2014 VW Jetta MK6 Bi-Xenon Converson
vapor.rob
Trinidad and Tobago
C?ID=325257
Hello Ross-Tech,
I'm a bit new here but i hope to make some valuable contributions to the forum through the tasks at which i am looking to venture into.
Vehicle:-
I am currently the owner of a Euro Spec 2014 VW Jetta MK6. My vehicle is RHD and came with a 1.4 Turbo Supercharged Engine
What I have:-
I purchased a Set of OEM VW Jetta Bi-Xenon DRL Headlights for my vehicle.
Part numbers: 5C7941751.D / 5C7941752.D
The vehicle came with Factory Installed Halogen Headlamps (Euro Spec).
Current Position:-
So I had the lights installed over the weekend and they look great. When i Turn the ignition on, There's no DRL. So i tired the headlights. At first both headlights came on and the High and Low beams of the Bi Xenon came on. The indicator works as well.
However, when i start the vehicle, the Bi-Xenon's begin to flicker and then turn off. Also the Headlight adjusters do not work and the lights are currently on the ground.
I purchased these off of eBay and they came with adapters (10pins to 14pins), however, when i took the tape off of it, i noticed that there were wires joined in all different patterns. After doing some research (on Ross Tech Forum), some of the pin arrangements were in the right place (I just did not trust the shabby cut and join work on the harness) but just to be safe I'm considering getting these off kufatec:-
https://www.kufatec.de/shop/en/volk...d-headlights-adapter-vw-jetta-5c-vw-sharan-7n
But To Note: The original harness coming from the vehicle (10pins) currently has 9pins in use and one vacant (Just in the event that this may add in the adapter decision)
Summery of what works and what doesn't:-
So with the Bi-Xenon's installed, i currently have the following:-
Loads of Errors on the Dash
Light Error Indicator on
No DRL Lights
Bi-Xenon Flickering and Cuts off
Height Adjusters not functional
Left light makes a "Motor Moving type sound" every time the light turns on
Indicator works
Turn assist does not function on the headlights
What I Purchased and Questioning:-
I today purchased a VCDS® HEX-V2® Enthusiast USB Interface from Ross Tech
I'm thinking about purchasing the Adapter/Converter Cable from kufatec but I'm looking for some advise on this before purchasing.
https://www.kufatec.de/shop/en/volkswagen/jetta/5c/xenon-hid-headlights-adapter-vw-jetta-5c-vw-sharan-7n
This harness Wires into the CECM at terminal 48 & 49. I've read that some persons who did this conversion, stated that they required to do this in order to get the DRLs working.
Assistance required:-
At this point, i really need some assistance in the following:-
Would the 10Pin to 14Pin cable be required for the correct functioning of the Xenon Headlights?
How can I resolve the Flickering and turning off issue with the Bi-Xenon?
How can i get the DRL's Working?
How can i get the Headlight Height adjusters working?
How do I code the CECM to remove these errors from the dash and have the lights working as they should?
