Hello all.
I've noticed a singular and weird (and ridiculous) peculiarity in the new Polo digital cluster, not only in my car, but in videos I've seen in youtube from all around: the cluster actually doesn't show the TIME.
And it's weird because, as far as I know, almost all the new MFD, even the small ones, color or mono, show the time on it.
Few days ago, I took a look in a Passat with AID, and, in this case, the "time" was there, and where I imagined it should be: on the top-middle of the screen, between the compass and the outside temp.
I messed around with the 17 module with another dongle (I got the old VCDS interface...) and couldn't find any adaptation channel for that. I imagine (only imagine) that there's something to do with coding in 17 module.
So, if anyone get any idea on how to show this so advanced widget called "time" on the AID (excluding fixing a watch on it...), I'll be thankful.
Here is a scan:
Here is a scan:
Tuesday,06,February,2018,21:31:53:30049
VCDS Version: 18.1.0.2 (x64)
Data version: 20180122 DS285.1
VIN: 9BWAH5BZXJP025086 License Plate:
Chassis Type: BZ-VW27 (2Q0)
Scan: 01 02 03 05 08 09 10 15 17 19 44 5F
Address 01: Engine (J623-DHSB) Labels: None
Part No SW: 04C 906 026 BT HW: 04C 907 309 AH
Component: R3 1.0l TFS H21 5244
Revision: WVH21---
Coding: 011A0012232400001000
Shop #: WSC 01530 935 00200
ASAM Dataset: EV_ECM10TFS01104C906026BT 001002
ROD: N/A
VCID: 74E05513DFCE4EE5A1-8020
Unsupported vehicle.Please upgrade to a current Ross-Tech interface.
No ASAM data for: "EV_ECM10TFS01104C906026BT" (VW27)
Readiness: 0010 0001
Address 02: Auto Trans (J217) Labels: None
Part No SW: 09G 927 158 CL HW: 09G 927 158
Component: AISIN AG6 G3 202 3409
Coding: 0000000000000000010000000000000000000000
ASAM Dataset: EV_TCMAQ250031 002009
ROD: N/A
VCID: 7F0A8A3FE6881DBDCC-802A
No ASAM data for: "EV_TCMAQ250031" (VW27)
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 2Q0 614 517 S HW: 2Q0 614 517 L
Component: ESC_base H12 0222
Serial number: 86400298171011
Coding: 33044C673743CCB232FCEC1E14E0126A49444D26226A242444541254452848569222B26444562424222A482AA229D64214946B4228
ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
ROD: N/A
VCID: 3E74B73BA102D4B587-806A
No ASAM data for: "EV_Brake1BOSCHESPMQBA0" (VW27)
No Faults Found
Address 05: Acc/Start Auth. (J518) Labels:. 5Q0-959-435.clb
Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G
Component: VWKESSYMQB 037 0906
Revision: 00037000 Serial number: 0452032701
Coding: 132C0C0723
ROD: N/A
No ASAM data for: "EV_KessyHellaMQBAB" (VW27)
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 2G0 907 057 D HW: 2G0 907 057 D
Component: Climatronic H03 0501
Coding: 0120000008000000000004000040010D0000000000000000000000000000
ASAM Dataset: EV_ACClimaBHBMQBA0 004017
ROD: N/A
VCID: 295E7467488C430DC2-807C
No ASAM data for: "EV_ACClimaBHBMQBA0" (VW27)
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 2Q0 937 089 HW: 2Q0 937 089
Component: BCM A0 Std H96 0915
Serial number: 20117264001702
ASAM Dataset: EV_BCMA0 204001
ROD: N/A
VCID: 77FA621FCEB825FD84-8022
Subsystem 1 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 047 0105
Serial number: S2Y17M09D15H20M48S45
Coding: 0038DD
Subsystem 2 - Part No SW: 2Q1 959 881 B HW: 2Q1 959 881 B
