Several technical questions regarding VCDS on a 2018 Audi S6
   #21
elp_jc
El Paso, TX USA
C?ID=323850
Damn, when am I going to get a freaking break. Aborted it, and now it's not recognized anymore: 'Interface not found'. Doesn't matter what I do. What's next? Uninstalling the whole damn thing? That's what I did. Will start from scratch, and see what happens. Geez.
   #22
Nope. Just start VCIConfig. It's in the Start Menu, under VCDS, or you can open the VCDS folder (C:\Ross\Tech\VCDS\) and start it directly.
elp_jc
El Paso, TX USA
C?ID=323850
Erased everything, downloaded it again, and as soon as I hook up the UBS cable, the unit flashes red. Obviously test didn't find it. What's next? Did what you told me, and now it crapped out. Is there a number I can call to get this damn thing sorted?
   #24
There is, but our office closes at 6:00pm eastern. PM me your phone number.
elp_jc
El Paso, TX USA
C?ID=323850
Can't get to the config part without testing correctly. Went to the folder, and nothing obvious. Under VCDS are the following folders only: Debug (empty), labels, logs, scaling, scans, and UDS_EV. What next?
   #26
Right, when VCDS doesn't see the interface, you have to start VCIConfig directly. There's a shortcut in the Start menu:
and the file itself is located in the folder C:\Ross-Tech\VCDS\
elp_jc
El Paso, TX USA
C?ID=323850
Okay, found that file, and was able to update whatever it updates successfully. Was also able to register the thing. Waiting for the email to finalize it. Will post another scan when I erase all codes and drive the car, to see what the experts suggest. Thanks.
elp_jc
El Paso, TX USA
C?ID=323850
Cleared all the codes. MMI still doesn't recognize the SIM card, as expected. Went to module 5, and didn't see any 'sub-menus', like the 'F' it was mentioned. On the 'safe' side there was nothing, and didn't want to mess with the advanced at this time, so didn't even open anything. The 'adaptation 10' was grayed out, by the way. Anyway, since I upgraded the version, here's the full scan again, now with the latest version, since somebody said it might make a difference. But the codes are erased now. Didn't start the car yet, but at least every module shows 'OK', with no faults. Let me know if you guys see anything differently. Or how to fix that SIM card issue. I'd like to give it a go now:D.
Tuesday,30,January,2018,17:17:56:26044
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
VCDS Version: 18.1.0.2  HEX-V2 CB: 0.4411.4
Data version: 20180122 DS285.1
VIN: WAUFFAFC0JN024395   License Plate:
Mileage: 3357km-2085mi   Repair Order:
Chassis Type: FC-AU57 (4G8)
Scan: 01 02 03 05 08 09 13 15 16 17 19 1B 20 22 28 34 36 3B 3C 42
          44 46 52 53 55 5F 62 6C 72 85 8B 8E 8F 90 A9 BA
VIN: WAUFFAFC0JN024395   Mileage: 3357km-2085miles
85-On Board Cam. -- Status: Malfunction 0010
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
BA-Motor Mounts -- Status: Malfunction 0010
Address 01: Engine (------CTGE)       Labels: None
   Part No SW: 4G0 906 014 D    HW: 4H0 906 014
   Component: 4.0l V8TFSI / H63 0002
   Revision: NCH63---
   Coding: 0A2500326546010E3000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM40TFS0114G0906014D 001002
   ROD: EV_ECM40TFS0114G0906014D.rod
   VCID: 231312902B53A3DF557-8076
   Part No SW: 4G0 927 166 F    HW: 0B5 927 156 K
   Component: 0B5 40TFSINAR H06 0007
   Revision: --H06---
   ASAM Dataset: EV_TCMDL501021 001022
   ROD: EV_TCMDL501021.rod
   VCID: 3039EDDC6AA50847D85-8064
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 65BED449A67D2B921B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41DFB818D10F91CF27B-8014
   Part No SW: 4H0 907 064 HR    HW: 4H0 907 064 HR
   Component: BCM2 2.0      H61 0825
   Coding: 0DA86F4E000000000000
   VCID: 00597D1C9A0558C7685-8054
   Serial number: 3217000121943016
   Part No SW: 4G0 820 043 BL    HW: 4G0 820 043 BL
   Serial number: 13071700041624
   Coding: 680130784D0000
   VCID: 6A8D3FB48CF9B297D61-803E
Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
   Part No SW: 4H0 907 063 GM    HW: 4H0 907 063 AM
   Component: BCM1 2.0      H20 0368
   Revision: 2102003S    Serial number: 00001715237202
   Coding: 01050011043C9FF2F90048C7A0003800CF9CD208AE08022180000894F10017020060003D030000
   VCID: 79AF10F8F9DF090F2FB-802C
   Component: WWS57X 170522  H38 0080
   Serial number:         170622061250
   Coding: 0045F7
   Serial number: 20338411X81A955547A0
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 AL    HW: 4G0 941 531 AL
