control Bank 2 Sensor 1
  1.54 V  Sensor Voltage Bank 2 Sensor 1
14:50:23 Group 036: Lambda Control (Sensor Readiness - After Catalyst)
  0.72 V  Sensor Voltage Bank 1 Sensor 2
  B1-S2 OK  Result Lambda Availability
  0.78 V  Sensor Voltage Bank 2 Sensor 2
  B2-S2 OK  Result Lambda Availability
14:50:32 Group 037: Lambda Control (Delta Lambda Bank 1)
  16.5 %  Engine Load
  0.10 V  Sensor Voltage Bank 1 Sensor 2
  0.000  Delta Lambda Bank 1 Sensor 2
  Test OFF  Result
14:50:41 Group 038: Lambda Control (Delta Lambda Bank 2)
  16.5 %  Engine Load
  0.70 V  Sensor Voltage Bank 2 Sensor 2
  0.000  Delta Lambda Bank 2 Sensor 2
  Test OFF  Result
14:50:55 Group 039: Lambda Control (Sensor Exchange)
  5.64 g/s  Mass Air Flow Sensor (G70)
  0.08 V  Sensor Voltage Bank 1 Sensor 2
  0.06 V  Sensor Voltage Bank 2 Sensor 2
  Test OFF  Result Sensor Exchange
14:50:58 Group 039: Lambda Control (Sensor Exchange)
  5.14 g/s  Mass Air Flow Sensor (G70)
  0.29 V  Sensor Voltage Bank 1 Sensor 2
  0.14 V  Sensor Voltage Bank 2 Sensor 2
14:50:59 Group 039: Lambda Control (Sensor Exchange)
  5.28 g/s  Mass Air Flow Sensor (G70)
  0.68 V  Sensor Voltage Bank 1 Sensor 2
  0.33 V  Sensor Voltage Bank 2 Sensor 2
14:51:12 Group 041: Lambda Control (Lambda Sensor Heating Bank 1)
  79 ohms  Resistance Bank 1 Sensor 1
  43.8 %  Heater Condition
  0.30 kOhm  Resistance Bank 1 Sensor 2
  Htg. S2 ON  Heater Condition
14:51:19 Group 042: Lambda Control (Lambda Sensor Heating Bank 2)
  80 ohms  Resistance Bank 2 Sensor 1
  0.13 kOhm  Resistance Bank 2 Sensor 2
14:51:28 Group 043: Lambda Control (Aging Check: Bank 1 Sensor 2)
  640 /min  Engine Speed (G28)
  475°C  Catalytic Converter Bank 1 Temp.
  0.72 V  Lambda Voltage Bank 1 Sensor 1
  B1-S2 OK  Result Aging Check
14:51:34 Group 044: Lambda Control (Aging Check: Bank 2 Sensor 2)
  475°C  Catalytic Converter Bank 2 Temp.
  0.70 V  Lambda Voltage Bank 2 Sensor 1
  B2-S2 OK  Result Aging
Address 01: DTCs cleared
                Address 19: CAN Gateway  (8T0 907 468 F)
14:54:00 Group 017: Power Supply (Battery)
  OK  Battery Type
  1  Battery Vendor
  2  Battery Size
  No  Battery Disconnect. Recognition
14:54:05 Group 018: Power Supply (Battery)
  12.600 V  Battery Voltage
  -10.8 A  Battery Current
  13.0°C  Battery Temp. (Estimate)
  9.0°C  Battery Temp. (Ambience)
14:54:11 Group 019: Power Supply (Battery)
  88.0 %  Battery State of Charge (SOC)
  100.0 %  Battery State (as shown in MMI)
  99.0 %  Battery Aging (derived fr. Load)
  126.0 %  Battery Aging (derived fr. Output)
This is not what I requested .........
Replace the MAF..........genuine only repair all shorts and be sure no FOD or false air exists anyplace especially in bank 2!