Component: FHSG_DRV 001 0001
Serial number: 00000000000016427985
Coding: 138000
Subsystem 3 - Part No SW: 2Q1 959 882 D HW: 2Q1 959 882 D
Component: FHSG_PSG 001 0002
Serial number: 00000000000016591300
Coding: 098000
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY1730041W8
Subsystem 5 - Part No SW: 5Q0 959 811 D HW: 5Q0 959 811 D
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000016738590
Coding: 030000
Subsystem 6 - Part No SW: 5Q0 959 812 D HW: 5Q0 959 812 D
Component: FOND_FHSG_PSG 005 0007
Serial number: 00000000000015668380
Coding: 1B0000
No ASAM data for: "EV_BCMA0" (VW27)
Address 10: Park/Steer Assist (J446) Labels:. 5Q0-919-294.clb
Part No SW: 5Q0 919 294 L HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0056
Revision: -------- Serial number: 55401725606446
Coding: 0031151011
ROD: N/A
VCID: 4480C5D3CFEEBE65D1-8010
No ASAM data for: "EV_EPHVA18AU3700000" (VW27)
Address 15: Airbags (J234) Labels: None
Part No SW: 2QB 959 655 HW: 2QB 959 655
Component: VW22Airbag 010 0246
Revision: --------
Coding: 88C0C00000000000540000CF000800000065
ASAM Dataset: EV_AirbaVW22BPAVW27X 001010
ROD: N/A
VCID: 0C102DF3A73E3625D9-8058
Subsystem 1 - Part No SW: ----------- HW: 442 1A0 910 17
Component: SideSensor_Df 2C4 0148
Serial number: 349B4D4C927F01A153B
Subsystem 2 - Part No SW: ----------- HW: 442 1A0 710 17
Component: SideSensor_Pf 2C4 0148
Serial number: 350B4D2BD2839F66A1E7
Subsystem 3 - Part No SW: ----------- HW: 442 131 509 17
Component: FrontSensor_D 290 118A
Serial number: 355AG119926E274383BX
No ASAM data for: "EV_AirbaVW22BPAVW27X" (VW27)
Address 17: Instruments (J285) Labels: None
Part No SW: 2G0 920 790 HW: 2G0 920 790
Component: KOMBI 513 0600
Coding: 042402082180000C020872001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBA0 001024
ROD: N/A
VCID: 64C025536F2EDE6531-8030
No ASAM data for: "EV_DashBoardVDDMQBA0" (VW27)
No Faults Found
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 2Q0 909 901 HW: 2Q0 937 089
Component: GW MQB A0 H96 0915
Coding: 0101000020085600F80002081C0F00000001070000000000000000000000
ASAM Dataset: EV_GatewA0 013020
ROD: N/A
VCID: 6FEA5A7FB6E86D3D5C-803A
Subsystem 2 - Part No SW: 56D 959 442 HW: 56D 959 442
Component: E221__MFL-834 H01 0130
Serial number: 000000000B0468060817
Coding: 200000
No ASAM data for: "EV_GatewA0" (VW27)
Address 44: Steering Assist (J792) Labels: None
Part No SW: 2Q1 909 144 J HW: 2Q1 909 144 F
Component: TRW_G4L_MQBA0 610 6030
Serial number: 0134638CB3H2793
Coding: 00000000000000000101020101000101000001
ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 009014
ROD: N/A
VCID: 397EA427B82CF38DB2-806C
No ASAM data for: "EV_SteerAssisTRWG4LMQBA0" (VW27)
Address 5F: Information Electr. (J794) Labels:. 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 864 C HW: 3Q0 035 864 C
Component: MU-S-N-ER 851 0867
Coding: 02720003BE00000041220001001828101F0500F401200400CF
ROD: N/A
VCID: 316E9C07605C3BCD0A-8064
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H50 8130
Serial number: VWZ6ZJT3101106
Subsystem 2 - Part No SW: 3G0 919 866 BF HW: -----------
Component: MRM2 2017/18 --- 0821
No ASAM data for: "EV_MUStd4CDELP" (VW27)
No Faults Found
End-------------------------(Elapsed Time: 02:57)--------------------------
