Help adjusting service interval - SEAT Ibiza
Blanco92
C?ID=64435
Hi all,
I'm trying to adjust the interval that the INSP and OIL service lights appear on my car. The car is a 2004 (6L) SEAT Ibiza 1.2 AZQ.
I previously had a 2002 (6L) SEAT Ibiza (also 1.2 AZQ) that, from factory, had a service regime set that INSP services occurred every 10k, with an OIL service in between every 5k miles. For example
5k miles - OIL service (just oil and oil filter change)
10k miles - INSP service (oil and ALL filters, spark plugs)
15k miles - OIL service
20k miles INSP service
And so on.
My current 2004 Ibiza doesn't do this, instead, every 15,000km it throws up the OIL service light, and every 30,000km it throws up the INSP light. I want to change this so it works like the 2002 Ibiza did. But I can't figure out how.
In address 17 Instruments, I've tried changing channel 06 (max distance to INSP) from 30 to 16. This would give me my desired 10k miles between INSP lights.
However, the SRI reset ignores the above change I made, and when I try to reset it, it continues to adjust channel 11 to 30, not the 16 that I expect to see.
Tuesday,23,September,2014,18:15:21:32646
VCDS Version: 12.12.3.0
Data version: 20140822
VIN: VSSZZZ6LZ5R00####   License Plate: #######
VCDS Release 12.12.3:  SRI Reset
Control Module Part Number: 6L0 920 901        Labels:  6L0-920-xx0-17.lbl
Component:KOMBI+WEGFAHRSP VDO V12, Coding:00437
Operation: Service Reset (INSP)
Channel  	Description                                       	Unit      	Current val.  	New val.
02       	Service Reminder Status                           	          	0             	---
05       	Maximum Distance to Oil Service (OEL)             	km x1000  	15            	---
06       	Maximum Distance to Inspection (IN1)              	km x1000  	16            	---
07       	Maximum Time to Inspection (IN2)                  	Month     	12            	---
10       	Distance to Oil Service (OEL)                     	km x100   	35            	150
11       	Distance to Inspection (IN1)                      	km x100   	1             	300
12       	Time to Inspection (IN2)                          	Days      	115           	---
There's probably a simple answer to this that I'm just not seeing...
Cheers.
Are you doing this on the SRI screen? If so, try changing the corresponding Adaptation channels directly.
However understand that some clusters arbitrary values in these channels.