2.8L
Canada
C?ID=324466
Sorry jack ... Ill eventualy get good at this lol
If you dont mind being more specific or give me an example of the logs your requesting .. Ill be glad to post them
As for unmeetered air ... Wouldnt you think i would detect it even after i clear the trim deviation and the car is running well
I wonder what can cause the fuel trim to get so out of wack after the car shuts off
Maybe terminal 15 is not being switched correctly...........
Time to watch some YouTube videos and read how to sections.........
2.8L
Canada
C?ID=324466
Thanks Jack ... i wasnt aware so much information was available on the website and youtube channel
I definitely want to understand and i dont expect you to solve/find the problem for me
So i done some fuel trim logs ( i hope i got it right this time )
Clearly the trims are lean before and after clearing the codes
Monday,12,February,2018,11:11:23:24481
11:11:20 Group 032: Lambda Control (Mixture Adaptation)
  -0.2 %  Adaptation (Idle) Bank 1 Sensor 1
  -0.4 %  Adaptation (Partial) Bank 1 Sensor 1
  0.0 %  Adaptation (Idle) Bank 2 Sensor 1
  -0.4 %  Adaptation (Partial) Bank 2 Sensor 1
11:11:20 Group 033: Lambda Control
  0.0 %  Lambda Control Bank 1 Sensor 1
  1.91 V  Sensor Voltage Bank 1 Sensor 1
  0.0 %  Lambda Control Bank 2 Sensor 1
11:12:33 Group 032: Lambda Control (Mixture Adaptation)
11:12:33 Group 033: Lambda Control
  14.5 %  Lambda Control Bank 1 Sensor 1
  0.90 V  Sensor Voltage Bank 1 Sensor 1
  17.6 %  Lambda Control Bank 2 Sensor 1
  0.98 V  Sensor Voltage Bank 2 Sensor 1
11:12:50 Group 032: Lambda Control (Mixture Adaptation)
11:12:50 Group 033: Lambda Control
  1.09 V  Sensor Voltage Bank 1 Sensor 1
  15.2 %  Lambda Control Bank 2 Sensor 1
  1.11 V  Sensor Voltage Bank 2 Sensor 1
11:13:43 Group 032: Lambda Control (Mixture Adaptation)
11:13:43 Group 033: Lambda Control
  16.8 %  Lambda Control Bank 1 Sensor 1
  1.31 V  Sensor Voltage Bank 1 Sensor 1
  21.1 %  Lambda Control Bank 2 Sensor 1
  1.29 V  Sensor Voltage Bank 2 Sensor 1
11:14:31 Group 032: Lambda Control (Mixture Adaptation)
  0.0 %  Adaptation (Idle) Bank 1 Sensor 1
  0.0 %  Adaptation (Partial) Bank 1 Sensor 1
  0.0 %  Adaptation (Partial) Bank 2 Sensor 1
11:14:31 Group 033: Lambda Control
  -3.9 %  Lambda Control Bank 1 Sensor 1
  1.48 V  Sensor Voltage Bank 1 Sensor 1
  4.3 %  Lambda Control Bank 2 Sensor 1
  1.48 V  Sensor Voltage Bank 2 Sensor 1
11:14:54 Group 032: Lambda Control (Mixture Adaptation)
11:14:54 Group 033: Lambda Control
  -2.0 %  Lambda Control Bank 1 Sensor 1
  5.9 %  Lambda Control Bank 2 Sensor 1
11:15:46 Group 032: Lambda Control (Mixture Adaptation)
11:15:46 Group 033: Lambda Control
  -3.1 %  Lambda Control Bank 1 Sensor 1
  1.52 V  Sensor Voltage Bank 1 Sensor 1
  4.7 %  Lambda Control Bank 2 Sensor 1
  1.52 V  Sensor Voltage Bank 2 Sensor 1
11:17:09 Group 032: Lambda Control (Mixture Adaptation)
11:17:09 Group 033: Lambda Control
  26.2 %  Lambda Control Bank 2 Sensor 1
  1.43 V  Sensor Voltage Bank 2 Sensor 1
11:17:14 Group 032: Lambda Control (Mixture Adaptation)
11:17:14 Group 033: Lambda Control
  16.4 %  Lambda Control Bank 1 Sensor 1
  1.54 V  Sensor Voltage Bank 1 Sensor 1
  20.7 %  Lambda Control Bank 2 Sensor 1
11:17:53 Group 032: Lambda Control (Mixture Adaptation)
11:17:53 Group 033: Lambda Control
  27.0 %  Lambda Control Bank 1 Sensor 1
  23.0 %  Lambda Control Bank 2 Sensor 1
  1.62 V  Sensor Voltage Bank 2 Sensor 1
11:17:56 Group 032: Lambda Control (Mixture Adaptation)
11:17:56 Group 033: Lambda Control
  21.5 %  Lambda Control Bank 1 Sensor 1
  1.43 V  Sensor Voltage Bank 1 Sensor 1
  27.0 %  Lambda Control Bank 2 Sensor 1
Can you confirm the battery was properly coded ... Its not an OEM battery ( the battery was changed by an other shop ... i only coded it ) ... i cheated by changing one digit of the serial number since its not oem ... would it be worth it to try an oem battery?
