Retrofit 1AT abs pump (Hill hold assist, tmps, etc) Audi A4 B8
Segadora
Denmark
C?ID=287924
Hello
My car as an 1AS abs pump part no. 8K0 907 379 BF
I changed the abs pump to an 1AT part no. 8K0 907 379 BT
However now I am strugging with invalid coding on the abs module.
Have anyone else tried this mod?
The coding on the pump is equal to the old pump. The original coding of the new abs pump was 080D18. The pump came from america, cause I got it cheap.
Thursday,18,January,2018,13:13:56:55653
VCDS Version: 17.8.1.0 (x64)  HEX-NET CB: 0.4409.4
Data version: 20171130 DS276.6
VIN: WAUZZZ8K  License Plate:
Mileage: 263240km-163569mi   Repair Order:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 69
          72
VIN: WAUZZZ8K6BA0xxxxx   Mileage: 263240km-163569miles
Address 01: Engine (J623-CAGA)       Labels:| 03L-906-022-CAG.clb
   Part No SW: 03L 906 022 MK    HW: 03L 906 022 B
   Component: R4 2.0l TDI   H05 9981
   Revision: 11H05---
   Coding: 0104002C02072118
   Shop #: WSC 46238 001 1048576
   ASAM Dataset: EV_ECM20TDI03L906022MK A01016
   ROD: EV_ECM20TDI03L906022C.rod
   VCID: 7AB83AE3FD063C96DF-802E
          U1113 00 [039] - -
                    Mileage: 263230 km
                    Date: 2018.01.18
                    Time: 12:52:19
                    Engine speed: 873.00 /min
                    Normed load value: 36.5 %
                    Coolant temperature: 45 °C
                    Intake air temperature: 11 °C
                    Voltage terminal 30: 13.860 V
                    Crankshaft speed (RPM): 873.0 /min
                    Vehicle speed: 0.00 km/h
                    Accelerator position: 0.00 %
                    Cruise Control System: specified speed: 0.00 km/h
                    Cr Ctl st Sh Off Irv Lst-Bit 0: 11111111
                    Cr Ctl st Sh Off Rv Lst-Bit 0: 11111111
                    Cruise Control System (CCS): switch position-Bit 0: 10000001
          U1113 00 [039] - -
                    Mileage: 263230 km
                    Date: 2018.01.18
                    Time: 12:52:19
Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
   Part No SW: 8K0 927 155 AF    HW: 0AW 927 156 H
   Component: 0AW 20TDI RdW H06 0009
   Revision: --H06---    Serial number: 0000000358
   Coding: 000002
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMVL381 A02017
   ROD: EV_TCMVL381.rod
   VCID: 77BE23D7CE1421FEA0-8022
   Part No SW: 8K0 907 379 BT    HW: 8K0 907 379 BT
   Component: ESP8 front    H04 0010
   Coding: 178500
   Shop #: WSC 02391 823 56573
   VCID: 0C546C3BAF923226FD-8058
01486 - System Function Test Activated
            000 -  -
                    Reset counter: 76
                    Mileage: 263243 km
                    Date: 2018.01.18
                    Time: 13:11:35
                    Hex Value: 0x0000
                    Hex Value: 0x07A2
                    Hex Value: 0x0031
                    Hex Value: 0x3199
                    Hex Value: 0x00FF
            000 -  -
                    Reset counter: 76
                    Mileage: 263243 km
                    Date: 2018.01.18
                    Time: 13:11:35
                    Hex Value: 0x0000
                    Hex Value: 0x07A2
                    Hex Value: 0x0014
                    Hex Value: 0x0799
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 CQ    HW: 8K0 907 064 CQ
   Component: BCM2 2.0      H04 0430
   Coding: 050200
   Shop #: WSC 00046 123 12345
   VCID: 014A4D0F98D06F4E9E-8054
   Serial number: 0210000145144012
   Part No SW: 8T1 820 043 AN    HW: 8T1 820 043 AN
   Component: KLIMA 1 ZONE  H08 0180
   Revision: A1000000    Serial number: 01270720101229
   Coding: 34100000
   VCID: 7DB231FFE4280BAEFA-8028
   Component: BCM1 1.0      H29 0392
   Revision: 10029001    Serial number: 00000000745979
   Coding: 260050914134AF010001000300001D0D401C670802010101000000
   VCID: 3C34FCFBBFB2C2A68D-8068
   Component: WWS 280710  H06 0070
   Serial number: SWF10070286141
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 11002332
   Coding: 025028
   Component: E1 - LDS  H08 0090
   Serial number: 00000000002107102038
   Part No SW: 8K0 919 475 Q    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0070
   Revision: 11001001    Serial number: 51241021728941
   Coding: 110103
   VCID: 47DE9317F674917E10-8012
   Part No SW: 8K0 959 655 J    HW: 8K0 959 655 J
   Component: AirbagVW-AU10 H41 0610
   Serial number: 003GKD0JF347
   Coding: 30343435363030303030554A304C384B3053
   VCID: 44C4841BCF42BA66F5-8010
   Serial number: 6334MSME56036F73I
   Serial number: 6344MSME5562730AC
   Serial number: 6352QSME2E672718O
   Serial number: 6362QSME3B6C1520I
   Serial number: 63732SME03693604U
   Serial number: 63832SME146A1508Z
   Revision: --------    Serial number: 90319JGR0001M
   Coding: 000017
   VCID: 3D32F1FFA4A8CBAEBA-8068
   Component: E221 - MFL  H02 0010