   Component: E1 - LDS  H07 0044
   Serial number: 06 07 2017  00000294
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z030F96D3
   Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA128226000035191519
   Coding: 020300
   Subsystem 6 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H01 0006
   Serial number: 054017B800PAG0MUFU03
03455 - Function Restriction due to Faults in Other Modules
            000 -  -  - Intermittent
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:43:59
   Part No SW: 4G0 907 561 B    HW: 4G0 907 561
   Component: ACC3          H21 0055
   Coding: 7E01010102
   ASAM Dataset: EV_AdaptCruisContrAU57X 002015
   VCID: 290F00B8497F798F1FB-807C
34816 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FAULT_CIM_TIMEOUT_SWA_01]
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:54
                    Control Module temperature: 19 °C
                    Voltage terminal 15: 12.514 V
35072 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FAULT_CIM_TIMEOUT_SWA_OBJLI]
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:54
35328 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FAULT_CIM_TIMEOUT_SWA_OBJMI]
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:54
35584 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FAULT_CIM_TIMEOUT_SWA_OBJRE]
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:54
93440 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_VIDEO_FAIL]
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:54
                    Voltage terminal 15: 12.517 V
Address 15: Airbags (J234)       Labels:| 4H0-959-655.clb
   Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
   Component: Airbag10.43   H62 0092
   Revision: --------    Serial number: 003G00049PZ6
   Coding: 303331343135303334354A55304C34473053
   VCID: 3431E1CC9EBD3467BCD-8060
   Serial number: 6940000Y170001LPCC03
   Serial number: 3575HRB400659LTKB9S2
   Serial number: 3585HRB400A5BCHAH1G7
   Serial number: 3515JRB400M59NFOQHCD
   Serial number: 3525JRB400859NFOE94F
   Serial number: 3554VRB40045BE5CGGHI
   Serial number: 3564VRB40045BE5CGQ9L
   Component: Lenks.Modul   H05 0005
   Revision: --------    Serial number: 90372QGE00058
   Coding: 0000FC
   VCID: 372BD6C08F4BDF7F99F-8062
   Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
   Serial number: 01 07 2017  D0000573
Address 17: Instruments (J285)       Labels:. 4H0-920-xxx-17.clb-SRI1
   Part No SW: 4G0 920 982 S    HW: 4G0 920 982 S
   Component: TBenUsaAccNv  H17 0225
   Revision: 18001312    Serial number: 658120717592019
   Coding: 0BC70905BF51D705020200
   ASAM Dataset: EV_RBD4K 004060
   ROD: EV_RBD4K_AU57.rod
   VCID: 3C21C9ECB6EDFC2774D-8068
   Part No SW: 4G8 907 468 K    HW: 4G8 907 468
   Component: J533--Gateway H15 0110
   Revision: --------    Serial number: 00000002665750
   Coding: C0ED074814
   ASAM Dataset: EV_GatewPkoUDS 002011
   ROD: EV_GatewPkoUDS_002_VW51.rod
   VCID: 40D9BD1CDA0598C7285-8014
   Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
   Serial number: 9275964504
   Voltage stabilizer:
   Serial number: 170429000000000007F9
5701 - High Beam Assistant Control Module
          U1070 00 [008] - No Communication
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:43:53
                    Voltage terminal 30: 12.7 V
                    Voltage terminal 15: 12.7 V
                    Control Module temperature: 21 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
0258 - Extended CAN Bus (SAE Bus C)
          U0046 00 [008] - Malfunction
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:53
                    Voltage terminal 30: 12.5 V
                    Voltage terminal 15: 12.4 V
                    Control Module temperature: 23 °C
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
          U140B 00 [008] - -
          [Powermanagement active]
                    Reset counter: 51
                    Mileage: 45 km
                    Date: 2017.12.09
                    Time: 15:26:47
                    Voltage terminal 30: 11.2 V
                    Voltage terminal 15: 11.2 V
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 1
   Part No SW: 8K0 907 144 N    HW: 8K0 907 144 N
   Component: DYNAMIKLENK.  H06 0740
   Revision: 52001005    Serial number: --------------
   Coding: 0E0100
   VCID: 3A2DCFF4BC59C217661-806E
Address 20: High Beam Assist. (J844)       Labels: None
   Part No SW: 4H0 857 511     HW: 4H0 857 511
   Component: FLA           H04 0021