Tuesday,09,January,2018,21:34:28:42155
VCDS Version: 17.8.1.0 (x64) HEX-V2 CB: 0.4409.4
Data version: 20171130 DS276.6
VIN: WVWZZZ16ZDM060166
Mileage: 30000km-18641mi
Chassis Type: 16-VW32 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 42 44 46 4F 52 56 62 72
77
VIN: WVWZZZ16ZDM060166 Mileage: 30000km-18641miles
Address 01: Engine (J623-CTHD) Labels:. 03C-907-309-V1.clb
Part No SW: 03C 906 026 BG HW: 03C 907 309 Q
Component: 1.4l R4 TSI H02 3743
Revision: LMH02--- Serial number: 00000000000000
Coding: 00250012002400000000
Shop #: WSC 00066 000 00189
ASAM Dataset: EV_ECM14TSI01103C906026BG 001002
ROD: EV_ECM14TSI01103C906026AB.rod
VCID: 66954BA358ED8787C0D-8032
4674 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [036] - -
Mileage: 30007 km
Date: 2018.01.09
Time: 17:16:18
Engine speed: 1898.00 /min
Normed load value: 8.2 %
Vehicle speed: 23 km/h
Coolant temperature: 51 °C
Intake air temperature: 34 °C
Voltage terminal 30: 14.065 V
Cruise Control System (CCS): status-Bit 0: 00001011
Cruise Control System: specified speed: 0.00 km/h
Cruise control switch-off: irreversible w. brake intervention-Bit 0: 00000000
Cruise control switch-off: reversible-Bit 0: 11111111
Cruise control switch-off: irreversible-Bit 0: 11111111
Acceleration: 0.000 m/s²
4675 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [047] - -
Fault Frequency: 15
Mileage: 29760 km
Date: 2018.01.02
Time: 16:07:04
Engine speed: 811.00 /min
Normed load value: 18.8 %
Coolant temperature: 89 °C
Intake air temperature: 58 °C
Voltage terminal 30: 13.428 V
Cruise Control System (CCS): status-Bit 0: 00001100
4629 - ECM Power Relay Load Circuit
P068A 00 [032] - Opens Too Early
5523 - Engine Start Blocked by Immobilizer
P1570 00 [032] - -
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 058 P HW: 0AM 927 769 D
Component: GSG DSG AG7 431 3652
Revision: 00043014 Serial number: CU501211266331
Shop #: WSC 02069 000 90108
VCID: 3E25C3C36C7DFF4768D-806A
006279 - Wheel-Speed Signal from ABS Control Module
P1887 - 000 - Implausible Signal - Intermittent
Fault Frequency: 25
Reset counter: 10
Mileage: 29733 km
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Revision: 00H31001
Coding: A63B60F8212800FA650C06EA841F0080211800
Shop #: WSC 00066 000 00000
VCID: 7DA704CF2DFB245F317-8028
03841 - RPM Sensor Rear Left: Incorrect Signal
Reset counter: 14
Mileage: 29829 km
Date: 2018.01.05
Time: 13:02:24
Count: 16384
Count: 14
Count: 12800
Count: 71
Count: 49408
Count: 65027
Count: 18749
Reset counter: 17
Mileage: 29836 km
Date: 2018.01.06
Time: 12:13:27
Count: 3
Count: 14
Count: 28672
Count: 128
Count: 43264
Count: 1
Count: 51
Fault Status: 00100011
Reset counter: 233
Mileage: 30007 km
Count: 12288
Count: 67
Count: 51201
Count: 64757
Count: 63488
Count: 59
Fault Status: 00101100
Reset counter: 229
Mileage: 29729 km
Date: 2018.01.01
Time: 06:29:28
Count: 16391
Count: 12
Count: 16896
Count: 64
Count: 45056
Count: 65280
Count: 52
Part No SW: 3AA 907 044 AF HW: 3AA 907 044 AF
Component: Climatronic H03 0303
Revision: 00001K02
Coding: 0010004002
Shop #: WSC 00066 000 00119
ROD: EV_ClimaAutoBasis_VW32.rod
VCID: 74B121EB1E3165174E9-8020
Part No SW: 5K0 937 086 M HW: 5K0 937 086 M
Component: BCM PQ35 M 021 0068
Revision: BC021001
Coding: 08000A3A802DE1C0408800801000816403000088508089605C 8000000040
VCID: 3E25C3C3607DFF4768D-806A
Subsystem 1 - Part No: 1K8 951 171
12 Faults Found:
Fault Status: 00100111
Fault Frequency: 252
Reset counter: 15
Mileage: 29586 km
Date: 2017.12.23
Time: 10:03:38