Also i should get the proper wiring diagram today since i only have acces to Mitchell's wiring diagram right now ... if i have to i will subscribe to erwin ... i really want to solve this issue
Follow the trouble tree and SVM the ecu at dealer as per the RTFB.
Install a correct battery with proper adaption performed and verification of the charging system.
I don't help retrofits of any kind.......and I absolutely dislike pervasive rationalization I find with induced FOD.
Want it right? Do it right .....it's that simple by JPPSG and following a proper methodical method.
Trace false air as aforementioned in the respective bank of deviation.
2.8L
Canada
C?ID=324466
Thanks Jack ... will do
I ordered a battery from the dealer ... i will receive it tomorrow ... ill keep you posted !!
Also ... my mother tongue is french ... my English is 80% .. i dont quite understand the meaning of : and I absolutely dislike pervasive rationalization I find with induced FOD.
per·va·sive
pərˈvāsiv/
adjective
[COLOR=#878787 !important]
  • (especially of an unwelcome influence or physical effect) spreading widely throughout an area or a group of people.
    [COLOR=#878787 !important]"ageism is pervasive and entrenched in our society"[/COLOR]
    synonyms:prevalent, pervading, permeating, extensive, ubiquitous, omnipresent, universal, rife, widespread, general[COLOR=#878787 !important]"the low-carb craze is pervasive"[/COLOR]
[/COLOR]​
2.8L
Canada
C?ID=324466
**** THE MAIN ISSUE WITH THE CAR IS : cant run the car until after i clear the fuel trims ( codes ) even tough no relevant codes are present .. once cleared codes ... i can run the car for ever as long as i dont shut it off ... when it is shut off ... i have to clear the codes or its undrivable ****
Hi Jack and folks!!
Im Back !! Sorry about the delay ... I spare you the details
Thanks for the literature lessons Jack ... i still prefer fuel injection lessons :)
Long story short ... I got the proper OEM battery and coded it
Fix the vacuum leaks i found ... few lines where suspicious ... suction jet pump was bad ... still has a bit from the intake ... smoked it .. smoke coming from the intake flap shaft seals and from around the seam of the intake ... i tried opening it to reseal it ... it did not happen .. i was never able to split it and since i dint want to break it i left it as is
Anyhow ... I dont think false air ever was my main issue ... it did help since there was defenitly some fasle air ... but im still having pretty much the same issue ... i cant run the car until after i clear the fuel trims .. once cleared i can run the car for ever as long as i dont shut it off ... when it is shut off ... i have to clear the codes or its undrivable ... if there was such a big vacuum leak to cause both bank deviating 25% + ... the car would start running bad again after a few minutes as the car would go into closed loop NO ? Im 99% sure ( i might be wrong ) the cars goes into closed loop after i clear the codes ... i see the fuel trims are normal +/- 5% ... i see the o2 voltage fluctuating on the 4 sensors as they should
I noticed key ON ... engine off i am reading 3.5V on fuse 5 ... i pull the fuse out and i have 3.5V on terminal both terminal 5 & 5A ... as soon as i start the car the voltage seems fine ... i would only expect to have voltage on the power side of the fuse .. in this case terminal 5
I get 3.5V on terminal T94/49 on ECU connector ( im expecting Ground here ) ... Batt voltage when running
I also get 3.5V on fuse 9 & 10 key on engine off ... Voltage seems fine when car as soon as car is running
Same for the J757 engine component power supply relay .. key on engine off i get 3.5V on terminal 4 & 8 ... i get batt voltage on terminal 2 & 6
There are many other terminal reading 3.5V key on engine off .. all of the power side coming from that red/white wire coming from the fuse 5
Im trying to find a common issue to all those components ... Im really starting to suspect the ECM
Any leads?