   Revision: AA001002
   VCID: 678B46809F6B8FFFC9F-8032
   Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H19 0200
   Serial number: 002806170001025
   VCID: 280905BC52754087005-807C
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0113
   Serial number: 20071700040181
   Coding: 20
   VCID: 3D27C4E8ADF7F52F433-8068
0075 - Button or Switch in Operating Unit
          B10C7 07 [008] - Mechanical Failure
                    Reset counter: 77
                    Mileage: 2100 km
                    Date: 2018.01.20
                    Time: 09:58:39
                    Outside air temperature: 13.5 °C
                    Left rear vent temperature: 37.0 °C
   Coding: 008006
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F3BEEA0779B17BFC1F-807A
          C10C8 00 [008] -  -
                    Reset counter: 62
                    Mileage: 85 km
                    Date: 2017.12.29
                    Time: 19:35:16
   Revision: AA000000    Serial number: 00000264708827
   VCID: 77AB16C0CFCB1F7F59F-8022
   Component: SARA 6D red   H04 0056
   Revision: --------    Serial number: EJ1BPA7E02X9HX
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 372BD6C08FCBDF7F99F-8062
   Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
   Component: SWA Master    H08 0070
   Serial number: 0447460632
   Coding: 040211
   VCID: 392FD0F8B9DFC90F6FB-806C
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
   Component: SWA Slave  H08 0070
   Serial number: 0447830783
   Coding: 040211
512270 - Extended CAN Bus (SAE Bus C)
          [Data bus headway control - defect]
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:53
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0511
   Coding: 011F17015E00628002000013
   VCID: 45D7AC08C5A7BDEF1B3-8010
   Component: RCevo         H54 0202
   Revision: 00000002    Serial number: 0000882256
   Coding: 011001010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A2DCFF4BCD9C217661-806E
   Revision: 00002001    Serial number: 0444726645
   Coding: 0106063A00FA408580B0088402070E470000000000000000000000000000
   Component: GTO BF  H01 0081
   Serial number: 00000000000000407338
   Subsystem 2 - Part No: 1K0 951 605 F
   Subsystem 3 - Part No SW: 4G8 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS40.402  H03 0004
   Serial number: 0000FST001OVAA400000
   Coding: 101F02
   Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Serial number: 0000000AP00030640034
   Subsystem 5 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 6600<58:
01503 - Bulb for 3rd Brake Light (M25)
                    Fault Status: 00101100
                    Reset counter: 57
                    Mileage: 115 km
                    Date: 2017.12.30
                    Time: 16:29:27
03725 - Control Module for Seat Belt Tensioner; Left Front
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:54
   Component: TSG BF        H03 0511
   Coding: 011F17015E00628002000002
   VCID: 46D5AB04F8A1B6F7129-8012
   Part No SW: 4H0 907 801 M    HW: 4H0 907 801 M
   Component: EPB-4         H01 0018
   Revision: --------    Serial number: 00000002250703
   ASAM Dataset: EV_ParkiBrake 001033
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 323DE7D464A93A57AE1-8066
   Coding: 04FA0A1122600400
   Coding: E01E00
   Coding: E01E00
12600832 - Extended CAN Bus (SAE Bus C)
          [E-CAN Bus defekt (bus off)]
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:53
13705491 - Databus
          [Timeout CAN-Message FLA_01 (0x645)]
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:43:56
   Part No SW: 4G1 035 025 G    HW: 4G1 035 025 C
   Component: MU-H-LNS-US   054 0980
   Serial number: A741G0HS005590
   Coding: 017551020000000013220002041A00102F0007E5F17001047E
   VCID: 221D17943449AAD75E1-8076
   Subsystem 1 - Part No SW: V03 959 801 PS    HW: -----------
   Component: NAR 2018  --- 0063
   Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
   Component: DU8 C7 SV  H63 0007
   Serial number: AUZ8Z9HY808BNX
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4G1 919 610 F    HW: 4G1 919 610 F
   Serial number: 90349QGA000ZC
   Compact Disc Database:
   Component: Gracenote2---  --- 3012
7188 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Garage door opener (0x14) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 57
                    Mileage: 115 km
                    Date: 2017.12.29
                    Time: 21:15:45
                    Voltage terminal 30: 13.4 V
