First Post - 2010 VW Touareg TDI Bluetooth issues
ZimZimmma
Canada
C?ID=319353
ok I am going to try to put as much information as possible
I purchased a 2010 VW Touareg Canadian version tdi..it came with Bluetooth (9w3 unit with the delta radio (no nav)) and was working fine...i decided to have a buddy install the aftermarket nav android radio
He had this great idea of using the stock mic, so he pulled my stock radio out, pulled the 2 mic wires from the green harness and connected them to a mini plug to us with the android unit..this did not work
I decided I did not like the android unit after using it and went back to stock...now my Bluetooth works except they cannot hear me from the speakers and voice control no longer works
Here is what I have done
1) checked the coding on the radio and Bluetooth unit (which I didn't need to)
2) disconnected the Bluetooth unit from under the passenger seat to reset it
3) disconnected the amp in the trunk to reset it
4) I have reset the main battery to reset everything
5) I replaced the mic with a brand new oem one
6) I have purchased a new 9w7 unit and tried that
7) Took it to VW and their testing (after ($118 CDN)) is that the Bluetooth unit is bad and a 9w7 will not work in my car (I have full red cluster) so another 9w3 will be needed
8) I have purchased a used working 9w3 out of the same year and tried that
9) tried different phones to see if it was my samsung s7
All these did not work, no voice controls and no audio(call sound) from the speakers but they can hear me and everything else is working...radio work fine, its only the Bluetooth call sound
I checked the coding on the new 9w3 and its 4077
no errors on the Bluetooth unit, sound system or radio
running out of options on what to check and fix
any help is greatly appreciated.
i have purchased VCDS and can provide scans and whatever else is needed
not sure what else to look at now
thank you
ZimZimmma
Canada
C?ID=319353
Chassis Type: A9 (6N0)
Scan: 01 02 03 05 08 09 0F 15 16 17 19 1C 22 36 46 47 55 56 68 69
          6D 6E 76 77
68-Wiper Electr. -- Status: OK 0000
6E-Ctrl Head Roof -- Status: OK 0000
Address 01: Engine (CAT)       Labels:. 059-907-401-CAT1.clb
   Part No SW: 7L0 907 401 T    HW: 7L0 907 401 K
   Component: 3.0TDI EDC17G004AG  0090
   Revision: 33H02---    Serial number:
   Coding: 0421002A590F0968
   Shop #: WSC 31414 790 00001
   VCID: 3C21CA5ADA7FA437472-5160
Address 02: Auto Trans        Labels: 09D-927-750.lbl
   Part No SW: 09D 927 750 LD    HW: 09D 927 750 LD
   Component: AL 750 6A           1667
   Revision: 00H89000    Serial number:
   Coding: 0004984
   VCID: 7BA309469FF1630F0E8-5160
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25E1.clb
   Part No SW: 7L0 907 379 P    HW: 7L0 614 517 C
   Component: ESP ALLRAD MK25E1   0304
   Revision: 00H53001
   Coding: 0004354
   VCID: 46D5A8B294E3EEE7216-8012
Address 05: Acc/Start Auth.        Labels: None
   Part No SW: 7L0 909 135 C    HW: 7L0 909 135 C
   Component:    Kessy            6850
   Revision: 00H22072    Serial number: VWX3Z0J2911891
   Coding: 0000232
   VCID: 313FEB6E0D6D595FE44-8064
Address 08: Auto HVAC        Labels: 7L6-907-040.clb
   Part No: 7L6 907 040 AL
   Component: CLIMAtronic R/L     4537
   Coding: 0003030
   VCID: 7AAD0C42909B5A0715E-802E
Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V2.clb
   Part No SW: 7L6 937 049 AF    HW: 7L6 937 049 AF
   Component: J519                2004
   Revision: -0004---    Serial number: --------------
   Coding: 230008002F00BC000000000000000000
   VCID: 00597EAAF64700D75BA-8054
   Part No SW: 8E0 035 593 P    HW: 8E0 035 593 P
   Component: SDAR SIRIUS     H07 0160
   Revision: 00000000    Serial number: AUZ4Z7K0572097
   Coding: 0000102
   VCID: 3635D872E4437E67B16-8062
            000 -  -
                    Reset counter: 24
                    Mileage: 164800 km
                    Date: 2018.01.06
                    Time: 12:09:19
Address 15: Airbags        Labels: 7L0-959-655.lbl
   Part No SW: 7L0 959 655 A    HW: 7L0 959 655 A
   Component: J234__0B VW8T       0270
   Revision: 92013027    Serial number: 003C6001FTK0
   Coding: 0012354
   VCID: 3B23C946DF21A30F4E8-806E
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 G
   Component: J527                3601
   Coding: 0010211
   VCID: 43D3B1A6A7D1DBCF068-8016
Address 17: Instruments        Labels: 7L6-920-xxx-7L6.lbl
   Part No SW: 7L6 920 876 B    HW: 7L6 920 876 B
   Component: J285 KOMBI-INST.    9833
