- Jan 11, 2018
- 41
- 13
- Trinidad and Tobago
- C?ID=325257
Hello Ross-Tech,
I'm a bit new here but i hope to make some valuable contributions to the forum through the tasks at which i am looking to venture into.
Vehicle:-
I am currently the owner of a Euro Spec 2014 VW Jetta MK6. My vehicle is RHD and came with a 1.4 Turbo Supercharged Engine
What I have:-
I purchased a Set of OEM VW Jetta Bi-Xenon DRL Headlights for my vehicle.
Part numbers: 5C7941751.D / 5C7941752.D
The vehicle came with Factory Installed Halogen Headlamps (Euro Spec).
Current Position:-
So I had the lights installed over the weekend and they look great. When i Turn the ignition on, There's no DRL. So i tired the headlights. At first both headlights came on and the High and Low beams of the Bi Xenon came on. The indicator works as well.
However, when i start the vehicle, the Bi-Xenon's begin to flicker and then turn off. Also the Headlight adjusters do not work and the lights are currently on the ground.
I purchased these off of eBay and they came with adapters (10pins to 14pins), however, when i took the tape off of it, i noticed that there were wires joined in all different patterns. After doing some research (on Ross Tech Forum), some of the pin arrangements were in the right place (I just did not trust the shabby cut and join work on the harness) but just to be safe I'm considering getting these off kufatec:-
https://www.kufatec.de/shop/en/volk...d-headlights-adapter-vw-jetta-5c-vw-sharan-7n
But To Note: The original harness coming from the vehicle (10pins) currently has 9pins in use and one vacant (Just in the event that this may add in the adapter decision)
Summery of what works and what doesn't:-
So with the Bi-Xenon's installed, i currently have the following:-
Loads of Errors on the Dash
Light Error Indicator on
No DRL Lights
Bi-Xenon Flickering and Cuts off
Height Adjusters not functional
Left light makes a "Motor Moving type sound" every time the light turns on
Indicator works
Turn assist does not function on the headlights
What I Purchased and Questioning:-
I today purchased a VCDS® HEX-V2® Enthusiast USB Interface from Ross Tech
I'm thinking about purchasing the Adapter/Converter Cable from kufatec but I'm looking for some advise on this before purchasing.
https://www.kufatec.de/shop/en/volkswagen/jetta/5c/xenon-hid-headlights-adapter-vw-jetta-5c-vw-sharan-7n
This harness Wires into the CECM at terminal 48 & 49. I've read that some persons who did this conversion, stated that they required to do this in order to get the DRLs working.
Assistance required:-
At this point, i really need some assistance in the following:-
Would the 10Pin to 14Pin cable be required for the correct functioning of the Xenon Headlights?
How can I resolve the Flickering and turning off issue with the Bi-Xenon?
How can i get the DRL's Working?
How can i get the Headlight Height adjusters working?
How do I code the CECM to remove these errors from the dash and have the lights working as they should?
__________________________________________________ __________________________________________________ __________________________________________________ _______________________________________________
I haven't received the Bi-Xenon 10pin to 14pin Adapter Cable yet. (The shipping has been rescheduled....sigh)
I did perform two changes and the headlight are not flickering anymore...
I Enabled "Bi-Xenon Headlights (with Shutter) Installed", in the Byte 14 - (This stopped the Flickering)
AND
I Enabled "High Beam via Shutter active/installed", in the Byte 25 (Tried this, but the high beam only works when the lights are on, but i cant flash the lights when the headlights are off.
Will install and try some more coding then. don't want to try much with these Adapters since they maybe wired incorrectly.
Any advise would be appreciated.
Thanks in advance everyone!