Voltage: 13.70 V
Fault Status: 00101010
Reset counter: 10
Mileage: 29586 km
Date: 2017.12.26
Time: 17:43:02
Voltage: 13.90 V
Fault Frequency: 191
Reset counter: 15
Mileage: 29586 km
Date: 2017.12.23
Time: 10:03:38
Voltage: 13.70 V
Fault Frequency: 24
Reset counter: 10
Mileage: 29586 km
Date: 2017.12.23
Time: 10:03:46
Voltage: 13.75 V
Reset counter: 4
Mileage: 29595 km
Date: 2017.12.26
Time: 22:58:02
Voltage: 11.90 V
01495 - Bulb for High-Beams; Left (M30)
Fault Status: 01101010
Reset counter: 218
Mileage: 29586 km
Date: 2017.12.23
Time: 09:18:40
Voltage: 11.60 V
Reset counter: 4
Mileage: 29595 km
Date: 2017.12.26
Time: 22:59:57
Voltage: 12.15 V
Reset counter: 218
Mileage: 29586 km
Date: 2017.12.23
Time: 09:50:23
Voltage: 11.85 V
Reset counter: 218
Mileage: 29586 km
Date: 2017.12.23
Time: 09:18:42
Voltage: 11.65 V
Reset counter: 218
Mileage: 29586 km
Date: 2017.12.23
Time: 09:50:24
Voltage: 11.85 V
Fault Frequency: 50
Reset counter: 233
Mileage: 29586 km
Date: 2017.12.23
Time: 09:20:13
Voltage: 12.10 V
Fault Frequency: 51
Reset counter: 233
Mileage: 29586 km
Date: 2017.12.23
Time: 09:50:29
Voltage: 11.90 V
Address 10: Park/Steer Assist (J446) Labels:| 1Q0-919-475.clb
Part No SW: 5C6 919 475 HW: 7E0 919 475 A
Component: PARKHILFE 8K H10 0005
Revision: -------- Serial number: 07381302100884
Coding: 108101
ASAM Dataset: EV_EPHVA18VW3610000 001003
ROD: EV_EPHVA18VW3610000.rod
VCID: 71BF28FF6123503FA5F-8024
Part No SW: 5C0 959 655 C HW: 5C0 959 655 C
Component: AirbagVW10 013 0613
Serial number: 003G6M085PSR
Coding: 00003241
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 323DE7F3A4A52B279C5-8066
Serial number: 3572MSME560E1376ZZZZ
Serial number: 3582MSME040C1376ZZZR
Subsystem 3 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3516KSME6C726420ZZZS
Serial number: 3526KSME0A096520ZZZM
Part No SW: 1K5 953 507 T HW: 5K0 953 549 B
Component: Lenks.Modul 008 0090
Revision: -------- Serial number: 90422LKU0004X
Coding: 088A140000
Shop #: WSC 00066 000 00187
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 42DDB73314059BA70C5-8016
Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0037
Serial number: 0053220 FLE 20130103
Coding: 820000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 5C6 920 872 HW: 5C6 920 872
Component: KOMBI H07 0705
Coding: 171B00
ROD: EV_Kombi_UDS_VDD_RM09_A04_VW32.rod
VCID: 6A8D3F934CF5A3E7E45-803E
Part No SW: 7N0 907 530 AH HW: 7N0 907 530 AH
Component: J533 Gateway H50 1634
Revision: H50 Serial number: 04011303290002
Coding: 351003
VCID: 76B51BE308CD770770D-8022
Component: IMMO H07 0705
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H19 0550
Revision: A1001003 Serial number: 7664004002
Coding: 010100
VCID: 2A0DFF938CF563E7245-807E
Component: TUER-SG FT 002 0515
Revision: 13110009 Serial number: 0006013436
Coding: 0002B5
Shop #: WSC 01383 790 50316
VCID: 5BE36A5793AFCA6F6F3-800E
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 704 B HW: 3C0 959 794 C Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 008 1508
Serial number: 00000007488986
Coding: 000290
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 69 3305
Revision: 00H22000
VCID: 372BD6E74347CE0FABB-8062
Fault Status: 00101101
Fault Frequency: 18
Reset counter: 18
Mileage: 30008 km
Date: 2018.01.09
Time: 17:46:04
Voltage: 14.00 V
DU
Temperature: 37.0°C
RPM: 1606 /min
Speed: 38.0 km/h
Speed: 38.0 km/h
Part No SW: 7N0 907 532 HW: 7N0 907 530 AH
Component: EZE_2 H50 1634
Coding: 01030100
VCID: 6FBB2E87779746CFB3B-803A
