07 Audi A5... airbag light on.... no faults in systems
akersgarage
C?ID=179893
Hello I have a 2007 Audi A5 3.0 tdi with a airbag light on.
Light is on all the time indicating a fault.
Scan the systems and there is never any fault in the airbag control unit.
I have tried two other diagnostic machines (different manufacturers) and they both show no faults in airbag.
When I select the driver airbag on steering wheel in measured values it comes up "cannot be measured currently" same term comes up for any other airbags I know the car has.
I have also did a lights/function test on the dash cluster, in this the warning light goes out as normal.
Wondering if anyone has had this before or seen similar.
Thursday,18,January,2018,09:40:58:45930
VCDS Version: 17.8.1.0 (x64)
Data version: 20171130 DS276.6
VIN: WAUZZZ8T18A015187   License Plate:
Chassis Type: 8T-AU48 (8T0)
Scan: 01 03 05 06 07 08 09 0E 10 15 16 17 19 1E 36 37 42 46 47 52
          53 55 56 77
VIN: WAUZZZ8T18A015187   Mileage: 193470km-120216miles
Address 01: Engine (J623-CAPA)       Labels:| 059-907-401-V1.clb
   Part No SW: 8K0 907 401     HW: 8K0 907 401
   Component: 3.0TDI EDC17  H01 0009
   Revision: --H01---
   Coding: 01140023180F0018
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_ECM30LTDIA5 A01010
   ROD: EV_ECM30LTDIA5_A01.rod
   VCID: 68D869D593C0B10639-803C
7901 - Right Engine Mount Solenoid Valve (N145)
          P1575 00 [039] - Short to Plus
                    Mileage: 193470 km
                    Date: 2018.01.18
                    Time: 09:22:45
                    Engine speed: 0.00 /min
                    Coolant temperature: 42 °C
                    Intake air temperature: 14 °C
                    Voltage terminal 30: 11.480 V
                    Engine speed: 0.0 /min
                    Vehicle speed: 0.00 km/h
                    Engine mounting valve: right: activation: 100.00 %
                    Engine mounting valve: left: activation: 100.00 %
                    Gearbox mounting valve 1: activation: 100.00 %
                    Gearbox mounting valve 2: activation: 100.00 %
                    Vehicle voltage terminal 30: 11480 mV
   Part No SW: 8K0 907 379 L    HW: 8K0 907 379 L
   Component: ESP8 quattro  H03 0170
   Coding: 1B0500
   VCID: 428C9B7DDD3CBB56C7-8016
   Part No SW: 8K0 907 289 C    HW: 8K0 907 289 C
   Component: BCM2.01       H38 0253
   Coding: 031000
   Shop #: WSC 06435 000 00000
   VCID: 397EFC91B0EAF88E96-806C
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Component: FBSAUDIB8 IDG  H34 0050
   Serial number: 0107000124328002
   Subsystem 2 - Part No SW: 8K0 905 852 A    HW: 8K0 905 852 A
   Component: ELVAUDIB8  H33 0039
   Serial number: 0107000051983008
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8T0 959 760 B    HW: 8T0 959 760 B
   Component: MEM-BFS       H09 0042
   Revision: AA000000    Serial number: 00001001032024
   Coding: 08217025002444111000
Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
   Part No SW: 8T0 035 729 E    HW: 4E0 035 729
   Component: Interfacebox    H43 4690
   Revision: 00000000    Serial number: 329IV077520726
   Coding: 0005002
   VCID: 3B72E6997AD6CA9E84-806E
   Subsystem 1 - Part No: 8T0 919 609
   Component: E0380 BedienteilH07 0100
   Subsystem 2 - Serial number: 00000000016883
   Subsystem 3 - Serial number: 0103.09.070000000100010121ÿ
   Subsystem 4 - Serial number: 010121ÿ
00003 - Control Module
                    Fault Status: 01100101
                    Reset counter: 223
                    Mileage: 193470 km
                    Date: 2018.01.18
                    Time: 09:04:30
   Part No SW: 8T2 820 043 M    HW: 8T2 820 043 M
   Component: KLIMA 3 ZONEN H05 0110
   Revision: D0000000    Serial number: 0117.09.070024
   Coding: 36060000
   VCID: 3C70E585BFD8CDA68D-8068
   Part No SW: 8K0 907 063 C    HW: 8K0 907 063 C
   Component: BCM1 1.0      H21 0253
   Revision: 04021001    Serial number: 00000000034974
   Coding: 260050910014AF010009000000005D5D001D038800010141000000
   Shop #: WSC 00383 210 80878
   VCID: 2F6AC2C97EAE263E38-807A
   Subsystem 1 - Part No SW: 8T2 955 119 B    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 110907  H11 0040
   Serial number: SWFBIE 0000249
   Coding: 00FD11
   Component: RLS  H04 0002
   Serial number: 10006071
   Coding: 02532C
   Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
