- Aug 10, 2016
- 2,157
- 2,570
- Eindhoven, NB, NL
- C?ID=284912
Hey guys, hope I'm not interrupting anyone watching the Bathurst 12h race. Spoiler alert: just completed the 1st racing lap.
The advanced measurement values of the 7E0 937 090 BCM of the cruise control, more specific, the cancel switch seems to be the wrong way around.
If the switch is at 'on' it says at the cancel button 'activated' and if cancel is selected, it says 'not activated'.
I do apologise for the bad video quality but it's a bit dark an keeping both the screen and the stalk visible was a bit tricky.
If you look closely, you can distinguish 'activated' and 'not activated'.
The switch works the way it's intended:
equipment:
equipment:
Tuesday,30,January,2018,15:48:11:11868
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86(VirtualBox)
VCDS Version 18.1.0.2 HEX-V2 CB: 0.4411.4
Data version: 20180122 DS285.1
VIN: WVWZZZ6RZBYiichel License Plate:
Mileage: Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 05 08 09 10 15 17 19 20 25 2B 2E 37 3C 44 47 55 56
61 69 6C 77
VIN: WVWZZZ6RZBYiichel Mileage:
Address 01: Engine (J000-CFWA) Labels:. 03P-906-021-CFW.clb
Part No SW: 03P 906 021 B HW: 03P 907 425
Component: R3 1.2l TDI H06 9980
Revision: 12005001 Serial number:
Coding: 00114036033401080000
ASAM Dataset: EV_ECM12TDI03103P906021B 001043
ROD: EV_ECM12TDI03103P906021AA.rod
VCID: 270B06DDAF6FF1FF09F-8073
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP90.clb
Part No SW: 6R0 907 379 AS HW: 6R0 907 379 AS
Component: ESP9.0i front H02 0002
Serial number: --------------
Coding: 21DD4885432500C5841A126EC25500521505
Shop #: WSC 00049 770 00138
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
ROD: EV_Brake1ESP90iBOSCH_003_VW21.rod
VCID: 0F7B4E7D27DF89BFE1F-805B
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6RA 959 654 HW: 6RA 959 654
Component: LENKW.SENSOR H02 0020
Serial number: 090465LBH0000C
Coding: 01
ASAM Dataset: EV_LWSKLOVW25X 005002
ROD: EV_LWSKLOVW25X.rod
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1202
Revision: 00092000 Serial number: 0346244897
Coding: 030C0C
ROD: EV_KESSY_PQ35GP.rod
VCID: 372BD69D7FCF617F99F-8063
Address 08: Auto HVAC (J255) Labels: 6R0-907-044.clb
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H12 0812
Revision: V0000000
VCID: 3829D5A172516E07905-806D
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 HW: 7E0 937 090
Component: BCM PQ25 Max4 H80 0733
Revision: B9080001 Serial number: 0771 092150183
Coding: 3CB02FF828CB2400933806E2FFEB9FD080A273EFE08D78D0A2 E400030800
VCID: 688945E162713E87C05-803D
Subsystem 1 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
Component: RLS 140415 03 37 0059
Coding: 0380DD
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8611
Serial number: KU0KU011111300010103
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8611
Serial number: KU0KU007111300016463
Coding: 1000AB
Subsystem 4 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K0 951 605 C
Subsystem 6 - Part No: 1K8 951 171 A
Subsystem 7 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-DC1 H03 0103
Serial number: 27140002547420014516
Coding: A4FFFF
Subsystem 8 - Part No SW: 6R0 959 811 B HW: 6R0 959 811 B
Component: J388__TSG_HL 002 0803
Serial number: KU0-KU008.06.0910897
Coding: 08BC32
Subsystem 9 - Part No SW: 6R0 959 812 B HW: 6R0 959 812 B
Component: J389__TSG_HR 002 0803
Serial number: KU0-KU004.06.0913330
Coding: 08BC32
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 L HW: 7N0 919 475
Component: PARKHILFE 8K H06 0106
Revision: -------- Serial number: 28231422402620