Subsystem 1 - Part No SW: 5K0 959 591 HW: 5K0 959 591
Component: J245 PS41.022 H10 0007
Serial number: WRH0007POUD
Coding: 180000
Component: TUER-SG BT 002 0515
Revision: 15110009 Serial number: 0006158935
Coding: 0002B4
VCID: 5CE1694B96A1CD57669-8008
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 703 B HW: 3C0 959 795 C Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 008 1508
Serial number: 00000007522919
Coding: 000290
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 B HW: 5K0 035 190 B
Component: Radio RCD510 005 0236
Revision: 00000001 Serial number: VWZ1Z3M9873940
Coding: 01000400040006
VCID: 241111ABEED1B5971E9-8070
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007663943662
Coding: 0A00000000010100
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3A2DCFD37CD5D367545-806E
End----------(Elapsed Time: 01:23, VBatt start/end: 12.3V/12.3V)-----------
__________________________________________________ __________________________________________________ __________________________________________________ _______________________________________________
I haven't received the Bi-Xenon 10pin to 14pin Adapter Cable yet. (The shipping has been rescheduled....sigh)
I did perform two changes and the headlight are not flickering anymore...
I Enabled "Bi-Xenon Headlights (with Shutter) Installed", in the Byte 14 - (This stopped the Flickering)
AND
I Enabled "High Beam via Shutter active/installed", in the Byte 25 (Tried this, but the high beam only works when the lights are on, but i cant flash the lights when the headlights are off.
Will install and try some more coding then. don't want to try much with these Adapters since they maybe wired incorrectly.
Any advise would be appreciated.
Thanks in advance everyone!
Kind regards,
Vapor.Rob
iichel
Eindhoven, NB, NL
C?ID=284912
>> yes
>> correct coding combined with correct BCM
>> Install module 55 Xenon Range and wire it all up
Byte 11 --> bit 2 = 0, bit 7 = 1
Byte 15 --> bit 3, 6, 7 = 1
Byte 18 --> HEX 04
Byte 24 --> bit 7 = 1 / Value set for DRL brightness to 100%
Byte 25 --> bit 6 = 0
Byte 26 --> bit 3 = 1
Byte 27 --> bit 2 = 1
Xenon range: install and wire module, install and wire AFS sensor, enable address 55 in gateway, go to 55, basic settings, enter 1446940.
Leveling headlights: go to 55, basic settings, adaptation, select ON/Off, wait for the calibration
vapor.rob
Trinidad and Tobago
C?ID=325257
>> yes
Byte 18 --> HEX 04
Hey iichel,
Thanks soo much for responding. This some useful information. Ok so i will try these and provide feedback. But can i use the lights without the automatic leveling system?
iichel
Eindhoven, NB, NL
C?ID=284912
i suppose you could, but a better question maybe whether you should.
often it's required simply by regulation. and it's better not to blind people with HID headlights.
vapor.rob
Trinidad and Tobago
C?ID=325257
Honestly i would prefer the automatic leveling but at the moment the cost is a bit high. So i wanted to get these lights working and then retro fit the auto leveling afterwards. Once i can use the leveling adjuster inside the car from the halogens i should be ok for the while. as for the regulations, were i live, there's currently no regulations on HIDs. its so bad, that you would not get a ticket for driving with hids but you would get a ticket for driving with your foglamps on :facepalm:
iichel
Eindhoven, NB, NL
C?ID=284912
it's not possible to use the manual headlight adjuster in the car with original HID headlights.