   Component: E1 - LDS  H07 0070
   Serial number: 00000000003008070200
   Part No SW: 8T2 035 110 B    HW: 8T2 035 110 A
   Component: MP3-Changer     H42 0380
   Revision: 00042002    Serial number: AUZ5ZBG4531871
   VCID: 2A5CD3DD854C4316EF-807E
   Part No SW: 8K0 919 475 B    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0010
   Revision: 11001001    Serial number: 75330724001119
   VCID: 3878F9958BE0E18669-806C
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Component: AirbagVW-AU10 H23 0409
   Serial number: 0038JD114CHZ
   Coding: 30323433363030303030554A305238543053
   ASAM Dataset: EV_AirbaECUVWAUDI010 A02001
   VCID: 3C70E585B7D8CDA68D-8068
   Serial number: 633
   Serial number: 634
   Serial number: 635
   Serial number: 636
   Serial number: 637
   Serial number: 638
   Component: Lenks.Modul   H10 0012
   Revision: --------    Serial number: 90304GIE000EQ
   Coding: 000012
   VCID: 3D76E881A4C2C4AEBA-8068
   Part No SW: 8T0 920 981 B    HW: 8T0 920 981 B
   Component: KOMBIINSTR.   H26 0212
   Revision: 00000000    Serial number: 71Y13JK97
   Coding: 2F05010002002600010000
   VCID: 3B72E699BAD6CA9E84-806E
   Part No SW: 8T0 907 468 F    HW: 8T0 907 468 F
   Component: GW-BEM 4CAN-M H07 0084
   Revision: EB002032    Serial number: 3200E078258307
   Coding: 000003
   Shop #: WSC 00483 210 50163
   VCID: 44809D65C728B566F5-8010
   Subsystem 1 - Part No SW: 8K0 915 181     HW: 8K0 915 181
   Component: J367-BDM  H06 0150
   Serial number: 170040C4050907
                    Reset counter: 223
                    Mileage: 193470 km
                    Date: 2018.01.18
                    Time: 09:23:07
Address 1E: Media Player 2 (R192)       Labels:. 4E0-035-785.lbl
   Part No SW: 4E0 035 785 B    HW: 4E0 035 785 B
   Component: SG ext.Player H15 0700
   Revision: 00000000
   VCID: 275A2AE9565E7E7EF0-8072
   Component: MEM-FS        H09 0042
   Revision: AA000000    Serial number: 00001001030466
   Coding: 08397325002444111000
   Part No SW: 4E0 910 887 T    HW: 4E0 919 887 M
   Component: MNS ECE         H50 1030
   Revision: 00000000    Serial number: 333IV077519651
   VCID: 3E74EF8D69C4DFB6A3-806A
   Part No SW: 8K0 959 793     HW: 8K0 959 793
   Component: TSG FA        H09 0149
   Revision:             Serial number: 0c
   Coding: 011002225E012201
   VCID: 7DF62881E44204AEFA-8028
   Revision: 00002001    Serial number: 0106070505
   Coding: 011B0682003904C0002000
   Component: DWA-Sensor  H02 0030
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASM.clb
   Part No SW: 8T0 035 223 P    HW: 8T0 035 223 A
   Component: DSP STD       H07 0250
   Revision: S2300000
   Coding: 010101
   Part No SW: 8K0 959 792     HW: 8K0 959 792
   Component: TSG BF        H09 0149
   Revision:             Serial number: 04Fc
   VCID: 7CF02585FF580DA6CD-8028
   Part No SW: 8K0 907 801 C    HW: 8K0 907 801 C
   Component: EPB Audi B8   H03 0040
   Revision: 00000003    Serial number: 00000000016803
   Part No: 8K0 907 357 A
   Coding: 0000002
   VCID: 3362CEB9528602DE5C-8066
   Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 L
   Component: TUNER EU/US/RDW H42 0620
   Revision: 00000000    Serial number: 336IO077518120
   Coding: 0000001
   VCID: 2E54DFCDB9A42F3633-807A
Address 77: Telephone
End-------------------------(Elapsed Time: 03:12)--------------------------
That's pretty strange.
Although I realized there aren't any faults showing, have you tried clearing faults in the airbag module, the instrument cluster, and the CAN gateway?
akersgarage
C?ID=179893
Yeah its a weird one for sure.
I have erased faults from all systems individually but makes no difference.
Right now im leaning towards replacing the airbag control unit
Jef
HQ
I see this as a 50/50 shot with Airbag Module or Instrument Cluster. I would suspect it would be easier to swap out the cluster... even if just for testing about any A5 cluster from a bone yard may be good enough to confirm it.... plug it up and turn the ignition on to see what the result is.
Gone But Not Forgotten
Check the adaption in 0x15 and recode it + recode the cluster and airbag controller to see if it makes the light blink on a broadcast by coding or changing an ADP such as selecting the pass side air bag off.....etc..
akersgarage
C?ID=179893
Unforunatley customer didnt want me to spend anymore time on the fault so no fix as of yet sorry
