Transporter T5.1 MFSW Retrofit (no illumination)
jason_rmh
C?ID=136293
Over the weekend I have retrofitted MFSW to my 2011 T5.1.
My T5 did not originally have MFSW installed.
The new steering wheel is the newer style one used in the new golf, polo, T6, but not MQB version etc.
My steering wheel is from a 2015 scirocco, has the 1K8 buttons (no cruise control).
I have BCM 7H0 937 087 H which is compatible with cruise control and MFSW.
At the T41 connector to the indicator / cruise / wiper stalks, I connected the following wires:
Pin 9: 12v ( from pin 28, switched 12v supply for cruise control)
Pin 19: LIN bus (to pin 17 BCM)
Coded in VCDS (Centr. Elect > MFSW Installed)
I have confirmed 12v at pin 9.
All buttons work to control head unit (station, volume etc) and MFD.
However, the buttons do not illuminate.
Could it be that the airbag loom, which has a 5 pin connector into the MFSW buttons, is incorrect?
My MFSW loom has a 5 pin connector with only pins 1,2,3 & 5 used.
I have used erwin to view the T5 wiring diagrams and can see the original MFSW would have a 6 pin connector to the buttons, with only 5 pins used:
J453 - Multifunction steering wheel control unit
6 Pin Connector (2011 T5 Transporter)
1 - 12v
2 - GND
3 - LIN
4 - Horn Plate
5 - Horn Plate?
6 - not used
And I *think* the 1K8 scirocco has a 5 pin connector, with all pins used.
Or im fearing these buttons illumination are controlled by the BCM?
Here is my autoscan:
Monday,05,February,2018,18:42:12:39540
VCDS Version: 18.1.0.2
Data version: 20180122 DS285.1
VIN: WV2ZZZ7HZCH029914   License Plate:
Mileage: 246970km-153460mi   Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 02 03 04 08 09 15 17 18 19 25 56 69 0B
VIN: WV2ZZZ7HZCH029914   Mileage: 246970km-153460miles
Address 01: Engine (J623-CCHA)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 DH    HW: 03L 907 309 K
   Component: R4 2,0L EDC   H43 9133
   Revision: 26H43---    Serial number: 00000000000000
   Coding: 0125401A233400080000
   Shop #: WSC 02756 790 50316
   ASAM Dataset: EV_ECM20TDI01103L906019DH 002008
   ROD: EV_ECM20TDI01103L906019DG.rod
   VCID: 74EDC508DF215BE5A1-8020
   Part No SW: 0BT 300 045 M    HW: 0BH 927 711 C
   Component: DSG DQ500-7F  H05 1712
   Revision: 00H05V01
   ROD: EV_TCMDQ500021_VW36.rod
   VCID: 3F875A24A6E7C8BD8C-806A
Address 03: ABS Brakes (-----)       Labels:. 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 H    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0107
   Revision: 00H43001
   Coding: 208724AD09A6049E24AB9072AA6210
   Shop #: WSC 02756 790 49152
   VCID: 3777320486D7F0FD44-8062
   Part No SW: 7E5 907 047 BA    HW: 7E5 907 047 BA
   Component: Climatic-T5   H19 0404
   Revision: 00001008
   Coding: 0000000002
   Shop #: WSC 02757 790 50316
   ROD: EV_ClimaT5Basis.rod
   VCID: 6FE7CA64B607783D5C-803A
   Part No SW: 7H0 937 087 H    HW: 7H0 937 087
   Component: BCM T5GP H+4  H47 0251
   Revision: BO047001    Serial number: 0429 220110457
   Coding: B8B079BA0E61241392284E102C2B8DD40080410F60044000300000000000
   Shop #: WSC 02756 790 12345
   VCID: 3973343CB0C3E68DB2-806C
   Subsystem 1 - Part No SW: 7E0 959 801 B    HW: 7E0 959 801 B  Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3311
   Subsystem 2 - Part No SW: 7E0 959 802 B    HW: 7E0 959 802 B  Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3311
   Subsystem 4 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H04 0103
   Serial number: 29170001538600027307
   Coding: A40000
03156 - Sensor for Anti-Theft System (G578)
                    Reset counter: 47
                    Mileage: 246979 km
                    Date: 2012.06.27
                    Time: 00:21:31
            000 -  -  - Intermittent
                    Mileage: 246979 km
                    Date: 2012.06.27
                    Time: 00:21:27