I'm not sure how expensive OEM HID's are and if you're going through the effort and expense of fitting OEM HID's, the AFS system is only a small in relation, both in cost and in effort.
and driving with your fogs on, in bright daylight makes you look like a 16 year old.
and driving with your fogs on, in darkness, makes you an idiot. i'm quite OK with people getting fines for this.
vapor.rob
Trinidad and Tobago
C?ID=325257
well it is what it is, but tell me, the lights would not raise to the correct level unless i install the automatic leveling? because at the moment they're on the ground....
vapor.rob
Trinidad and Tobago
C?ID=325257
Hey everyone,
so I got the Adapter from kufatec today, and i'm in a little more trouble. So i installed them, the light were exactly as they were before, (beams on the ground, no drl, or high beam flash with control).
I tired the byte adjustments above and it didnt change the behavour of the lights, however, my rear lights are really dim and the reverse light turns on when i turn the switch on.
I put the Byte 18 back to the original setting which is "00 Lighting: Standard/Parameter Settings (EEPROM) which did not help.
I also revert all the other setting back to its original settings and i am still having the problem with the reverse light being on and the dim rear park lights.
Any assistance on how i can get this fixed? seems like im grounded for the evening....
vapor.rob
Trinidad and Tobago
C?ID=325257
Update: so I went back into the byte18 and changed the value to "Jetta - RoW" and I was able to get things back to normal.
But I still can't get the DRLs working, headlight height adjuster or the high beam flash. Any suggestions....
Per a PM from the OP: Hex 8C Jetta (162/VW361) Rest if Word (ROW) fixed up the Byte 18 problem. That may be valuable to someone with a RoW 162 chassis sedan that needs to get factory functions re-enabled.
I agree with iichel here. Installing a 55-Xenon range module is a requirement for assistance from us directly .. but more importantly having a fully functional AFS system is a much better driving experience and safer for all oncoming traffic. The conventional short coding he provided (1446940) would apply to the older CAN protocol 55 type. We have that Software Part Numbers 5M0-907-357 through 5M0-907-357-D split shown on this page: VW Golf (1K) Headlight Aim Control (Xenon with AFS)
Software Part Numbers 5M0-907-357-E and above are the newer UDS type. What we see frequently is new UDS modules sourced from 3rd party suppliers that have No End of Line Programming DTCs which prevent coding and Basic Settings. For that reason I would try to retrofit the complete system from an older CAN setup if possible.​
Next, factory installed BCMs with part numbers other than ?K0-937-087-?? (i.e.087) rarely have the terminals inside the controller for proper high beam shutter activation. There are some exceptions to that rule .. but they are rare.
This may not be the most up to date revision but PL24 shows this BCM as the direct replacement by VIN: 5K0-937-087-R/ZHB
So, if you wanted to install a BCM that was guaranteed compatible with this vehicle and install all of the components required for a factory-like AFS system I would double check to make sure that number is the latest version and install the higher end BCM. You would still have to iron out the AFS details after a 55 module is installed and communicating.
vapor.rob
Trinidad and Tobago
C?ID=325257
Hey Dana,
Thanks for this information. I am currently looking into acquiring the wiring and modules required for the Automatic Leveling systems. I will work on this as soon as I acquire it. Thanks for this, so my headlight level would be pending until i acquire this.
As for the CECM, i spoke to a friend in the UK with a VW bearing the same CECM who was able to get their headlights fully functional.
I used some information they supplied me and was able to get my high beam flash working. using the following code "08000A3A802DE1C040880080100089640304000850808960E4 8400000040"
However, the DRLs arent working still. I was able to get them on for a few seconds by disabling the "LED-Daytime Running Light (DRL) Module for Parking/Position Light & Daytime Running Light (DRL)" and saving (the DRLs came on for a second and then came off)
Would you be able to advise me onto what codes i can look into to get the DRLs working?
No problem. One exception to the 087 BCM rule is my own 2012 Tiggys SEL that was born with a 086 BCM: WVGBV7AX1CW000438 The Xenon Headlights with LED DRLs (facelift in 2012) were factory installed so it is possible your BCM may have the proper terminals in it. I didn't want to give you false hope but someone else reporting success with the same BCM is optimistic.