                    BAP-BAP_Function_ID: 11
   Component: TSG HL        H03 0511
   Coding: 010F17004000628002000002
   VCID: 49CFA038E9BF598FFFB-801C
Address 6C: Back-up Cam. (J772)       Labels:* None
   Part No SW: 4S0 980 556     HW: 4M0 980 556
   Component: RVC Compact   H08 0140
   Coding: 027500010A002003000040
   ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
   ROD: EV_CamSysRVRVCPANAAU57X.rod
   VCID: 78A915FCC2551007505-802C
13762560 - Databus
          U1200 00 [008] - Defective
          [Databus defective]
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:53
   Component: TSG HR        H03 0511
Address 85: On Board Cam. (J852)       Labels:* None
   Component: DPC-SG        H28 0081
   Coding: EA060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C01F9AC468D6CA7E4D-8078
0600 - Extended CAN Bus (SAE Bus C)
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:53
                    Outside air temperature: -41.5 °C
                    Voltage terminal 15: 12.5 V
                    Control Module temperature: 25.0 °C
   Part No SW: 4G0 907 541 B    HW: 4G0 907 541
   Coding: 7E01010102
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
   VCID: 270B06805F6B4FFF09F-8072
          U1111 00 [008] - -
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:54
                    Voltage terminal 15: 12.535 V
                    Velocity_vehicle_reference: -0.00 m/s
          U1111 00 [008] - -
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:54
                    Voltage terminal 15: 12.534 V
          U1111 00 [008] - -
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:54
          U1111 00 [008] - -
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:54
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H34 0090
   Serial number: 005002451805177
   Coding: 04C1BA1B0111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
0061 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [SWA_Timeout]
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:54
                    Outside air temperature: 17.5 °C
                    Control Module temperature: 23.0 °C
0091 - Function Limitation due to Missing Video Data
          C1108 00 [008] -  -
          [DPC_SystemError]
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:54
Address 8F: Pretens. Frt Left (J854)       Labels:. 4H0-980-94x-RGS.clb
   Component: RGS-VL        H16 0080
   Coding: 0066E608031F0376070308014240C0010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313FE8D861AF014FD7B-8064
12583168 - Extended CAN Bus (SAE Bus C)
          [High Speed CAN Communication Bus defect]
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:53
Address 90: Pretens. Frt Right (J855)       Labels:. 4H0-980-94x-RGS.clb
   Component: RGS-VR        H16 0080
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:53
   Part No SW: 4G0 907 159 B    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0010
   Serial number: 170514200712
   Part No SW: 4H0 907 145 B    HW: 4H0 907 145
   Component: AEM - LEAR    H10 0008
   Revision: 00001001    Serial number: 97813008680901
   ROD: EV_AEMLearAU64X.rod
0512 - Extended CAN Bus (SAE Bus C)
          [FC_CAN_BUSOFF]
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:53
1648 - Extended CAN Bus (SAE Bus C)
          U0047 00 [008] - Performance
          [FC_CAN_Global_Communication_Timeout]
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:53
End----------(Elapsed Time: 02:43, VBatt start/end: 12.3V/12.3V)-----------
Gateway Installation List:  4G8 907 468 K
For the record, saw fault codes on auto high-beam, adaptive cruise, and lane change, and all worked perfectly on my last trip. What I'm a bit more disturbed about are the DTCs with the suspension, motor mounts, and some CAN-BUS crap. Let's see what happens next time I drive the car. And after that. Will start looking for instructions how to choose a sub-module, like '5F'. Wasn't obvious when looking at the module options. This thing will be next to useless without knowing what to do. If I get no codes after a short drive, can I at least do the small mods I bought this thing for? But I REALLY want input how to fix that SIM recognition issue. Thx.
elp_jc
El Paso, TX USA
C?ID=323850
Hey Uwe, have several usage questions for you. Now that everything is installed and current, have these questions:
1. HOOK CABLE: cable on USB port first, then on car, then ignition on, then open software on computer? Like when doing it the first time?