Help is greatly appreciated !!!
Edit: Obnoxious blinking graphic removed.
Please post a fresh auto-scan and before you shut it down with codes and trims learned!
I want to see scans from the OBD2 side and the VAG side!
2.8L
Canada
C?ID=324466
I hope these are what you requested
Auto Scan Before i clear the codes ( car running rough )
Thursday,15,March,2018,10:58:30:24481
VCDS Version: 18.2.0.3 (x64)  HEX-NET CB: 0.4411.4
VIN: WAURV68T38A010499   License Plate: BEFORE CLEAR
Mileage: 175610km-109118mi   Repair Order:
VIN: WAURV68T38A010499   Mileage: 175610km-109118miles
   Revision: 76H10---
   VCID: 3E30D15AA92814B42A-806A
                    Mileage: 175618 km
                    Date: 2007.06.06
                    Time: 19:20:25
                    RPM: 650 /min
                    Load: 27.8 %
                    Temperature: 67.0°C
                    Temperature: 21.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 14.224 V
                    Mileage: 175618 km
                    Date: 2018.03.15
                    Time: 10:54:27
                    RPM: 198 /min
                    Load: 100.0 %
                    Temperature: 53.0°C
                    Temperature: 24.0°C
                    Voltage: 11.303 V
   Coding: 110500
   VCID: 40CCAFA2D3DC624458-8014
   Coding: 0F2000
                    Fault Status: 00100001
                    Reset counter: 71
                    Mileage: 175618 km
                    Date: 2007.06.06
                    Time: 19:24:47
   VCID: 55E26EF63C5EF7EC1B-8000
   Coding: 0025003
   VCID: 43C6A0AE02CA795C45-8016
   Coding: 48022000
   VCID: 302CFF62637CF2C4A8-8064
   Coding: 005914
   Coding: 02532C
                    Reset counter: 31
                    Mileage: 175618 km
                    Date: 2007.06.06
                    Time: 19:02:00
   VCID: 2A18ED0A85A0881466-807E
   Coding: 0000102
   VCID: 312AFA66A876FBCCA7-8064
            000 -  -
                    Reset counter: 31
                    Mileage: 175618 km
                    Date: 2007.06.06
                    Time: 19:02:26
   Coding: 200002
   VCID: 76A0097AC1989CF432-8022
   VCID: 3D32D656AC2E0FAC33-8068
   Coding: 000016
   VCID: 3D32D656A42E0FAC33-8068
   VCID: 44C4A3B2C7C47E647C-8010
            000 -  -
                    Reset counter: 31
                    Mileage: 175618 km
                    Date: 2007.06.06
                    Time: 19:02:16
   Coding: 000003
            000 -  -  - Intermittent
                    Reset counter: 71
                    Mileage: 175618 km
                    Date: 2007.06.06
                    Time: 19:02:16
            000 -  -
                    Reset counter: 31
                    Mileage: 175618 km
                    Date: 2007.06.06
                    Time: 19:02:21
   Revision: 00000000
   VCID: 2B16E80E4A5A911C9D-807E
   VCID: 7DB21656E4AECFAC73-8028
   Coding: 020101
   VCID: 3FCEAC5EAE221DBC21-806A
03175 - Invalid Data Set
            000 -  -
                    Reset counter: 31
                    Mileage: 175618 km
                    Date: 2007.06.06
                    Time: 19:43:30
                    Voltage: 12.80 V
                    Temperature: 25.0°C
                    Temperature: 24.0°C
                    Bin. Bits: 00000100
                    Bin. Bits: 00000001
                    Bin. Bits: 00000000
   VCID: 7CB41B52FFB4C6A444-8028