   Part No SW: 8K0 920 930 N    HW: 8K0 920 930 N
   Component: KOMBIINSTR.   H21 0258
   Revision: 00000000    Serial number: EJC50RU7A
   Coding: 033F10000200000C010001
   VCID: 383CE0EB8B8AEE8669-806C
   Part No SW: 8T0 907 468 AD    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0117
   Revision: EC000056    Serial number: 5600E107028204
   Coding: 00C303
   Shop #: WSC 06325 123 12345
   VCID: 0346470782CC7D5E8C-8056
   Component: J367-BDM  H07 0170
   Serial number: 1002710D120710
   Part No SW: 8K0 959 793 M    HW: 8K0 959 793 M
   Component: TSG FA        H12 0357
   Revision:             Serial number: 0000011050784
   Coding: 01101A205000410001
   VCID: 4AD8AA23E5666C160F-801E
   Revision: 00002001    Serial number: 0129154309
   Coding: 013A1E2020BD00818120023280000000
   Part No SW: 8K0 959 792 M    HW: 8K0 959 792 M
   Component: TSG BF        H12 0357
   Revision:             Serial number: 0000011040519
   VCID: 49DA952FE060670E06-801C
   Revision: 00000003    Serial number: 10000000581486
   VCID: 3424D4DB97E20AE645-8060
   Part No: 8K5 907 357 B
   Coding: 0000004
   VCID: 393AE5EF7080F78E96-806C
   Part No SW: 4G0 035 056 H    HW: 4G0 035 056
   Component: Radio U STD   H51 0134
   Revision: AB001007    Serial number: 469H.0A7545112
   Coding: 010003020100000001
   VCID: 26003E93513E6876CB-8072
   Part No SW: 8R1 035 666 L    HW: 8R1 035 666 H
   Component: H-BN-EU       H48 1036
   Revision: --------    Serial number: 514L 0E7507304
   Coding: 0F010001000681FD0180EF5E00000401E40001020000000000
   VCID: 41CA8D0FD850AF4EDE-8014
   Subsystem 1 - Part No: 8R0 060 884 EM
   Component: EUR 2017/2018  2503
   Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
   Component: DU7 High  H43 0098
   Serial number: 9466GS0A0067232
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000000789149
   Component: CD-Database  5950
            000 -  -
                    Reset counter: 75
                    Mileage: 263230 km
                    Date: 2018.01.18
                    Time: 12:49:46
                    Bin. Bits: 00000000 00000000
                    Bin. Bits: 00000000 00000100
   Part No SW: 8K0 959 795 F    HW: 8K0 959 795 F
   Component: TSG HL        H11 0357
   Revision:             Serial number: 0000106878936
   Coding: 01001A204000210001
   VCID: 45C2991FCC78836EE2-8010
Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Revision: 1A001001    Serial number: 00000193916114
   Coding: 0100000000000000
   VCID: 3620EED3819E18F67B-8062
   Component: TSG HR        H11 0357
   Revision:             Serial number: 0000106878933
End----------(Elapsed Time: 01:39, VBatt start/end: 12.2V/12.1V)-----------
iichel
Eindhoven, NB, NL
C?ID=284912
Segadora
Denmark
C?ID=287924
first thing: I dont know if its compatible. I have not checked if it works with auto trans, the engine and chassis.
I have checked that the abs module is from a FWD car as mine.
Since it's from america, I think its likely it was from a petrol car, but I might be wrong. I can try research and see if I can figure it out, if it matters.
iichel
Eindhoven, NB, NL
C?ID=284912
wheels, brakes | Audi Audi A4/Avant 2011, anti-locking brake syst. -abs- D - 25.05.2009>> ESP 8.0
8K0614517EF << your original pump
Cancelled since 01.11.2011 abs unit
to use for:
SG-HW:
see parts bulletin:
D - 31.05.2010>>
* 8K0 614 517 ED
8K0 907 379 BF
(6-55)
Model data: frt.-wh.dr.+
PR-1AS
8K0614517FM << retrofitted module
abs unit
to use for:
SG-HW:
svm code
see parts bulletin:
D - 03.08.2009>> - 18.01.2010 8K0 614 517 FK
8K0 907 379 BT
(6-55)
PR-1AT
1AS BRS Electronic stabilization program (ESP)
1AT BRS Electronic stabilization program (ESP)
So, next question, does 1AT require any different cables or extra equipment?
Segadora
Denmark
C?ID=287924
The ABS unit exist in two versions:
1AT - ESP ready for TMPS and Hill Hold
1AS - ESP not ready for TPMS and Hill Hold
The only problem I can see is that the part is not for the same year as mine.
http://www.audienthusiasts.com/VagComABS.html
EDIT: so far I know does it not require other cables. I can add extra cables on it, but that is on a later todo.
Segadora
Denmark
C?ID=287924
This part is the same as the one I got https://www.bildelsbasen.se/?link=item&searchmode=3&query=8K0907379BT&post_id=29488923
My engine is CAGA and gearbox LLA as part above.
The only difference is the 0010 where my part says 0030. Do you know what it mean?
EDIT: Nvm mine is the same
iichel
Eindhoven, NB, NL
C?ID=284912
0010 / 0030 is the software version.
Segadora
Denmark
C?ID=287924
I was lucky. I tried random codes and apparently hit the correct one by mistake.
Revision: 11H05---
Coding: 000002
Coding: 088508
Coding: 050200
Coding: 34100000
Coding: 00FD11
Coding: 025028
Coding: 110103
Coding: 000017
Coding: 00C303
Coding: 0000004
Reset counter: 76
Mileage: 263243 km
Date: 2018.01.18
Time: 16:42:55
