Well here goes, ive a bora 1J chassis here at the minute, 90bhp AGR, with basically no power worth talking about.
I can view alot of live data etc with the delphi which is what I have to manage with right now (if you can recommend a genuine seller of in the UK please do as there are so many fakes), anyway it seems to have 2 seperate issues when driving hard over 3000rpm it goes in to limp mode, an over boost fault comes up, the agr has a wastegate turbo not vnt, when I go into component activation and select the wastegate actuator it doesnt open, ive
tried this on another agr engined car with no problems and its the same however this test works on all other vnts in other vag cars and also the t4 transporters with turbo his test functions correctly. Is this something to do with the agr ?
Also there is no other faults relating to the car having no power. The only thing that I spot in live data is 'Fuel Quantity Adjuster' 0 volt, again I locked at this data on the other fully functioning carand it was saying over 4volts, so back to car number 1 I disconnected and reconnected the injector pump connector and viola the reading went over 4 volt however this only lasts for a couple of minutes
I looked at all connections and im a bit confused with it now, ive traced the quantity adjuster wire on autodata and then looked at the corresponding wire in the car and it is ok, no breaks loose connections etc, can anyone tell me is the feeding the quantity adjuster with the voltage or would a faulty injector pump '' cause this issue.
Sorry for the essay but any pointers would be great, thanks