Kind regards,
Vapor.Rob
Vehicle:-
What I have:-
Current Position:-
No DRL Lights
Indicator works
Tuesday,09,January,2018,21:34:28:42155
VCDS Version: 17.8.1.0 (x64) HEX-V2 CB: 0.4409.4
VIN: WVWZZZ16ZDM060166
Mileage: 30000km-18641mi
Chassis Type: 16-VW32 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 42 44 46 4F 52 56 62 72
77
VIN: WVWZZZ16ZDM060166 Mileage: 30000km-18641miles
Address 01: Engine (J623-CTHD) Labels:. 03C-907-309-V1.clb
Part No SW: 03C 906 026 BG HW: 03C 907 309 Q
Component: 1.4l R4 TSI H02 3743
Revision: LMH02--- Serial number: 00000000000000
Coding: 00250012002400000000
Shop #: WSC 00066 000 00189
ASAM Dataset: EV_ECM14TSI01103C906026BG 001002
ROD: EV_ECM14TSI01103C906026AB.rod
VCID: 66954BA358ED8787C0D-8032
4674 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [036] - -
Mileage: 30007 km
Date: 2018.01.09
Time: 17:16:18
Engine speed: 1898.00 /min
Normed load value: 8.2 %
Vehicle speed: 23 km/h
Coolant temperature: 51 °C
Intake air temperature: 34 °C
Voltage terminal 30: 14.065 V
Cruise Control System (CCS): status-Bit 0: 00001011
Cruise control switch-off: irreversible w. brake intervention-Bit 0: 00000000
Cruise control switch-off: reversible-Bit 0: 11111111
Cruise control switch-off: irreversible-Bit 0: 11111111
Acceleration: 0.000 m/s²
4675 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [047] - -
Fault Frequency: 15
Mileage: 29760 km
Date: 2018.01.02
Time: 16:07:04
Engine speed: 811.00 /min
Normed load value: 18.8 %
Coolant temperature: 89 °C
Intake air temperature: 58 °C
Voltage terminal 30: 13.428 V
Cruise Control System (CCS): status-Bit 0: 00001100
4629 - ECM Power Relay Load Circuit
P068A 00 [032] - Opens Too Early
5523 - Engine Start Blocked by Immobilizer
P1570 00 [032] - -
Part No SW: 0AM 300 058 P HW: 0AM 927 769 D
Component: GSG DSG AG7 431 3652
Revision: 00043014 Serial number: CU501211266331
Shop #: WSC 02069 000 90108
VCID: 3E25C3C36C7DFF4768D-806A
006279 - Wheel-Speed Signal from ABS Control Module
P1887 - 000 - Implausible Signal - Intermittent
Fault Frequency: 25
Reset counter: 10
Mileage: 29733 km
Revision: 00H31001
Coding: A63B60F8212800FA650C06EA841F0080211800
Shop #: WSC 00066 000 00000
VCID: 7DA704CF2DFB245F317-8028
03841 - RPM Sensor Rear Left: Incorrect Signal
Reset counter: 14
Mileage: 29829 km
Date: 2018.01.05
Time: 13:02:24
Count: 16384
Count: 14
Count: 12800
Count: 71
Count: 49408
Count: 65027
Count: 18749
Reset counter: 17
Mileage: 29836 km
Date: 2018.01.06
Time: 12:13:27
Count: 3
Count: 14
Count: 28672
Count: 128
Count: 43264
Count: 1
Count: 51
Fault Status: 00100011
Reset counter: 233
Mileage: 30007 km
Count: 12288
Count: 67
Count: 51201
Count: 64757
Count: 63488
Count: 59
Fault Status: 00101100
Reset counter: 229
Mileage: 29729 km
Date: 2018.01.01
Time: 06:29:28
Count: 16391
Count: 12
Count: 16896
Count: 64
Count: 45056
Count: 65280
Count: 52
Part No SW: 3AA 907 044 AF HW: 3AA 907 044 AF
Component: Climatronic H03 0303
Revision: 00001K02
Coding: 0010004002
Shop #: WSC 00066 000 00119
ROD: EV_ClimaAutoBasis_VW32.rod
VCID: 74B121EB1E3165174E9-8020
Part No SW: 5K0 937 086 M HW: 5K0 937 086 M
Component: BCM PQ35 M 021 0068
Revision: BC021001
Coding: 08000A3A802DE1C0408800801000816403000088508089605C 8000000040
VCID: 3E25C3C3607DFF4768D-806A
Subsystem 1 - Part No: 1K8 951 171
12 Faults Found:
Fault Status: 00100111
Fault Frequency: 252
Reset counter: 15
Mileage: 29586 km
Date: 2017.12.23
Time: 10:03:38
Term 15 On
Voltage: 13.70 V
Fault Status: 00101010
Fault Frequency: 6
Reset counter: 10
Mileage: 29586 km
Date: 2017.12.26
Time: 17:43:02
Term 15 On
Voltage: 13.90 V
Fault Frequency: 191
Reset counter: 15
Mileage: 29586 km
Date: 2017.12.23
Time: 10:03:38
Term 15 On
Voltage: 13.70 V
Fault Frequency: 24
Reset counter: 10
Mileage: 29586 km
Date: 2017.12.23
Time: 10:03:46
Term 15 On
Voltage: 13.75 V
Reset counter: 4
Mileage: 29595 km
Date: 2017.12.26
Time: 22:58:02
Term 15 On
Voltage: 11.90 V
Fault Status: 01101010
Reset counter: 218