   Revision: KHH05V44
   Coding: 0007301
   Shop #: WSC 39254 002 104857
   VCID: 3B23C946DF61A30F4E8-806E
                    Reset counter: 67
                    Mileage: 165666 km
                    Date: 2018.01.17
                    Time: 21:11:23
Address 19: CAN Gateway        Labels:. 6N0-909-901-7L.clb
   Part No SW: 6N0 909 901     HW: 7L6 920 876 B
   Component: J533  GW-K-CAN TP20 9833
   Coding: 77E2EF9BE3066002
   VCID: 70B92E6AC6A71057ABA-8024
                    Reset counter: 67
                    Mileage: 165666 km
                    Date: 2018.01.17
                    Time: 21:11:23
Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
   Part No SW: 7L6 919 879 B    HW: 7L6 919 879 B
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1439802T1EHZ02
   VCID: 46D5A8B294A3EEE7216-8012
   Part No: 0AD 927 755 BG
   Component: TRANSFERCASE        0126
   VCID: 015F7BAEFD1D09DF544-5160
   Part No: 7L0 959 760
   Component: Sitzverstellung     0702
   VCID: 77AB1576A389476F6A0-8022
Address 46: Central Conv.        Labels: 7L0-959-933.lbl
   Part No: 7L6 959 933 A
   Component: 4M HSG              0601
   Coding: 0000085
   VCID: 40D9BEAAB697C0D71BA-4B1E
   Subsystem 1 - Part No: 7L0 959 701 N
   Component: Tuersteuergeraet FS 6304
   Subsystem 2 - Part No: 7L0 959 702 N
   Component: Tuersteuergeraet BF 6304
   Subsystem 3 - Part No: 7L0 959 703 C
   Component: Tuersteuergeraet HL 0201
   Subsystem 4 - Part No: 7L0 959 704 C
   Component: Tuersteuergeraet HR 0201
   Part No SW: 7L6 035 456 B    HW: 7L6 035 456 B
   Component: 08K Audioverst.     0008
   Revision: 00006000    Serial number: 00000008156215
   VCID: 323DE462082B62479DE-8066
Address 55: Headlight Range        Labels: 7L6-907-357-A.lbl
   Part No SW: 7L6 907 357 C    HW: 7L6 907 357 C
   Component: AFS-Steuergeraet    0143
   Coding: 1290435
   Component: AFS-Lst.-Modul l    0005
   Coding: 00000019
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0005
   Coding: 00000019
Address 56: Radio        Labels: 7L6-035-180-56.lbl
   Part No SW: 7L6 035 180 C    HW: 7L6 035 180 C
   Component: Radio DE2           0008
   Revision: 00007000    Serial number: VWZ4Z4K7330545
   Coding: 0003000
   VCID: 2D07F71E11153DBFC0C-8078
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L6 955 119 B
   Component: J400__ Front Wiper  5301
   Coding: 0001397
   VCID: 392FD34ED55D911F5C4-806C
   Component: RLS     130210 054  0403
   Coding: 00208941
   Shop #: WSC 31414
Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
   Part No SW: 7L0 907 383 N    HW: 7L0 907 383 N
   Component: J345  Anhaenger     0080
   Revision: 4A008002    Serial number: 00000126144967
   Coding: 0016386
   VCID: 3FDBBD56CB39BF2F620-806A
Address 6D: Trunk Elect.        Labels: 7L6-959-107.clb
   Part No SW: 7L6 959 107 B    HW: 7L6 959 107 B
   Component: J605  HECKKLAPPE    1310
   Revision: --H05---    Serial number: --------051983
   Coding: 0122110
   VCID: 3A2DCC42D01B9A0755E-806E
Address 6E: Ctrl Head Roof        Labels: None
   Part No SW: 7L6 919 044 AD    HW: 7L6 919 044 AD
   Component: J702  Dachdisplay   0401
   Revision: 1030006S    Serial number: 00000000155342
   VCID: 79AF134E95DD511F1C4-802C
   Part No: 7L0 919 283 F
   Component: 0L Einparkhilfe     1108
   VCID: 392FD34ED51D911F5C4-806C
Address 77: Telephone        Labels: 5P0-862-335.lbl
   Part No SW: 1Z0 035 729 E    HW: 1Z0 035 729 E
   Component: FSE_2P8x        H40 0190
   Revision: 00000000    Serial number: 00000005243983
   Coding: 0004077
   Shop #: WSC 05311 000 00000
   VCID: 3A2DCC42D05B9A0755E-806E
End----(Elapsed Time: 02:09, VBatt start/end: 12.3V/11.8V. VIgn 11.8V)-----
ZimZimmma
Canada
C?ID=319353
the delta radio is coded at 3000 and the 9w3 is coded at 4077
thank you
ZimZimmma
Canada
C?ID=319353
also if anyone has a wiring diagram of the radio and bluetooth module I can check the wires, that would help
thank you in advance
ZimZimmma
Canada
C?ID=319353
any one have a possible solution or something for me to try?
ZimZimmma
Canada
C?ID=319353
anyone have an idea?
ZimZimmma
Canada
C?ID=319353
This can be closed, I was able to spend sometime and find out the issue
the dealer told me the unit was gone, so I bought a used one and it did the same thing
I traced all the cables and under the passenger seat (at the harness) there was one wire that was slightly cut where it attaches to the pin..hardly noticeable as I had to trace the cables with a trace tool to find out, fixed and now everything works.