   Component: VW10Airbag009 H06 0013
   Revision: --------    Serial number: 003HL006ZWXI
   Shop #: WSC 02754 790 50316
   VCID: 356B380C94DB02ED56-8060
   Part No SW: 7E0 920 970 E    HW: 7E0 920 970 E
   Component: KOMBI         H04 0305
   Coding: 460E00
   Shop #: WSC 00000 790 50316
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   VCID: 2C5D1D684791432539-8078
Address 18: Aux. Heat        Labels: None
   Part No: 7E0 815 071 B
   Component: J737__Standheizung  0605
   Revision: 00085000    Serial number: 09019275F00000
   Coding: 0000031
   Shop #: WSC 02757 790 00000
   VCID: 244DF548E7418B65F1-8070
   Part No SW: 6N0 909 901     HW: 7H0 937 087
   Component: GW-K-CAN TP20 H47 0251
   Revision: BO047001
   Coding: 042300
   VCID: 70E5C918A33967C545-8024
   Component: IMMO          H04 0305
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6AD1DB708DE59D150B-803E
   Part No SW: 7E0 035 156 B    HW: 7E0 035 156 B
   Component: Radio         H42 0105
   Revision: R0000000    Serial number: VWZAZ1L2264317
   Coding: 0000020002
   Shop #: WSC 02754 790 00000
   VCID: 2241F3503D55855583-8076
   Part No SW: 1K0 907 383 G    HW: 1K0 907 383 G
   Component: Towbar module H10 0110
   Revision: 3A001001    Serial number: ÀÁ006789000000
   Coding: 010D000100000000
   VCID: 31630C1C68B32ECD0A-8064
End-------------------------(Elapsed Time: 03:12)--------------------------
Monday,05,February,2018,18:52:49:39540
   Revision: 00H05V01
   Revision: 00H43001
   Revision: 00001008
   Coding: 0000000002
   Coding: B8B079BA0E61241392284E102C2B8CD40080410F60004000300000000000
   Coding: A40000
                    Reset counter: 47
                    Mileage: 246979 km
                    Date: 2012.06.28
                    Time: 00:06:25
   Coding: 460E00
   Coding: 0000031
   Revision: BO047001
   Coding: 042300
   Coding: 0000020102
End-------------------------(Elapsed Time: 03:11)--------------------------
This fault is also worrying....
                    Mileage: 246979 km
                    Date: 2012.06.27
                    Time: 00:21:27
I notice there is no coding information for the 1K8 buttons?
Hopefully the above makes sense and someone can give some advice on the situation.
Jason
m87a
Bosnia and Herzegovina
C?ID=156900
your mfsw control module doesn't support illumination same as mk5 mfsw module, so you either solder some wires for illumination or replace module
check this
jason_rmh
C?ID=136293
I thought that may be the case, thanks for confirming!
On the T5, is the control module controlled via the BCM, via LIN bus?
On the mk5 there is an actual module under the steering column.
Jason
iichel
Eindhoven, NB, NL
C?ID=284912
I agree with m87a. The button illumination data is sent by LIN. If you want the buttons illuminated, you'll need a 7E0 BCM.
Your coding for the BCM seems to be fine.
My wheel with 7E0 BCM has the coding:
Subsystem 7 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-DC1 H03 0103
Serial number: 27140002547420014516
Coding: A4FFFF
your assumption for the pinout is almost correct.
1 - 12v
2 - GND
3 - LIN
4 - Horn Plate
5 - Cruise control
jason_rmh
C?ID=136293
Resolved
To summarize the golfgti thread, as it may help others:
1K8 buttons work but will not illuminate.
1K8 buttons can be forced to illuminate by soldering a wire to pin 2 of the 5 pin connector inside the MFSW buttons, but they will then be on all the time (with ignition).
6C0 buttons (6C0 959 442) will work and illuminate:
The 6C0 version C and D buttons have cruise control buttons.
C standard cruise, D adaptive cruise.
Cruise buttons will not work and be redundant, but the other buttons will work fine.
6C0 with no revision letter, do not have cruise and fully work and illuminate.
Jas
iichel
Eindhoven, NB, NL
C?ID=284912
I suppose one could also consider 2H0 959 442