Mileage: 29586 km
Date: 2017.12.23
Time: 09:18:40
Term 15 On
Voltage: 11.60 V
Reset counter: 4
Mileage: 29595 km
Date: 2017.12.26
Time: 22:59:57
Term 15 On
Voltage: 12.15 V
Reset counter: 218
Mileage: 29586 km
Date: 2017.12.23
Time: 09:50:23
Term 15 On
Voltage: 11.85 V
Reset counter: 218
Mileage: 29586 km
Date: 2017.12.23
Time: 09:18:42
Term 15 On
Voltage: 11.65 V
Reset counter: 218
Mileage: 29586 km
Date: 2017.12.23
Time: 09:50:24
Term 15 On
Voltage: 11.85 V
Fault Frequency: 50
Reset counter: 233
Mileage: 29586 km
Date: 2017.12.23
Time: 09:20:13
Term 15 On
Voltage: 12.10 V
Fault Frequency: 51
Reset counter: 233
Mileage: 29586 km
Date: 2017.12.23
Time: 09:50:29
Term 15 On
Voltage: 11.90 V
Address 10: Park/Steer Assist (J446) Labels:| 1Q0-919-475.clb
Part No SW: 5C6 919 475 HW: 7E0 919 475 A
Component: PARKHILFE 8K H10 0005
Revision: -------- Serial number: 07381302100884
Coding: 108101
ASAM Dataset: EV_EPHVA18VW3610000 001003
ROD: EV_EPHVA18VW3610000.rod
VCID: 71BF28FF6123503FA5F-8024
Part No SW: 5C0 959 655 C HW: 5C0 959 655 C
Component: AirbagVW10 013 0613
Serial number: 003G6M085PSR
Coding: 00003241
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 323DE7F3A4A52B279C5-8066
Serial number: 3572MSME560E1376ZZZZ
Serial number: 3582MSME040C1376ZZZR
Serial number: 3516KSME6C726420ZZZS
Serial number: 3526KSME0A096520ZZZM
Part No SW: 1K5 953 507 T HW: 5K0 953 549 B
Component: Lenks.Modul 008 0090
Revision: -------- Serial number: 90422LKU0004X
Coding: 088A140000
Shop #: WSC 00066 000 00187
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 42DDB73314059BA70C5-8016
Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0037
Serial number: 0053220 FLE 20130103
Coding: 820000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 5C6 920 872 HW: 5C6 920 872
Component: KOMBI H07 0705
Coding: 171B00
VCID: 6A8D3F934CF5A3E7E45-803E
Part No SW: 7N0 907 530 AH HW: 7N0 907 530 AH
Component: J533 Gateway H50 1634
Revision: H50 Serial number: 04011303290002
Coding: 351003
VCID: 76B51BE308CD770770D-8022
Component: IMMO H07 0705
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H19 0550
Revision: A1001003 Serial number: 7664004002
Coding: 010100
VCID: 2A0DFF938CF563E7245-807E
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0515
Revision: 13110009 Serial number: 0006013436
Coding: 0002B5
Shop #: WSC 01383 790 50316
VCID: 5BE36A5793AFCA6F6F3-800E
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 704 B HW: 3C0 959 794 C Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 008 1508
Serial number: 00000007488986
Coding: 000290
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 69 3305
Revision: 00H22000
VCID: 372BD6E74347CE0FABB-8062
01316 - ABS Control Module
Fault Status: 00101101
Fault Frequency: 18
Reset counter: 18
Mileage: 30008 km
Date: 2018.01.09
Time: 17:46:04
Voltage: 14.00 V
DU
Temperature: 37.0°C
RPM: 1606 /min
Speed: 38.0 km/h
Speed: 38.0 km/h
Part No SW: 7N0 907 532 HW: 7N0 907 530 AH
Component: EZE_2 H50 1634
Coding: 01030100
VCID: 6FBB2E87779746CFB3B-803A
Subsystem 1 - Part No SW: 5K0 959 591 HW: 5K0 959 591
Component: J245 PS41.022 H10 0007
Serial number: WRH0007POUD
Coding: 180000
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0515
Revision: 15110009 Serial number: 0006158935
Coding: 0002B4
VCID: 5CE1694B96A1CD57669-8008
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 703 B HW: 3C0 959 795 C Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 008 1508
Serial number: 00000007522919
Coding: 000290
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 B HW: 5K0 035 190 B
Component: Radio RCD510 005 0236
Revision: 00000001 Serial number: VWZ1Z3M9873940
Coding: 01000400040006
VCID: 241111ABEED1B5971E9-8070
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007663943662
Coding: 0A00000000010100
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3A2DCFD37CD5D367545-806E
End----------(Elapsed Time: 01:23, VBatt start/end: 12.3V/12.3V)-----------
AND
Kind regards,
Vapor.Rob