2. TO UNHOOK: Reverse of the above? No comments on the manual about that; at least I didn't see any. Hey, forgot to turn ignition off last time, unhooking cable before switching ignition off. Any issues with that?
3. Do you need to test the connection every time? I didn't do it when messing with the module 5 (after the second full scan), and it went to it (didn't change anything though). But curious if we need to do that, and 'save' every time.
4. Does computer have to be connected to the internet while using the cable on the car? If yes, why?
Thanks man.
JC
   #30
MasterTommy
Amsterdam
C?ID=295586
1. What matters for me is to hook up the usb to the computer first, and then the interface to the car. The rest doesnt matter and you sure as hell cant break anything by screwing this up. Worst case scenario, and I mean when the stuff really hits the fan, is that you have to unplug the interface from both the pc and the car. But then we're getting biblical. Of course the program doesnt do anything until there is an interface connected, and the interface cant a whole lot without the ignition on, but both of those things can be fixed at any moment. On my PC the interface tends to not get recognized when i connect it to the car first.
2. Doesnt matter at all.
3. No, you dont. You only need to test the connection when you re-install the program or update it.
4. No
5. Take a deep breath
elp_jc
El Paso, TX USA
C?ID=323850
Thanks a lot for your help Tommy. Hey, do you know how to tackle my MMI not recognizing the SIM card by any chance?:D Since no DTCs appeared when I cleared them, and MMI still can't read the SIM card, I could try to reset the appropriate channel via VCDS, but need somebody who knows how to do it. Would I have better luck on a different forum? This is the 'pre-sales' forum after all, therefore not really the appropriate place to discuss that IMO.
I'd also like to know if VCDS can reset the SRI (service reminder) on a 981 (2015) Porsche Boxster. Saw a post somewhere where a Cayenne owner used VCDS to tackle more serious stuff, and was successful, hence my asking. I know the Porsche specific tool is 'Durametric', but maybe this thing works for scans and SRI resets. Thx.
Nope. Plug / unplug order doesn't matter, nor does the state of the ignition.
No, you don't. You only need to do that when:
  • You first install, or later update the software
  • If you use a different cable.
No, it does not. It only needs to be connected to the internet in order to update the firmware in the cable, or to register the cable (which you've already done).
I think you've asked this before and I think I told you something to the effect of: I rather doubt it.
elp_jc
El Paso, TX USA
C?ID=323850
Indeed. So let me rephrase my question: Could I hurt anything if I try?:D If not, should I try both a scan and an SRI reset, or just the SRI reset? I'd relay my results here. If it's possible to hurt something, then we'll have to live with your doubt. He he. Thanks.
And on the MMI SIM-card recognition issue, where should I post for better results? The 'Car Repair Support' forum? Thx.
   #35
No, I don't think you can hurt anything, but I would definitely start with a scan, or even just an attempt to access 17-Instruments.
This is a 2018 car, right with a warranty, right? ;)
Going back to page 1 of this thread for context, how exactly did you "disable the data module"? That was before you had VCDS, no?
elp_jc
El Paso, TX USA
C?ID=323850
Yep, 2018 car with warranty, but I don't take my cars to a dealer unless I absolutely have no choice. Now I still do, and it's called VCDS. He he. When having issues, I first disabled WiFi, and then the data module. Both are on the AudiConnect menu... when you can access it. Ha ha. Now I can't do anything, because MMI is not recognizing the SIM card. When I deactivated the module, it changed from 'turn data module off', to 'turn data module on', or something like that. After turning engine off and back on, that's when I couldn't access AudiConnect anymore.. but my other issues went away, like media sources not having sound, and not being able to connect my phone to BT.
By the way, programmed both the lap timer and D+S gear indicator today, since those modules didn't have malfunctions. Worked fine, but thought the oil temp gauge wasn't working, since it only showed '---' until oil heated up to 145º, which was exactly when the tach segments went from 5,500 rpm to the 6,400 redline. That's odd, but I'll take it over no gauge. Ha ha. Okay, so guess will mess with the module 5F myself, since nobody knows how to do it. Wish me luck:D. And will also report what happened to the Porsche. If VCDS wants me to use another VIN before I'm pretty sure it'd work, will abort. Results shortly.
