7-Speed S-Tronic Direct-Shift Gearbox (DSG/0B5) calibration
UWSCSI
Norway
C?ID=134408
Monday,29,January,2018,20:01:55:19306
VCDS Version: 18.1.0.2
Data version: 20180122 DS285.1
VIN: WAUZZZ8R1AA051164   License Plate: UF43336
Mileage: 114380km-71072mi   Repair Order:
Chassis Type: 8R-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 20 42 46 52 53 55 56 5F 62
          69 72
VIN: WAUZZZ8R1AA051164   Mileage: 114380km-71072miles
Address 01: Engine (J623-CAHA)       Labels:| 03L-906-022-CAG.clb
   Part No SW: 03L 906 019 AS    HW: 03L 906 022 B
   Component: R4 2.0l TDI   H03 9977
   Revision: 11H03---
   Coding: 01210023240F2920
   Shop #: WSC 34629 001 1048576
   ASAM Dataset: EV_ECM20TDI03L906019AS A01011
   ROD: EV_ECM20TDI03L906019AR.rod
   VCID: 7CFD0BF9F7A00DA5E9-8028
   Part No SW: 8R0 927 156 K    HW: 0B5 927 156 E
   Component: 0B5 20 TDIRdW H03 0006
   Revision: --H03---    Serial number: 0000001111
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_TCMDL501 A02044
   ROD: EV_TCMDL501.rod
   VCID: 438FB005CADEB25DE8-8016
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V1.clb
   Part No SW: 8R0 907 379 L    HW: 8R0 907 379 L
   Component: ESP8 quattro  H07 0010
   Coding: 0D9540
   VCID: 4993A22DE0F2680D22-801C
   Part No SW: 8K0 907 064 DP    HW: 8K0 907 064 DP
   Component: BCM2 1.1      H02 0326
   Coding: 010500
   VCID: 01037A0D9842604DBA-8054
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Serial number: 0509000060794009
   Serial number: 0209000079325008
   Component: KLIMA 3 ZONEN H08 0171
   Revision: C1000000    Serial number: 01261020091711
   Coding: 34110000
   VCID: 00057F0993486945B5-8054
   Component: BCM1 1.0      H28 0380
   Revision: 10028001    Serial number: 00000000375651
   Coding: 2600D0914074AF010001000300001D0D0F1C670800010141000000
   VCID: 3C7DCBF9BF20CDA5A9-8068
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 091019  H10 0041
   Serial number: 90243014091015085703
   Coding: 01DD13
   Component: RLS  H04 0003
   Serial number: 10649037
   Coding: 024D25
   Component: E1 - LDS  H08 0090
   Serial number: 00000000001910091823
   Part No SW: 8K0 919 475 J    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0050
   Revision: 11001001    Serial number: 39840930121371
   Coding: 110108
   VCID: 4085BF09D3C8A945F5-8014
Address 15: Airbags (J234)       Labels:| 8R0-959-655.clb
   Part No SW: 8R0 959 655 C    HW: 8R0 959 655 C
   Component: AirbagVW-AU10 H39 0560
   Serial number: 003FQD05PYZR
   Coding: 30423331313030303030554A304C38523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 448DB319CFD0B565D1-8010
   Serial number: 6334MSME4A454278H
   Serial number: 6344MSME4C66247CR
   Serial number: 6352QSME7A401728G
   Serial number: 6362QSME61410E06A
   Serial number: 63732SME77404F081
   Serial number: 63832SME5F404630.