Please post the resulting scan with that coding entered including any fault codes that set after operation of the lights.
vapor.rob
Trinidad and Tobago
C?ID=325257
I totally understand.
With the codes given, most of the faults were gone. I'm left with two pairs:-
Here's a copy of the scan
Friday,26,January,2018,19:46:53:42155
VCDS Version: 18.1.0.2 (x64)  HEX-V2 CB: 0.4411.4
Data version: 20180122 DS285.1
VIN: WVWZZZ16ZDM060166   License Plate:
Mileage: 30450km-18920mi   Repair Order:
          77
VIN: WVWZZZ16ZDM060166   Mileage: 30450km-18920miles
   VCID: 66954BA358ED8787F29-8032
Readiness: 1110 0101
   VCID: 3E25C3C36C7DFF475A9-806A
   Revision: 00H31001
   VCID: 7DA704CF2DFB245F033-8028
   Revision: 00001K02
   Coding: 0010004002
   VCID: 74B121EB1E3165177CD-8020
   Revision: BC021001
   Coding: 08000A3A803FE1C040880080100089640304000850808960E48400000040
   Shop #: WSC 00066 123 12345
   VCID: 3E25C3C3607DFF475A9-806A
                    Reset counter: 249
                    Mileage: 30452 km
                    Date: 2018.01.26
                    Time: 19:44:54
                    Voltage: 12.20 V
                    Reset counter: 249
                    Mileage: 30452 km
                    Date: 2018.01.26
                    Time: 19:44:54
                    Voltage: 12.20 V
   Coding: 108101
   VCID: 71BF28FF6123503F97B-8024
   Coding: 00003241
   VCID: 323DE7F3A4A52B27AE1-8066
   Coding: 088A140000
   VCID: 42DDB73314059BA73E1-8016
   Coding: 820000
   Coding: 171B00
   VCID: 6A8D3F934CF5A3E7D61-803E
   Coding: 351003
   VCID: 76B51BE308CD7707429-8022
   ROD: EV_Immo_UDS_VDD_RM09.rod
   Coding: 010100
   VCID: 2A0DFF938CF563E7161-807E
   Coding: 0002B5
   VCID: 5BE36A5793AFCA6F5D7-800E
   Slave Driver:
   Coding: 000290
   Revision: 00H22000
   VCID: 372BD6E74347CE0F99F-8062
   Coding: 01030100
   VCID: 6FBB2E87779746CF81F-803A
   Coding: 180000
   Coding: 0002B4
   VCID: 5CE1694B96A1CD5754D-8008
   Slave Passenger:
   Coding: 000290
   VCID: 241111ABEED1B5972CD-8070
   VCID: 3A2DCFD37CD5D367661-806E
End----------(Elapsed Time: 01:19, VBatt start/end: 12.3V/12.3V)-----------
Thanks again
MasterTommy
Amsterdam
C?ID=295586
Seeing as it is a bulb fault thats popping up, i’m pretty sure the BCM is not aware of the fact you installed LED DRL’s. I’d focus my attention on that.
Fault in coding, fault in adaptations and/or wrong module are all still on the table.
I agree with Tommy here. I would have expected coding such as this example to work:
08000A3A803FE1C040880080100089640304000850808960E48400040040
You might want to make sure those headlights are equipped with LED DRL modules and then see which TFL/DRL terminals at the BCM connect to the factory side of the car harness to see if power is getting there. If the DRL power is present on the car side harness (with coding similar to my above example and handbrake off) but not at the headlight connector after the 3rd party adapter you may need to move wires in the adapter.
Double check the factory level wiring diagrams for a Jetta in your market with LED DRLs but I think terminal 12 at each lamp is a blue/yellow trace wire. Assuming that applies to your car the BCM terminal positions should be T52a/7 and T52a/8 meaning terminals 7 and 8 in the "A" (black) main BCM connector.
vapor.rob
Trinidad and Tobago
C?ID=325257
So i've reviewed the points here and i believe we're on to something. The My vehicle is a Euro Spec jetta. The OEM Bi Xenons i've got are US Spec Lights.