   #37
elp_jc
El Paso, TX USA
C?ID=323850
Here's the new scan after using the car 10 miles:
Saturday,03,February,2018,15:33:59:26044
Mileage: 3372km-2095mi   Repair Order:
VIN: WAUFFAFC0JN024395   Mileage: 3372km-2095miles
   Revision: NCH63---
Readiness: 0010 0001
   Revision: --H06---
   Coding: 0045F7
   Coding: 02006D
   Coding: 020300
   Coding: 7E01010102
   Coding: 0000FC
   Coding: 03CD0905BF51CF05020200
   Coding: C0ED074814
   Voltage stabilizer:
   Coding: 0E0100
   Revision: AA001002
   Coding: 20
   Coding: 008006
   ROD: EV_SARA2.rod
   Coding: 040211
   Coding: 040211
   Coding: 101F02
   Coding: E01E00
   Coding: E01E00
   Coding: EA060000
   Coding: 7E01010102
   ROD: EV_BC7.rod
   ROD: EV_RGS_L.rod
   ROD: EV_RGS_R.rod
End----------(Elapsed Time: 02:57, VBatt start/end: 12.2V/12.2V)-----------
Looks like no faults, even though MMI still doesn't let me into AudiConnect. Will mess with module 5F in a little bit. But all is well then??? Only 10 miles, but if I had a canbus issue, or some other crap, that'd be enough, correct? Only messed with module 17 (instruments), making changes nobody has posted (like changing pressure from kPa to PSI), but since my car doesn't have TPMS sensors, maybe it's irrelevant, but changed it anyway. He he. Have other questions/concerns that I saw, but you're probably not going to know since they're Audi S6 7.5 specific, so will have to ask at the Audi forum. For instance, saw 'cruise control system installed' not checked, and was wondering if I click it, if I could have both, like on my other cars. On this one, it's only adaptive or nothing. Also saw byte 2, bit 3-5 checked as 'Audi A6/S6 limousine', which makes no sense, but the other choices are avant, allroad, so maybe it's the correct one. Do you know what that particular bit range is for? Thx. Oh, also byte 10, bit 0 'brake pad warning active' was unchecked, which would be fine with me, but why? My main concers was with the codes. Hopefully you'll give my car a clean bill of health. Ha ha. Thanks Uwe.
   #38
South Molton, UK
limousine = sedan
elp_jc
El Paso, TX USA
C?ID=323850
limousine = sedan
Oh, thanks. Guess it's so freaking big it's a limo in Europe, right? Ha ha. Thanks man. Another bit, the one for the fuel tank (probably for size) didn't have an S6 or even an A6, but an A7/S7 (selected), also with Avant and Allroad options, but since I confirmed via google all 4 variants have the same 19.8-gal size tank, no worries there either.
Hey guys, one more question. Most of the time I don't like adaptive cruise control (ACC), and much prefer regular CC. Well, my stupid car seems like it doesn't do that, at least now. On my other cars, I just press the distance button for a second after turning cruise on, and it toggles between ACC and CC. Tried everything on this car and nothing. But found this option on instruments (byte 1, bit 5): 'cruise control system installed', which wasn't checked on my car. Do you guys think if I click on it I'd be able to have both, or it'd have to be either one or the other? Don't remember seeing 'adaptive cruise control installed', but I'm sure it's there somewhere. Just curious if you think I should try clicking on both, but would need to know how to toggle them. As an alternative, it'd be good to toggle between them on the driver assistance menu, instead of having to code one or the other only in the garage. Thank you in advance for your help on this.
   #40
MasterTommy
Amsterdam
C?ID=295586
In instruments, you're only changing the settings of (wait for it...) the instrument cluster. You could tell the instrument cluster that a conventional cruise control system is installed. In which case the instrument cluster will immediately throw cruise control errors since nothing is replying to its messages on the bus all while receiving messages its not expecting. If you want to disable ACC and enable CCS, you'd have to start at the radar sensor control module. Then tell the ABS that theres no ACC anymore but just CCS, then the engine control module, probably some other units and finally the instrument cluster.
All things aside, VCDS is a tool. A pretty handy one at that, but tools have to be mastered. No manual could possibly contain everything you can, can't, can but not in combination with this and that, can't unless circumstance X is met, etcetera.
Your best bet is to start off by reading in to HOW the system works. What is a databus? What is the function of the Gateway? For function X, which control modules are involved and what are their roles? That is info that allows you to come to a conclusion.
Now I'm not saying you'd better take a year or two in seclusion with an old Golf and have at it. But there is an enormous amount of info regarding VCDS use aside from what the manual says (although the manual could also use an overhaul) available online, both written and on video.
