Always OK? The fault code is for an intermittent problem...I've tested the gear lever position against the "Selector lever position - Shift Position" data and it is okay
Intermittent fault codes, like all fault codes, don't necessarily represent the current state but the state when the fault was logged, so you should always clear them and then test.tested the gear lever data again - it still matches the gear position even with the intermittent fault code still showing on a scan
Any chance you could advise me on a part number or link for this gear selector switch pleaseIntermittent fault codes, like all fault codes, don't necessarily represent the current state but the state when the fault was logged, so you should always clear them and then test.
Fault finding intermittent problems is always harder, you often need some luck to find the cause. The best approach is to check thoroughly ALL the connections.
I will say again that several UK Octavia DSG owners have had this problem and it's ALWAYS been a faulty gear selector switch.
Sorry I don't have access to a part number catalogue.Any chance you could advise me on a part number or link for this gear selector switch please