I've noticed from the adapter I got there are about 3 pins that are not covered on the headlights. Let me confirm what are working:-
1) Both Indicators
2) Both Low Beams
3) Both High Beams Via Shutter
4) Both Shutter Works
5) Both High Beam Flash when lights are on
6) Both Headlight Level Motors sounds when the car turns on (due to no AFS - Pending Install)
What doesn't work (as we know) are the DRLs
I am unable to get wiring diagrams for my vehicle after looking everywhere, i was hoping someone would be able to tell me which pins on the headlights are for which function since I am unable to get this info anywhere at the moment. I'm really hoping someone can guide me with the possible pins that may require moving to get these DRLs working.
So for reference:-
This is the 10 Pin Connector on my car
The Pins
Bi Xenon Plug on Headlights (One Pin is in the Dark)
Kufatec Adapter 14 pin End
Kufatec Adapter 10 pin End
The Pins on the Kufatec Adapter
14 pin Side
10 pin Side
OK, I'm guessing that blue/yellow trace wire on the car side (which appears to be in terminal #4 of the 10 pin) is the DRL wire. To confirm I'd get an old-school incandescent test light, ground the test light to earth, stretch the VCDS laptop under the hood with the key on and handbrake off, prop the test light probe into that pin, connect to 09 and clear DTCs. If the test light bulb lights and you don't get a reoccurring DTC for whichever side of the car you are testing at that point you can confirm the wire is correct.
You may be able to use a LED test light or a DVOM but I'm not sure what the BCM wants to see for a current draw before it flags a DTC and decides to stop sending power to the ckt.​
Either way, put the handbrake on and make sure power goes away.
If we confirmed the proper terminal the next thing to do is see if that adapter happens to connect it to terminal 12 (T14r/12) on the headlight side or not. That should be the proper NAR pin. You may be able to use erWin VW RoW to obtain NAR wiring diagrams but if not I'd search RoW repair info for something close to this name:
Headlamps Bixenon HID with range control, cornering lamp, LED daytime running lamps , (8IM)
from June 2012
which was diag No. 97
We need to tread very lightly to avoid copyright police but this is a small snip from J519 to J861: http://ft.trillian.im/7a467daf2651281430c9375002268189594cfb6d/6WRjtqc92Qq3mvs83F3077d1gWBQi.jpg
vapor.rob
Trinidad and Tobago
C?ID=325257
Hey Dana,
Your a God sent, thank you for this info. This saved me a lot of effort because i was just about to test each pin with my DVOM and do up an excel spread sheet with the info.
As soon as i get back in, i will follow these instructions to check for power from the vehicle side and then i will check on the harness side for Terminal 12 as suggested.
I will provide updates on this as soon as i try these.
Thanks Dear
vapor.rob
Trinidad and Tobago
C?ID=325257
Hey Dana,
So I tried the suggestion and here's the results.
Still no DRLs...sigh
I checked the #4 pin on the car harness and well there's power (12.01v) when the switch is off, and no power when the parking lights are on or headlights so I confirm that this is indeed the DRL Connection.
I checked additionally and there's constant power on pin #1 (12.01v) and on pin 2 (10.0v)
When the switch is placed in the Parking light position, there's 12,01v at pin 10
I've just checked the Kufatec adapter and the #4 Terminal on the 10 pin side is indeed connected to the #12 Terminal on the 14pin side....
Its either something is wrong with these lights or there's another pin responsible for the DRLs....sigh
On the headlight side however, I tried connecting pin 4 on car side to pin 12 on the headlight side, and there's no DRL and the same with pin 14 on the headlight side.
I did some reading and i'm understanding that some persons who weren't able to get their DRLs working, wired Terminal #13 to the BCM. In the Diagram, I am seeing a connection to the to Terminal #13 (T14r/13). Do you think this might be necessary?