Coding: 318001
ASAM Dataset: EV_VW75XParkAssis8K 001003
ROD: EV_EPHVA18VW250GPCS_VW25.rod
VCID: 3B23CAAD43E7451F7D7-806F
Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
Component: VW10Airbag01M H10 0020
Revision: -------- Serial number: 003GX0142TCE
Coding: 00314D
Shop #: WSC 01383 785 00200
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4ACD9F691C3DEC97F61-801F
Serial number: 3575HRB40650BI7U48C8
Serial number: 3585HRB405J09RECEOUJ
Serial number: 3515RRB405T0BTBEF9G7
Serial number: 3525RRB405R0BTBEKPFQ
Part No SW: 6R0 920 870 A HW: 6R0 920 870 A
Component: KOMBI H04 0709
Coding: 140E01
VCID: 3333E28D6BB78D5FA57-8067
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H80 0733
Revision: B9080001
Coding: 042200
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10 0003
Revision: AA001001
Coding: 040C00E200000000000000
ASAM Dataset: EV_HighBeamAssisAU316 001004
ROD: EV_HighBeamAssisAU316.rod
VCID: 2E05F3F98095A0B7CA9-807B
Component: IMMO H04 0709
Coding: 000007
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A8D3FE97CFD0C97D61-803F
Address 2B: Steer. Col. Lock (J764) Labels:| 5K0-905-861.clb
Part No SW: 5K0 905 861 B HW: 5K0 905 861 B
Component: ELV-PQ35 H20 0240
Revision: 00000000 Serial number: 11000256123005
Coding: 4100000000000000
ROD: EV_ELVMarquMPVW36X.rod
VCID: 2F3BEEFD879FA9BFC1F-807B
Part No SW: 5N0 035 342 G HW: 5N0 035 342 G
Revision: A1001003 Serial number: 7666620365
Coding: 010100
VCID: 2B03FAEDB307D59FED7-807F
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 686 E HW: 1T0 035 686 H
Component: RNS-MID H26 6276
Revision: AB001001 Serial number: VWZ6Z7P1950254
Coding: 00070002010000A10001
VCID: 3635DB9978459877829-8063
Component: EU West V15 8515
Part No SW: 7E0 907 566 C HW: 4H0 907 566 F
Component: SWA Master H07 0030
Serial number: 0384674663
Coding: 030321
Shop #: WSC 54321 321 54321
ROD: EV_LaneChangAssis_VN75.rod
VCID: 3039ED819AA1B647D85-8065
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 7E0 907 568 C HW: 4H0 907 568 F
Component: SWA Slave H08 0030
Serial number: 0432634593
Coding: 030321
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11241
Shop #: WSC 54321
VCID: 2F3BEEFD8E5FA9BFC1F-807B
Part No SW: 5C6 035 456 C HW: 5C6 035 456 C
Component: KonzernAmp10K H08 6831
Revision: -------- Serial number: EAA098C0000052
ASAM Dataset: EV_AudioVerst10KanalSTT4 001001
ROD: EV_AudioVerst10KanalSTT4.rod
VCID: 280905E1A271FE87005-807D
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Coding: 0192000001000000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_HeadlRegulVWLWRPt 001004
ROD: EV_HeadlRegulVWLWRPt_VW25.rod
VCID: 77AB169D3F4FA17F59F-8023
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H80 0733
Coding: 030F1A5A
Subsystem 1 - Part No SW: 6C0 915 181 HW: 6C0 915 181
Component: J367-BDM H08 0223
Serial number: 61083A44504351928092
Part No SW: 1K0 907 383 E HW: 1K0 907 383 E
Component: Anhaenger H07 0080
Revision: 3A002002 Serial number: 00000116932377
Coding: 0100000100000000
VCID: 2F3BEEFD871FA9BFC1F-807B
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 7E0 907 441 HW: 7E0 907 441
Revision: 00H08000 Serial number: 525PA8-J060533
Coding: 0030115
VCID: 65974CD5996323EFFB3-8031
Address 77: Telephone (J412) Labels:| 3C8-035-730-A.clb
Part No SW: 3C8 035 730 E HW: 3C8 035 730 E
Component: Telefon 025 0983
Revision: -------- Serial number: 35502105254406
Coding: 020100000100010000000101
ASAM Dataset: EV_UHVPremi 002709
ROD: EV_UHVPremi.rod
VCID: 25170CD5D563E3EF3B3-8071
End----(Elapsed Time: 02:19, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