   Revision: --------    Serial number: 90315IJT00048
   Coding: 000017
   VCID: 3D7BC6FDA43AC4AD9E-8068
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 930 D    HW: 8R0 920 930 D
   Component: KOMBIINSTR.   H10 0255
   Revision: 00000000    Serial number: CJL43CYA9
   Coding: 0F06220002000008010000
   VCID: 356BDEDD9C0A1CED56-8060
   Part No SW: 8T0 907 468 AA    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0105
   Revision: FB900055    Serial number: 5500F09A148179
   Coding: 00C303
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0107
   Serial number: 00000000004140727448
   Part No SW: 8K0 857 511 E    HW: 8K0 857 511 A
   Component: FLA           H04 0004
   Revision: AA001002
   Coding: 02012064747464545425363E
   VCID: 336FE0C5927E02DD78-8066
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000009550792
   Coding: 011D02205000440004
   VCID: 458BAE1DCCEA8C6DC6-8010
   Revision: 00002001    Serial number: 0122999648
   Coding: 01000620203904800520053280000000
                    Fault Status: 00101001
                    Fault Frequency: 67
                    Reset counter: 194
                    Mileage: 112946 km
                    Date: 2018.01.01
                    Time: 12:20:30
                    Fault Status: 00101100
                    Reset counter: 189
                    Mileage: 113498 km
                    Date: 2018.01.11
                    Time: 16:33:45
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Revision:             Serial number: 0000009556307
   VCID: 448DB319C7D0B565D1-8010
   Revision: 00000003    Serial number: 00000000483123
   VCID: 346DE3D9977005E561-8060
   Part No: 8K0 907 357 B
   Component: Dynamische LWR  H01 0030
   Coding: 0000006
   Shop #: WSC 06334 000 00000
   VCID: 346DE3D9577005E561-8060
   Part No SW: 4F0 035 056 B    HW: 4F0 035 056
   Component: Radio U STD   H45 0020
   Revision: AB001007    Serial number: 342J6097699753
   Coding: 010003020100000001
   VCID: 1F471C750EF6B6BDAC-804A
   Part No SW: 8T1 035 652 D    HW: 8T1 035 652 D
   Component: B-BN-EU       H52 0048
   Revision: --------    Serial number: 323J%097528297
   Coding: 01010006010581ED01002B0E000000010000
   Shop #: WSC 00150 218 176870
   VCID: 3669D9D1810C17F55F-8062
   Subsystem 1 - Part No SW: 4L0 919 604     HW: 4L0 919 604
   Component: DU6 Basic  H43 0306
   Serial number: 9355JN091042423
   Subsystem 2 - Part No SW: 8T0 919 609     HW: 8T0 919 609
   Serial number: 00000000392803
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Revision:             Serial number: 0000102195026
   Coding: 010C02204000240004
   VCID: 4281B501DDC4BB55E3-8016
Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
   Part No SW: 8K0 907 383 C    HW: 8K0 907 383 C
   Component: Anhaenger     H08 0080
   Revision: 1G002002    Serial number: 00000123114950
   Coding: 0109080000000000
   Revision:             Serial number: 0000102195036
End-------------------------(Elapsed Time: 03:53)--------------------------
UWSCSI
Norway
C?ID=134408
What does "Erase counter for start and stop processes" do actually?
UWSCSI
Norway
C?ID=134408
Any help would be much appreciated...
UWSCSI
Norway
C?ID=134408
OK. As I read through the forum and S-tronic related topics, I notice that most threads just keep hanging without any answer to their problems.
Are not VCDS able to perform the Clutch valve calibration and the Distance sensor calibration on the DSG/0B5 gearbox?
I really need to solve this...
downtime
Finland
C?ID=280813
I never got it to work :( With ODIS it goes fine but VCDS is not able to perform the calibration, it always just hangs in the initial step and nothing happens.
UWSCSI
Norway
C?ID=134408
That's not good... I thought VCDS was the ultimate tool for this...
Where can I obtain ODIS? Do I need a new OBD adapter and the SW?
Will this product do the trick?
[Edit: Link removed. Do not post links to pirated products in this forum]
Uwe or anyone from Ross-Tech... Why doesn't this work with VCDS?
Not sure. The fact that we have a Wiki page for it indicates it has worked for at least some people on some of these transmissions.
UWSCSI
Norway
C?ID=134408
Well, that does not help me...
UWSCSI
Norway
C?ID=134408
Well, I have som issues with going from R to D, it is like the transmission is lagging for 0.2 s before it works again. Happens now and then. Also, sometimes when in reverse, I get a smell from the clutch. I would like to perform the calibration in order to rule out any issues with the clutch. In my opinion it is a good start, but I am far from an expert on this DSG/S-tronic... Nice link...
NostraJackAss
If you smell clutch, you need a clutch with this POS trans & maybe a mech or accumulation of particulate contamination & which need remediation ! :rolleyes:
Start watching YouTube videos!
NostraJackAss
tell us how you *really* feel Jack!
NostaJackASS Proverb say?
All VAG-CHAZ automatic transgender mutations & disguised as sticks with nein sticks, are an abomination for torque output conversions & which never bottom out the red-line!
UWSCSI
Norway
C?ID=134408
I have read on some forums that to perform this calibration have had some positive impact on cranky transmission, so I thought it was worth a shot.
If you disagree, then I will have to send my car to the workshop...
NostraJackAss
I have seen more DSG's destroyed than helped & is only temporary if it does help, now wouldn't it be?
Don't believe everything you read on the net, most of the time there is an agenda to pick your pocket.
When tolerances are warn on the clutch, the slave actuators indeed must now push further and this in end pops fluid as a result, almost seems deliberate right?
D-Dub
C?ID=272151
Says the mechanic.
On the internet.
/ducks, I couldn't help it!
But seriously though, Jack has a knack for knowing, disregard his opinion at your peril.
FWIW, we tested it again today on the closest transmission we have access to.
Address 02: Auto Trans (J217)       Labels: None
   Part No SW: 8W1 927 155 B    HW: 0CK 927 156 S
   Component: 0CL 20TFSINAR H06 0003
   Revision: --H06---    Serial number: 0000000148
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_TCMDL382021 002023
   ROD: EV_TCMDL382021_VW51.rod
No problems.