                    Reset counter: 31
                    Mileage: 175618 km
                    Date: 2007.06.06
                    Time: 19:09:52
   VCID: 2F2EFC1E7E42ED3CB1-807A
   Coding: 0000017
   VCID: 3C34DB527F3406A404-8068
   Coding: 0000002
   Coding: 0CD154
                    Reset counter: 31
                    Mileage: 175618 km
                    Date: 2007.06.06
                    Time: 19:43:26
                    Bin. Bits: 00000000 00001001
                    Voltage: 13.10 V
                    Text:  16,0°C;n.erkannt;     n.erkannt
   Coding: 1000008
   VCID: 75A20E761C9E97EC3B-8020
   Coding: 0010900
   VCID: 281C17029BACBA0470-807C
End----------(Elapsed Time: 01:52, VBatt start/end: 14.4V/14.6V)-----------
VAG fuel trims before codes a cleared
11:01:02 Group 032: Lambda Control (Mixture Adaptation)
11:01:02 Group 033: Lambda Control
  25.0 %  Lambda Control Bank 1 Sensor 1
  1.86 V  Sensor Voltage Bank 1 Sensor 1
  25.0 %  Lambda Control Bank 2 Sensor 1
  1.95 V  Sensor Voltage Bank 2 Sensor 1
11:02:12 Group 032: Lambda Control (Mixture Adaptation)
11:02:12 Group 033: Lambda Control
  1.82 V  Sensor Voltage Bank 1 Sensor 1
  1.88 V  Sensor Voltage Bank 2 Sensor 1
11:08:01 Group 032: Lambda Control (Mixture Adaptation)
11:08:01 Group 033: Lambda Control
  2.07 V  Sensor Voltage Bank 1 Sensor 1
  2.11 V  Sensor Voltage Bank 2 Sensor 1
OBD2 generic mode fuel trim logs before clear codes ( sorry about the format ... not sure if im doing this right ... i dont know if its supposed to be an excel file )
VAG Auto SCan after clear
Thursday,15,March,2018,11:10:45:24481
VIN: WAURV68T38A010499   License Plate: AFTERCLEAR
   Revision: 76H10---
                    Mileage: 175618 km
                    Date: 2018.03.15
                    Time: 11:08:37
                    RPM: 725 /min
                    Load: 29.4 %
                    Temperature: 96.0°C
                    Temperature: 13.0°C
                    Voltage: 14.224 V
   Coding: 110500
   Coding: 0F2000
                    Reset counter: 71
                    Mileage: 175618 km
                    Date: 2007.06.06
                    Time: 19:24:47
   Coding: 0025003
   Coding: 48022000
   Coding: 005914
   Coding: 02532C
                    Reset counter: 31
                    Mileage: 175618 km
                    Date: 2007.06.06
                    Time: 19:02:00
   Coding: 0000102
            000 -  -
                    Reset counter: 31
                    Mileage: 175618 km
                    Date: 2007.06.06
                    Time: 19:02:26
   Coding: 200002
   Coding: 000016
            000 -  -
                    Reset counter: 31
                    Mileage: 175618 km
                    Date: 2007.06.06
                    Time: 19:02:16
   Coding: 000003
                    Reset counter: 71
                    Mileage: 175618 km
                    Date: 2007.06.06
                    Time: 19:02:16
            000 -  -
                    Reset counter: 31
                    Mileage: 175618 km
                    Date: 2007.06.06
                    Time: 19:02:21
   Revision: 00000000
   Coding: 020101
            000 -  -
                    Reset counter: 31
                    Mileage: 175618 km
                    Date: 2007.06.06
                    Time: 19:43:30
                    Voltage: 12.80 V
