Hi, new here
I've had the car (Octavia RS 220 TSI DSG6 2017) for about 4 months and recently I'm getting "Starter system faulty workshop!" error after I turn off the switch . If I turn off the engine and switch quickly at once, it doesn't appear.
So far I've been to the importer's service 3 times and they've yet to figure out the problem, although they're working according to Skoda's instructions (so they say) .
I don't have any ignition issue with the car what so ever. Here's a scan i took today:
I think the "10763 - Starter Enable from Selector Lever Sensor System" error has something to do with this issue, as I'm not getting it every scan.
I've replaced the original stereo system with aftermakret Alpine multimedia so i guess some of the Can bus errors have to do with that ,
no idea where the airbag "Supply Voltage
B201C 00 [008] - Implausible Signal" comes from - should this be a concern?
Any advise or lead would be most appreciated
Friday,02,February,2018,15:20:47:12953
VCDS Version: 18.1.0.2 HEX-V2 CB: 0.4411.4
Data version: 20180122 DS285.1
VIN: TMBAE7NE4H01XXXXX License Plate:
Mileage: 3445km-2140mi Repair Order:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F A9
VIN: TMBAE7NE4H01XXXXX Mileage: 3445km-2140miles
Address 01: Engine (J623-CHHB) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 C HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 0C1D00124424010B0000
Shop #: WSC 19383 002 1048576
ASAM Dataset: EV_ECM20TFS0205G0906259C 001005
ROD: EV_ECM20TFS0205G0906259C.rod
VCID: 2E05F397B0946CE7CA9-807A
Readiness: 1000 0001
Part No SW: 0D9 300 042 S HW: 02E 927 770 AS
Component: DQ250-6F MQB H54 5010
Revision: 06454104 Serial number: TFK01610120525
Shop #: WSC 73430 031 00063
ROD: EV_TCMDQ250021.rod
VCID: 290F008B897A0BDF1FB-807C
P1734 00 [002] - -
Address 03: ABS Brakes (J104) Labels:| 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 614 517 AF HW: 5Q0 614 517 AF
Component: ESC H62 0398
Revision: 00000000 Serial number: 63006000001556
Coding: 1A076B91542119704078060241CB2958D62A98026082947600410070C00903
ASAM Dataset: EV_Brake1UDSContiMK100ESP 035019
ROD: EV_Brake1UDSContiMK100ESP_035_SK37.rod
VCID: 75B71CFB15421F3F4B3-8020
Part No SW: 5E0 907 044 AB HW: 5E0 907 044 AB
Component: Climatronic H04 1601
Revision: 00001K07
Coding: 01010004000110011005000000101002
ASAM Dataset: EV_ACClimaBHBVW37X 006142
ROD: EV_ACClimaBHBVW37X_006_SK37.rod
VCID: 65974CBBA5E2EFBFFB3-8030
Air quality sensor:
Part No SW: 5Q0 937 084 CL HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number: 01061629000275
Coding: 0C101A42C24722FB47E04000000C07280000000000000000000000000000
Shop #: WSC 73430 790 00000
ROD: EV_BCMBOSCH_015.rod
VCID: 0451713F4E9836B74CD-8050
Subsystem 1 - Part No SW: 5E1 955 119 HW: 5E1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 161004 041 0570
Serial number: 161018094438
Coding: 065DDD
Component: RLHS 042 0105
Serial number: S3Y16M10D31H09M51S07
Coding: 00885D
Sun Roof:
Subsystem 3 - Part No SW: 6R0 959 591 D HW: 6R0 959 591 D
Component: J245 PS72.403 H03 0004
Serial number: 0000FST0018NRYL00000
Coding: 981803
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 F HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0054
Revision: -------- Serial number: 39261629502863
Coding: 0001050011
ROD: EV_EPHVA14AU3700000_002_VW27.rod
VCID: 3C21C9DF76E88E7774D-8068
Part No SW: 3Q0 959 655 AS HW: 3Q0 959 655 AS
Component: Airbag VW20 013 0200
Revision: -------- Serial number: 003SQPMWG67-
Coding: 98CCC000000000005C5400CC000800000065
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 0F7B4E1317DE45EFE1F-805A
Subsystem 1 - Part No SW: ----------- HW: 454 000 710 16
Serial number: 3576U000000241E8BD1J
Subsystem 2 - Part No SW: ----------- HW: 454 000 310 16
Serial number: 3586U000000235244E11
Subsystem 3 - Part No SW: ----------- HW: 454 800 610 16
Serial number: 3516REB80310D0000006
Subsystem 4 - Part No SW: ----------- HW: 454 801 310 16
Serial number: 3526RF8242F0C000000F
Subsystem 5 - Part No SW: ----------- HW: 454 800 810 16
Serial number: 3556V422EF90C000000M
10492928 - Supply Voltage
[Powersupply implausible signal]
Reset counter: 26
Mileage: 3445 km
Date: 2018.02.02
Time: 15:17:18
Part No SW: 5Q0 953 521 T HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF034034 Serial number: 20161026500471
Coding: 1410
Shop #: WSC 73430 031 00000
ROD: EV_SMLSVALEOMQB.rod
VCID: 43D3B2230B16F18F357-8016
Part No SW: 5E0 920 746 C HW: 5E0 920 746 C
Component: KOMBI 205 8311
Coding: 07A5010829800008010A2A001000000000000000
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 F
Component: GW MQB High 128 1265
Revision: -------- Serial number: 0005454104
Coding: 030100047F085900EB00026A1C0F00010001050000000000000000000000
ROD: EV_GatewLear_013_SK37.rod
VCID: 7CA109DF36684E7734D-8028
Subsystem 2 - Part No SW: 3V0 919 719 B HW: 3V0 919 719 B
Component: E221__MFL-PR6 H02 0160
Serial number: 000000000A0320111016
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Serial number: 75410803001610260561
131699 - Control unit for information electronics 1
U1054 00 [009] - No Communication
[Timeout Knoten 0x73 / 5F - Steuerger\E4t f\FCr Informationselektronik 1]
Reset counter: 238
Mileage: 3429 km
Date: 2018.01.30
Time: 15:28:43
Supply voltage: Terminal 30: 12.1 V
Terminal 15: On
8531970 - Quiescent Current
U1406 00 [008] - Too High
[Ruhestrom oberer Grenzwert \FCberschritten]
Reset counter: 26
Mileage: 3436 km
Date: 2018.01.30
Time: 22:28:17
Supply voltage: Terminal 30: 12.4 V
Terminal 15: OFF
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 010 0032
Serial number: 0000223728077
Coding: 001D0120D000040000001100
VCID: 47CBA6333F2EDDAFE9F-8012
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000011987022
Coding: 010200
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 8107
ROD: EV_SteerAssisMQB_013.rod
VCID: 3A2DCFC77CDCB047661-806E
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 010 0032
Serial number: 0000225193883
VCID: 46D5AB373824C4A7129-8012
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000012042926
Coding: 190200
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 03DA00003F000000
Shop #: WSC 73430 790 00063
VCID: 40D9BD2F1A00EA97285-8014
Subsystem 1 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo links H06 0009
Coding: 3E0000
Subsystem 2 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo rechts H06 0009
Coding: 3E0000
Part No SW: 5E0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0001
Serial number: 161008200130
VCID: 698F408B49FACBDFDFB-803C
End----(Elapsed Time: 01:31, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