                    Temperature: 25.0°C
                    Temperature: 24.0°C
                    Bin. Bits: 00000100
                    Bin. Bits: 00000001
                    Bin. Bits: 00000000
                    Reset counter: 31
                    Mileage: 175618 km
                    Date: 2007.06.06
                    Time: 19:09:52
   Coding: 0000017
   Coding: 0000002
   Coding: 0CD154
                    Reset counter: 31
                    Mileage: 175618 km
                    Date: 2007.06.06
                    Time: 19:43:26
                    Voltage: 13.10 V
   Coding: 1000008
   Coding: 0010900
End----------(Elapsed Time: 01:53, VBatt start/end: 14.6V/14.6V)-----------
VAG Trims after clear
11:15:00 Group 031: Lambda Control (Lambda Sensor Voltages)
  0.95  Lambda Control Bank 1 (actual)
  0.88  Lambda Control Bank 1 (specified)
  0.95  Lambda Control Bank 2 (actual)
  0.88  Lambda Control Bank 2 (specified)
11:15:00 Group 032: Lambda Control (Mixture Adaptation)
  1.0 %  Adaptation (Idle) Bank 1 Sensor 1
  0.8 %  Adaptation (Partial) Bank 1 Sensor 1
  1.3 %  Adaptation (Idle) Bank 2 Sensor 1
  0.8 %  Adaptation (Partial) Bank 2 Sensor 1
11:15:00 Group 033: Lambda Control
  1.33 V  Sensor Voltage Bank 1 Sensor 1
  3.1 %  Lambda Control Bank 2 Sensor 1
  1.33 V  Sensor Voltage Bank 2 Sensor 1
OBd2 Generic fuel trims after clearing codes
VAG Fuel trims after shut the car off then restart ( before clearing codes )
11:28:09 Group 031: Lambda Control (Lambda Sensor Voltages)
  1.16  Lambda Control Bank 1 (actual)
  0.90  Lambda Control Bank 1 (specified)
  1.13  Lambda Control Bank 2 (actual)
  0.90  Lambda Control Bank 2 (specified)
11:28:09 Group 032: Lambda Control (Mixture Adaptation)
  1.9 %  Adaptation (Idle) Bank 1 Sensor 1
  2.3 %  Adaptation (Idle) Bank 2 Sensor 1
11:28:09 Group 033: Lambda Control
  1.80 V  Sensor Voltage Bank 2 Sensor 1
11:31:04 Group 030: Lambda Control (Sensor Status)
      0110  Bank 1 Sensor 2
      0110  Bank 2 Sensor 2
11:31:58 Group 030: Lambda Control (Sensor Status)
     01111  Bank 1 Sensor 1
     01111  Bank 2 Sensor 1
11:31:58 Group 031: Lambda Control (Lambda Sensor Voltages)
  1.20  Lambda Control Bank 1 (actual)
  0.93  Lambda Control Bank 1 (specified)
  1.20  Lambda Control Bank 2 (actual)
  0.93  Lambda Control Bank 2 (specified)
11:31:58 Group 032: Lambda Control (Mixture Adaptation)
Trims after restarting then clearing the codes
Here are some screenshots of OBD2 generic readiness status
2.8L
Canada
C?ID=324466
Im still very annoyed by that #5 fuse under the ECM reading ~3.5 volts ...
Some of the place I traced it to was pin T94/49 and T94/93 of ECM connector
Even with the relay J299 SAI pump relay removed ... im still picking up 3.5V at terminal 49 witch as far as im concerned should be straight ground
Im pretty sure the ECM is shorted ... A new one is 3006.85$ CAD ... i never found a used one locally to test
Also it the ECM has been changed in 2011
( Sorry about my ugly diagram ... my computer with alldata crashed yesterday .. its being fixed at this moment so this is the only diagram i have available right now )
Component: 4.2l V8/4V H10 0008 <<<<<<<<<<<<<<<<<<<<<<< Firmware update required 0009 or higher!
Are you sure you have current there or just low amounts of residual voltage?
Please correct faults to engine mount and intake.
Fault Found:
Why are we dicking around at J299 ?
